Datasat LS10 - Page 43 - AVS Forum | Home Theater Discussions And Reviews
 410Likes
post #1261 of 1516 Old 01-22-2018, 08:21 AM
audioguy's Avatar
Quoted: 5514 Post(s)
Liked: 4616
On my RS20i, after I installed the new HDMI board, I would occasionally get "hangups" when I switched inputs to my Oppo (but never to any other input). Based upon what another user had done, I created a button that did a firmware reset of the HDMI board. So now, when that "hangup' happens, I just hit that button, wait a second at then hit the input button I really want. Sure beats doing a power cycle of the RS20i. While not perfect, I don't have to wait for Datasat to create a new firmware update.
Based upon your experience and mine and a few others, there is some discontinuity between the Datasat and Oppo.
Gotta love technology --- or not!!
grtuck likes this.
audioguy is online now
post #1262 of 1516 Old 01-23-2018, 10:54 AM
Quoted: 106 Post(s)
Liked: 112
Having this new board got me thinking, do we know if this one has ARC capability? I don't use it or need it, but I am just curious.
Also, do we know if this new HDMI board will pass Dolby Vision to the TV? It does EDID (I think) so I suspect it does.
Sony 75" Z9D - Tivo Bolt+ - Roku Ultra - OPPO UDP-203 - Apple TV 4K
Datasat LS10 (w/ DIRAC - Atmos - DTS-X) - Two Emotiva XPA-7's (2nd Gen)
Seven Triad InWall Silver LCR's & Four KEF Ci200RR-THX Atmos speakers - Two Deep Sea Sound Mariana 24" subs - Vicoustic room treatment
grtuck is offline
post #1263 of 1516 Old 01-24-2018, 01:30 AM
westmd's Avatar
Quoted: 992 Post(s)
Liked: 415
Best is to ask MDS directly. They are very quick and helpful in respomding.
http://www.mds.com/technologies/hdmi-video/
grtuck likes this.
westmd is offline
post #1264 of 1516 Old 01-24-2018, 01:44 AM
westmd's Avatar
Quoted: 992 Post(s)
Liked: 415
Originally Posted by audioguy View Post
What DECODERPOST would we use to select DTS:Neural-X? For reasons unknown, it does not always get selected when a legacy DTS movie is being played. Same question for selecting the Dolby up-sampler.
And what does SPKRS SPK13 do?
Thanks again and thanks for the HDMI reset function. So far, works like a charm !!
Sorry i think I oversaw your questions and did not answer.
The LS10 allows in the bass management to either choose an Auro compatible or Atmos/DTS:X compatible setup. If for instance you do have the Auro bass management active the LS10 does not allow you to either choose DSU or DTS: Neural X. I always had to change the bass management through VNC to be able to choose another decoder.
The command you read first is for the correct bass management (SPKRS SPK13 for an Auro 13.1 setup) and then the correct decoder I always use DECODERPOST 10 which is Auto1 (meaning DTS:Neural X for everything except native Dolby signals). I always boot with Auto 1 and have one button on my remote programmed to Auro (as I still prefer it for 5.1and 7.1 sources).
grtuck likes this.
westmd is offline
post #1265 of 1516 Old 01-24-2018, 01:48 AM
westmd's Avatar
Quoted: 992 Post(s)
Liked: 415
ARC should work (see attached table)
grtuck likes this.
westmd is offline
post #1266 of 1516 Old 01-24-2018, 07:39 AM
Quoted: 106 Post(s)
Liked: 112
Thank you tons!
I also contacted MDS to see what they say about Dolby Vision.
grtuck is offline
post #1267 of 1516 Old 01-24-2018, 02:57 PM
Quoted: 34 Post(s)
Liked: 37
From what I am reading:
HSR-72Q 7 input, HDMI switcher/repeater. One 600 MHz full
featured output, one 300 MHz HDCP 1.4
• HDMI 1.4 & 2.0b mandatory formats
• Up to “4K” pixel rates at 24-60 Hz (4:4:4)
• 4K 4:2:0 format video at 60 Hz
• Up to 12 bit Deep Color and HDR
• All typical colorspaces supported
• Audio extraction/injection (I2S standard) and loop through
• CEC switch and Audio System device support
• ARC (primary output)
grtuck likes this.
dj_white is offline
post #1268 of 1516 Old 01-25-2018, 10:47 AM
deyre's Avatar
Quoted: 33 Post(s)
Liked: 36
LS10 and RS20i do not support ARC.
My understanding is that the board should pass Dolby Vision through to the TV.
deyre is offline
post #1269 of 1516 Old 01-25-2018, 06:32 PM
Quoted: 106 Post(s)
Liked: 112
Thank you tons for the letting us know.
MDS did answer me and said that the board has the capability to work with ARC but only if the manufacturer set that up in the firmware. As I mentioned, I don't use it or need it so no problem for me. You would be the person in the know though, so thank you for sharing
They also said that the board should work with all CURRENT Dolby Vision (DV) stuff, but it may not work with future DV requirements and changes to their specs. This part makes me nervous due to the recent Sony DV update that isn't working for really anything....
grtuck is offline
post #1270 of 1516 Old 01-26-2018, 03:36 PM
jdlynch's Avatar
Quoted: 392 Post(s)
Liked: 154
I am wondering what benefit I would receive from purchasing the latest HDMI upgrade for my LS10. The only source I ever use is my Oppo for playing Blurays and streaming Tidal and Netflix.
Is the main benefit for those that need switching for multiple sources?
Current Equipment: Datasat LS10 w/ Atmos and DIRAC, ATI AT6005, Audio Control Savoy G3, Aerial Acoustics LR5's (LCR), SR3's sides, LR3's (rears),(4) RSL C34E’s (Atmos), Submersive HP, Marantz VP15s1, 123" diag 16:9 Stewart Cima Neve screen, Oppo BDP-103, Palliser Flicks Seating AC Power: Eaton whole-house surge protector at main panel, (3) 20 amp circuits, Surgex XR315 at equipment rack, Cyberpower 1400VA/900 watt, true sine wave UPS.
jdlynch is offline
post #1271 of 1516 Old 01-27-2018, 03:33 AM
audioguy's Avatar
Liked: 4616
None if you never have any interest in going to 4K.
post #1272 of 1516 Old 01-28-2018, 04:45 PM
Quoted: 34 Post(s)
Liked: 37
There also seems to be some audio enhancements....my invoice read: Sub-Assy, HSR-72Q w/audio enhancement mods (H678-02 rev. A), but maybe those are just to the MDS board, and not to the LS10 overall. ??
dj_white is offline
post #1273 of 1516 Old 01-29-2018, 01:47 AM
Gideon's Avatar
How to determine the Delay value for each of the output channels? Is there a formula to be used? Thanks.
Gideon is offline
post #1274 of 1516 Old 01-29-2018, 02:14 AM
westmd's Avatar
Quoted: 992 Post(s)
Liked: 415
DIRAC would do that automatically quite well (except for the sub). Would you do it manually? There is a formula you can find online if you just googke it.
westmd is offline
post #1275 of 1516 Old 01-29-2018, 02:18 AM
Gideon's Avatar
Not sure whether this formula is correct:-
1 ms = 1.1 feet from listening position to speaker.
Regards.
Norman
Gideon is offline
post #1276 of 1516 Old 01-29-2018, 07:31 AM
jdlynch's Avatar
Quoted: 392 Post(s)
Liked: 154
Chuck, I'm confused by your comment; please correct me if I'm wrong:
I thought my LS10 (without the latest HDMI board) would pass through 4K content through at least one input and one output. Is that not the case?
I currently have no 4K equipment but will be replacing my aging projector in the near future. Will I need the new HDMI board to be able to play 4K material through my LS10?
jdlynch is offline
post #1277 of 1516 Old 01-29-2018, 08:22 AM
westmd's Avatar
Quoted: 992 Post(s)
Liked: 415
4K yes but HDR not! As most 4k contents are also HDR you should go for the new board if interested in 4k!
westmd is offline
post #1278 of 1516 Old 01-29-2018, 11:21 AM
audioguy's Avatar
Liked: 4616
post #1279 of 1516 Old 01-29-2018, 11:57 AM
BP
BP's Avatar
Quoted: 53 Post(s)
Liked: 31
Saw new ATI processor at CES. It's the LS10 reborn as an ATI branded unit.
llang269 and grtuck like this.
BP
Open mind, open ears. There are no absolutes!
BP is offline
post #1280 of 1516 Old 01-29-2018, 02:14 PM
jdlynch's Avatar
Quoted: 392 Post(s)
Liked: 154
Thanks Ingo and Chuck for confirming that now there is something else I can look forward to buying to feed my hobby!
grtuck likes this.
jdlynch is offline
post #1281 of 1516 Old 01-29-2018, 06:01 PM
audioguy's Avatar
Liked: 4616
Should have read:
Thanks Ingo and Chuck for confirming that now there is something else I can look forward to buying to feed my hobby! addiction!!
grtuck likes this.
post #1282 of 1516 Old 01-29-2018, 07:46 PM
sdrucker's Avatar
Quoted: 1777 Post(s)
Liked: 1453
LS10 system guts with a new interface, or a rebadged LS10?
Audio Gear: Trinnov Altitude 32 (24 channel), NAD M27 amps (3)
Video: JVC RS600, Seymour 100" UF Screen, Lumagen Radiance Pro 4444 (coming soon)
Speakers: PSB Imagine T3 LCR, Imagine T Wides/Side Surround 1, T2 Side Surrounds, Imagine XB rears, Image B6 screens, PSB CS1000 ceilings (6), HSU ULS-15 Mk 2 subs (4) - 13.4.6
HAA HT1 and HT2 Certification
sdrucker is online now
post #1283 of 1516 Old 01-29-2018, 07:56 PM
Marc Alexander's Avatar
Quoted: 6110 Post(s)
Liked: 5667
Rebadged LS10 with 16 outputs instead of 15.
Marc Alexander is offline
post #1284 of 1516 Old 01-29-2018, 10:31 PM
westmd's Avatar
Quoted: 992 Post(s)
Liked: 415
I would assume that except for the main board which features 16 channels instead of LS10 15 channels the rest of the AP16 will be more or less identical. That would even increase the life span of the LS10 as additioms/improvements will be done for both systems together.
llang269 likes this.
westmd is offline
post #1285 of 1516 Old 01-31-2018, 06:48 AM
llang269's Avatar
Quoted: 152 Post(s)
Liked: 86
So I’m having a problem with my Ls10 it’s not automatically switching to what the source is playing. When I first turn it on it starts out with 2.0 pcm and stays there until I switch it to Auro and back to no upmixing. I also noticed Auro upmixer disappeared on the main screen. I’ll call today a see what they say. I hope it’s an easy fix.
llang269 is online now
post #1286 of 1516 Old 02-03-2018, 12:48 AM
westmd's Avatar
Quoted: 992 Post(s)
Liked: 415
Originally Posted by llang269 View Post
So I?m having a problem with my Ls10 it?s not automatically switching to what the source is playing. When I first turn it on it starts out with 2.0 pcm and stays there until I switch it to Auro and back to no upmixing. I also noticed Auro upmixer disappeared on the main screen. I?ll call today a see what they say. I hope it?s an easy fix.
Had a similar issue with the very first HDMI board that came with the LS10. Switch of HDMI boards (which was done by Datasat under warranty) solved all issues!
westmd is offline
post #1287 of 1516 Old 02-03-2018, 08:43 AM
llang269's Avatar
Quoted: 152 Post(s)
Liked: 86
Thanks talked to Mike at Datasat and he is working on a fix. If he cant solve it I’ll just send it in.
post #1288 of 1516 Old 02-03-2018, 07:53 PM
deyre's Avatar
Quoted: 33 Post(s)
Liked: 36
Which version of HDMI card and LS10 software do you have?
If it is the HSR72Q, the LS10 had an EDID bug which caused the 2.0 PCM on startup. This was fixed a couple of months back. The fix will be in the upcoming 1.02.02 release, and might also have been in the 1.02.01 release candidate which some users with the 72Q were given - I can't remember for sure.
deyre is offline
post #1289 of 1516 Old 02-04-2018, 10:30 AM
llang269's Avatar
Quoted: 152 Post(s)
Liked: 86
That’s exactly what I was told. They are still working on the 1.02.02 and it should be released next month. I still have the 1.02.00 and was told to wait for the new firmware. I’ll call Mike on Monday and see if he can email me the 1.02.01
post #1290 of 1516 Old 02-04-2018, 10:56 AM
westmd's Avatar
Quoted: 992 Post(s)
Liked: 415
There is another really annoying problem I found out over the weekend. I attached my Apple TV4k to the input of my OPPO 203. Reason is that I use the HDR settings in the Oppo to adjust the AppleTV material to best suite my projector. When I switch the Oppo from BluRay to HDMI in I have to reset the board about 5 times before I get a picture. Once I have chosen something on the AppleTV I loose the picture again and have to reset the board again several times. BluRays and UHD BluRays work first time. Another issue is the Oppo home screen which also requires several reboots (which is not too much of a problem as I seldomly need this.) Will get in contact with Datasat to discuss this problem!
westmd is offline
