Kaleidescape Strato Movie Player 4K HDR $4,500 - Page 182 - AVS Forum | Home Theater Discussions And Reviews
 2093Likes
post #5431 of 5479 Old 01-06-2020, 06:08 PM
uderman's Avatar
Quoted: 130 Post(s)
Liked: 58
Quite a collection.
Art
Also have just as many in dead formats like laserdiscs, d-vhs and hd-dvds lol
Wanted:
HD-VMD Discs
Muse/Hi-Vision Discs - Mint/Complete Only!
uderman is offline
post #5432 of 5479 Old 01-06-2020, 06:50 PM
JaremyP's Avatar
Quoted: 774 Post(s)
Liked: 435
https://www.mediaplaynews.com/uhd-al...msung-philips/
FYI.
Montucky and A7mad78 like this.
Video: JVC NX7, Stewart Cima Neve 135"
Audio: Marantz AV7704, Emotiva XPA-11 Gen 3
Speakers: Focal Electra 1038 Be x 2, Electra CC 1008 Be, Aria 906 x 8, REL S5 SHO x 2
Sources: Apple TV 4k, Kaleidescape Strato, Xbox One X, Nintendo Switch
Xbox Live: TrackZ
JaremyP is offline
post #5433 of 5479 Old 01-10-2020, 09:40 AM
Naylorman32's Avatar
Quoted: 513 Post(s)
Liked: 222
hey everyone,
what HDMI cables are you using these days for your K components? I have been using the ones that came with each device but lately i've been having audio/video hiccups during movies (maybe once or twice a movie) and im wondering if my cables are starting to go bad?
I'm currently using this for my projector-processor
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
JTR Speakers, RSL Atmos, Kaleidescape, Lumagen Radiance Pro, Marantz Processor, Emotiva Amps, JVC RS540
Naylorman32 is offline
post #5434 of 5479 Old 01-10-2020, 09:46 AM
thrang's Avatar
Quoted: 2664 Post(s)
Liked: 2165
Originally Posted by Naylorman32 View Post
hey everyone,
I’ve been dealing with audio drops for a few seconds, once or twice an evening... I’ve tried 5 different 18 gib certified cables, same issue... K is actively investigating, I would suggest emailing their support with the issue as strength in numbers always helps (you’ll likely get a reply from Rusty...)
Naylorman32 likes this.
UPDATED 4/29/17 Thrang's Home Theater (for now...)
Sony VPL-VW5000es • Panamorph Paladin DCR • Trinnov Altitude 32/24 • Crown DCIn amplifiers • JBL M2 (LCR-LW-RW) • JBL S2S-EX subwoofers x2 • JBL SCL-4 (side/rear surrounds) • JBL SCS12 (x4) SCS8 (x2) TH/RH/TM • Lumagen Radiance Pro • Panasonic UB820 • Apple TV 4k • Synology RAID (45 TB total storage) • RTI control system
thrang is offline
post #5435 of 5479 Old 01-10-2020, 09:52 AM
Quoted: 513 Post(s)
Liked: 222
I guess its a bit comforting knowing its not just a ME issue. Yeah i sent Rusty a note. Thanks! hopefully its just a small bug.
post #5436 of 5479 Old 01-10-2020, 09:55 AM
cmcjo's Avatar
Quoted: 16 Post(s)
For the guys experiencing dropouts , are you using a strato playing movies on its internal drives or playing movies across your network ?
JOE
cmcjo is offline
post #5437 of 5479 Old 01-10-2020, 10:07 AM
adidino's Avatar
Quoted: 530 Post(s)
Liked: 360
hey everyone,
Interesting both you and Thrang have a Radiance in your chain.
AudioXtream
Authorized Dealer:
Trinnov, Anthem, SVS, Triad, Genelec,
Revel, JBL Synthesis/JBL Pro, Paradigm, Kaleidescape, PS Audio, JVC,
Panamorph, LG
adidino is offline
post #5438 of 5479 Old 01-10-2020, 10:25 AM
fatherom's Avatar
Quoted: 536 Post(s)
Liked: 224
From Jim Peterson at Lumagen on the Lumagen thread (last week):
Concerning audio dropouts after an update:
I can say from experience that if you do an update and then get any dropouts, this comes down to the HDMI cabling. The different releases can have slightly different output jitters. The Pro has some of the lowest jitter measurements of any HDMI device I know about, but the low jitter does vary from release to release by a small margin. However, this should not affect either audio or the video. If it does check your cables:
- Make sure you did not loosen a HDMI plug while updating. It happens. I did this to myself on the latest release. I had a drop out in video and then discovered a plug slightly moved out. Plugged it back in and no more dropouts.
- Make sure all passive HDMI cables are 2 to 3 meters long and 18 GHz Certified. Very important. Cables under 2 meter can cause issues with the signal being "too hot" and audio goes first due to the IMO poor decision that it is carried as a non-coherent data stream on top of video. I solve issues in the field all the time by getting people to replace their 1 meter cables with 2 meter cables.
- I recommend the Tributaries UHDP passive HDMI cables, but there are a few other good HDMI cables available. Getting people to switch to the UHDP has solved issues on a number of occasions.
- Might even help to clean the contacts. Pull each end of every HDMI cable half way out and push back in five times. This cleans the contacts and better forms the contacts together. This little trick has resolved a lot of issues in various systems.
steelman1991 and Naylorman32 like this.
Theater 1: LG OLED55E6P, Oppo UDP-203, Apple TV 4K, Dune HD Solo 4K
Theater 2: Sony VPL-VW885ES, Seymour Premier 16:9 128", Lumagen 4242, Oppo 103D (CFW) & 203, Apple TV 4K, Sony MDR-DS7500 Wireless Surround Headphones & Denon AVR-X6500H (7.1.4)
fatherom is offline
post #5439 of 5479 Old 01-15-2020, 01:44 PM
thrang's Avatar
Liked: 2165
Terminator: Dark Fate has an issue with double subtitles - not every subtitle, but some random and repeatable number of them...
thrang is offline
post #5440 of 5479 Old 01-15-2020, 02:14 PM
Quoted: 89 Post(s)
Liked: 37
I have hda both the Radiance and Strato on my chain for the last 4 weeks and have not yet experienced this issue. I'm using the those 6' Monoprice certified premium high speed HDMI 18Gbps cables...
Kris Deering likes this.
Speakers: L/C/R: Ascend Sierra Towers (Raal) / Ascend Horizon (Raal) Subwoofers: 2 x JTR Captivator 2400ULF Surrounds: Revel S16(4) / Atmos: RSL C34e (4)
Video: JVC RS2000, Lumagen 4444, 132.8" SeymourAv 2.40:1 with dual roller masking to 16:9
Other: Anthem AVM60 / DSonic M3a 2800-7 / Crown XLS 1002 (2) / Kaleidescape Strato S, XBOX One X, ATV4k, UB820, Elan G1, 2x GC-100-18R
crg28 is offline
post #5441 of 5479 Old 01-15-2020, 02:18 PM
thrang's Avatar
Liked: 2165
I dont pass audio through the Radiance... I also tested without the Radiance even for the video portion
Its not frequent but once or twice a long night of movie watching. I dont know for certain, but it may only be Atmos titles - I dont recall on Blu Ray or UHD's with True HD/DTS-MA-HD or lower
I also don't get the drop from my ATV4k which does run through the Radiance (Strato originally did the same - running through the Radiance - but switched months ago as a troubleshooting step to the HDMI Audio only out direct to the Trinnov).
thrang is offline
post #5442 of 5479 Old 01-15-2020, 09:42 PM
tspotorno's Avatar
Quoted: 136 Post(s)
Liked: 56
FYI, recently switched from Datasat RS20i to the Trinnov Altitude 32... I am experiencing audio drop outs couple times per movie as well. Honestly, never remember having this issue with the Datasat, or at least I don't remember it. I do run audio thru the Lumagen...
Got some new cables today to see if that makes a difference.
I reported it to KScape and they are having me do a bunch of diag steps and have to send them the results. Want a log that I have to get when it happens.
Very annoying as I have to stop the movie, and restart it to regain the audio...
Sony VW5000 | Stewart Vistascope 14' ST100 screen
Trinnov Altitude 32/24 | 3 x MC601 | 2 x ATI AT526NC | Oppo 205 | Lumagen Radiance Pro
B&W 800 / HTM 2 Diamonds | 4 x Paradigm ADP3 | 2 x Fathom F212 | 6 x ML Vanquish
D-Box HEMC & 2 x SRP 330 platforms | Synology DS3615xs 12x6TB drives
tspotorno is offline
post #5443 of 5479 Old 01-15-2020, 11:18 PM
SJHT's Avatar
Quoted: 1211 Post(s)
Liked: 818
I would recommend discussing with Lumagen Support. My Trinnov arrives this week and they have suggestions for this setup. They have the same gear in their Lumagen Theater. SJ
SJHT is offline
post #5444 of 5479 Old 01-16-2020, 04:42 AM
jbm007's Avatar
Quoted: 158 Post(s)
Liked: 63
Are you loosing video as well or just audio?
If its just audio you can rule out the K unit.
Are all your HDMI cables at least 6 feet long?
Shorter HDMI cables can cause timing issues.
Lumagen scaler has the most rigid HDMI protocol standards in the world.
Which Lumagen software release are you using?
Lumagen updates its software every couple of weeks.
Try changing the audio input feed to the Trinnov to a different HDMI port.
We have 4 Kal units here and a Lumagen 4442, Trinnov 16 s and have never had audio drop outs.
Video drop outs.... YES, depending on the current software release from Lumagen.
jbm007 is offline
post #5445 of 5479 Old 01-16-2020, 04:59 AM
thebland's Avatar
Quoted: 2338 Post(s)
Liked: 1551
Good advice here but did you simply bypass the Lumagen to see if the drop outs continue?
Goodbye to a great audio and video genius and writer... JOHN GANNON. I enjoyed your friendship, wit and a nice long run we took around Indianapolis at CEDIA years back... and for buying my Runco 980 Ultra years back... you saved my ass! Rest in peace.
thebland is offline
post #5446 of 5479 Old 01-16-2020, 05:01 AM
thrang's Avatar
Liked: 2165
I don’t know if that’s necessarily true. I am running audio output only from the strato and bypassing the lumagen... it’s either the strato, connectivity to the terra, or the Altitude. I’ve tried multiple 6 foot 18 gig certified cables so it’s not that.
Both my Strato and Terra are on the same gig switch in my rack with Fluke certified gig enet cables as well.
Sounds like tspotorno is having a different issue than some of us reporting here... once the audio drops it’s gone until he restarts playback? That’s how his post reads.
My drops are momentary (1-2 seconds)
thrang is offline
post #5447 of 5479 Old 01-16-2020, 05:09 AM
Quoted: 513 Post(s)
Liked: 222
Mine also drops out just for 1-2 seconds, definitely seems different than what tspotorno is saying (at least i think). I havent thought to look into it being a problem with my aging gig switch, so thats a good point.
I logged a couple instances last week, but havent fired my theater back up since. I only use my Lumagen for the NLS and DTM features, and if i need to buy new HDMI cables its going to be a pain. So i posted it in the classifieds to see if i can get back what i paid. If not, i'll just keep troubleshooting it with Rusty at K, and maybe send Jim a note to see if he has suggestions.
post #5448 of 5479 Old 01-16-2020, 05:41 AM
jbm007's Avatar
Quoted: 158 Post(s)
Liked: 63
Well we have similiar setups.
One thing is different. We feed the audio/video to the Lumagen and send the audio out the second Lumagen output to the Trinnov.
We use a Cisco 1000 gig sw. and all Cat 8 cabling in our systems. We use a Luxul EPIC 3 – DUAL BAND WIRELESS AC3100 GIGABIT ROUTER W/ DOMOTZ & ROUTER LIMITS
We use Velox Passive HDMI® Cables
We have 4 Stratos, and 2 Terra servers.
No audio drop outs have occurred in our system to date.
Guess I just cursed us................
jbm007 is offline
post #5449 of 5479 Old 01-16-2020, 06:41 AM
thrang's Avatar
Liked: 2165
We use Velox Passive HDMI®️ Cables
I originally ran combined audio and video to the Radiance and then audio out to the Altitude.
When I heard the dropouts I tried the Strato audio only direct to the Altitude to see if running through the Radaince was the problem, but same type of occasional and sporadic behavior occurs.
thrang is offline
post #5450 of 5479 Old 01-16-2020, 06:57 AM
thebland's Avatar
Liked: 1551
Anyone know when MGM and James Bond are coming to K?
thebland is offline
post #5451 of 5479 Old 01-16-2020, 06:59 AM
thrang's Avatar
Liked: 2165
That and what happened to general MGM releases - we got a first batch then nothing
NBC/20th Century advanced codecs and MA updates would be appreciated as well
A7mad78 likes this.
thrang is offline
post #5452 of 5479 Old 01-16-2020, 07:08 AM
steelman1991's Avatar
Quoted: 509 Post(s)
Liked: 292
Thought you guys ran and recommended Tributaries cable?
steelman1991 is online now
post #5453 of 5479 Old 01-16-2020, 07:11 AM
Quoted: 509 Post(s)
Liked: 292
I reckon we're flogging a dead horse on that subject Thrang.
post #5454 of 5479 Old 01-16-2020, 07:16 AM
jbm007's Avatar
Quoted: 158 Post(s)
Liked: 63
We do. But for our customer's systems.
But when you have $800 worth of other cables in your demo systems, you don't get a wild hair up your ass and replace them.
jbm007 is offline
post #5455 of 5479 Old 01-16-2020, 07:17 AM
Quoted: 509 Post(s)
Liked: 292
LOL - touche. Thanks Jim
post #5456 of 5479 Old 01-16-2020, 07:25 AM
thrang's Avatar
Liked: 2165
Personally the Tributaries is one of 4-5 18gig certified cables I’ve tried
I think Jim at Lumagen puts too much emphasis on cables when there are issues. Yes bad cables can be an issue but in reality any certified cable should be fine and I’ve had plenty of non certified cables work in other 4k/lossless audio implementations without issue
Usually a wonky cable is a very obvious issue
tcramer likes this.
thrang is offline
post #5457 of 5479 Old 01-16-2020, 07:26 AM
thrang's Avatar
Liked: 2165
My arm does not tire though... 🙁
steelman1991 likes this.
thrang is offline
post #5458 of 5479 Old 01-16-2020, 07:44 AM
Quoted: 509 Post(s)
Liked: 292
Definitely - I have "Omars" 2M Premium Certified (cheap as chips) cables and they are solid in my set-up.
post #5459 of 5479 Old 01-16-2020, 07:57 AM
SJHT's Avatar
Liked: 818
Also (recommended by Lumagen and how they have theirs setup), try only using input 6 or 7 on the Altitude. Not 1-4 as they go through two HDMI chips in series...
SJHT is offline
post #5460 of 5479 Old 01-16-2020, 08:33 AM
jbm007's Avatar
Quoted: 158 Post(s)
Liked: 63
Actually I think its the connectors that are the real issue.
Some connectors are just too loose and the quality of the pin outs is subject.
jbm007 is offline
