Trinnov Altitude - Page 236 - AVS Forum | Home Theater Discussions And Reviews
 2805Likes
post #7051 of 8067 Old 04-24-2019, 09:58 AM
mineforever's Avatar
Quoted: 26 Post(s)
Liked: 3
Originally Posted by RUR View Post
Everything is done in the digital domain, including basics like gains/delays and even volume (64bit FP). There is no pure analog path thru the Altitude.
Thanks for reply. What is the best way to play DSD files?
mineforever is offline
post #7052 of 8067 Old 04-24-2019, 10:26 AM
Steve Bruzonsky's Avatar
Quoted: 1417 Post(s)
Liked: 676
I set ROON to downsample to 88k and play via Alt32 in Auro-3D, for both multi-channel and two channel DSD, DSD256 or DSD512. You can play DSD, etc in straight stereo if you set ROON to 176k, but not Auro-3D.
https://www.avsforum.com/avs-vb/show....php?t=1158431 No dealer is authorized to tell you I refer to them - any referrals I make will be done personally by me. Over the years I have found certain dealer(s) who I cannot recommend for good reason.
! 9.4.13 Trinnov Altitude 32 Theatre renovation/upgrade starts end of July 2019!
Steve Bruzonsky is online now
post #7053 of 8067 Old 04-24-2019, 11:55 AM
Berland's Avatar
Quoted: 310 Post(s)
Liked: 200
Hi everyone,
I have a question on the optimization applied on the sound by the Trinnov32. Is this optimization applied on the digital signal or the analogue one?
I am asking to see how best to listen to my DSD music, if the optimization is appolied on the analogue signal then i use a DSD DAC as a source to feed the trinnov with an analogue signal.
Optimizer works in the digital domain. DSD music; if you are playing from Roon - Roon will convert to PCM when using Altitude32 as a Roon endpoint (over ethernet)
You can of course use a DSD DAC; but then you will convert the analog to digital when entering the Trinnov; then back again - not optimal. DSD through the Trinnov (PCM converted in Roon) sounds fantastic. No need to make it more complicated.
Wookii likes this.
HT: Trinnov Altitude32 (AL32-1632)/Amplitude8/8M - BRYSTON 4B SST2 - B&W 803D2, 2*DB1, HTM2D2, 804D2, SCMS, Nautilus SCM1, 805D2 - NORDOST Heimdall2/Frey2 - ISOTEK EVO3 Titan,Sigmas - LG OLED65B7V - GIK ACOUSTICS
HP: 2*MOON 430HA D, 2*MiND2 Network Player - 2*Yggdrasil - 2*Hydra Z/ZPM - ISOTEK EVO3 Sigmas, Aquarius - NORDOST Heimdall 2 - AUDEZE LCD-4 rev2, 2*LCD-XC - SHURE SE846
Berland is online now
post #7054 of 8067 Old 04-24-2019, 12:52 PM
Berland's Avatar
Quoted: 310 Post(s)
Liked: 200
No, set Altitude32 to maximum 96kHz in Roon, and you will get DSD converted to 88.2kHz. With maximum 192kHz you will not get Auro-3D for anything above 96kHz. But if you don't want to use Auro-3D, this will make DSD play in 176.4kHz.
Edit:
Many DSD compatible DACs actually work internally in PCM domain; they just do an internal conversion of DSD to PCM. Other works the other way; they internally work in DSD then PCM is internally converted to DSD. Another side note; many DACs with sigmadelta DAC chips actually only use the PCM part internally in the chip (these are then converted to DSD). So DSD is not DSD just because you can send this into the DAC. The world is more complicated.
Name:	Skjermbilde 2019-04-24 kl. 21.52.08.png
post #7055 of 8067 Old 04-24-2019, 04:21 PM
Liked: 676
Edit:
I agree with you!!! Except that one may want to use different DSP filters in ROON, which you only get by enabling DSP, and then settings must be set for each sampling resolution/rate.
post #7056 of 8067 Old 04-25-2019, 06:18 AM
Berland's Avatar
Quoted: 310 Post(s)
Liked: 200
I'm fairly sure that the selected DSD filter is used when Roon is by default converting DSD to PCM with DSP/Sample Rate Conversion disabled.
post #7057 of 8067 Old 04-25-2019, 08:05 AM
Liked: 676
Aside from the DSD filter, there are four other filters you can use. See photos. But you cannot change the filter unless you engage the DSP function.
ID:	2558032   Click image for larger version
post #7058 of 8067 Old 04-25-2019, 02:45 PM
ss9001's Avatar
Quoted: 602 Post(s)
Liked: 626
Steve B, which SGC roon server do you use? I assume it's one of the sonictransporter models. Since you can get multi-channel out of yours, I'd like to know if you have an i5 or i7 model. I had emailed Andrew before I bought one asking about the HDMI connection, which he confirmed they don't support, and he thought he implied they don't support multichannel, which is why I'm asking I bought an i5 model, the one with the CDR drive, same model as audioguy's. It'd be nice if the one I have can send 5.1 to the Altitude
I still have to setup a Roon acct so haven't dived into the weeds yet. Roon & Tidal or Qobuz will all be new to me.
Steve
ss9001 is offline
post #7059 of 8067 Old 04-25-2019, 03:01 PM
Liked: 676
Both the Small Green Computer Sonic Transporter i5 and also the i7 for ROON DSP will work as a ROON Core for both 2 and multi-channel. If you have multi-channel DSD or higher that you are downsampling via ROON, the i5 might get hung up a bit over long ethernet runs (from one room to another). Might. I had an i5 and then got an i7 because the latter has 2 ethernet inputs/outputs, so one can connect to network switcher, one can connect direct to Altitude 32 (or 16). Some at Audiophile Style thought the direct ethernet connection sounds better. it maybe did with my prior SSP, but now with Alt32 I don't know, haven't tested it either way. Plus I use a DJM Electronics Gigafoil v4 between my i7 ROON Core and the Alt32 - takes ethernet in, outputs ethernet, but inside is fiber/optical conversion to eliminate/reduce any EMI noise.
post #7060 of 8067 Old 04-25-2019, 03:09 PM
Kal Rubinson's Avatar
Quoted: 1216 Post(s)
Liked: 1075
SGC has been elusive about multichannel for years but there is no reason that their i5 or i7 models cannot support multichannel via Roon. I have used a older MacMini i5 exactly this way with the A32.
Kal Rubinson
"Music in the Round"
Kal Rubinson is offline
post #7061 of 8067 Old 04-25-2019, 03:27 PM
Berland's Avatar
Quoted: 310 Post(s)
Liked: 200
Roon Nucleus/Nucleus+ works flawless with multichannel. Why make it complicated? Or build your own based on Intel NUC (much cheaper).
post #7062 of 8067 Old 04-25-2019, 05:01 PM
Liked: 1075
Yes, as long as you do not use much DSP/resampling.
Kal Rubinson
post #7063 of 8067 Old 04-25-2019, 05:02 PM
Liked: 676
SGC are less money, more power, better deal and work as flawlessly or better than the ROON Nucleus models. Any ROON Core device can serve as a ROON Core for multichannel music. The question is the ROON endpoint. My up for sale Sonore Signature Rendu SE w Tier 3 optical/fiber mod (USB to Berkeley Audio Alpha USB Converter, just sold) was 2 channel only. I used a modded CAPSv3 HDMI out (for sale now) for multi-channel audio with my prior Theta CBIVA SSP. But not only is the Altitude 32 (and 16) ROON Ready ethernet, I found that ROON Ready sounded about the same as using my "expensive" Sonore USB player/Berkeley combo. And before HDMI multi-channel not as good sounding as two channel in my prior system, as HDMI just is good but not as good sounding as Sonore/Berkeley 2 channel. Now my ROON Ready ethernet for ROON 2 and multi-channel sound fantastic and identical.
By the way go over to www.highdefinitiontapetranspfers for a few days they have a 20% off sale. Their stuff sounds awesome, recorded originally back in the day on Reel to Reel at 15 LPS!
post #7064 of 8067 Old 04-25-2019, 05:21 PM
mani's Avatar
Quoted: 258 Post(s)
Liked: 103
Main advantage of nucleus is that it can be incorporated into Control4 or other automation systems . Roon provides drivers for main automation systems but they only work with nucleus . That was the main reason I ended up getting nucleus rather that building my own , which I always prefer in computers .
Something to consider if that is important to you
mani is offline
post #7065 of 8067 Old 04-25-2019, 10:24 PM
Liked: 676
My Sonic Transporter i7 for ROON DSP is always on, so I don't see any need to control. I should also mention that Small Green Computer/Andrew Gillis has customized a Linux - Sonic Orbiter - operating system just as the ROON Nucleus has done.
post #7066 of 8067 Old 04-25-2019, 11:12 PM
Liked: 3
so im gathering equipment for my soon (hopefully) to be built dedicated theater.
reading and gathering info on processors. until today i thought i had settled on the Marantz AV8805.
my buddy told me i should check out the Altitude 16.
with fairly limited research completed as of yet...i have reached my first observation/question.
i know the Alt 16 processes 16 channels. i dont see subwoofer outs on rear panel.
does this mean if i want 2 subs i am maxed out with 14 full range speakers?
ex: 7.2.4....maybe adding VOG
then im done, right?
thanks for your time
googoogjoob is offline
post #7067 of 8067 Old 04-26-2019, 12:51 AM
maikeldepotter's Avatar
Quoted: 1451 Post(s)
Liked: 510
Using identical subs and a splitter you only need 1 channel, leaving 15 channels to go all the way up to e.g. 9.x.6.
googoogjoob likes this.
A good idea and understanding lies at the base of every successful project.
maikeldepotter is offline
post #7068 of 8067 Old 04-26-2019, 03:48 AM
ss9001's Avatar
Quoted: 602 Post(s)
Liked: 626
In Trinnov-world, there aren't designated channel xlr connections. You map each channel to any number & position of speakers or number of subs as you want; it's all done in the software's speaker layout. For example, you could have 4 subs, one on each channel for 7.4.4. The only downside is using up channels for each sub that could be used for more speakers.
If your 2 subs are at identical distances from main listening position, especially if they are identical subs (mine aren't), then you can combine them into 1 channel with a y-cable as maikeldepotter suggested. A y-cable isn't a bad way to start. I did that for a short time until I mastered how to use an external DSP and how to set the delays & gains for each sub.
This is also a Trinnov trick for managing multiple subs that still uses 1 channel & connection per sub but is another option for calibration purposes.
Steve
ss9001 is offline
post #7069 of 8067 Old 04-26-2019, 06:58 AM
Berland's Avatar
Quoted: 310 Post(s)
Liked: 200
Or alternatively you go for the Altitude32 with 24 or 32 channels
post #7070 of 8067 Old 04-26-2019, 08:38 AM
mani's Avatar
Quoted: 258 Post(s)
Liked: 103
Hi Steve
The advantage I was referring to was that I don’t have to give kids and the family access to Roon app where they can change settings etc . Control4 can create Roon zones and I can name everyone’s favorite list and from control 4 remote or touch panel they can play their list in any zone . I am still in the programming stages of this with Control4 , so don’t know how seemless this will work . Again that advantage may or may not be important based on everyone’s listening conditions .
mani is offline
post #7071 of 8067 Old 04-26-2019, 09:03 AM
Liked: 7
Is there a difference in sound quality in music servers A vs B (SGC vs Roon Nucleus/+, PS Audio, ETC playing over the Ethernet? I agree using a PC may be bad because of noise. I believe the endpoint makes the difference. Enquirer wants to know!!
Papouche Le Mec is offline
post #7072 of 8067 Old 04-26-2019, 11:37 AM
Liked: 676
Probably not so much a ROON Core vs absolutely on your ROON Endpoint or ROON Ready device.
The beauty of ROON is that you can separate the ROON Core device, which does all the processing and sample rate conversion, from the endpoint or ROON Ready device, which is the player. This improves the audio quality. Initially with ROON I used a CAPSv3 Zuma modded (Computer Audiophile Pocket Server) (custom built to my specs by Small Green Computer) (see my ad at Audiophile Style/Computer Audiophile For Sale Forum as I'm selling this as no longer use) but then ROON came out with an update providing for separate ROON Core and ROON Ready devices, and I then got the Sonore Microrendu, and the better sonics were clear.
You don't need to worry - you've got the Trinnov SSP which is ROON Ready.
However, you could do what I have done. Add a DJM Electronics Gigafoil v4 https://www.djmelectronics.com/gigaf...et-filter.html inbetween your ROON Core and the Altitude. Provides ethernet to fiber/optical to ethernet conversion, saying bye bye to EMI noise in the line.
DJM Electronics is a military supplier of this and related technology. And just use the supplied wall wart LPS power supply, it works fine - I've tested a separate LPS (linear power supply) and took it out because the wall wart LPS sounds as good.
post #7073 of 8067 Old 04-26-2019, 03:02 PM
Liked: 3
only if you are contributing!
Berland likes this.
post #7074 of 8067 Old 04-26-2019, 03:05 PM
Liked: 3
thats good to know. thanks. 9.2.6 is my goal. ill be using 2 B&W CT SW15s which employ an outboard amp/crossover which powers 2 subs.
problem solved! thanks again to Maikel & SS9001
Last edited by googoogjoob; 04-26-2019 at 03:07 PM. Reason: additional thoughts...
post #7075 of 8067 Old 04-26-2019, 06:18 PM
Liked: 7
Thank you.
post #7076 of 8067 Old 04-27-2019, 04:25 AM
ss9001's Avatar
Quoted: 602 Post(s)
Liked: 626
That's why I have an Altitude 16
sdrucker and googoogjoob like this.
Steve
ss9001 is offline
post #7077 of 8067 Old 04-27-2019, 12:07 PM
Quoted: 39 Post(s)
Anyone know if the warranty is transferable on the Altitude's?
Nicholas Vit is offline
post #7078 of 8067 Old 04-27-2019, 12:38 PM
Berland's Avatar
Quoted: 310 Post(s)
Liked: 200
Have not checked how it works on Trinnov units, but all other warranties I have used - they never cared about who originally purchased it. I'm guessing it is the same for Trinnov.
post #7079 of 8067 Old 04-27-2019, 12:40 PM
kingwiggi's Avatar
Quoted: 552 Post(s)
Liked: 354
Yes, new owner gets the balance of the 5 year warranty.
Sent from my iPhone using Tapatalk Pro
Trinnov Altitude 32, LCR JBL M2, JBL LSR 708i, 705i, Q-SYS Core 110f, Amps- QSC CXD4.2Q, 4.3Q, 4.5Q
Kaleidescape Strato, Zapitti 4K HDR Duo, Xbox One X, 8TB Tivo Roamio Pro,
JVC RS600 + ISCO IIIL, 158" 2.40:1 AT screen, Calman 5 Enthusiast, i1 Pro 2, i1 Display Pro, Spyder 5, 3D LUT Box
Oppo UDP-203, BDP-105, Onkyo DAC-1000s, Onkyo DP-X1 DAP, QNAP TVS-871
kingwiggi is offline
post #7080 of 8067 Old 04-28-2019, 04:42 AM
madhuski's Avatar
Quoted: 1286 Post(s)
Liked: 823
Originally Posted by appelz View Post
Recommended practice is to reboot the Altitude at least once daily.
Is this as simple as turning it off and on with the power button, or do you have to go into a menu to do this?
(trying to suss out how easy/difficult an altitude would be for a wife and small kids to use daily)
madhuski is offline
