Trinnov Altitude - Page 162 - AVS Forum | Home Theater Discussions And Reviews
 2517Likes
post #4831 of 7501 Old 08-16-2018, 04:16 PM
Dan Hitchman's Avatar
Quoted: 4412 Post(s)
Liked: 2478
Originally Posted by kingwiggi View Post
Not a K-Scape owner but I received my disc copy early.
This movie has a phenomenal soundtrack, I heard no evidence of any dynamic range compression. The soundtrack is a minimum 7.1.6 with very active use of all 6 height speakers throughout. Wides were deadly silent. The LFE track is one of the best I have heard and it wasn't used just for explosions they used it judiciously to portray emotion in some of the darker scenes of the movie.
I would give video and audio a 10/10 on this one. Some V. good demo material.
So, it looks like Disney is still in the practice of doing some sort of fixed pattern Atmos mix render even if they kept their gloved hands away from the dynamic range compressor knob this go-around.
Listen up, studios! Dolby Atmos Lite™ print-outs must stop!!
Dan Hitchman is offline
post #4832 of 7501 Old 08-16-2018, 04:28 PM
kingwiggi's Avatar
Quoted: 545 Post(s)
Liked: 346
Not necessarily Sdrucker or someone else with 24 > channels will be able to tell whether or not it’s been hobbled. All we know for now is that it is at least 7.1.6 and the dynamic range hasn’t been compressed.
I will probably be adding another 8 channels soon.
Sent from my iPhone using Tapatalk Pro
Trinnov Altitude 32, LCR JBL M2, JBL LSR 708i, 705i, Q-SYS Core 110f, Amps- QSC CXD4.2Q, 4.3Q, 4.5Q
Kaleidescape Strato, Zapitti 4K HDR Duo, Xbox One X, 8TB Tivo Roamio Pro,
JVC RS600 + ISCO IIIL, 158" 2.40:1 AT screen, Calman 5 Enthusiast, i1 Pro 2, i1 Display Pro, Spyder 5, 3D LUT Box
Oppo UDP-203, BDP-105, Onkyo DAC-1000s, Onkyo DP-X1 DAP, QNAP TVS-871
kingwiggi is offline
post #4833 of 7501 Old 08-17-2018, 07:20 AM
audioguy's Avatar
Quoted: 4421 Post(s)
Liked: 3200
For those Trinnov users who use an external box for managing your subs:
I know many use one of the QSC products. What are the advantages it has over something like a miniDSP or Xilica? What specific product in the QSC line do you use and why that one? Does it have remote management capabilities? The last I looked, it seemed like the one that was recommend cost something like $6,000 !!!!!
I have been happily using a miniDSP but it may have gone "toes up" and I am going to investigate what other options I have.
audioguy is online now
post #4834 of 7501 Old 08-17-2018, 11:53 AM
sdrucker's Avatar
Quoted: 1558 Post(s)
Liked: 1198
"Hobbled" isn't as good a word as "primitive" in how they approached the Atmos mix on Infinity Wars. See my comments on the UHD's movie thread:
https://www.avsforum.com/forum/187-o...l#post56648960
I have another screenshot I took of the peaks of the movie, and it's obvious they just rendered to 7.1.6. They didn't make much use sonically of the heights (unless you listen at reference all the time, their impact is at best subtle), but they did use all three pairs, which I guess is progress over 7.1.4. I still had to raise my db level about +8 over my normal setting, though, so Disney did their mix to low levels approach again.
Pretty obvious to heard the difference in how mixes are rendered - put on the first few minutes of Jumanji: Welcome to the Jungle, and the heights leap out at you right away, with music score being elevated by the nice use of the front height speakers. If it were Disney the score would just be in the mains.
Dan Hitchman and mikela like this.
Audio Gear: Trinnov Altitude 32 (24 channel), NAD M27 amps (3)
Video: JVC RS600, Seymour 100" UF Screen, Lumagen Radiance Pro 4444 (coming soon)
Speakers: PSB Imagine T3 LCR, Imagine T Wides/Side Surround 1, T2 Side Surrounds, Imagine XB rears, Image B6 screens, PSB CS1000 ceilings (6), HSU ULS-15 Mk 2 subs (4) - 13.4.6
HAA HT1 and HT2 Certification
sdrucker is offline
post #4835 of 7501 Old 08-17-2018, 06:48 PM
farsider3000's Avatar
Quoted: 1405 Post(s)
Liked: 792
I am using an Xilica XP-4080 and the only limitation I am aware of is the fact that the lowest frequency I can set a PEQ is 20Hz. I know Adam Pelz with the Erskine Group uses the QSC products. I will look through my correspondence and find out which model.
7.4.6 system: Processors:Marantz 8805 || Xilica XP4080 Amps: Parasound A31 and ATI AT528NC & AT526NC n-core ||Speakers: Procella P8 LCR, Procella P5 for surround & ceiling
Subs: JTR Captivator S2, JTR Captivator S1, 2 Seaton Submersive (dual 15")
Screen: 2.40:1 Seymour XD Acoustically Transparent, 128" diagonal / 118" wide || Projector: JVC X570/RS420
farsider3000 is offline
post #4836 of 7501 Old 08-17-2018, 06:58 PM
Liked: 792
I agree that the soundtrack is phenomenal ... after I boosted my main volume about 5dB and then had to boost my sub levels about 4dB. It is pretty well discussed in some of the bass forums. This disc is not nearly as bad as Black Panther regarding compression. The general soundtrack is quite amazing on Infinity Wars once the levels are boosted.
post #4837 of 7501 Old 08-17-2018, 08:59 PM
audioguy's Avatar
Liked: 3200
Are you talking about Avengers Infinity Wars? $44.00 for a Blu Ray on Amazon?
post #4838 of 7501 Old 08-17-2018, 09:12 PM
mikela's Avatar
Quoted: 377 Post(s)
Liked: 575
Cheaper here
mikela is offline
post #4839 of 7501 Old 08-17-2018, 09:41 PM
Javs's Avatar
Quoted: 6766 Post(s)
Liked: 6383
Not sure I understand this. Are you saying that the "after" curves below DO NOT include the Target Curves? If not, what objective(s) does Optimizer use in setting the shape of its results?
With a 'before' scan like that it shows how well your room is set up! Well done. I really like your room, it has the sort of acoustic treatment detail I am looking to do myself when I get to building mine.
JVC X9500 (RS620) | 120" 16:9 | Marantz AV7702 MkII | Emotiva XPA-7 | DIY Modular Towers | DIY TPL-150 Surrounds | DIY Atmos | DIY 18" Subs
MadVR Settings | UHD Waveform Analysis | Arve Tool Instructions + V3 Javs Curves
Javs is online now
post #4840 of 7501 Old 08-17-2018, 11:05 PM
Liked: 2478
Goddamn it! What is it with those jokers... really!
post #4841 of 7501 Old 08-18-2018, 07:21 AM
audioguy's Avatar
Liked: 3200
Thank you for the nice words. The room is well treated, thanks to the expert (and basically free****) advice of Glenn Kuras (GIK). And even without room correction, the mids/highs are very good. But, the graph you referenced is a bit misleading in that the scale is (major increments) 20db!! I know GIK ships internationally but his prices may not be so acceptable given where you live.
**** I paid very little for the overall initial plan (<$1000 if I recall correctly) done by someone associated with his company but then Glenn and I altered it a bit. The money came in when I decided to implement ALL of his recommendations - so I have about $10,000 invested in room treatment.
post #4842 of 7501 Old 08-18-2018, 01:16 PM
appelz's Avatar
Quoted: 531 Post(s)
Liked: 526
It is a well set up room, but there is also some PEQ in place to get the nice looking "before" graphs.
Adam Pelz ,Acoustic Mafia - Hear No Evil
JBL Master ARCOS Calibrator, CEDIA Designer, Home Acoustics Alliance Instructor LIII, THX HT1+ HT2+ Video
Mercenary Calibrator for Manufacturers, Integrators and System Owners
appelz is offline
post #4843 of 7501 Old 08-18-2018, 02:39 PM
audioguy's Avatar
Liked: 3200
It does indeed have PEQs in place. But even with them disabled but at the scale shown, the response still looks very good. I tend to evaluate response where the major increments are 5db with the individual lines at 1dB. Few FR's look so "pretty" at that scale.
post #4844 of 7501 Old 08-18-2018, 03:17 PM
sdrucker's Avatar
Liked: 1198
Silly question: are your Optimizer graphs at 1/12 octave display resolution?
sdrucker is offline
post #4845 of 7501 Old 08-18-2018, 08:00 PM
Javs's Avatar
Liked: 6383
Ahh I really thought that was 10db scale...
EDIT: now I see each notch is 2.5db hmm.
I am highly considering the Altitude 16, it looks phenomenal. The Optimiser seems to be amazing.
Here are my active modular towers I designed dialled in across a 6point measurement at the MLP. Build is in my signature if you are interested. Can't wait to get these into a really good room so they can sing properly. 1/12th smoothing. 5db scale.
Javs is online now
post #4846 of 7501 Old 08-18-2018, 08:23 PM
audioguy's Avatar
Liked: 3200
First of all, the Altitude 16 is a phenomenal piece of equipment. I don't know what you are using now but the improvement achieved from moving from your "basic" $3500 SSP to this caliber piece of equipment is kind of mind boggling. Most certainly not an inexpensive piece but if your objective is the ultimate 3D audio envelopment experience, this is what will get you there
Secondly, your measured response is excellent. I am sure your system sounds great.
post #4847 of 7501 Old 08-20-2018, 04:50 PM
sdrucker's Avatar
Liked: 1198
Major Trinnov news here in the US:
http://www.hiddenwires.co.uk/news/ar...y-and-new-hire
sdrucker is offline
post #4848 of 7501 Old 08-20-2018, 05:07 PM
Jish9's Avatar
Quoted: 276 Post(s)
Liked: 106
Though not a Trinnov user (yet), I have/had both the miniDSP and QSC core products in use. The miniDSP was used exclusively for sub management via correction filters needed for seat to seat variability (DIRAC Live user), and with the QSC core upgrade, I use it (the core) to manage the entire system including the subs. If the goal is to simply add shelving filters post-processing, and adjusting individual levels, then the miniDSP is pretty much all you need. With other systems, gaps exist for sound management that something like a QSC core fills in very nicely albeit with a steep learning curve. This is not the case with an Altitude 16 or 32 that has most of this functionality built into the software.
Jish9 is offline
post #4849 of 7501 Old 08-20-2018, 05:13 PM
Venger99's Avatar
Quoted: 104 Post(s)
I read a review of the altitude 16 which mentioned the speaker remapping of a standard 7.1.4 atmos layout to Auro. It said it could remap all the higher rows but not the “voice of god” top speaker.
https://www.avforums.com/review/trin...6-review.15079
Is this correct, and if so why? Surely the VOG speaker could just be created by all ceiling speakers giving the same signal.wouldnt this centre the image in the middle?
Venger99 is offline
post #4850 of 7501 Old 08-20-2018, 05:14 PM
audioguy's Avatar
Liked: 3200
Yeah for US Trinnov customers. I had a chance to communicate with Chuck Back during my Trinnov purchase. He will be a good addition to the Trinnov team.
sdrucker likes this.
post #4851 of 7501 Old 08-20-2018, 05:50 PM
adidino's Avatar
Quoted: 499 Post(s)
Liked: 339
That's been in place for a couple of months now.. Chuck actually worked for the rep company that handled Trinnov at the time... good guy.
adidino is offline
post #4852 of 7501 Old 08-20-2018, 05:56 PM
sdrucker's Avatar
Liked: 1198
Agreed he’s a stand-up professional from the conversations we’ve had at CEDIA shows. It’s a good move to more formally bring him aboard.
sdrucker is offline
post #4853 of 7501 Old 08-20-2018, 06:22 PM
audioguy's Avatar
Liked: 3200
Is it true that the Optimizer (target curves) can do no adjustment south of 20Hz? Even my Datasat would go lower.
post #4854 of 7501 Old 08-20-2018, 06:30 PM
sdrucker's Avatar
Liked: 1198
Not with 7.1.4. But if you have a 7.1.6 setup with top middles, with simple reconfiguration of speakers for Auro and also having both TMs play the T (VOG) content, as long as you also have top rears as well, 3D remapping will give you a reasonable approximation. Better to have a true pair of surround heights rather than rely on remapping for mapping Atmos to an Auro layout, but considering the tradeoffs and available content, it’s better than no Auro IMO.
You might need some pro support to get this right, though.
sdrucker is offline
post #4855 of 7501 Old 08-20-2018, 06:56 PM
The Bogg's Avatar
Quoted: 549 Post(s)
Liked: 221
I didn't realize Sound Developments no longer distributed Trinnov, who is the current distributor in the US?
Design by Rives...dollars by The Bogg
Click for my build thread
The Bogg is offline
post #4856 of 7501 Old 08-20-2018, 07:03 PM
adidino's Avatar
Quoted: 499 Post(s)
Liked: 339
They are direct to dealer now. Which i prefer, personally. Support seems better and much quicker shipping.
AudioXtream
Authorized Dealer:
Trinnov, Anthem, SVS, Genelec,
JBL Synthesis/JBL Pro, Paradigm, Kaleidescape, PS Audio, JVC,
Panamorph, LG
adidino is offline
post #4857 of 7501 Old 08-20-2018, 08:36 PM
Liked: 792
I am considering an Altitude 16. I owned the Datasat LS10 for about a year and now I have the Marantz 8805 due to the ability to run another set of Atmos speakers. The Marantz is just too limiting (in the PEQ / EQ area) but it really does sound incredible for the price. I was proficient with the Datasat and setting PEQ. I am an engineer and love to tinker, but how hard is the Trinnov to program / set up if I want to do it my self (including use of the room optimizer). I am pretty confident I can master if fairly easy but want the groups input.
Are there decent online manuals or tutorials? Or does the training only go to the dealers?
post #4858 of 7501 Old 08-21-2018, 06:52 AM
RUR
Innocent Bystander
RUR's Avatar
Quoted: 639 Post(s)
Liked: 562
FWIW, see Gareth's @Wooki experience here: https://www.avsforum.com/forum/86-ul...l#post56359322
RUR is offline
post #4859 of 7501 Old 08-21-2018, 07:08 AM
audioguy's Avatar
Liked: 3200
Setting PEQs, is not difficult just different than the LS10. Same with target curves. With some exceptions, the primary issue in setting this up vs the LS10 is trying to find stuff. Organized totally different. It has lots of features/capabilities/strenghts that the LS10 does not have - too many to list here. I will post a link to the user manual below. There are some areas where it was STRONGLY suggested that I not touch (by Jon Herron and Chuck Back) so I had Adam do all of the initial setup and now I can diddle with other settings until I get bored.
As long as you don't "unlock" the settings/presets that someone else did (in my case Adam Pelz) you are good to go. Just make a copy of his presets and modify as you desire.
Just go buy one and join the group!
PM sent !!
MANUAL
post #4860 of 7501 Old 08-21-2018, 08:17 AM
RUR
Innocent Bystander
RUR's Avatar
Quoted: 639 Post(s)
Liked: 562
A16 is a finalist in Best New Products for CEDIA.
https://www.cedia.net/insights/cedia...d=1062257&jb=0
mikela, ss9001 and sdrucker like this.
RUR is offline
