Official DataSat RS20i thread. (Setup Tips, Questions,General Info, etc) - Page 163 - AVS Forum | Home Theater Discussions And Reviews
 1171Likes
post #4861 of 6045 Old 07-17-2017, 12:52 PM
llang269's Avatar
Quoted: 131 Post(s)
Liked: 68
Originally Posted by Mr. Integration View Post
I did an upgrade to the RS20 from the LS10. While they should sound "the same" it seemed much more effortless from the RS20i. I found out it has 9 DSPs vs 3 on the LS10. It is really worth the upgrade
Actually the Ls10 now has 5 dsp's
llang269 is offline
post #4862 of 6045 Old 07-17-2017, 12:55 PM
Mr. Integration's Avatar
Quoted: 276 Post(s)
Liked: 209
you are correct. I meant that the next closest competitor has 3.
llang269 likes this.
I know it sounds great and looks great.....but can we communicate with it? If not it is useless:)
Mr. Integration is offline
post #4863 of 6045 Old 07-17-2017, 03:24 PM
audioguy's Avatar
Quoted: 5096 Post(s)
Liked: 3951
The RS20i has the ability to use PEQ's prior to Dirac - which in turn allows you to deal with any narrow band high energy peaks in the uncorrected response - assuming you have any. In my experience, Dirac did not deal with those very well but using the PEQ's prior to Dirac I do get much better measurable response. And if you do that for all 11 channels, you can end up with more uniform channel to channel response - which can mean better envelopment.
Is it easily audible - or even audible at all? My expectation bias says yes - and I refuse to do a blind test because it is too much work.
That's my story and I'm sticking to it
What I am comfortable saying is that the RS20i (along with DTS:X and Neural:X) provide the best audio I have ever heard in my home. And the few HT systems I have heard outside of my home (e.g. CEDIA) that I thought sounded as good - or in one case better - were each driven by Datasat RS20i's
joerod likes this.
Mark 10:45 ][ Home Theater Of The Month: The Oconee Theater ][ Music by Leslie Austin ][Jeremiah 4:1-2
audioguy is offline
post #4864 of 6045 Old 07-18-2017, 09:36 AM
Ganymed4's Avatar
Quoted: 301 Post(s)
Liked: 154
I mean, you can easily test it and have a full Dirac EQed setting without PEQ and one with PEQ. Theoretically and from the 'feeling' POV that all REQ systems do something wrong, the approach to use PEQ prior to REQ and therefore make the REQ work less, is quite understandable and reasonable for me. Personally, it is too much work for me to use REW and EQ each single channel, before I use DIRAC. I am very happy with the DIRAC results and have checked them once on one speaker with REW. The result was very good and close to what DIRAC was trying to achieve. See below - different smoothing.
But I agree to your point of view. It is always OK to do a manual PEQ before DIRAC, at least in my opinion. And I am not saying that you cannot improve DIRAC by fine tuning or by using PEQ.
Name:	124 teufel r.jpg
ID:	2243385   Click image for larger version
Name:	REW R var smoothing.jpg
Ganymed4 is offline
post #4865 of 6045 Old 07-18-2017, 11:04 AM
audioguy's Avatar
Liked: 3951
Definitely too much work ... but when I run out of things to do, I just may do it !!
Ganymed4 likes this.
audioguy is offline
post #4866 of 6045 Old 07-18-2017, 11:29 AM
Ganymed4's Avatar
Quoted: 301 Post(s)
Liked: 154
Ganymed4 is offline
post #4867 of 6045 Old 07-20-2017, 03:36 AM
maikeldepotter's Avatar
Quoted: 1585 Post(s)
Liked: 591
Originally Posted by sdurani View Post
Every time I've heard a comparison between full-range vs below-Schroeder with Dirac (or Trinnov), I've always ended up preferring full-range correction. That's probably because good room correction doesn't try to EQ the hair/grass in the high frequencies but instead does broad tonal shaping of the overall sound for speaker-to-speaker consistency. Even Audyssey XT32 does this.
Take Toole's comments in the context of what he considers good speakers: wide dispersion, flat anechoic response on-axis, consistent and smoothly changing response off-axis. Speakers typically radiate like a lantern in the lower frequencies and beam more like a flashlight at higher frequencies (not much influence from the room). So above a certain frequency, equalization is no longer doing room correction but instead doing speaker correction. IF you're using the type of well behaved speakers that Toole describes AND you like how they sound, then there isn't much need to EQ them. Or so the theory goes.
With full-range frequency correction, directional speakers which are not sufficiently aimed at MLP/measuring location can exhibit exaggerated highs for those sitting closer to on-axis. If that happens, limiting the correction to the lower frequencies might give better average results. I believe at a Trinnov class held at Pro Audio Technologies such limiting was applied (up to 120 or 200 Hz IIRC).
A good idea and understanding lies at the base of every successful project.
maikeldepotter is offline
post #4868 of 6045 Old 07-20-2017, 05:18 AM
audioguy's Avatar
Liked: 3951
Here is a slightly different view.
If using full range correction and with speakers that are not sufficiently aimed at the MLP, using wider microphone placement during measurement can help deal with that issue.
My speakers ARE aimed at the MLP and I do use full correction. What I have discovered with the 77 bazillion corrections I have done in my room is that if I use the very narrow spacing (as shown on the Dirac screen when measuring for a single seat) I can, on occasion have some upper midrange glare and/or high frequency "bite". That may be caused when Dirac sees a narrow band dip in that frequency range and creates the filter to fix it. It is not atypical that if I move to wider measurement positions (but not as wide as the couch diagram), that problem disappears. That same technique would also help deal with the problem you described.
One of the many beauties of Dirac on the RS20i (and maybe even the LS10) is that you can create filters using different measuring positions for separate groups of speakers. In my case, I measure LCR's as a group, surrounds as a group, heights as a group and LFE as a group and then place each of those groups into the same Dirac slot. I also, therefore, have the ability to use different mic placement for each of those groups. So I do use wider mic placement for the LCR's than I do for any of the other groups. I also don't need to concern myself with the mic being out of direct line of site for the LCR's by where I put the mic. And, for example, when I measure the surrounds, I don't use the same measuring positions I do for the LCR's as I DO need to be concerned about blocking the mic from the speaker because of the back of the seat. And lastly, this allows me to only remeasure that group of speakers if I make a change to that group. For example, I will be replacing my height speakers at the beginning of next month and will only need to re-measure those. In my case, the primary benefit of this feature is the constant "diddling" I do with my subs in trying to achieve what I know they are capable of. I only need to re-measure one speaker (4 feeds 13) and it takes a very short amount of time.
Lastly, Dirac does not seem to do much correction in the higher frequencies. In some cases, it looks like it does none.
All of that to say, I have not found any downside of using full frequency correction. I don’t know anything about how Trinnov does room correction so maybe there is more benefit of not doing full range for that product.
maikeldepotter likes this.
audioguy is offline
post #4869 of 6045 Old 07-20-2017, 06:50 AM
Liked: 591
Indeed, using multiple locations spread over the entire listening area seems to be the appropriate way in such situations. Like Dirac, the Trinnov Optimizer allows for advanced multi-point measurement (instead of using an averaged response, every single measurement point is taken into account, and each point can individually be weighted).
So to avoid any more guessing from my part, I will take this to the Altitude thread, and try to get some more details from the people who actually attended named workshop ...
post #4870 of 6045 Old 07-20-2017, 09:09 AM
sdurani's Avatar
Quoted: 7355 Post(s)
Liked: 6417
You can always find speakers to support the idea of limiting the correction. Likewise, you can use speakers with wide dispersion and consistent off-axis response to show that full range correction benefits every seat. I really do think this comes down to a case-by-case basis, with multiple variables at play in each case: speakers, room, treatments, and what type of correction is being done once you transition out of the modal range. That's why I can't support a blanket statement on this topic. It might be fashionable these days to say that limiting correction to below-Schroeder is better, but that hasn't been my personal experience (at least with competent room correction systems).
audioguy and maikeldepotter like this.
Sanjay
sdurani is offline
post #4871 of 6045 Old 07-20-2017, 10:19 AM
The Bogg's Avatar
Quoted: 611 Post(s)
Liked: 255
Originally Posted by farsider3000 View Post
I need some advice / personal experience recommendations.
I have a dedicated theater room and currently use the Datasat LS10 with Dirac and Atmos and have an opportunity to purchase a used RS20i. I have a 7.4.4 Atmos setup and wonder if there is any real reason to move to the 20i in my small (14ft x 25ft) theater. Is there any additional capability in the Dirac implementation in the 20i?
The one area that the 20i is better is the fact that it can address all four of my subs separately but no way to know if this will improve sound quality.
There are also some additional EQ settings but again not sure if they will make any difference.
Farsider, I saw your post in the Trinnov thread about you considering the RS20 vs the Altitude 16. I can offer some opinions but as the saying goes, opinions are like a$$holes; everyone has one but the only one that matters is your own.
I had the Trinnov ST2 and I had considered the Altitude vs the RS20 and for various reasons I went with the RS20. Both are excellent products with each having some strengths over the other from a functional point of view. The ST2 was used for 2 channel in my system and obviously I can't compare multichannel Trinnov vs RS20. But I can say that for 2 channel I have found the RS20 to be a really good performer. I initially thought there must be some eq on because the bass was much better than with the Trinnov. On the RS20 it said "eq1" on the display so I figured it was a basic eq that boosted the bass or something. Turns out it is NOT an eq curve, it is the default setting of no eq. The speakers and listening position etc haven't changed so that wouldn't explain the bass difference. This was pre-dirac with no filters on at all.
I liked the Trinnov approach but I did find that unless you were "perfect" about the orientation of the microphone then you would introduce a little timing error which would definitely impact the imaging for 2 channel. Dirac was more forgiving and easier to get a really good result (based on my experience with the Emotiva XMC1). I'm currently setting up the Dirac in the RS20 and will comment again after that's done.
Design by Rives...dollars by The Bogg
Click for my build thread
The Bogg is offline
post #4872 of 6045 Old 07-20-2017, 08:04 PM
farsider3000's Avatar
Quoted: 1620 Post(s)
Liked: 1008
Lots of great responses. Thanks to everyone. My bass response sounds so good right now with the two JTR Captivator S2 in front and the S1 in the rear along with my two Seaton Submersives on the side walls I am not sure how much better it can get (with the RS20i ability to calibrate 4 subs), but I have been wrong before about how much better my room can sound (like when I owned two JL Audio F112 speakers and thought they were amazing ).
There are compromises like the fact that I will have to buy a high end switcher that can be automated.
hmmm. I will have to ponder this some more especially since the Trinnov Altitude 16 is coming. It's a cool time to be alive isn't it? Many amazing audio technologies available right now.
It does sound like the RS20i can make it possible to take my theater room to a higher level. Now I will have to decide if I want to put money into the 2014 RS20i or sell my LS10 and buy the Trinnov.
7.4.6 system: Processors:Marantz 8805 || Xilica XP4080 Amps: Parasound A31 and ATI AT528NC & AT526NC n-core ||Speakers: Procella P8 LCR, Procella P5/P5 in-wall
Subs: JTR Captivator subs: One S2, Two RS2, One S1
Screen: 2.40:1 Seymour XD Acoustically Transparent, 128" diagonal / 118" wide || Projector: JVC X570/RS420
farsider3000 is offline
post #4873 of 6045 Old 07-21-2017, 06:20 AM
audioguy's Avatar
Liked: 3951
I don't recall your channel count. What, in your mind, it the real advantage of switching to the Trinnov vs the LS10 or RS20i?
I also don't recall how you are "managing" all of your subs now. Which SSP are you using? Based upon a lot of experience in the rooms I have set up (lots of others as well as my own), the best way to get the most out of all of those subs is to correct them as a group, not individually, though, on occasion that can work. The RS20i (provides both options) but an external device (e.g. miniDSP) may still be necessary to get them all to work at the very optimum level.
audioguy is offline
post #4874 of 6045 Old 07-21-2017, 06:43 PM
thrang's Avatar
Quoted: 2650 Post(s)
Liked: 2153
Rumor is Datasat is sold, and not good news for the home market. Purportedly a press release coming over the weekend...
I'm guessing the sale was to a pro industry entity and the home side is being discontinued. Tough news if true...
thrang is offline
post #4875 of 6045 Old 07-21-2017, 07:00 PM
sdrucker's Avatar
Quoted: 1678 Post(s)
Liked: 1352
There were also rumors on the British forum and by a poster to Home Theatre Enthusiasts that Datasat was showing off a new pre-pro at CEDIA. Who knows what the truths are...
Audio Gear: Trinnov Altitude 32 (24 channel), NAD M27 amps (3)
Video: JVC RS600, Seymour 100" UF Screen, Lumagen Radiance Pro 4444 (coming soon)
Speakers: PSB Imagine T3 LCR, Imagine T Wides/Side Surround 1, T2 Side Surrounds, Imagine XB rears, Image B6 screens, PSB CS1000 ceilings (6), HSU ULS-15 Mk 2 subs (4) - 13.4.6
HAA HT1 and HT2 Certification
sdrucker is online now
post #4876 of 6045 Old 07-21-2017, 07:02 PM
thrang's Avatar
Liked: 2153
This came from someone involved in the distribution of Datasat products (US)
thrang is offline
post #4877 of 6045 Old 07-21-2017, 08:27 PM
VGI
VGI's Avatar
Quoted: 417 Post(s)
Liked: 190
Guys
Very much not pro industry purchase.
I am going to detail a bit more what's happening in a post shortly.
Thx
Craig
joerod, sdrucker and llang269 like this.
VGI is offline
post #4878 of 6045 Old 07-21-2017, 08:57 PM
stephenbr's Avatar
Quoted: 199 Post(s)
Liked: 100
Bloody hell. I hope you have some good news Craig.
stephenbr is offline
post #4879 of 6045 Old 07-21-2017, 09:04 PM
dschulz's Avatar
Quoted: 866 Post(s)
Liked: 610
This seems unlikely to me. The content business has gone away with the demise of film as an exhibition format (the occasional 70mm release such as Dunkirk excepted), and while they still sell the AP20 cinema processor to movie theaters, that product is greatly overshadowed in volume and revenue by the home theatre lineup of LS10, RS20i and the amplifiers. It wouldn't make any sense at all to discontinue the home side of the business, since that *is* the business.
Eagerly awaiting any real news and the press release!
dschulz is offline
post #4880 of 6045 Old 07-21-2017, 09:10 PM
thrang's Avatar
Liked: 2153
I hope you're correct...there wasn't much detail except to say it was not good news for the home cinema market (and good news for Trinnov, though not sure if that was said for a specific reason or more generally from a competitor dropping out)...but hopefully Craig or someone will have more positive info.
thrang is offline
post #4881 of 6045 Old 07-21-2017, 11:11 PM
VGI
VGI's Avatar
Quoted: 417 Post(s)
Liked: 190
Ok Boys , Here we go -
Datasat was acquired by Morris Kessler of ATI.
Over the coming days you will see some press releases and more and more info but let me shed some light on this tonight.
As one of Morris's dealers and friend, I can tell you that there is no better person in this industry to have stepped up and bought Datasat. As he has done with Theta he will make Datasat a huge success. Datasat as you guys know is a fantastic pre-processor company and honestly they made me very nervous over the years as I had the largest installed base of Theta Casablancas in the world and I was losing people to Datasat. I myself became a Datasat dealer years ago to make sure I could offer the best solutions regardless of the brand.
My first setup of an RS20 years back showed me how capable these guys were and how they could dominate the Pre-
Pro Market. The Audiophiles of course cling to Theta with their Dac flexibility and overall sound but the Theater Enthusiasts were flocking to Datasat. The Setup and EQ capability of the LS and RS machines are incredible as you guys know.
Morris Kessler who by the way owns Amplifier Technologies and under that umbrella has B&K, BGW, Theta Digital and also OEM produces Amplifiers for many of the companies all which you know so well.
Morris has been producing amplifiers as long or longer than anyone else in the business and he is the guy who started SAE back in the day which was amazing Audiophile gear. He loves this business and continues to pour his resources into his brands and Datasat will be better than ever with him behind the wheel.
Keep this in mind - One of the early engineers of the Theta Casablanca Dave Kerstetter is working at Datasat and is very much behind lots of the RS20 and LS10 design. He is now under the umbrella of ATI which should be great for all these brands. In theory ATI and their high end brands like Theta and Datasat can share tech and allow for both brands to grow like never before.
This is good news my friends and will allow Datasat and Theta to grow in a way they couldn't before. Morris's resources are the best there are and he will take Datasat places they would have never gotten to.
Lots more good news to come.
Craig Shumer
Theatermax LLC
www.theatermax.com
Craig Shumer
President of Theatermax
VGI is offline
post #4882 of 6045 Old 07-21-2017, 11:18 PM
llang269's Avatar
Quoted: 131 Post(s)
Liked: 68
This is actually great news! Thanks for the updated info Craig..
llang269 is offline
post #4883 of 6045 Old 07-22-2017, 02:10 AM
thrang's Avatar
Liked: 2153
@VGI
Good news it seems Craig - thanks for that clarification
thrang is offline
post #4884 of 6045 Old 07-22-2017, 07:32 AM
audioguy's Avatar
Liked: 3951
It may or may not be good news. Theta has not exactly been a hallmark of getting to market quickly with new technology. SLOW with their HDMI product and even slower with the addition of Dirac.
Let's just hope that whatever bottlenecks have been in the way of timely product offering from Theta don't affect Datasat, that while not the fastest to get products to market, was a lot faster than Theta.
Time will tell!!
audioguy is offline
post #4885 of 6045 Old 07-22-2017, 07:58 AM
CINERAMAX's Avatar
Quoted: 2273 Post(s)
Liked: 1292
Send a message via Skype™ to CINERAMAX
Datasat was propelled by the ap-20 in the cinema , Dolby was really upset for years their sales of the cp-650 processor went to crap. That money is what funded the residential arm, and the engineering of the ap-20 was so far ahead thanks to Carl and Dave that they were able to milk the cow. Then the cinema expansion to digital slowed down, and now you can get an ims3000 media sevrver from dolby but basically made by dormi which they acquired. The media server that the projector needs now has a full blown surround processor built in in 7.1 for like 13k. If you want to convert it to 64 channels all you have to do is pay a 16 k license and then it becomes a 24K atmos cp-850 with 64 channels AND 12 tops. This IMS-3000 will work with some led walls.
Datasat also had a contract to build BARCO AURO processor based on the same platform, with object based auromax the new barco processors went to a nother oem. Add that to the perfect storm that took the cinema processors from Explosive growth to red on the bottom line in 7 years.
The Point being The next gen processor and amplifiers from both brands should be similar, just like gm sells buick, gmc, chevrolet and olds.
It is good for datasat owners that you don't have a brick in your hands, there will be a new processor line for both based on a common architectures but slight differentiators, and ncore amps will come to datasat which is a great nut-saver for older folks like us.
Carl_Huff, llang269 and grtuck like this.
CINERAMAX is offline
post #4886 of 6045 Old 07-22-2017, 11:01 AM
Liked: 1008
I like the idea of the 3D remapping to fine tune the speaker locations. But not sure how effective this is.
post #4887 of 6045 Old 07-22-2017, 11:06 AM
Liked: 1008
On screen display
How is everyone doing simple things like seeing the volume that the LS-10 is set to when passing a 4k signal? When on a 1080P source the LS-10 will output a tiny on screen indication of the volume level but this goes away when displaying a 4k source.
Does the RS-20i offer better on screen display options? Any word on how this will work when the new HDMI 2.0 board comes out?
post #4888 of 6045 Old 07-22-2017, 11:07 AM
audioguy's Avatar
Liked: 3951
Based upon the reading I have done, if the speakers are close to where they belong, you buy very little with 3D remapping. Unless I had a room with current or soon-to-be large speaker count, the Trinnov would not even be under consideration if it were me.
audioguy is offline
post #4889 of 6045 Old 07-22-2017, 03:37 PM
Ganymed4's Avatar
Quoted: 301 Post(s)
Liked: 154
No, it doesn't at all and has no picture overlay at all, nor any video conversation. I just installed a Control4 system to control all my equipment, but this is relatively expensive and you need an installer. Then you get a volume indication on the tablet they offer but no overlay.
Thank you to Craig and Peter and all the others for this new information about the change of ownership of Datasat. I see a lot of problems for the existing Datasat platforms and I am thinking, that they are EOL. I hope not but we will see what will happen and I don't have the best hopes for it. Peter described this very well in my understanding. RS and LS are based on the AP20 and this star is definitely declining. My feeling is, this is a dead end. Something new will come, I am sure but it won't have anything in common with the LS or RS platform and we are left alone or get - at best - an offer for an upgrade, if at all.
Well, maybe I am seeing this too black but it could happen.
On the other hand, I also don't see any new developments in the sound formats. We have now the ceiling layer and there will be no floor layer, as far as my judgment goes. We have a height layer from Auro and a VOG. What else could come?
Therefore, I think, I can enjoy - and others too - my/their RS20i and LS10 for quite some time.
Just my 2 cents
audvid and grtuck like this.
Ganymed4 is offline
post #4890 of 6045 Old 07-22-2017, 04:32 PM
Liked: 1008
Just my 2 cents
My guess is that we will see further refinement using new acoustic models that further enhance the surround bubble but at some point we will have rung out all the improvements that science can offer. The acoustic engineer I am working with suspects maybe Dirac Unison is next for the home environment (I don't know too much about Unison). I agree that there are not too many locations left to add speakers unless we just line all the walls and ceiling with small speakers (maybe this will come as speaker wallpaper some day.. idea trademarked by farsider3000 ). I am actually surprised that the home theater market thrives since literally none of my friends or colleagues that can afford a theater give a care about Dolby Atmos or 4,000 watt subwoofers.
grtuck likes this.
