Trinnov Altitude - Page 288 - AVS Forum | Home Theater Discussions And Reviews
 3629Likes
post #8611 of 9371 Old 09-03-2019, 02:08 AM
Wookii's Avatar
Quoted: 3024 Post(s)
Liked: 2233
Originally Posted by appelz View Post
4.2.8.2 off the top of my head.
The public release of what you guys running RC versions have should be very soon.
I was told that the new FW is ready for release, but they're waiting until after the summer break (French manufacturers typically shut down for about 6 weeks over summer) - they'll probably launch it at Cedia, if we're lucky, with DTS:X Pro ready to go also, and we'll hopefully all get it in the days/weeks following that.
Wookii is offline
post #8612 of 9371 Old 09-03-2019, 02:25 AM
Marc Alexander's Avatar
Quoted: 5631 Post(s)
Liked: 5221
Dts:X Pro will not be in this next release (webinar Thursday). It will be the following (Q4).
Marc Alexander is offline
post #8613 of 9371 Old 09-03-2019, 05:34 AM
Quoted: 120 Post(s)
Liked: 51
Any idea what the major changes are in the new firmware update?
Tuning is offline
post #8614 of 9371 Old 09-03-2019, 06:02 AM
Wookii's Avatar
Liked: 2233
As far as I've been told there's quite a few things in it, but the main headline things are:
- Target curve + graphing down to 10Hz
- Separate resolution/smoothing options for IIR and FIR filters
- Saving and loading of target curves (per output channel or linked output channels)
- 12v Triggers programmable by source (Alt 16 only, sadly)
Tuning likes this.
Wookii is offline
post #8615 of 9371 Old 09-03-2019, 08:07 AM
Venger99's Avatar
Quoted: 120 Post(s)
I had a demo of the altitude 16 and Lyngdorf MP50 yesterday and the Trinnov blew the Lyngdorf away. I am now the proud owner of an altitude 16!
How do I control it via an iPad? Download VPN app? Do I also have to download the trinnov app on my Mac desktop?
Venger99 is offline
post #8616 of 9371 Old 09-03-2019, 08:16 AM
audioguy's Avatar
Quoted: 5121 Post(s)
Liked: 3978
On my Mac I use "Chicken of the VNC". On my iPad, I use "Mocha VNC". I have not been inclined to try to use the Trinnov app. And congratulations. You now own the best processor brand on the planet!!
audioguy is online now
post #8617 of 9371 Old 09-03-2019, 08:37 AM
RUR
Innocent Bystander
RUR's Avatar
Quoted: 664 Post(s)
Liked: 612
Yes, download the app onto your iPad. I've used both Real VNC and Mocha VNC with no problems.
Only if you plan to control the Altitude using the desktop.
Congrats on the purchase!
RUR is offline
post #8618 of 9371 Old 09-03-2019, 09:12 AM
Venger99's Avatar
Quoted: 120 Post(s)
Thanks 😀
Look forward to hours of tweaking 😂
Venger99 is offline
post #8619 of 9371 Old 09-03-2019, 09:20 AM
ss9001's Avatar
Quoted: 678 Post(s)
Liked: 681
Congratulations! You made a great choice. And I also use the free version of RealVNC on an ipad. Works great. There are also free wake-on-lan apps you can download if you want to turn it on remotely. It does respond to WOL. I don't use that often but it's handy on occasion if nothing else to do some tweaking to your configuration on a PC that's not in the same room.
Steve
ss9001 is online now
post #8620 of 9371 Old 09-03-2019, 09:35 AM
Ringnut's Avatar
Quoted: 24 Post(s)
Liked: 40
Cogratulations on your decision, care to elaborate on your findings and also where those demos took place?
Edit: Forget that, I think I've found your excellent and very detailed report.
Ringnut is offline
post #8621 of 9371 Old 09-03-2019, 10:51 AM
rola's Avatar
Quoted: 51 Post(s)
Liked: 32
Info about the new firmwareupgrade: https://www.trinnov.com/?p=15022
Tuning and kingwiggi like this.
rola is online now
post #8622 of 9371 Old 09-03-2019, 11:45 AM
kingwiggi's Avatar
Quoted: 571 Post(s)
Liked: 365
4.2.11 - Update Queued & Completed in < 10 minutes
Name:	Screen Shot 2019-09-03 at 1.42.06 PM.png
ID:	2610658   Click image for larger version
Name:	Screen Shot 2019-09-03 at 1.52.54 PM.png
ID:	2610662   Click image for larger version
Name:	Screen Shot 2019-09-03 at 2.07.19 PM.png
ID:	2610666   Click image for larger version
Name:	Screen Shot 2019-09-03 at 2.07.49 PM.png
ID:	2610668   Click image for larger version
Name:	Screen Shot 2019-09-03 at 2.07.59 PM.png
Name:	Screen Shot 2019-09-03 at 1.51.09 PM.png
Trinnov Altitude 32, LCR JBL M2, JBL LSR 708i, 705i, Q-SYS Core 110f, Amps- QSC CXD4.2Q, 4.3Q, 4.5Q
Kaleidescape Strato, Zapitti 4K HDR Duo, Xbox One X, 8TB Tivo Roamio Pro,
JVC RS600 + ISCO IIIL, 158" 2.40:1 AT screen, Calman 5 Enthusiast, i1 Pro 2, i1 Display Pro, Spyder 5, 3D LUT Box
Oppo UDP-203, BDP-105, Onkyo DAC-1000s, Onkyo DP-X1 DAP, QNAP TVS-871
kingwiggi is offline
post #8623 of 9371 Old 09-03-2019, 12:38 PM
Stereojeff's Avatar
Quoted: 233 Post(s)
Liked: 133
Altitude 16 IR Turn-on/Turn-off codes
In a different AVS thread, Lexicon64 posted details about the Altitude 16 I was not aware of. He wrote:
Actually discovered there is a discrete power off. You hold the info button for 5 seconds. (We should really have guessed that one shouldn’t we?!) I have managed to load both commands in to the Harmony using the Trinnov remote and get it all to work.
For Altitude 16 IR power on, simply press the OK button.
Jeff
ss9001 likes this.
Stereojeff is offline
post #8624 of 9371 Old 09-03-2019, 12:38 PM
Rise & Grind
dinamigym's Avatar
Quoted: 327 Post(s)
Liked: 296
My A16 shows update available. How do I get the update to go forward? TY
Trinnov Altitude 16, Magico A3, Magico ACC, Magico A1s, Dual Rythmik FV25HP
Amps- ATI AT523NC, AT524NC, AT528NC
Kaleidescape Terra Server/Strato, Oppo UDP-203, Apple TV4k, XFinity X1
Sony VPL-VW5000, 136" 2.35:1 Stewart Studiotek 100 screen, Lumagen Pro 4242
dinamigym is online now
post #8625 of 9371 Old 09-03-2019, 12:56 PM
rola's Avatar
Quoted: 51 Post(s)
Liked: 32
”Although an option is available to start the update from the user interface, that option is locked by default, in which case, you have to contact your local reseller or distributor to perform the update and/or ask to remove that limitation from your unit. In both cases, please ensure your unit is connected to internet prior to making that request.”
dinamigym likes this.
rola is online now
post #8626 of 9371 Old 09-03-2019, 01:00 PM
dancjodanc's Avatar
Quoted: 291 Post(s)
I see the new software update is out...but not sure what I need to do. I read something about port 22? But not sure how to get to these menu's, or what to do? Help
dancjodanc is offline
post #8627 of 9371 Old 09-03-2019, 01:00 PM
Rise & Grind
dinamigym's Avatar
Quoted: 327 Post(s)
Liked: 296
Thank you. Jon is going to get me going.
post #8628 of 9371 Old 09-03-2019, 01:03 PM
ss9001's Avatar
Quoted: 678 Post(s)
Liked: 681
Then this is the official non-RC version? I've been running the last RC version, rc9, that had several quirks that I trust are resolved.
I'll be attending Thurs webinar so will wait until afterwards.
Steve
post #8629 of 9371 Old 09-03-2019, 01:32 PM
ss9001's Avatar
Quoted: 678 Post(s)
Liked: 681
I'm sure several of us will be contacting him
Steve
post #8630 of 9371 Old 09-03-2019, 02:36 PM
Paladin80N's Avatar
I sent an e-mail to my dealer, Craig at TheaterMax and within 10 minutes the download restriction was removed. I requested and got the update 5 minutes later. Awesome service!
ss9001 likes this.
Paladin80N is offline
post #8631 of 9371 Old 09-03-2019, 03:20 PM
Kain's Avatar
Quoted: 2016 Post(s)
Liked: 916
@appelz
Which of the following two setups do you think is better?
1. 9.1.6 setup with an Altitude16 (leaves one free output on the Altitude16 for the subwoofer) + DSP for multiple subwoofers such as the QSC Core 110f. Speakers managed by the Altitude16 and subwoofers managed by the QSC Core 110f.
2. 9.1.6 setup with an Altitude32 16-24. All speakers and subwoofers managed by the Altitude32.
Basically, what I am trying to get at is, is it better to have a DSP to manage/correct the subwoofers over just relying on the Altitude? Do you gain any added "functionality" or "control" (in terms of fine tuning or adjustments) when adding a nice DSP for the subwoofers?
Lastly, what is your preferred DSP? In a previous post in this thread (maybe a year ago), you stated that the QSC Core 110f was your go-to DSP. Is that still true?
Kain is offline
post #8632 of 9371 Old 09-03-2019, 03:31 PM
ShaharT's Avatar
Quoted: 41 Post(s)
Hi, awesome forum. I've spent many hours reading through it.
Got me so impressed, I'm as of today a proud new owner of an Altitude 32 16-24. Very excited about this!
It's to be connected to a 7.2.14 speaker setup.
One thing that's not clear to me despite all my reading, is how do the different speakers get mapped in the various formats.
For example, do my right-front-height, left-front-heigh, right-top-middle, left-top-middle (etc) - get mapped only into Atmos and Dolby, and are left as None for Auro3d, Dts:x and DTS? Seems a waste to have all these speakers and amps, and that at any point in time only a small subset is being used based on the specific surround format used.
Or is that going to be the case, until DTS:X Pro is available, at which time I'll use this format to drive all speakers?
Asking after looking on the layout screen through vnc, after all my speakers are positioned.
I'm sure it's a complete newbie question and my trusted and amazing installer will have the answers, but trying to figure it myself as well.
ShaharT is offline
post #8633 of 9371 Old 09-03-2019, 04:13 PM
ss9001's Avatar
Quoted: 678 Post(s)
Liked: 681
Unlocked, updated & done. And 1 RC issue I had seen seems to be resolved, hurray! Support from Trinnov is great. Wish I could be going to CEDIA, if nothing else to meet Jon & hear the DTS-X Pro demo. But alas, not going.
Steve
post #8634 of 9371 Old 09-03-2019, 04:27 PM
Berland's Avatar
Quoted: 456 Post(s)
Liked: 273
DTS:X Pro got nothing to do with firmware; it can come at any time.
Edit:
I'm fairly sure the firmware will come first, but they are not connected. DTS:X Pro is a codec update (which can be pushed independent of the firmware).
HT: Trinnov A32 (AL32-1632)/AMP8/8M - BRYSTON 4B SST2 - B&W 802D3, 803D2, 2*DB1, HTM2D2, 804D2, SCMS, Nautilus SCM1, 805D2 - NORDOST Heimdall2/Frey2 - ISOTEK EVO3 Titan,Sigmas - LG OLED65B7V - GIK ACOUSTICS
HP: 2*MOON 430HA D, 2*MiND2 - 2*Yggdrasil - 2*Hydra Z/ZPM - ISOTEK EVO3 Sigmas, Aquarius - NORDOST Heimdall 2 - AUDEZE LCD-4 rev2, 2*LCD-XC - SHURE SE846 - Bose NC 700
Berland is offline
post #8635 of 9371 Old 09-03-2019, 04:58 PM
Berland's Avatar
Quoted: 456 Post(s)
Liked: 273
Update done here as well.
Soon 1AM Central European Time. The Trinnov people still at work; impressed
Name:	Skjermbilde 2019-09-04 kl. 00.58.07.png
Berland is offline
post #8636 of 9371 Old 09-03-2019, 05:06 PM
Berland's Avatar
Quoted: 456 Post(s)
Liked: 273
Release notes for 4.2.11
https://drive.google.com/file/d/1d06...nQK6O2pQO/view
There are also some undocumented improvements - let's see who finds them
Berland is offline
post #8637 of 9371 Old 09-03-2019, 06:52 PM
Liked: 5221
Like a thief in the night?
Thanks, for the clarification. I stand corrected.
I do believe that the HDMI hardware has firmware, but doesn't the Altitude itself utilize software for both the management interface and codecs?
post #8638 of 9371 Old 09-04-2019, 12:35 AM
Berland's Avatar
Quoted: 456 Post(s)
Liked: 273
HDMI board got its own firmware actually (I have upgraded this several times).
But codecs does not have anything to do with HDMI board. DTS:X Pro only affects rendering of the DTS:X; so it uses all channels for objects and some clever upmix support for beds in addition to remove the 11+sub restriction. What comes from the source is DTS:X; you will never find a blu-ray with DTS:X Pro.
Berland is offline
post #8639 of 9371 Old 09-04-2019, 12:46 AM
Dan Hitchman's Avatar
Quoted: 4734 Post(s)
Liked: 2774
Here's the problem... even if DTS: X Pro is a better, improved codec and a little bit more like Atmos, there are only 20 titles, from one foreign based studio (which has now switched to Atmos), that actually have 5 positionable objects included that we know of. ID4's 4k disc track only has one additional non static object and then that's all she wrote.
The rest of the home DTS: X titles have to use upmixing to have sound come out of any speaker beyond the 7.1.4 fixed track limitation.
Might as well have called this Neural: X Pro.
appelz likes this.
Listen up, studios! Dolby Atmos Lite™ print-outs must stop!!
Dan Hitchman is offline
post #8640 of 9371 Old 09-04-2019, 02:20 AM
Venger99's Avatar
Quoted: 120 Post(s)
Sorry to ask about a basic question. I downloaded mocha VNC lite to try and control the trinnov from my iPad. I entered the MAC address for the trinnov and also tried putting in the IP address. When I clicked connect it kept saying password incorrect. Where do I find the password for the trinnov?
Is there a guide somewhere as to how to set this up?
Venger99 is offline
