Trinnov Altitude - Page 263 - AVS Forum | Home Theater Discussions And Reviews
 3127Likes
post #7861 of 8493 Old 07-09-2019, 05:54 AM
Berland's Avatar
Quoted: 368 Post(s)
Liked: 237
Originally Posted by audioguy View Post
I must be doing something wrong. I am using Qobuz within Roon and can find nothing that remotely looks like your attachment.
If I log on directly to Qobuz, I get a different interface (nothing like you posted) but there I can find access to the Qobuz Store.
You need to use the Qobuz app directly (not Roon). If you search up an album you have the option to buy it (ref previous attachment).
HT: Trinnov Altitude32 (AL32-1632)/Amplitude8/8M - BRYSTON 4B SST2 - B&W 802D3, 803D2, 2*DB1, HTM2D2, 804D2, SCMS, Nautilus SCM1, 805D2 - NORDOST Heimdall2/Frey2 - ISOTEK EVO3 Titan,Sigmas - LG OLED65B7V - GIK ACOUSTICS
HP: 2*MOON 430HA D, 2*MiND2 Network Player - 2*Yggdrasil - 2*Hydra Z/ZPM - ISOTEK EVO3 Sigmas, Aquarius - NORDOST Heimdall 2 - AUDEZE LCD-4 rev2, 2*LCD-XC - SHURE SE846
Berland is online now
post #7862 of 8493 Old 07-09-2019, 06:26 AM
Wookii's Avatar
Quoted: 2893 Post(s)
Liked: 2095
Originally Posted by pennynike1 View Post
I take it no one is using 5 mains or rear wides?
By '5 mains' do you mean L, Lc, C, Rc, R? If so, yes, I'm using those. How much Lc and Rc actually contribute though, I can't tell you, I imagine I could probably do without them.
Wookii is offline
post #7863 of 8493 Old 07-09-2019, 06:30 AM
Berland's Avatar
Quoted: 368 Post(s)
Liked: 237
Originally Posted by santodx5 View Post
Wow 400TB!! I only have 50TB at the moment, mostly REMUX and BDVM movies.
Have you tested Vero 4K vs Oppo 205? I have modified Oppo 205 but want to see if something is better out there.
Vero 4K+ (the latest one) works very well. I don't have Oppo 205, but I have the Oppo 203. The Vero 4K+ is much more user-friendly. Video quality is on the same level (I know work is being done to further improve the Vero 4K+ regarding video quality especially for content with lower bitrate). Currently I would say the Oppo 203 is slightly better on low bitrate content. And the Vero 4K+ does not support dolby vision, but it supports HDR10 and with the LG OLED dynamic contrast enabled (lowest level) the TV actually adjust the gamma curve according to content on the fly. So difference is minimal compared to Dolby Vision.
post #7864 of 8493 Old 07-09-2019, 07:22 AM
santodx5's Avatar
Quoted: 162 Post(s)
Thank you. Modified Oppo 205 is significantly much better than original in picture and SQ, so I think I have one of the best player in the market at the moment. Dolby vision is a must for me as many latest blockbuster movies have it and it is superior than HDR10
I calibrated my OLED with HDR10 + DV pattern with Calman.
santodx5 is offline
post #7865 of 8493 Old 07-09-2019, 07:51 AM
pennynike1's Avatar
Quoted: 624 Post(s)
Liked: 585
Yes, that is exactly what I meant. I am debating on doing the Left center and Right center with 2 SCL-2 (to compliment my M2 LCR) vs doing 3 sets of rear surrounds.
I suppose I can experiment with both, but I was hoping to find someone who already has already done some comparisons on their own. Doing LC and RC requires relocating 2 subs to the rear of the theater.
For sale: 4 Mackie c300z speakers, Tag Mclaren av32r preamplifier
pennynike1 is offline
post #7866 of 8493 Old 07-09-2019, 05:20 PM
madhuski's Avatar
Quoted: 1305 Post(s)
Liked: 845
Originally Posted by Ringnut View Post
Is there any consensus as to what the best mic holder is for the 3D Trinnov mic?
this is what I used:
https://www.amazon.com/gp/aw/d/B014C...b_b_asin_title
Ringnut likes this.
Selling in AVS Classifieds
Revel Studio2 Pair - gloss black
madhuski is online now
post #7867 of 8493 Old 07-09-2019, 05:36 PM
Berland's Avatar
Quoted: 368 Post(s)
Liked: 237
Originally Posted by madhuski View Post
I'm using the same; got one from Trinnov as well - but the one you linked to is better.
post #7868 of 8493 Old 07-09-2019, 05:38 PM
Berland's Avatar
Quoted: 368 Post(s)
Liked: 237
Soon time to get my much talked about 9 ceiling speakers mounted... But I'm not 100% in agreement with myself here
L and R are currently at 30 degrees.
So my plan:
Lfh/Rfh 30
Ltf/Rtf 50
Ltm/Rtm 80
Ltr/Rtr 120
Ch 0
Any views here ?
Existing speakers:
L/R 30
Lw/Rw 45 (I would like these to be 55-60, but not doable - well, it is doable, but it will be complicated entering the room)
Ls/Rs 90
Lrs/Rrs 135
C 0
post #7869 of 8493 Old 07-09-2019, 07:17 PM
audioguy's Avatar
Quoted: 4704 Post(s)
Liked: 3498
What do you like better about it. And it is hard to tell from the image but how does the mic stay in place?
audioguy is online now
post #7870 of 8493 Old 07-09-2019, 07:58 PM
Berland's Avatar
Quoted: 368 Post(s)
Liked: 237
It is more solid/higher quality. There is a mechanical spring that holds the microphone in place; if you look at the picture you can see it - squeeze to open; release to hold in place. Pure magic
Edit:
Keep in mind, most likely you don't need it at all - a microphone stand alone located on the seat of the MLP indicate you don't need this thing.
I use this one with microphone directly attached. You can set it directly on the seat (with all possibilities to adjust microphone to be aligned on all 3 axis).
https://www.amazon.com/25960-500-55-...gateway&sr=8-1
Ringnut likes this.
post #7871 of 8493 Old 07-09-2019, 11:32 PM
Ringnut's Avatar
Quoted: 23 Post(s)
Liked: 35
Thanks, that's really helpful.
Ringnut is offline
post #7872 of 8493 Old 07-10-2019, 05:47 AM
Quoted: 14 Post(s)
Hi,
A quick question regarding 7.x.6 vs 9.x.4?
About to get my Alt16 in the next week and wondering which way to go first. I have been trying to read lots of posts re: movies with Atmos tracks - is it correct in assuming that most movies will output Atmos to whichever speakers in your setup other than Disney movies which seem to be encoded as 7.1.4 only?
Back to the first question, I'm currently running 7.4.4 and planning to either go 9.3(one paired sub).4 or 7.3(4).6 with the most practical choice of going the option of front wides as this is much easier to setup rather than installing another pair of ceiling speakers, which I would do if this was the better way to go.
I know a bit long winded but...
jon1199 is offline
post #7873 of 8493 Old 07-10-2019, 06:05 AM
Rise & Grind
dinamigym's Avatar
Quoted: 315 Post(s)
Liked: 297
Originally Posted by jon1199 View Post
Hi,
I’ve had my A16 for a little over a month now coming from a 8805 and then SP4. I come to appreciate the A16 more and more as I become increasingly familiar with it. I have tried both configs and settled on a 7.2.6. I’m looking at moving to a 9.2.6 (I combine my subs on one output with minidsp). I found the 7.2.6 far more immersive in my room.
jon1199 likes this.
Trinnov Altitude 16, Magico A3, Magico ACC, Magico A1s, Dual Rythmik FV25HP
Amps- ATI AT523NC, AT524NC, AT528NC
Kaleidescape Terra Server/Strato, Oppo UDP-203, Apple TV4k, XFinity X1
Sony VPL-VW5000, 136" 2.35:1 Stewart Studiotek 100 screen, Lumagen Pro 4242
dinamigym is online now
post #7874 of 8493 Old 07-10-2019, 06:16 AM
Quoted: 14 Post(s)
dinamigym likes this.
jon1199 is offline
post #7875 of 8493 Old 07-10-2019, 06:24 AM
audioguy's Avatar
Liked: 3498
I have 9.x.6 but the center heights seem to get more use than the wides. So I would recommend 7.x.6.
jon1199 and dinamigym like this.
post #7876 of 8493 Old 07-10-2019, 06:43 AM
Quoted: 14 Post(s)
I did come across an earlier post from you stating that 7.x.6 is the better option and haven't come across anyone else saying go front wides. Just that I've been suggested by the distributor for Trinnov to go front wides to fill in the space between the front speakers and the surrounds - but my understanding is that the Atmos tracks are often encoded with a 'limit' to how many surrounds are used - would that be correct? And most movies have not been encoded to use front wides?
Thanks for the info!
jon1199 is offline
post #7877 of 8493 Old 07-10-2019, 07:05 AM
santodx5's Avatar
Quoted: 162 Post(s)
How to find out if each movies I am playing will have 9.x.6? How to check? Trinnov output indicator only?
santodx5 is offline
post #7878 of 8493 Old 07-10-2019, 07:36 AM
audioguy's Avatar
Liked: 3498
post #7879 of 8493 Old 07-10-2019, 08:23 AM
sdrucker's Avatar
Quoted: 1631 Post(s)
Liked: 1282
More like many mixers don’t make good use of them. And Disney keeps most to all of their content to 7.1.4 as some sort of corporate philosophy. But it’s not a hard and fast rule across the board.
A bit old, but you can start with this thread:
https://www.avsforum.com/forum/86-ul...ng-thread.html
I'd also add Gravity, A House with a Clock on Its Walls, Red Sparrow, and Spiderman: Homecoming among this list.
farsider3000 and jon1199 like this.
Audio Gear: Trinnov Altitude 32 (24 channel), NAD M27 amps (3)
Video: JVC RS600, Seymour 100" UF Screen, Lumagen Radiance Pro 4444 (coming soon)
Speakers: PSB Imagine T3 LCR, Imagine T Wides/Side Surround 1, T2 Side Surrounds, Imagine XB rears, Image B6 screens, PSB CS1000 ceilings (6), HSU ULS-15 Mk 2 subs (4) - 13.4.6
HAA HT1 and HT2 Certification
sdrucker is online now
post #7880 of 8493 Old 07-10-2019, 08:55 AM
Wookii's Avatar
Liked: 2095
Quick question to the group (I'm asking blind here as I'm at work, and not in front of my unit):
1. When the Altitude has Roon selected as the input, will it output the signal digitally over AES/EBU XLR?
2. If I wanted to have two 'Roon' modes, one with the 12v output triggers enabled, and a second with the 12v output triggers disabled, how would I set that up (or work around to achieve it)?
Wookii is offline
post #7881 of 8493 Old 07-10-2019, 09:20 AM
farsider3000's Avatar
Quoted: 1410 Post(s)
Liked: 795
Trinnov Altitude
I have a 7.4.6 system (not Trinnov) and I have recently tied my front and middle row of Atmos speakers together (just splitting off the front row signal from my processor) as I am testing to see if the middle row is really making a difference. So far I don’t feel that I am missing anything. My theater is approximately 24ft long with two rows of seating. My ceiling is 9.5ft high.
Whether you can hear a difference between four and six ceiling speakers will depend on if the mix is true Atmos or fixed to four speakers, how high your ceilings are, how much space is between each row of speakers and your room acoustics... and the processing done my the Trinnov.
My next test will be to just listen to the middle row of speakers in some Atmos “active” movies and see how much sound actually comes through the middle row.
Sent from my iPhone using Tapatalk Pro
jon1199 likes this.
7.4.6 system: Processors:Marantz 8805 || Xilica XP4080 Amps: Parasound A31 and ATI AT528NC & AT526NC n-core ||Speakers: Procella P8 LCR, Procella P5 for surround & ceiling
Subs: JTR Captivator S2, JTR Captivator S1, 2 Seaton Submersive (dual 15")
Screen: 2.40:1 Seymour XD Acoustically Transparent, 128" diagonal / 118" wide || Projector: JVC X570/RS420
farsider3000 is online now
post #7882 of 8493 Old 07-10-2019, 09:27 AM
audioguy's Avatar
Liked: 3498
A couple other options: You can look at the Datasat meters or you can mute the front and rear ceiling speakers. Use (if you have it) the Atmos Demo disc to see how it helps (or doesn't) in your room.
My ceiling is only 8 feet and the front and rear ceiling speakers are about 9 feet apart. And even thought the tweeter is aimed directly at the MLP, having the center ceiling speakers helps in those situations where the mix wasn't fixed to 7.x.4.
sdrucker, jon1199 and dinamigym like this.
post #7883 of 8493 Old 07-10-2019, 10:46 AM
Quoted: 27 Post(s)
Liked: 1
Hello all,
I am recreating my Marantz based, 7.2.4 home theater from scratch, by focusing on the stereo listening performance first, and to that extend I pulled the trigger for a set of Tannoy Westminsters and a Luxman M900u amplifier. That put me in a totally new territory and I am looking for the upgrade path over the next years, for critical listening first and then slowly rebuilding my home theater. I have been lurking every now and then in this thread, which is now a sizeable one, so excuse me if my following questions have been answered already:
1. From a standard "audiophile" point of view, a Pre-amp and/or a DAC would be the next component to invest in. High-end pre-amps, like the Luxman C900u are comparable to and can even surpass a Trinnov Altitude 16 in price. If the Room Correction and 3D remapping aspect of Trinnov come into play, does this make the Altitude the winner against any pre-amp from any price for music listening? Is there any reason why one would prefer a standard Pre-amp instead? Has somebody compared Trinnov + Room Correction versus top end preamps + DACs?
2. Is it recommended to correct the main speakers only till a certain frequency e.g. 500 Hz or it is preferred to have the Room Correction and a home curve for the full frequency spectrum for music?
3. What would happen if an immersive codec like Atmos/DTS-X is folded only to a stereo pair in absence of other speakers? Will the Trinnov speaker remapping capability try to emulate the missing speakers by using wall reflections, essentially emulating a soundbar? Would that affect what room treatment is employed?
Many thanks
AVR: Marantz SR7011 (11.2 Atmos/DTS-X/Auro3D), Amps: Parasound HCA-2205a, Rotel rkb-8100, Front L/R: Tannoy DC10Ti, Center: Tannoy D750, Surrounds: Kef 3001, B&W 601S3
Heights: Focal Domes, B&W M1, Subwoofers: Tannoy TS2.10, Genelec HTS4
ioanni is online now
post #7884 of 8493 Old 07-10-2019, 11:23 AM
byron69's Avatar
Quoted: 18 Post(s)
I’m interested in you opinion comparing A16 and 8805.
Envoyé de mon iPhone en utilisant Tapatalk
byron69 is offline
post #7885 of 8493 Old 07-10-2019, 11:28 AM
Berland's Avatar
Quoted: 368 Post(s)
Liked: 237
I'm much more interested in why he went from SP4 to A16
One I know of actually dropped buying the A16 and went for a SP4 instead; big mistake in my opinion. So it is interesting to see someone going the other direction.
Edit:
I went from Marantz AV8802a to Trinnov Altitude32, they are not in the same universe even. Completely different league.
post #7886 of 8493 Old 07-10-2019, 11:45 AM
audioguy's Avatar
Liked: 3498
Forgetting the hardware improvements channels supported, upgradability, etc, Audyssey vs Room Optimizer are not even close to the same league. I did a blind comparison a long time ago except it didn't need to be blind. With Optimizer (or even Dirac) the bass was better integrated; the bass was cleaner; the room was FAR more enveloping; the clarity of the vocals was far better; sound didn't come from any speakers but was placed in the exact location where it was intended. I could go on.
I still am absolutely dumb founded that Audyssey, which once OWNED the room correction market, fell in the toilet. Audyssey is WAY better than no correction - usually- (or the home grown "product" on Onkyo products) but truly has been left in the dust with both Dirac and now Optimizer.
As I have heard on TV "Fuh get about it" !!
But I must add, one cost $17.000 and the other cost about $5000!! In this case, you actually do get what you paid for!
ss9001, sdrucker and llang269 like this.
post #7887 of 8493 Old 07-10-2019, 12:31 PM
pennynike1's Avatar
Quoted: 624 Post(s)
Liked: 585
Edit:
Hi there. I went from a Marantz 8802a, to the 8805, and then an Emotiva RMC-1.
The Trinnov beckoned me due to the versatility and 32 channel count, and the fact that the RMC-1 was quite buggy. The RMC-1 seemed to handle bass extremely well IMHO though, and sounded quite clean when not committing errors. The Emotiva could have been a keeper had it not been for other engineering issues and the 9.1.6 limitation.
I must say though, that the RMC-1 seemed quite promising, without even yet having the benefit of Dirac room correction.
I am curious, what specifically, other than channel count, the optimizer and versatility, do you consider the Trinnov provides that is in a different universe?
post #7888 of 8493 Old 07-10-2019, 12:55 PM
byron69's Avatar
Quoted: 18 Post(s)
You said everything. Thanks for your experience.
byron69 is offline
post #7889 of 8493 Old 07-10-2019, 01:04 PM
Rise & Grind
dinamigym's Avatar
Quoted: 315 Post(s)
Liked: 297
For what its worth here is my take...
First, let me say I do not consider myself a brand loyalist to anyone. I've been at this hobby for 30 years now and, since we are talking processors, I'll stick to that. I've owned the following processors in that time:
Lexicon MC-1
Lexicon MC12B
Classe' CT-SSP
Marantz 8802A
Marantz 8805
Bryston SP4
Trinnov A16
I make every effort to balance need/want, value, & price. Right or wrong I measure everything off the 8805. Mainly because, although it won't dazzle anyone with its specs, it does everything and it does it well. I'm going to compare it to the RMC-1 for a second just to clarify. I was really interested in that piece but it doesn't matter what the specs are, how good the dacs are, how many channels it can implement, what codecs it has available, what room correction it will have available. None of that matters if it cant perform the most basic functions well. So when I measure a piece it has to do the basics well first and then the bells and whistles become the icing on the cake.
The biggest flaw to me with the 8805 was Audyssey. I could not, for the life of me, get it to sound good in my room. I even went so far as to use a Wisdom SC3 in the system just so I could run Dirac to all 15 channels. The Bryston SP4 had the stability of the 8805 and the extras including Dirac made it an excellent bang for the buck in my book. To some, that probably sounds crazy talking about an upper 4 figure piece but we are all in this game at the level we are so it is what it is. I truly struggled with the decision but the Trinnov has always been on my to do list. I've always placed an emphasis on video and spent a good amount of money on projectors from Runco, DPI, & now Sony. As I've gotten older, audio has taken on a new importance for me. At some level it may have over taken video. So I guess, if Im willing to spend that kind of dollars on video then why should audio have different expectations. I will fully admit there are many on here with far more acoustical knowledge than me. I also fully admit that much of the functionality of the Trinnov is probably not being fully utilized in my system yet. That being said, I can also say without a doubt, it provides me with the most acoustical enjoyment of any piece I've owned to date. So much so that I do contemplate moving to an A32 at some point. Not because I think I will be additionally wowed sonically by its more expansive counterpart but because I may want to increase my speaker count. I won't even try to argue that, on paper, the A32 has better sonic capabilities. Just simply, for me...I don't care. Mainly because I honestly don't think I'd hear a difference. If I do upgrade it will be for channel requirements alone.
Is the A16 worth 3x the 8805...probably not. Is it worth 2x? Based on other market options currently available absolutely in my book. It does everything the 8805 did and does it well. The optimizer is light years ahead of anything else. It has every configuration option imaginable and it is upgradable. Again, basing this purely in my room after experiencing Audyssey, Dirac and now Trinnov. So in my book it becomes a question of is the extra $4-$5k of luxury tax as I'll call it for the Trinnov A16 worth the added enjoyment? For me it has been.
Peace Out,
Paul
post #7890 of 8493 Old 07-10-2019, 01:56 PM
byron69's Avatar
Quoted: 18 Post(s)
Thank you for your detailed answear! It seems that the A16 ou A32 is my next upgrade.
byron69 is offline
