Did my 8700UB die? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 06-27-2020, 06:28 PM - Thread Starter
DedicatedHT's Avatar
Quoted: 32 Post(s)
Please tell me my trusty 8700UB didn’t die. I was watching a movie, paused to do something, came back to Source: HDMI1 No Signal
Swapped out the disk player to a spare
Tried a different cable
Tried HDMI2 on the projector
Checked all connections
Switched inputs and came back to BD on receiver
Getting audio from the disk but no video
Normally I hear a lens sound switching sources and don’t now
Projector auto shuts off after sitting on no signal
DedicatedHT is online now
post #2 of 6 Old 06-28-2020, 04:26 AM
Quoted: 2023 Post(s)
Liked: 649
Can you see the projector menu?
Unplug it for around 30 min.
noob00224 is online now
post #3 of 6 Old 06-28-2020, 08:16 AM - Thread Starter
Quoted: 32 Post(s)
Yes I unplugged over night. I see the menu But there is no signal info. Still getting audio is it an hdmi handshake issue ?
post #4 of 6 Old 06-28-2020, 08:19 AM
Liked: 649
So the audio is routed through the projector?
Try another display of you have to check the source is not the problem.
Or reset the projector's settings to defaults.
post #5 of 6 Old 06-28-2020, 11:01 PM
rekbones's Avatar
Quoted: 1382 Post(s)
Liked: 718
Where there any electrical storms in the area when the failure occurred? This is the #1 reason for HDMI chip failure, ESD (electrostatic discharge) very common during thunder storms or very low humidity. Long HDMI cables are way more likely to generate a pulse.
"Smart enough to know better, to old to care" ------ Dedicated Bat Cave Home Theater, JVC RS49U/BenQ 3550 Projectors, 110" 16:9 Jamestown screen with variable power masking for CIW 2.50:1 to 16:9, Denon 4500H with 7.1.4 Atmos with Ohm mains, SVS PB2000, 3 DIY Subs (2 15" (1 ported, 1 sealed and a 12" 4th order bandpass), 1 DIY butt kicker, Custom Built HTPC, 18TB DroboFS NAS
rekbones is offline
post #6 of 6 Old 07-06-2020, 03:33 PM - Thread Starter
Quoted: 32 Post(s)
I never circled back but appreciate the help!
No storms, I do run a Monster power block. HDMI is 50’.
I switched to out2 (Non ARC) on the Denon receiver and everything working again. It was the AVR not the FP
