Trinnov Altitude - Page 239 - AVS Forum | Home Theater Discussions And Reviews
 2887Likes
post #7141 of 8159 Old 05-04-2019, 08:02 AM
mani's Avatar
Quoted: 260 Post(s)
Liked: 103
Originally Posted by A7mad78 View Post
Q : to whom have lumagen with trinnov and k-scape strato
Do u get in lumagen info page in out 1
The 18G Y and hdcp 2.2
Not as showing in my page besides 18G N and hdcp 1.x
If you have only one 18G output card , I believe only one output of the card is configured as dedicated 18G video out and other as audio out by default . May want to go through the manual . I dont remember exact details off hand
appelz likes this.
mani is offline
post #7142 of 8159 Old 05-04-2019, 08:05 AM
adidino's Avatar
Quoted: 507 Post(s)
Liked: 355
I have a Lumagen but not setup yet. @thrang has one setup and active. He might be able to check but depending how you configured the Lumegan when you ordered, you need to specify which inputs and outputs are 18g and there's usually a cost for the additional upgraded cards. .
AudioXtream
Authorized Dealer:
Trinnov, Anthem, SVS, Triad, Genelec,
Revel, JBL Synthesis/JBL Pro, Paradigm, Kaleidescape, PS Audio, JVC,
Panamorph, LG
adidino is offline
post #7143 of 8159 Old 05-04-2019, 08:11 AM
Steve Bruzonsky's Avatar
Quoted: 1421 Post(s)
Liked: 679
Each 18G output card has the higher numbered output 18G and the lower numbered output 9G. Your memory is good!
https://www.avsforum.com/avs-vb/show....php?t=1158431 No dealer is authorized to tell you I refer to them - any referrals I make will be done personally by me. Over the years I have found certain dealer(s) who I cannot recommend for good reason.
! 9.4.13 Trinnov Altitude 32 Theatre renovation/upgrade starts end of July 2019!
Steve Bruzonsky is online now
post #7144 of 8159 Old 05-04-2019, 08:13 AM
Quoted: 174 Post(s)
Liked: 67
Yes ur right it mention out 2 as 18G
Out 1 as audio
And that led to me to be limited to 7.1 on K even if it show the edid stuck to 7.1 from hours I do many scenario with no improve even trinnov honestly to work hard with me and still we don’t resolve
A7mad78 is online now
post #7145 of 8159 Old 05-04-2019, 08:14 AM
Quoted: 174 Post(s)
Liked: 67
That’s the problem I have
post #7146 of 8159 Old 05-04-2019, 08:23 AM
Liked: 679
Your KScape display doesn't show "Audio HDMI" because you haven't connected the audio HDMI cable - you are using the KScape video HDMI out (which also includes audio) to the Radiance Pro with then audio HDMI out to the Trinnov SSP. So long as the Trinnov SSP display shows that you are getting the right audio (which mine does with KScape, as I've connected this way for now, too, with Radiance Pro and KScape) you are fine.
post #7147 of 8159 Old 05-04-2019, 08:37 AM
Quoted: 174 Post(s)
Liked: 67
I try to connect k to trinnov and the out 2 from trinnov to lumagen input and get the same result even though I unplug the k to refresh the EDID
In the 2 way I get limited to 8 ch max
post #7148 of 8159 Old 05-04-2019, 09:25 AM
appelz's Avatar
Quoted: 564 Post(s)
Liked: 566
I don't see a problem. Under HDMI, every indicator is Blue, indicating sent without adjustments.
Can you play a known Atmos movie and post a screen shot of the Decoder settings on the Altitude?
Adam Pelz ,Acoustic Mafia - Hear No Evil
JBL Master ARCOS Calibrator, CEDIA Designer, Home Acoustics Alliance Instructor LIII, THX HT1+ HT2+ Video, Level III Trinnov Altitude Calibrator
Mercenary Calibrator for Manufacturers, Integrators and System Owners
appelz is online now
post #7149 of 8159 Old 05-04-2019, 09:44 AM
Quoted: 174 Post(s)
Liked: 67
post #7150 of 8159 Old 05-04-2019, 09:50 AM
appelz's Avatar
Quoted: 564 Post(s)
Liked: 566
Everything is perfectly fine. The incoming codec is Dolby Atmos.
post #7151 of 8159 Old 05-04-2019, 09:53 AM
Quoted: 174 Post(s)
Liked: 67
Thx that’s what K report to me why it show it’s max to 8 ch atmos and it show not supported object based
Thx for ur help
CEA Audio Data Block
FormatLinear PCM (uncompressed)
Max num channels2
Frequencies (kHz)32 44 48 88 96
Sample size (bits)16 20 24
Max num channels8
FormatAC3
Max num channels8
Max bit rate (kb/s)648
FormatDolby Digital Plus
Max num channels8
Frequencies (kHz)44 48
Format defined info81
FormatDTS
Max num channels8
Max bit rate (kb/s)1536
FormatDolby TrueHD
Max num channels6
Frequencies (kHz)48 96 192
Format defined info1
FormatDolby TrueHD
Max num channels8
FormatDTS-HD
Max num channels6
FormatDTS-HD
Max num channels8
post #7152 of 8159 Old 05-04-2019, 10:00 AM
appelz's Avatar
Quoted: 564 Post(s)
Liked: 566
Not sure about the object based part, but the object metadata for Atmos is embedded in the 8ch bitstream. You won't ever see 15ch or 23ch etc etc. I've never actually seen that page on a Kaleidescape ?
On the Altitude, find a meters tab while an Atmos movie is playing and you can see what is going on. Hit the Gears icon and then Meters.
EDIT : Ah, that is from the Kscape onscreen menus, not the web interface.
post #7153 of 8159 Old 05-04-2019, 10:02 AM
Quoted: 174 Post(s)
Liked: 67
It’s useful and just I get it on 30/4/2019 they updated there web interface and add this and more features
post #7154 of 8159 Old 05-04-2019, 10:17 AM
Quoted: 174 Post(s)
Liked: 67
Originally Posted by J.Green View Post
Most people can leave the "HDMI Content Type Metadata" on its default setting of "Do not transmit content type metadata".
There are some projectors which perform aspect ratio detection by examining the black areas of the projected image. However, the layout of the OSD covers place when in CinemaScape mode could cause those projectors to miscalculate the required aspect ratio and end up cropping the image (for example, Barco projectors were affected by this).
If your projector consistently miscalculates the required aspect ratio when automatically zooming, enabling "Transmit content type metadata" may fix the issue.
And yes, as you've discovered, we've added two new tabs to the HDMI Capabilities popup to aid in diagnostics when you aren't getting the expected video or audio output. There is now an "Audio Capabilities" tab that shows you which ports are active and what their status is.
The second addition is a tab where you can view the HDMI EDIDs for the primary and secondary (if connected) HDMI ports.
Here is a Quote from k-Scape owners when I post about the new web interface
post #7155 of 8159 Old 05-04-2019, 05:25 PM
madhuski's Avatar
Quoted: 1290 Post(s)
Liked: 823
is there a way to “factory reset” an Altitude?
Selling in AVS Classifieds
Revel Studio2 Pair - gloss black
madhuski is offline
post #7156 of 8159 Old 05-05-2019, 07:14 AM
appelz's Avatar
Quoted: 564 Post(s)
Liked: 566
Not that I am aware of. Any unused preset is essentially "factory" tho, aside from any source config or such. Early on, I'd break mine now and then playing in the "Here there be LARGE dragons" area, but even reloading that I don't think would be a true "factory reset".
I'd guess the engineers in France would have a way to clear out files in a machine from their end, but based on how the Altitude works, really not much need for it.
madhuski likes this.
post #7157 of 8159 Old 05-05-2019, 07:21 AM
madhuski's Avatar
Liked: 823
Thanks, that’s what it seemed to me. I cleared the sources and saved presets but wanted to make sure there was nothing else that needed to be emptied before starting.
madhuski is offline
post #7158 of 8159 Old 05-05-2019, 08:03 AM
sdrucker's Avatar
Quoted: 1616 Post(s)
Liked: 1262
So now you've joined us?????
That didn't take long. Which Altitude did you buy - the Altitude 16 or the 32?
Audio Gear: Trinnov Altitude 32 (24 channel), NAD M27 amps (3)
Video: JVC RS600, Seymour 100" UF Screen, Lumagen Radiance Pro 4444 (coming soon)
Speakers: PSB Imagine T3 LCR, Imagine T Wides/Side Surround 1, T2 Side Surrounds, Imagine XB rears, Image B6 screens, PSB CS1000 ceilings (6), HSU ULS-15 Mk 2 subs (4) - 13.4.6
HAA HT1 and HT2 Certification
sdrucker is online now
post #7159 of 8159 Old 05-05-2019, 08:29 AM
madhuski's Avatar
Liked: 823
heh, yeah- it wasn’t a planned joining but a Alt 16 came up locally for sale. Figured it was meant to be.
madhuski is offline
post #7160 of 8159 Old 05-06-2019, 02:29 PM
sdrucker's Avatar
Liked: 1262
So, what are your future plans? If I remember correctly, you have a 7.1.4 room. Are you just going to use the Altitude 16 for managing subs in a 7.1.4 context, or are you going to go to 7.1.6 or 9.1.6 (or if you've the room, some variation of 11.1.4 LOL) and have subs managed by a MiniDSP or Xilica? The speaker configuration menu is a good place to start, as well as your priorities. That would probably be Atmos vs. Auro vs. DTS:X, as well as the more esoteric Trinnov practice of "universal format" in The Cedia Designer.
You do know, that other than price/value compelling you to try a more limited pre/pro, there's nowhere to go from here .
My advice is that you want to focus on how to get the most out of your new toy. While you can just look at "sound quality" without any acoustic correction or level/delay management, you only begin to get the value out for your purchase decision by running the Trinnov Optimizer. Some will tell you that just running the Optimizer with the Configuration Wizard is "80%" getting you there, IMO the key to this processor is exploring target curves and determining just how the Optimizer parameters will work best for your specific experience. That assumes that you have your own 3D mic as part of the conditions of the purchase. And I'd strongly seeking at least rudimentary - even for a few hours of walking you through the unit and a basic calibration - assistance from a pro calibrator or other support. You're in the big leagues now...
post #7161 of 8159 Old 05-06-2019, 06:38 PM
kingwiggi's Avatar
Quoted: 552 Post(s)
Liked: 354
https://www.trinnov.com/2019/04/29/t...tmos-trailers/
https://www.youtube.com/watch?time_c...&v=Dpi2_FqHMYY
Download Link
jstrossner likes this.
Trinnov Altitude 32, LCR JBL M2, JBL LSR 708i, 705i, Q-SYS Core 110f, Amps- QSC CXD4.2Q, 4.3Q, 4.5Q
Kaleidescape Strato, Zapitti 4K HDR Duo, Xbox One X, 8TB Tivo Roamio Pro,
JVC RS600 + ISCO IIIL, 158" 2.40:1 AT screen, Calman 5 Enthusiast, i1 Pro 2, i1 Display Pro, Spyder 5, 3D LUT Box
Oppo UDP-203, BDP-105, Onkyo DAC-1000s, Onkyo DP-X1 DAP, QNAP TVS-871
kingwiggi is offline
post #7162 of 8159 Old 05-07-2019, 09:22 AM
dancjodanc's Avatar
Quoted: 288 Post(s)
I have noticed that the Altitude makes a fair amount of noise, 'clicking' sound...when the sound input is being changed...or the surround format. Is that normal? And, is anyone else using a 3rd party controller to control their Trinnov? I have all the feed backs working....but was wondering if their is a 'stereo' label...or if you can get the video output format? It is displayed in the Trinnov app....but was wondering if you could get that info on the 3rd party controller as well?
dancjodanc is offline
post #7163 of 8159 Old 05-07-2019, 09:26 AM
Quoted: 174 Post(s)
Liked: 67
I get this sound when changing source of first play before the pic appear I am using crestron I used to it and I think it’s normal my amp are QSC DCA
post #7164 of 8159 Old 05-07-2019, 09:30 AM
Quoted: 833 Post(s)
Liked: 667
Is it from the speakers, or the Altitude? If it's coming from the Altitude, it's probably just muting relays.
Lyngdorf MP-50 | Yamaha MX-A5200 | Ascend Sierra Towers | Ascend Sierra Horizon | Ascend Sierra Lunas | Ascend HTM-200SE | SVS SB-13 x4
duckymomo is offline
post #7165 of 8159 Old 05-07-2019, 09:37 AM
Quoted: 174 Post(s)
Liked: 67
It’s not from the speaker and I think it’s normal and properly as u describe ..mute relays or so
post #7166 of 8159 Old 05-07-2019, 09:37 AM
dancjodanc's Avatar
Quoted: 288 Post(s)
It's not from the speakers..no...it's from the Trinnov itself. Clicking....as it changes formats say from DD to Atmos. It's loud...but as long as it's normal.....fine
post #7167 of 8159 Old 05-07-2019, 09:39 AM
Quoted: 174 Post(s)
Liked: 67
Yes it in the beginning was annoying especially if I want to shot a video but now it’s normal to me
post #7168 of 8159 Old 05-07-2019, 09:59 AM
Liked: 679
I agree. At least we now the Trinnov SSP is working and not losing sync/audio, like my prior Theta Casablanca SSP did all too often!
A7mad78 likes this.
post #7169 of 8159 Old 05-10-2019, 05:43 AM
blazar's Avatar
Quoted: 1189 Post(s)
Liked: 876
not sure anyone cares, but I was able to finally get a whole house audio box (made by VSSL) which will be rolling out airplay2 on it for every zone. So far an excellent product with very good fidelity and parametric EQ built in.
I am still hoping that the altitude would be able to "listen" for airplay2/homekit commands natively but I'm not sure that will ever be done by development team. I am guessing not since the altitude does not really stay 'always on'. I'm not sure if it is possible to put Homekit into the altitude from a technical perspective since it really only has wake on lan.
Blazar!
blazar is offline
post #7170 of 8159 Old 05-10-2019, 04:19 PM
Berland's Avatar
Quoted: 325 Post(s)
Liked: 215
Yes, Trinnov can do this for you (did it with my device after doing a downgrade of software at one point; restored profile backed up on previous version (target of downgrade) post downgrade.
HT: Trinnov Altitude32 (AL32-1632)/Amplitude8/8M - BRYSTON 4B SST2 - B&W 803D2, 2*DB1, HTM2D2, 804D2, SCMS, Nautilus SCM1, 805D2 - NORDOST Heimdall2/Frey2 - ISOTEK EVO3 Titan,Sigmas - LG OLED65B7V - GIK ACOUSTICS
HP: 2*MOON 430HA D, 2*MiND2 Network Player - 2*Yggdrasil - 2*Hydra Z/ZPM - ISOTEK EVO3 Sigmas, Aquarius - NORDOST Heimdall 2 - AUDEZE LCD-4 rev2, 2*LCD-XC - SHURE SE846
Berland is online now
