Trinnov Altitude - Page 235 - AVS Forum | Home Theater Discussions And Reviews
 2865Likes
post #7021 of 8150 Old 04-22-2019, 06:45 AM
jbuccino's Avatar
Quoted: 82 Post(s)
Originally Posted by jbuccino View Post
I hope so. It has been over 12 hours though. I hope I haven'y lost my database. The unit just shows the red light for a second and then it goes out. Nothing on the screen - no blue light and no way to connect via ssh.
Bad news. Sam finally got back to me last evening and nothing we tried - even re-installing would work. The installation screen would not come up no matter what we tried. I lost everything in my database and have to return the unit. The unsettling thing is that the "crash" happened while the unit was idle. It was working perfectly on Thursday night and then nothing of Friday when I turned my system on. (The power to the Vero was never disconnected.) I just haven't been having much luck with my technology lately. I guess I just have to wait for the replacement, rebuild and try again.
Trinnov Altitude 16, Denon POA-A1, Harmony Elite
Oppo UDP-205, Logitech Transporter, Apple Mini 2018, Vero 4K+ (Kodi 96T RAID 5), AppleTV 4K, Rega RP10, Ayre P-5xe
Sony XBR 65A1E, Runco Q750i onto a Stewart Cabaret 120
Paradigm Signature S8, C5, ADP, Sub 1, Polk Audio RT3000p
jbuccino is offline
post #7022 of 8150 Old 04-22-2019, 08:20 AM
Steve Bruzonsky's Avatar
Quoted: 1420 Post(s)
Liked: 678
Jon Herron of Trinnov got back to me regarding whether it was possible, since Auro-3D runs only up to 96k, for two channel music, for the front left and right stereo channels to run up to 192k, with the remaining channels running up to 96k. Jon checked with France on this to find out that the Altitude 32 cannot run at different sampling rates on different channels; and that Trinnov does not have the source code for Auro's upmixer with the code that Trinnov has working only to 96k.
I've already confirmed that the difference of 192k vs 96k, or 176k vs 88k, is very, very slight at best; whereas the difference using Auro-3D is much more prolific in terms of sonics as far as I am concerned. And of course, there is always the option of playing in "native" stereo for two channel at the higher resolution.
https://www.avsforum.com/avs-vb/show....php?t=1158431 No dealer is authorized to tell you I refer to them - any referrals I make will be done personally by me. Over the years I have found certain dealer(s) who I cannot recommend for good reason.
! 9.4.13 Trinnov Altitude 32 Theatre renovation/upgrade starts end of July 2019!
Steve Bruzonsky is offline
post #7023 of 8150 Old 04-22-2019, 08:29 AM
audioguy's Avatar
Quoted: 4580 Post(s)
Liked: 3349
Originally Posted by Steve Bruzonsky View Post
J I've already confirmed that the difference of 192k vs 96k, or 176k vs 88k, is very, very slight at best; whereas the difference using Auro-3D is much more prolific in terms of sonics as far as I am concerned. And of course, there is always the option of playing in "native" stereo for two channel at the higher resolution.
192K in two channel vs 96K in Auro? No comparison.
Another subject. Have you been able to play any of your ripped 4.0 or 5.1 DVD-A discs on the Trinnov via Roon? For some reason (probably Operator Error) I am still unable to get anything but 2 channel even though Roon shows that is delivering multi-channel.
audioguy is offline
post #7024 of 8150 Old 04-22-2019, 08:35 AM
Liked: 678
Yes, I have no issue at all playing ripped SACD or DVD-A or purchased downloaded hi rez multi-channel albums (NativeDSD.com). The ROON display always shows the proper # of channels playing. And I've checked the Alt32 processing tab (with Alt32 audio mode set to native so that processing tab will show incoming native channels) and it shows all channels playing. I have ROON set to channel mapping only. However, I will triple check this later today and I'll let you know 100% for sure.
I wonder if this could have anything to do with your Alt32 having a defective firewire card. Remember, my Alt32 skipped on stereo and multi-channel above 96k and the firewire card was replaced as it bandwith issues. No issues anymore.
post #7025 of 8150 Old 04-22-2019, 08:52 AM
Kal Rubinson's Avatar
Quoted: 1227 Post(s)
Liked: 1087
Yes.
Kal Rubinson
"Music in the Round"
Kal Rubinson is offline
post #7026 of 8150 Old 04-22-2019, 09:27 AM
Berland's Avatar
Quoted: 321 Post(s)
Liked: 209
Weird, I had multiple OSMC units without any issues. Hope you get better luck with the next one. By the way, I have heard of units die, but usually that is due to bad ventilation (sticking the Vero 4K+ in narrow places on top of surround processor with no circulation of air).
HT: Trinnov Altitude32 (AL32-1632)/Amplitude8/8M - BRYSTON 4B SST2 - B&W 803D2, 2*DB1, HTM2D2, 804D2, SCMS, Nautilus SCM1, 805D2 - NORDOST Heimdall2/Frey2 - ISOTEK EVO3 Titan,Sigmas - LG OLED65B7V - GIK ACOUSTICS
HP: 2*MOON 430HA D, 2*MiND2 Network Player - 2*Yggdrasil - 2*Hydra Z/ZPM - ISOTEK EVO3 Sigmas, Aquarius - NORDOST Heimdall 2 - AUDEZE LCD-4 rev2, 2*LCD-XC - SHURE SE846
Berland is online now
post #7027 of 8150 Old 04-22-2019, 09:31 AM
jbuccino's Avatar
Quoted: 82 Post(s)
Yeah, hopefully just bad luck. Ventilation and heat was not a problem with mine. It was on an open shelf with plenty of airflow and space and never got that warm even in constant use. "Uptime" showed an average of 2% processor load. But then - all of a sudden - nothing. It is quite frustrating after spending so much time getting it set up.
jbuccino is offline
post #7028 of 8150 Old 04-22-2019, 09:39 AM
Berland's Avatar
Quoted: 321 Post(s)
Liked: 209
I run the database on mysql (on one of my NAS boxes) - then only thing I need to do is to connect the device to database; the rest just works - takes 2 minutes maximum. Also today a version built on kodi 18.1 was released; seems to work very well.
Using a database on network also enables me to use it on multiple devices.
Edit:
Your issue can also be connected to faulty power supply; if you have access to a different power supply with same specifications you could try that.
post #7029 of 8150 Old 04-22-2019, 09:43 AM
jbuccino's Avatar
Quoted: 82 Post(s)
I'm not sure I understand. I don't see any option for moving the Kodi database to another volume. But regardless of where it is, I will have to rebuild it. And that requires a bit of manual intervention on my part so that all my movie and TV show descriptions are downloaded properly.
jbuccino is offline
post #7030 of 8150 Old 04-22-2019, 09:50 AM
Berland's Avatar
Quoted: 321 Post(s)
Liked: 209
You can set up mysql on any device; and connect any kodi client to this device (read: database). Easy Google knows
post #7031 of 8150 Old 04-22-2019, 09:53 AM
jbuccino's Avatar
Quoted: 82 Post(s)
OK. Maybe I will look into it when I get a replacement device. I have not heard anything about shipping. I hope they don't make me wait until they get my defective unit back. I am already frustrated enough. I hate when my system is down and I can't do anything about it.
jbuccino is offline
post #7032 of 8150 Old 04-22-2019, 10:13 AM
Berland's Avatar
Quoted: 321 Post(s)
Liked: 209
Just push them and say you want it fast
post #7033 of 8150 Old 04-22-2019, 10:16 AM
jbuccino's Avatar
Quoted: 82 Post(s)
I did. There has been no response at all since last evening. That is why I suspect nothing is happening.
jbuccino is offline
post #7034 of 8150 Old 04-22-2019, 01:49 PM
Marc Alexander's Avatar
Quoted: 5287 Post(s)
Liked: 4803
@Kal Rubinson have you written about the Altitude 32 or 16 in your column? Google only seems to find your report on the R-972.
Do you own an Altitude now?
Mike_WI likes this.
Marc Alexander is offline
post #7035 of 8150 Old 04-22-2019, 01:59 PM
Liked: 1087
Currently, in press for the July issue.
No.
Mike_WI and Papouche Le Mec like this.
Kal Rubinson
post #7036 of 8150 Old 04-22-2019, 02:32 PM
Liked: 4803
A16 or A32?
post #7037 of 8150 Old 04-22-2019, 04:23 PM
Liked: 1087
A16 or A32?
Altitude32-816
mikela, ss9001, sdrucker and 1 others like this.
Kal Rubinson
post #7038 of 8150 Old 04-22-2019, 04:51 PM
Liked: 678
No.
Altitude32-816
Very very [email protected]@@
You will find the ROON Ready ethernet working and sounding great! Like me, you can experiment for albums where you have hi rez two channel vs hi rez multi-channel as to which sounds better - in Auro-3D (but you have to set ROON to output no higher than 96k for Auro-3D to work) .
post #7039 of 8150 Old 04-22-2019, 06:04 PM
Liked: 7
As a crazy audiophile, I want my sonics to be top notch and I have clearly noted leaving the Altitude 32 on gives me best sonics as it has no standby feature. Easy to keep my TIVO OTA Bolt or DirecTV playing with volume turned all way down; and easy once in awhile to turn off and back on to avoid "log filling up".
I received this message from Curt today.
Today, 11:31 AM - Thread Starter
Curt_Trinnov
3D Audio Consultant
Curt_Trinnov's Avatar
Quoted: 81 Post(s)
Liked: 141
Logs details
Yes, more detail, as your post is not clear enough
“applies to beta 4.2.11 only: Selecting HDMI source with no clock will quickly fill logs. Logs are continuously getting error “no clock”
For production software, yes better to turn off each night as the oldest log is replaced by the new one, which has the effect of good log housekeeping, keeping log sizes to a minimum. Logs are essential land necessary for this complex box, to allow diagnosing issues when they occur.
Happy easter, cheers!
Curt Hoyt
3D Audio Design & Tuning Services
CEDIA 2017 Best Home Cinema Level IV - (3D audio consulting- see profile)
Papouche Le Mec is offline
post #7040 of 8150 Old 04-23-2019, 12:07 AM
Liked: 678
Curt_Trinnov
3D Audio Consultant
Quoted: 81 Post(s)
Liked: 141
Logs details
Curt Hoyt
Thanks. Good info.
post #7041 of 8150 Old 04-23-2019, 07:57 AM
audioguy's Avatar
Liked: 3349
Steve:
Thanks for the link to that website. Very nice stuff.
Other than downloading to my computer and then moving the file to my SGC, is there another way to get it on the i5 without the double step?
audioguy is offline
post #7042 of 8150 Old 04-23-2019, 08:52 AM
dancjodanc's Avatar
Quoted: 288 Post(s)
I'm new to Trinnov..so new it has not arrived yet! But had a few questions. On the Altitude 16, does it have support for ARC? I might be getting rid of my cable box, and wanted to know if I could route the sound back to the 16 that way?
Also, I know it has digital outputs....would those be 'on' all the time? If I go with audio via ethernet, I need sound out of the 16 to a pre/pro that I use for another zone of music...controlled by a totally different system. I would just want the same music being played throughout the house!
dancjodanc is offline
post #7043 of 8150 Old 04-23-2019, 09:00 AM
Liked: 1087
Indeed. Very good stuff.
In theory, you can download it to any drive on your network to avoid having to move it from one device to another. However, the downloads are zipped files and you may find it easier to unzip them on your computer.
Kal Rubinson
post #7044 of 8150 Old 04-23-2019, 09:26 AM
Liked: 678
Steve:
I agree. I download to a pc and then copy to both my main Western Digital 32 TB MyCloudPR4100 and also to the backup drive.
By the way, good sites to purchase and download hi rez music from:
www.hdtracks.com
www.prostudiomasters.com
www.nativedsd.com (includes multi-channel)
www.highresaudio.com
(some music may not be purchased in US due to territorial restrictions, but a lot still can be purchased including most albums with label 2xHD)
www.bluecoastmusic.com
A7mad78 likes this.
post #7045 of 8150 Old 04-23-2019, 09:28 AM
Mike_WI's Avatar
Quoted: 434 Post(s)
Liked: 411
www.hdtracks.com
I would add Qobuz for those that purchase Qobuz Sublime+
https://www.qobuz.com/us-en/music/streaming/offers
https://www.qobuz.com/us-en/shop
HT: Oppo UDP-203 -> Lumagen RadiancePro 4446 {18 GHz input x2 & 18 GHz output x1 cards} - "new (112818 FW)" 18 GHz microcode - parallel outs to --> [Audio: Denon 5308CI] --> [Video: JVC RS520 FW v30.1]
HT Details: link
Mike_WI is offline
post #7046 of 8150 Old 04-23-2019, 10:44 AM
mry110's Avatar
Quoted: 157 Post(s)
Liked: 69
My Trinnov is all of the sudden having issues with my DirecTV the last few weeks. It appears to be an HDCP issue. I was getting an error message saying the TV was incompatible with the content protection. I decided to take this opportunity to upgrade my system to see if a new box would solve the problem. I just had a technician out at the house this morning upgrading to a Genie 2 system, which involved changing over to a 4K client box for my media room. Same issue with the new box, it was as if the DTV box was not seeing my 4K HDMI chain. I narrowed the issue down to the Trinnov, because if I hooked the DTV box directly up to my JVC RS4500, everything worked fine. Any ideas?
mry110 is offline
post #7047 of 8150 Old 04-23-2019, 12:56 PM
Liked: 678
www.hdtracks.com
One more, last but not least.
www.highdefinitiontapetransfers.com
Lately I've been getting some of their jazz titles and they are amazing sounding - stereo!!! Mostly old concerts recorded on reel to reel at 15 LPS!
post #7048 of 8150 Old 04-23-2019, 02:03 PM
madhuski's Avatar
Quoted: 1289 Post(s)
Liked: 823
Then let me give you a completely biased statement. If you ever want expandability beyond 16 channels; if you want to be able to get Codec changes via download vs chip changes; if you want a processor that has more built-in calibrator functionality than any thing on the market; if the pricing of the Trinnov is in your budget, then buy the Trinnov. If those things are not important to you, then you have lots of other excellent choices - and you should consider investigating other products/threads.
Thanks Chuck - I'm probably maxxed at 7.2.4. I've got a Bryston sp4 (storm audio clone) right now, but I've got the "what if" re: the Trinnov. I'm debating wether or not it'd be worth it to just compare both in my room.....
madhuski is offline
post #7049 of 8150 Old 04-24-2019, 08:33 AM
mineforever's Avatar
Quoted: 26 Post(s)
Liked: 3
Hi everyone,
I have a question on the optimization applied on the sound by the Trinnov32. Is this optimization applied on the digital signal or the analogue one?
I am asking to see how best to listen to my DSD music, if the optimization is appolied on the analogue signal then i use a DSD DAC as a source to feed the trinnov with an analogue signal.
mineforever is offline
post #7050 of 8150 Old 04-24-2019, 09:31 AM
RUR
Innocent Bystander
RUR's Avatar
Quoted: 649 Post(s)
Liked: 577
Originally Posted by mineforever View Post
Hi everyone,
Everything is done in the digital domain, including basics like gains/delays and even volume (64bit FP). There is no pure analog path thru the Altitude.
RUR is offline
