Acer H5380BD Display Issues - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 06-05-2020, 04:34 PM - Thread Starter
Liked: 0
Recently purchased an Acer H5380BD that has some display issues. When their is no image or during dark scenes, bright spots - one of which is brighter and more visible- can be seen around the center and just below center right of the image. The top left corner is noticeably dimmer with a yellow highlight, its most apparent during bright scenes. The lamp housing and fan had some dust build up. Lamp hours is 2700, placement is tabletop.
Perhaps a new lamp and cleaning/adjusting the light tunnel may correct the picture?
ID:	2737660   Click image for larger version
ID:	2737662   Click image for larger version
wisd42 is offline
post #2 of 5 Old 06-06-2020, 01:40 AM
rekbones's Avatar
Quoted: 1375 Post(s)
Liked: 711
Yes dust in the optics generally cause light spots in dark images. At 2700 hrs a new lamp is a good idea. !!CAUTION!! never use any kind of compressed air on an assembled projector as this almost always forces more dust into the optics.
"Smart enough to know better, to old to care" ------ Dedicated Bat Cave Home Theater, JVC RS49U/BenQ 3550 Projectors, 110" 16:9 Jamestown screen with variable power masking for CIW 2.50:1 to 16:9, Denon 4500H with 7.1.4 Atmos with Ohm mains, SVS PB2000, 3 DIY Subs (2 15" (1 ported, 1 sealed and a 12" 4th order bandpass), 1 DIY butt kicker, Custom Built HTPC, 18TB DroboFS NAS
rekbones is offline
post #3 of 5 Old 06-06-2020, 04:10 AM
Quoted: 2005 Post(s)
Liked: 645
It might be faulty and not something you can fix. A Benq HT1070A refurb is very cheap, or other DLP 1080p RGBRGB projectors. A new lamp is not worth it IMO, and at 2700h it's getting close to when it should be replaced.
https://www.benq.com/en-us/explore-b...e-theater.html
Unless you spent $12 on this unit I would look elsewhere.
For cleaning the light path has to be opened, an example here at around 11 minute mark:
noob00224 is offline
post #4 of 5 Old 06-06-2020, 02:06 PM - Thread Starter
Liked: 0
Thanks for the feedback. I will sidestep what could be a rabbit hole of repair on this unit and look for a refurbished BenQ instead. The HT1070A refurb always seems to be OOS with no notification system for when it is available. Any suggestion for when is best to find one in stock, constant F5? Otherwise a good condition HT1075 or HT2050 may be the choice.
wisd42 is offline
post #5 of 5 Old 06-06-2020, 04:40 PM
Liked: 645
There are a few 1080p RGBRGB models.
Benq HT2050, HT2050a, HT3050, HT1070, HT1070a, W1070.
Or Viewsonic PX725HD
PX727HD
Pro7827HD
