Epson apparently doesn't produce the projector I want? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 06-29-2020, 04:42 PM - Thread Starter
Quoted: 13 Post(s)
Liked: 2
I've had an Epson HC3200 installed ceiling mounted for a few months now, and have struggled with having consistent focus. Finally installed a Silver Ticket 142" screen at 184" throw so I could verify it wasn't due to a lumpy wall.
Still cannot get good focus across the whole screen. Epson has sent me two replacement units, and the issue is there with all of them. I even unmounted the projector, centered it perfectly on the screen with no keystone or lens shift, and duplicated the problem.
A tech finally called me today and essentially said they don't think they produce a projector that can give me 4K with sharp focus across the whole screen at mid zoom. While this meets the specs of the 3200 and looks totally fine with movies, it is unusable for computer work because text cannot be in focus in the middle and the corners. And with COVID...I'm working from home on this screen several hours a day.
They want to refund my money and have me send it back. I need to know if I'm asking too much, and if there is a projector that can do this at a reasonable price point yet? I'm honestly a bit shocked that they couldn't even recommend a higher model of theirs that would do better, as they said they all essentially use the same technology and setup, just with varying contrast/brightness/etc.
I'm a bit nervous to order something else now from someone with less stellar customer service and get stuck with it! I'd like something with the clarity to do computer work, and the contrast to still do great for 4K HDR movies in a blacked out theater room.
Thumbnails are from panel alignment, with center in focus and top right blurry.
ID:	2750840   Click image for larger version
srees304 is offline
post #2 of 7 Old 06-29-2020, 05:05 PM
XK_HT's Avatar
Quoted: 13 Post(s)
Liked: 4
All projectors have different focus uniformity; have you done research on what the reviews have reported for this model? typically a better lens resolves focus uniformity problems. Sony uses some trickery in high end models to improve edge to edge sharpness. You can also try panel alignment.
XK_HT is offline
post #3 of 7 Old 06-29-2020, 05:31 PM
Liked: 0
For small computer print your going to have better luck with a DLP projector. No convergence issues, better pixel fill. Benq makes some budget projectors with excellent reputations for sharpness. I have worked on a 1080p Benq with my pc and the text was fine.
TSO2 is offline
post #4 of 7 Old 06-30-2020, 03:32 AM
Quoted: 1534 Post(s)
Liked: 813
My UHD50 and W1070 have no problems with even focus over 145-150in screens. The UHD50 would work well as a monitor on a 142in screen.
If you are mainly using it as a monitor check out an Epson HC1040 refurb or their similar WUXGA business projectors.
In lieu of the HC3200/3800 I would look at the ZH403, ZH406, GT1090HDR or ZU406.
The TK800M would be a good choice too (check out the deals found subforum).
DunMunro is offline
post #5 of 7 Old 07-14-2020, 01:48 PM
mostau's Avatar
Hi,
I'm going to try to get the same zoomed in pictures from my 3800 and see how it compares. I've posted a panel alignment picture previously that seems to look A OK, but I did not zoom in to the pixel level on those pictures.
I'll keep you posted.
mostau is offline
post #6 of 7 Old 07-14-2020, 01:57 PM - Thread Starter
Quoted: 13 Post(s)
Liked: 2
Originally Posted by mostau View Post
Hi,
I went ahead and picked up a 5050UB, and it is definitely sharper and more uniform with focus. Worth twice the price? Not sure, but it works and the blacks are indeed pretty impressive for movies too.
srees304 is offline
post #7 of 7 Old 07-14-2020, 10:28 PM
mostau's Avatar
Glad you picked up something you are happier with.
I just did 9 quick and dirty hand held camera shots from 9 different screen positions.
These are not perfect, my camera work is a little shaky, and my camera seems to move the red to the left (does not look like that with my eyes), but I would say I am happy with the focus on all 9 sections.
9 Panel Alignment Pictures
mostau is offline
