JBL Synthesis SDP-75 - Page 21 - AVS Forum | Home Theater Discussions And Reviews
 207Likes
post #601 of 623 Old 01-31-2020, 06:48 AM
ROCKNMUD's Avatar
Liked: 0
Is there a setting to delay the output of the trigger to the amps?
ROCKNMUD is offline
post #602 of 623 Old 02-01-2020, 01:36 PM
ccool96's Avatar
Quoted: 830 Post(s)
Liked: 1168
So glad to see, in addition to the DTS X Pro update, the SDP75 now has the full Altitude PEQ. That’s in addition to the pre-loaded anechoic files for all the JBL speakers.
Sent from my iPhone using Tapatalk Pro
appelz, SOWK, DonH50 and 1 others like this.
ccool96 is online now
post #603 of 623 Old 02-05-2020, 03:03 PM
Lioarlan's Avatar
Quoted: 27 Post(s)
Liked: 9
I had my unit updated last night - and this PEQ functionality is not there Just the previous AEQ. I wonder what made your update special?
Bummer, I would like to get that Minidsp out of my multi sub layout.
Lioarlan is offline
post #604 of 623 Old 02-05-2020, 03:07 PM
ccool96's Avatar
Quoted: 830 Post(s)
Liked: 1168
What version are you on?
It isn’t just my SDP75 that now has PEQ.
Of the 5-6 SDP75 units I know of, they all have PEQ after the latest 4.2.15 DTS:X Pro update.
post #605 of 623 Old 02-05-2020, 03:14 PM
Lioarlan's Avatar
Quoted: 27 Post(s)
Liked: 9
Mine shows 4.2.15. It's a 24 ch unit. This is a mystery ...
Lioarlan is offline
post #606 of 623 Old 02-05-2020, 03:19 PM
ccool96's Avatar
Quoted: 830 Post(s)
Liked: 1168
Can you send a picture of what you see when you click on the “AEQ” button.
post #607 of 623 Old 02-05-2020, 03:23 PM
Lioarlan's Avatar
Quoted: 27 Post(s)
Liked: 9
Will send when I get home from work. It shows the usual drop down of choices for my speakers (Salon2, Voice2, LSR 705i).
Lioarlan is offline
post #608 of 623 Old 02-05-2020, 03:56 PM
appelz's Avatar
Quoted: 739 Post(s)
Liked: 793
Strangely enough, Chris and I just talked about something completely different, but chatted about this as well.
My first guess was a mistake in the rush to get units updated, and the wrong firmware was applied, which exposed the AEQ filters on the SDP-75's. If anyone isn't aware, AEQ and PEQ are really the same thing. AEQ is just a group of PEQ filters that are derived from JBL's spinorama measurements, loaded into the SDP-75 and then hidden, and additional PEQ filters locked.
Second guess is that since everyone including JBL realizes that having access to PEQ is critical, they finally decided to not treat those filters as proprietary and the SDP-75's now behave exactly like Altitudes regarding PEQ's. Filter sets can be saved, loaded, recalled, additional PEQ filters added, etc.
If some units have PEQ exposed and some are still locked to AEQ, I'd wager it was a mistake.
If any of the DSP-75's that show PEQ also have remapping available, then definitely a mistake.
Rex Anderson likes this.
Adam Pelz ,Acoustic Mafia - Hear No Evil
JBL Master ARCOS Calibrator, CEDIA Designer, Home Acoustics Alliance Instructor LIII, THX HT1+ HT2+ Video, Level III Trinnov Altitude Calibrator
Mercenary Calibrator for Manufacturers, Integrators and System Owners
appelz is offline
post #609 of 623 Old 02-05-2020, 04:04 PM
ccool96's Avatar
Quoted: 830 Post(s)
Liked: 1168
So my SDP75 doesn’t have “Remapping” feature, but does have PEQ.
So sounds like your second guess is correct, in that JBL knew they needed PEQ, even if it did expose their Speaker Tuning filters.
post #610 of 623 Old 02-05-2020, 07:01 PM
Lioarlan's Avatar
Quoted: 27 Post(s)
Liked: 9
So I just rechecked, my firmware is listed as 4.2.15.1
My guess is, that .1 is a fix for the "mistake". Too bad ...
Lioarlan is offline
post #611 of 623 Old 02-05-2020, 07:10 PM
thebland's Avatar
Quoted: 2437 Post(s)
Liked: 1628
Really? WHen did you download the new version??
Goodbye to a great audio and video genius and writer... JOHN GANNON. I enjoyed your friendship, wit and a nice long run we took around Indianapolis at CEDIA years back... and for buying my Runco 980 Ultra years back... you saved my ass! Rest in peace.
thebland is online now
post #612 of 623 Old 02-05-2020, 07:11 PM
Lioarlan's Avatar
Quoted: 27 Post(s)
Liked: 9
It was downloaded last night.
Lioarlan is offline
post #613 of 623 Old 02-05-2020, 07:13 PM
thebland's Avatar
Liked: 1628
Wow... Didn't take long. I wonder why it's such an issue to keep secret?
post #614 of 623 Old 02-05-2020, 07:18 PM
ccool96's Avatar
Quoted: 830 Post(s)
Liked: 1168
That’s the same version I am on with the full PEQ.
JBL indicated to me that the PEQ was added on purpose and had been in the works for a while.
If they had accidentally loaded the standard Altitude firmware, my SDP75 would have speaker remapping, which it doesn’t.
post #615 of 623 Old 02-05-2020, 07:26 PM
Lioarlan's Avatar
Quoted: 27 Post(s)
Liked: 9
If they had accidentally loaded the standard Altitude firmware, my SDP75 would have 3D remapping, which it doesn’t.
Huh! Time for me to get JBL support involved in my case.
Screenshot of my AEQ dropdown attached ...
Lioarlan is offline
post #616 of 623 Old 02-05-2020, 07:26 PM
appelz's Avatar
Quoted: 739 Post(s)
Liked: 793
Great news then. I still prefer having an external DSP when I can, but sometimes there are constraints and at least this gives me options.
appelz is offline
post #617 of 623 Old 02-05-2020, 07:28 PM
thebland's Avatar
Liked: 1628
I just noticed the .1 patch too and my PEQ is gone!
post #618 of 623 Old 02-05-2020, 07:35 PM
ccool96's Avatar
Quoted: 830 Post(s)
Liked: 1168
So everyone disregard my post.
I just looked back at the speaker layout screen and the PEQ is gone. It’s back to AEQ.
I didn’t realize they had pushed another update or patch to my unit since it stays off unless it’s in use.
I guess they did load the standard Altitude firmware by accident like @appelz said!
That’s a bummer as my JBL rep told me that they had been working to have PEQ on the SDP75, but I guess they still want to keep their speaker tunings secret.
Bummer.
post #619 of 623 Old 02-05-2020, 07:39 PM
thebland's Avatar
Liked: 1628
Not so secret... I have screen shots of the speaker tunings... It's public domain now. They should bring it back..
Marc Alexander and ccool96 like this.
post #620 of 623 Old 02-05-2020, 07:48 PM
appelz's Avatar
Quoted: 739 Post(s)
Liked: 793
Bummer.
Imma just delete my "yay" post then...hehe.
Having access to both the AEQ filter sets and PEQ is definitely something they want. Last I heard from someone who would know was that it wasn't going to be real soon.
appelz is offline
post #621 of 623 Old 02-05-2020, 08:18 PM
ccool96's Avatar
Quoted: 830 Post(s)
Liked: 1168
One last interesting point.
I just checked with an SDP75 owner who is still on 4.2.15.
His unit shows an update for 4.2.15.1 is available but he hasn’t updated.
But even on the 4.2.15, where he had PEQ the other day, now it’s back to AEQ.
So it don’t know what the 4.2.15.1 update does, but that isn’t want caused the PEQ to disappear.
post #622 of 623 Old 02-05-2020, 08:26 PM
Lioarlan's Avatar
Quoted: 27 Post(s)
Liked: 9
Anybody with free REW and a cheap audio interface can measure the response of a speaker AEQ, and trivially reverse engineer the PEQ to closely match that response. If JBL is thinking that this is a primary differentiation of the SDP-75, seems like a pretty thin reed to me ... I think the bigger value prop for the SDP-75 vs Altitude is the one stop shopping for complete systems including SOTA speakers, amps, subs, etc along with the necessary installation, calibration, and support.
Lioarlan is offline
post #623 of 623 Old 02-05-2020, 08:28 PM
appelz's Avatar
Quoted: 739 Post(s)
Liked: 793
Possible that it was just a bit flipped @jamin and the fix didn't require a firmware upload. Just that the machine be powered on and connected to the Trinnov servers, and changed on the fly.
jamin likes this.
appelz is offline
