Datasat LS10 - Page 47 - AVS Forum | Home Theater Discussions And Reviews
 371Likes
post #1381 of 1412 Old 08-22-2018, 09:59 AM
audvid's Avatar
Quoted: 543 Post(s)
Liked: 161
I was using Digital video essentials to calibrate video of my new projector.
I was displaying the brightness adjustment pattern which has the three vertical black bars on each side. I think the outer most vertical black bar is called "blacker than black"?. Anyway, I cannot see this outer most vertical black bar, if I route the signal through my Datasat ls10 but I can see it if I connect the projector directly to Onkyo. The instructions say that if I cant see that bar, despite all adjustments, the signal is getting clipped. The only point in the chain for this to happen is the LS10. Is there a setting in LS10 that I should change?
I was using only 1080p Bd.
audvid is offline
post #1382 of 1412 Old 08-22-2018, 10:54 AM
audioguy's Avatar
Quoted: 4746 Post(s)
Liked: 3534
I never had any issue calibrating PJs through the Datasat on 1080P.
audioguy is offline
post #1383 of 1412 Old 08-22-2018, 04:57 PM
audvid's Avatar
Quoted: 543 Post(s)
Liked: 161
Then what am I missing?
Projector settings were right at the middle - at 50%, as factory reset.
1. I plugged the hdmi cable into the OPPO. I could see the blacker than black bar.
2. I put the LS10 in the loop - oppo to ls10's hdmi 1 and hdmi out of ls10 to projector hdmi. I could not see the same black bar.
3. I repeated step 1. I could see the bar.
4. I repeated step 2 - I could not see the bar.
I tried to adjust the brightness to try and see the bar but to no avail.
What am I missing? Is there a setting in LS10 that I should know about?
audvid is offline
post #1384 of 1412 Old 08-30-2018, 12:08 PM
krolsen's Avatar
Hello, I‘ve heard that the LS10 is capable of 5.1.6 Atmos. Is that correct? And if so, is it also possible to run Auro-3D as 11.1 incl. HC and TC in paralell?
The newest manual which I could find is from 2016, which doesn‘t reflect the above.
I could get a used LS10 fully equipped inlc. Dirac, for less than 10k€. It might be worth it, doesn‘t it?
Epson EH-LS10000, 109" Image Screen iMask reference 21:9 with BS65k, Oppo UDP-203, Anthem AVM60, Integra DTA-70.1, L/C/R XTZ Cinema M6, Surr. XTZ Cinema S5, ATMOS 4x XTZ Cinema S2, DBA 4x SVS SB12 NSD.
krolsen is offline
post #1385 of 1412 Old 09-08-2018, 07:11 AM
westmd's Avatar
Quoted: 977 Post(s)
Liked: 405
In theory yes. You can create different setups for Auro and Atmos. Nevertheless you will then have different speaker outputs for the different systems. Say you will have the two rear speakers for Auro on the same output as the rear heights for Atmos.
I am still hoping though that there will be an 7.x.6 upgrade fir the RS20i/LS10!
westmd is offline
post #1386 of 1412 Old 09-26-2018, 01:30 AM
Liked: 0
I found a good dataset support site and you could download the latest documents and software. URL: https://datasatdigital.sugarpixels.c...products/ls10/
p4s2wd is offline
post #1387 of 1412 Old 09-26-2018, 02:14 AM
stephenbr's Avatar
Quoted: 199 Post(s)
Liked: 99
Woo hooo - at last an updated website!
stephenbr is offline
post #1388 of 1412 Old 10-27-2018, 04:46 PM
markb1234's Avatar
Quoted: 16 Post(s)
Liked: 57
I am hoping someone can answer this. I have the LS-10 with Atmos and Dirac. I can't find any documentation on the the stereo surround setting. For me, besides playing all channel stereo, it really boosts the bass. Can someone tell me exactly what this setting is doing with respect to post processing and ideally why Datasat included it? On a lot of the music I listen to I like the effect. On some types it really screws it up such as acoustic solo artists.
markb1234 is offline
post #1389 of 1412 Old 03-10-2019, 12:26 PM
cannga's Avatar
Quoted: 1869 Post(s)
Liked: 1825
Datasat LS10 owners, take heart, it's only a matter of time. Why? The way ATI "upgrades" Casablanca is it essentially guts internal components; really not an upgrade, but more like a new machine, sometimes even with new chassis. The only questions for LS10 Mark II with 16 channels are when (you have to be patient welcome to ATI :-)), and how much.
Back of ATI 16
Back of Datasat LS10
llang269 and grtuck like this.
Regards, Can
My System & Theta Casablanca Mini-Review (CB IVa setup help HERE) Uncontrolled passion for music, and sound.
Interesting Audio Diagrams :-) & High-End Speaker Reviews
JTR Subwoofer Thread I don't always listen to subwoofers, but when I do, it's JTR :-).
cannga is offline
post #1390 of 1412 Old 03-11-2019, 07:01 AM
jdlynch's Avatar
Quoted: 339 Post(s)
Liked: 131
I haven’t lost any love for my LS10. It is an awesome sounding unit and meets my needs perfectly. I will never go beyond 7.2.4 so I should be set.
audioguy and llang269 like this.
jdlynch is offline
post #1391 of 1412 Old 03-11-2019, 07:10 AM
mani's Avatar
Quoted: 264 Post(s)
Liked: 108
I will be listing my LS10 ( without Atmos card) , for sale . I have the Dirac license and software that I bought with it that I can give with the unit . I will prefer local pick up and transaction and will give a good deal . Let me know if any one locally is interested
mani is offline
post #1392 of 1412 Old 03-20-2019, 10:34 PM
Chris_Stephens's Avatar
Quoted: 30 Post(s)
Liked: 37
I have a quick question.. The LS10 IR remote. Are its codes the same as any other device ? To control it with a universal remote, they don't have Datasat, hehehehe..
While I can control it via VNC and Crestron via IP and even a learned Harmony, I would really like to have it as volume on a DirecTV remote..
http://www.xtremeprojectors.com/ I dont take new clients tho :( - Its more of a hobby making insanity rooms.
Chris_Stephens is offline
post #1393 of 1412 Old 03-21-2019, 04:38 AM
Quoted: 104 Post(s)
Liked: 105
I use a Logitech Harmony remote, and they added it for me when I contacted them.
I just sent them the link on this page (see below) and they did it from there.
https://www.manualslib.com/manual/11...0.html?page=96
Hope that helps!
Sony 75" Z9D - Tivo Bolt+ - Roku Ultra - OPPO UDP-203 - Apple TV 4K
Datasat LS10 (w/ DIRAC - Atmos - DTS-X) - Two Emotiva XPA-7's (2nd Gen)
Seven Triad InWall Silver LCR's & Four KEF Ci200RR-THX Atmos speakers - Two Deep Sea Sound Mariana 24" subs - Vicoustic room treatment
grtuck is offline
post #1394 of 1412 Old 03-22-2019, 04:13 AM
Quoted: 104 Post(s)
Liked: 105
I just noticed that there is an update to the LS10 (V1.02.03) that was released this week.
https://www.datasatdigital.com/produ...loads/#57-ls10
grtuck is offline
post #1395 of 1412 Old 03-22-2019, 09:18 PM
Quoted: 30 Post(s)
Liked: 37
Yep.. I got it for the Harmony. Works perfect..
BUT.. For a basic universal remote, you can't update.. So the question is does Datasat use IR codes that happen to be from another mfgr ? If so, I might be able to add it to the DirecTV remote directly.
post #1396 of 1412 Old 03-26-2019, 09:19 AM
Quoted: 104 Post(s)
Liked: 105
I'm not sure if they use the same codes or not, but the first link I posted does list all of their IR codes. Admittedly, I wouldn't know what to do with them.
grtuck is offline
post #1397 of 1412 Old 07-05-2019, 02:20 PM
llang269's Avatar
Quoted: 112 Post(s)
Liked: 58
It’s been really quiet in here, so I heard the rumor again that Ati will offer an upgrade to us Ls10 owners to match the ATP16 and go to 16 channels! I really hope this is true
llang269 is online now
post #1398 of 1412 Old 07-05-2019, 03:05 PM
westmd's Avatar
Quoted: 977 Post(s)
Liked: 405
Originally Posted by llang269 View Post
It’️s been really quite in here, so I heard the rumor again that Ati will offer an upgrade to us Ls10 owners to match the ATP16 and go to 16 channels! I really hope this is true
That would be great. Is the AP16 even out yet?
llang269 likes this.
westmd is offline
post #1399 of 1412 Old 07-06-2019, 12:03 PM
Quoted: 104 Post(s)
Liked: 105
That would be sweet to see, if they make it happen.
grtuck is offline
post #1400 of 1412 Old 07-06-2019, 01:14 PM
llang269's Avatar
Quoted: 112 Post(s)
Liked: 58
Supposedly after Cedia. We shall see
post #1401 of 1412 Old 07-08-2019, 03:43 PM
jdlynch's Avatar
Quoted: 339 Post(s)
Liked: 131
It’s been really quite in here, so I heard the rumor again that Ati will offer an upgrade to us Ls10 owners to match the ATP16 and go to 16 channels! I really hope this is true
Would the upgrade offer anything besides upping the channel count to 16?
Current Equipment: Datasat LS10 w/ Atmos and DIRAC. ATI 6005, AT527NC, Aerial Acoustics LR5's (LCR), SR3's sides, LR3's (rears), Seaton Submersive HP, Marantz VP15s1, 123" diag 16:9 Stewart Cima Neve screen, Oppo BDP-103, Palliser Flicks Theater Seating AC Power: Eaton whole-house surge protector at main panel, three dedicated 20 amp circuits, Surgex XR315 surge protector at equipment rack, Cyberpower 1400VA/900 watt, true sine wave UPS.
jdlynch is offline
post #1402 of 1412 Old 07-08-2019, 05:35 PM
Marc Alexander's Avatar
Quoted: 5347 Post(s)
Liked: 4846
Most likely, Dirac Live Tier One Bass Management
https://www.dirac.com/news/dirac-liv...gement-ces2019
Stay tuned for CEDIA 2019
Marc Alexander is online now
post #1403 of 1412 Old 07-09-2019, 06:45 AM
Quoted: 104 Post(s)
Liked: 105
I don't currently need more channels, however I am hoping for the new DIRAC and really hoping it doesn't require a licensed installer to use it (even though they do provide great results). The closest installer to me is like 8 hours away, so it makes it very difficult to have them come over if I want to tweak something.
grtuck is offline
post #1404 of 1412 Old 07-11-2019, 05:52 AM
audioguy's Avatar
Liked: 3534
ATI/Datasat really needs to provide the measurement tools to end users - and not at $3000!! A $75 mic with a calibration file and a software license for $500 (or less) should be all that is necessary. I can't think of any other processor company who is so restrictive. Even Trinnov, will sell the end user the mic and they can then figure out how to either do the measurements themselves or hire someone to do it and then modify as necessary.
If tATI continues to be so ridiculously restrictive, I don't see them surviving long term.
audioguy is offline
post #1405 of 1412 Old 07-11-2019, 09:16 AM
jdlynch's Avatar
Quoted: 339 Post(s)
Liked: 131
I think we will see an announcement regarding a consumer based calibration software option as soon as the ATP16 is released.
jdlynch is offline
post #1406 of 1412 Old 07-11-2019, 10:59 AM
llang269's Avatar
Quoted: 112 Post(s)
Liked: 58
That has been the rumor for awhile now! We shall see
post #1407 of 1412 Old 07-28-2019, 01:09 PM
blake's Avatar
Quoted: 116 Post(s)
Is it true there is NO Graphic user interface with the LS10? I am building a home theater and my AV rack will be in another room. Without a video overlay, how do you know what input your are on, volume level set to etc ?
blake is offline
post #1408 of 1412 Old 07-28-2019, 01:14 PM
llang269's Avatar
Quoted: 112 Post(s)
Liked: 58
VNC app tells you all of that
post #1409 of 1412 Old 07-28-2019, 11:10 PM
blake's Avatar
Quoted: 116 Post(s)
That is a pain - ie have to use a dedicated pc or device to know the current volume and input device. I wonder if a control system like Crestrons new remote controls can be programmed to display some basic information like this right on the remote.
jkscherk likes this.
blake is offline
post #1410 of 1412 Old 07-30-2019, 07:33 PM
appelz's Avatar
Quoted: 608 Post(s)
Liked: 633
Yes, any control system capable of displaying feedback from devices will be able to show that information.
Adam Pelz ,Acoustic Mafia - Hear No Evil
JBL Master ARCOS Calibrator, CEDIA Designer, Home Acoustics Alliance Instructor LIII, THX HT1+ HT2+ Video, Level III Trinnov Altitude Calibrator
Mercenary Calibrator for Manufacturers, Integrators and System Owners
appelz is online now
