The Official Mcintosh Labs MX-151 & MX150 Owner's Thread - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 107Likes
post #61 of 1268 Old 07-13-2013, 05:07 PM
G-Rex's Avatar
Quoted: 1174 Post(s)
Liked: 832
If you listen at moderately loud levels (similar to a commercial theater) "action" would likely be best for action movies, while "movie" would likely be best for all other movies ie drama, thrillers etc... If you listen at moderately to low-ish levels then movie+action has the boost in dynamics for all movies. I believe that's what Chuck conveyed to me. Seems to make sense based on the posted curves for movie, action, and movie+action. I only listen at moderate levels.
G-Rex is offline
post #62 of 1268 Old 07-13-2013, 08:01 PM
adidino's Avatar
Quoted: 529 Post(s)
Liked: 360
I typically use the Movie target for 90% of my film viewing. I will try neutral on occasion if I feel the dialog is a bit soft.
I do however, take advantage of the DSP built into my Triad subs. There is one target preset built into my sub "cinema mode" which gives a 3db boost at 35hz and a sharp rolloff at 25hz which is to my liking. That combined with Movie voicing works pretty well.
AudioXtream
Authorized Dealer:
Trinnov, Anthem, SVS, Triad, Genelec,
Revel, JBL Synthesis/JBL Pro, Paradigm, Kaleidescape, PS Audio, JVC,
Panamorph, LG
adidino is offline
post #63 of 1268 Old 07-13-2013, 10:37 PM
wse
wse's Avatar
Quoted: 2207 Post(s)
Liked: 814
Originally Posted by thrang View Post
@Roger If you are ever in the northeast, come visit addino and I. The default curves are actually quite good! Though it would be nice if Mac would update the app so it would work in this century
@Grex. I generally watch Movie or Action, rarely Action+Movie, though I will give it a try more...I use Music voicing for Music, and Neutral for most TV
wse is offline
post #64 of 1268 Old 07-13-2013, 11:15 PM - Thread Starter
thrang's Avatar
Quoted: 2652 Post(s)
Liked: 2153
Originally Posted by wse View Post
After some simple blood screening and background check, sure!
thrang is offline
post #65 of 1268 Old 07-14-2013, 02:05 AM
Roger Dressler's Avatar
Quoted: 3029 Post(s)
Liked: 1786
@Roger
I'd love to do that.
I'd probably use Action for music, and Movie (or Neutral, if that means no Re-EQ) for movies, because I have the SSP set up to drop the bass (sub) by 6 dB for movies compared to music.
Deadwood II Theater (Previous Deadwood Theater HTOM)
Anthem AVM 60 7.4.4; Classé SSP-800 PLIIx 7.4; MiniDSP OpenDRC-AN
Oppo UDP-203; Oppo BDP-93; Win10 media PC w/Roon+Kodi; Roku Ultra; DirecTV Genie
Adam Audio S3V/S3H LCR, KEF Ci200QS 4 srrnd, Tannoy Di6 DC 4 hts, Hsu ULS-15 4 subs
JVC RS520; Stewart Cima Neve screen 125" diag 2.35:1, MLP at 115"
Roger Dressler is offline
post #66 of 1268 Old 07-14-2013, 05:36 AM
G-Rex's Avatar
Liked: 832
Adidino, when you say "neutral" do you mean Lyngdorf bypassed/off?
G-Rex is offline
post #67 of 1268 Old 07-14-2013, 06:34 AM - Thread Starter
thrang's Avatar
Liked: 2153
I mentioned neutral...it is a voicing option.
thrang is offline
post #68 of 1268 Old 07-14-2013, 08:17 AM
adidino's Avatar
Quoted: 529 Post(s)
Liked: 360
Thrang - I referred to it as well on my post.
Neutral is one of the voices which is flat target response. "Bypass" will bypass all the filters applied by RP.
AudioXtream
Authorized Dealer:
Panamorph, LG
adidino is offline
post #69 of 1268 Old 07-14-2013, 08:51 AM
G-Rex's Avatar
Liked: 832
Ok, neutral was missing from the 6 graphs posted ^^ so I forgot it was one of the voicing options.
G-Rex is offline
post #70 of 1268 Old 07-14-2013, 08:55 AM - Thread Starter
thrang's Avatar
Liked: 2153
Oops
thrang is offline
post #71 of 1268 Old 07-14-2013, 09:32 AM
adidino's Avatar
Quoted: 529 Post(s)
Liked: 360
Oops
AudioXtream
Authorized Dealer:
Panamorph, LG
adidino is offline
post #72 of 1268 Old 07-14-2013, 12:25 PM
blaste's Avatar
Many thanks !
Any way to get the tool from anybody here ?
Cheers
blaste is offline
post #73 of 1268 Old 07-14-2013, 12:32 PM
adidino's Avatar
Quoted: 529 Post(s)
Liked: 360
Originally Posted by blaste View Post
Many thanks !
Cheers
PM me your email address
AudioXtream
Authorized Dealer:
Panamorph, LG
adidino is offline
post #74 of 1268 Old 07-15-2013, 02:22 PM
wse
wse's Avatar
Liked: 814
Originally Posted by thrang View PostAfter some simple blood screening and background check, sure!
wse is offline
post #75 of 1268 Old 07-16-2013, 09:13 PM - Thread Starter
thrang's Avatar
Liked: 2153
Uploaded the McIntosh MX150 Voicing App program in the Known Issues and tips posts at the top of the thread.
Confirmed working on Windows 7, but I do not think it works under Windows 8 (according to addino's early testing)
@Roger - take a look at this - pretty neat...
thrang is offline
post #76 of 1268 Old 07-17-2013, 05:58 AM
adidino's Avatar
Quoted: 529 Post(s)
Liked: 360
Confirmed. Works on Win 7. I could not get it to work on Win 8.
AudioXtream
Authorized Dealer:
Panamorph, LG
adidino is offline
post #77 of 1268 Old 07-17-2013, 07:28 AM - Thread Starter
thrang's Avatar
Liked: 2153
Nice - did you load some of the other preset curves to try them out?
thrang is offline
post #78 of 1268 Old 07-17-2013, 01:05 PM - Thread Starter
thrang's Avatar
Liked: 2153
Updated the Voicing Tips section: added the older 32-bit version pf the tool and the factory default voicing XML file. The 32-bit version works under Windows XP
thrang is offline
post #79 of 1268 Old 07-17-2013, 01:14 PM
adidino's Avatar
Quoted: 529 Post(s)
Liked: 360
I played with creating a couple of custom curves (including the Thurman Munson smile.gif ) but haven't uploaded yet. Very easy tool so far...
AudioXtream
Authorized Dealer:
Panamorph, LG
adidino is offline
post #80 of 1268 Old 07-17-2013, 01:39 PM - Thread Starter
thrang's Avatar
Liked: 2153
Agreed - I'm really not sure if McIntosh markets this product as well as it deserves. Not only does the hardware and Room Perfect create a superb sound, the voicing editor provides incredible flexibility for fine tuning and personal preferences. It really should be touted much more prominently - when people think of amps, McIntosh is on the top of many lists, so they don't have to do too much. But when you think of high end processors, McIntosh rarely comes to mind, so there should be proactiveness around the product...unless its near EOL!
thrang is offline
post #81 of 1268 Old 07-17-2013, 06:00 PM
adidino's Avatar
Quoted: 529 Post(s)
Liked: 360
My attempt to recreate the JBL Synth curve.. pretty close..
AudioXtream
Authorized Dealer:
Panamorph, LG
adidino is offline
post #82 of 1268 Old 07-17-2013, 06:34 PM - Thread Starter
thrang's Avatar
Liked: 2153
Can you save that individual XML and post?
thrang is offline
post #83 of 1268 Old 07-17-2013, 06:40 PM
adidino's Avatar
Quoted: 529 Post(s)
Liked: 360
Attached
jblsynth.voicing.xml 1k .xml file
AudioXtream
Authorized Dealer:
Panamorph, LG
adidino is offline
post #84 of 1268 Old 07-17-2013, 07:37 PM
Liked: 1786
I spent some time getting this curve to overlay the Harman SDEC curve as close as I could. The red trace is from the SDEC plot. The green is the newly created curve. I cannot actually hear this curve, so I rely on others to see what it sounds like.
Here's the xml file: RWD SDEC.voicing.xml 1k .xml file
adidino likes this.
post #85 of 1268 Old 07-17-2013, 07:46 PM
adidino's Avatar
Quoted: 529 Post(s)
Liked: 360
Thanks Roger! I uploaded to the MX. I will try it out tonight or in the am. Awesome.. You typically use this one for movies or music or both?
AudioXtream
Authorized Dealer:
Panamorph, LG
adidino is offline
post #86 of 1268 Old 07-17-2013, 07:58 PM
Liked: 1786
I cannot use a target curve, per se, in the SSP. But the way I tune my room, it tends to agree with Harman's empirically derived target. I'd say with the bass rise that would be my Music mode. Less bass with movies, which I have to achieve by reducing the sub gain 6 dB.
I also have the option of a similar highpass near 20 Hz, or running without the highpass. The latter is my normal mode. I only activate the highpass if movies are too bass-rambunctious. wink.gif
post #87 of 1268 Old 07-17-2013, 08:29 PM
adidino's Avatar
Quoted: 529 Post(s)
Liked: 360
I'll experiment. Perhaps a modified version of this curve with a 4db cut on the low end would be a good target curve for movies.
AudioXtream
Authorized Dealer:
Panamorph, LG
adidino is offline
post #88 of 1268 Old 07-17-2013, 10:08 PM - Thread Starter
thrang's Avatar
Liked: 2153
Roger and addino - thanks for the target curve posts - I uploaded them tonight but too late to test them out...
My ability to edit custom curves is hampered by my laptop screen resolution and non-resizable edit window, so I haven't played much - but roger, what combination of settings gave you the 3db rise in the low frequency?
thrang is offline
post #89 of 1268 Old 07-18-2013, 02:38 AM
Liked: 1786
The boost comes from the 20 Hz high-pass filters' Q=1. Each gives 1.5 dB.
I don't think it is a problem, as whatever RoomPerfect creates in the end for the applied EQ filter will be calculated to avoid saturation. And if it were me, I'd probably apply a lot less rolloff < 20 Hz, or move them lower, but the exercise here was to clone the Harman curve.
And what is that Gain control for, right under the Name? I see no effect.
To keep things orderly, I swapped 2 of the 6 filters. Now top row 1,2,3 deal with bass, and bottom row 4,5,6 deal with the high frequencies. There's no change in the curve, but if you want to edit, this wold be a better place to start.
post #90 of 1268 Old 07-18-2013, 11:48 AM
adidino's Avatar
Quoted: 529 Post(s)
Liked: 360
Watched about an hour of Dark Knight with this curve engaged. Very impressive... I really love this target curve. Need to test other films but works very well with DK.
AudioXtream
Authorized Dealer:
Panamorph, LG
adidino is offline
