The McIntosh MX160 A/V Processor Owner's Thread - Page 106 - AVS Forum | Home Theater Discussions And Reviews
 1628Likes
post #3151 of 3442 Old 07-22-2018, 12:31 PM
vercingetorix's Avatar
Quoted: 27 Post(s)
Liked: 24
Some MX160 owners pass on the very specific details they are told from dealers, while other MX160 owners are on NDA with McIntosh and are not allowed to comment.
joerod likes this.
vercingetorix is offline
post #3152 of 3442 Old 07-22-2018, 03:37 PM
OzHDHT's Avatar
Quoted: 1235 Post(s)
Liked: 753
As an owner(I realise now I mistagged you earlier due not picking the couple of posts that mention you owning one) who spoke to one specific dealer a few months ago, it's great but doesn't make a MX170 a certainty, no matter how good the dealer. I've shared a lot of precise new model info on Sony and JVC projectors over the last 5 or so years, passed straight to me from Senior employees at local factory owned distribution level that's come straight from those factories. Yet as interested as folks here get, nobody takes it as gospel. That's just the nature of internet forums. Yes, most of us are all well aware there are owners and dealers here on the forums quite often under NDA or asked specifically not to share pre-release info. If you're very close friends with some of these people, you never know your luck - I know I've been fortunate there and have done similar for them in return with info
JFR0317, vercingetorix and Jan T like this.
OzHDHT is offline
post #3153 of 3442 Old 08-12-2018, 12:54 PM
DrMichael's Avatar
Quoted: 478 Post(s)
Liked: 249
Does anyone know what settings are used to do upfiring Atmos speakers? Thanks!
DrMichael is offline
post #3154 of 3442 Old 08-12-2018, 01:38 PM
Quoted: 398 Post(s)
Liked: 112
Speaker set up guide says select Dolby Enabled speaker in speaker set up menu for the appropriate channel. For the left upfiring speaker select Dolby enabled in the Left front speaker set up. The guide then says the 160 will assign which XLR output to be used for that Dolby enabled speaker. In my case for the left and right upfiring speakers it assigned LTM and RTM as the outputs to be used.
It doesn’t work. After going round and round with Mc they said to simply use LTF/ RTF. They said it’s exactky the same thing. I don’t buy it but it’s the only way I was able to use the upfiring speakers.
daimler2015 is offline
post #3155 of 3442 Old 08-12-2018, 01:41 PM
DrMichael's Avatar
Quoted: 478 Post(s)
Liked: 249
Does it still sound good? Thanks for the help!
post #3156 of 3442 Old 08-12-2018, 01:50 PM
Quoted: 398 Post(s)
Liked: 112
Sounds ok. But I think the system needs to know that upfiring speakers are being used. I believe the Dolby papers say the signal is processed differently for upfiring speakers as to assist with the spatial effect.
post #3157 of 3442 Old 08-12-2018, 02:02 PM
Quoted: 398 Post(s)
Liked: 112
PS- to measure distance for the upfiring speakers I put a small piece of painters tape on the ceiling where the tweeter/ horn should be hitting the ceiling. Then measured from the MLP to the painters tape, added those numbers together and entered that for the speaker distance.
DrMichael likes this.
post #3158 of 3442 Old 08-12-2018, 02:10 PM
DrMichael's Avatar
Quoted: 478 Post(s)
Liked: 249
Thanks! I hope they fix this issue
post #3159 of 3442 Old 08-13-2018, 11:27 PM
Marc Alexander's Avatar
Quoted: 5457 Post(s)
Liked: 4953
Hello, REQ does need to know that upfiring, Dolby-enabled speakers are connected. In the Lyngdorf/McIntosh this is NOT INTUITIVE!
You must choose Dolby-enabled in the speaker setup for the position you are placing the DE speaker on top of.
I have never tested DE speakers, @joerod may know or can find out. I would guess that Front L/R - Top Front, SS - Top Middle and RS - Top Rear.
Marc Alexander is offline
post #3160 of 3442 Old 08-14-2018, 12:03 AM
Quoted: 398 Post(s)
Liked: 112
Hey Marc
After several attempts enabling DE does not function correctly. No signal whatsoever is sent to the channels. That’s why Mc said to use the LTF / RTF and of LTR / RTR.
post #3161 of 3442 Old 08-14-2018, 12:28 AM
Liked: 4953
Hey Marc
You enabled LTF/RTF (also enabling DE on LF/RF) and LTR/RTR (DE on LRS/RRS)?
Does Speaker Verify emit tones?
post #3162 of 3442 Old 08-14-2018, 12:42 AM
Quoted: 398 Post(s)
Liked: 112
After enabling DE with LF and RF, the 160 showed that LTM and RTM were now enabled. LTF and RTF we’re still greyed out. As per speaker config document those were the XLR outputs to be used for those channels and connected to the amp accordingly. After doing, no signal present, even with verify speaker tones. Contacted Mc and was told not to enable DE and to use top outputs for upwards firing speakers.
Did not test rear DE set up.
post #3163 of 3442 Old 08-14-2018, 12:51 AM
Liked: 4953
I was able to test and it works. You need to delete TF, TM & TR. You do all config on F, SS and RS. You can only use 2 pairs of DE speakers. Matrixing is not available when using DE speakers. Aux subs and Auro positions are available.
I did not run RP but it makes sense if RP skips DE speakers because of their special FR curve/notch. Verify using Verify Speakers. Here is what is should look like.
joerod likes this.
post #3164 of 3442 Old 08-14-2018, 12:52 AM
Liked: 4953
I am running 3.0.7
post #3165 of 3442 Old 08-14-2018, 01:22 AM
Quoted: 398 Post(s)
Liked: 112
I am running 3.0.7
Marc
Think I understand. Could we chat bout this via email? [email protected]
post #3166 of 3442 Old 08-14-2018, 04:32 AM
Liked: 4953
Marc
Sure
post #3167 of 3442 Old 08-14-2018, 05:14 AM - Thread Starter
joerod's Avatar
Quoted: 1149 Post(s)
Liked: 1217
Are you guys squared away? Do I need to ask them anything?
4K HDR10- ignore the “rules” and trust your eyes!
joerod is offline
post #3168 of 3442 Old 08-14-2018, 05:44 AM
DrMichael's Avatar
Quoted: 478 Post(s)
Liked: 249
I’m very curios if this works because I’m holding on buying upfiring speakers at this time because of the uncertainty with the 160’s ability to do it. Thanks!
post #3169 of 3442 Old 08-14-2018, 04:36 PM
Quoted: 398 Post(s)
Liked: 112
Hey Joe,
No, not squared away. Over a year ago when I tried doing speaker set up (while using 2 Dolby enabled speakers) no signal was present for those up firing speakers. I followed the speaker set up doc. That’s when Mc told be to set them up without selecting Dolby enabled in set up and to set them up as LTF and RTF.
A few firmware updates later I asked Mc if the issue was fixed and was told to leave them as LTF and RTF since doing so is the same thing as selecting Dolby enabled during set up.
post #3170 of 3442 Old 08-14-2018, 04:58 PM - Thread Starter
joerod's Avatar
Liked: 1217
Hey Joe,
I will ask over there and report back shortly.
joerod is offline
post #3171 of 3442 Old 08-14-2018, 04:59 PM - Thread Starter
joerod's Avatar
Liked: 1217
Isn’t it about time for a new firmware update? I will ask about that too.
JFR0317 and OzHDHT like this.
joerod is offline
post #3172 of 3442 Old 08-14-2018, 05:08 PM
Quoted: 398 Post(s)
Liked: 112
Thank you, Joe
OzHDHT, Jan T and DrMichael like this.
post #3173 of 3442 Old 08-15-2018, 12:13 PM
cn256's Avatar
Quoted: 35 Post(s)
My issue when experimenting with up firing "DE" vs. LTF and RTF, was that the Dolby Upmixer wasn't using the DE speakers a while back (no idea if that has changed). Only Atmos soundtracks were using them. That is why I ended up choosing to use the LTF and RTF so that I could have them used during up-mixed audio.
cn256 is offline
post #3174 of 3442 Old 08-16-2018, 10:00 AM
SJHT's Avatar
Quoted: 1094 Post(s)
Liked: 729
Will the new MX170 be shown at Cedia? I see that McIntosh has a booth. I will stop by when I'm there and talk to them! SJ
JFR0317 and Jan T like this.
SJHT is offline
post #3175 of 3442 Old 08-16-2018, 03:48 PM
Liked: 4953
I would be surprised since there has been no recent updates from Lyngdorf regarding the new HDMI board.
I would also expect a MX161 or MX160 mkII badge rather than 170.
post #3176 of 3442 Old 08-17-2018, 05:47 PM
cn256's Avatar
Quoted: 35 Post(s)
Actually, I just changed my up-firing speakers to Dolby enabled to try it again (I hadn't tried for a long time), and it seems to be working well now. I recommend it.
daimler2015 likes this.
cn256 is offline
post #3177 of 3442 Old 08-17-2018, 05:53 PM
Quoted: 398 Post(s)
Liked: 112
Once selecting Dolby enabled in speaker set up which channel outputs did the 160 assign for the DE speakers?
Also, does it sound better than your prior set up?
post #3178 of 3442 Old 08-17-2018, 10:13 PM
Liked: 4953
Dolby Enabled needs to be identified so that REQ accounts for the virtualization curve.
Originally Posted by sdurani View Post
When applied to sounds, it tricks our human hearing into thinking they're elevated above ear height. In my experience, the height virtualization processing plays a much bigger role in creating the height effect than aiming speakers at the ceiling does (as you've discovered).
cn256 and daimler2015 like this.
post #3179 of 3442 Old 08-18-2018, 10:21 AM
cn256's Avatar
Quoted: 35 Post(s)
I have four speakers that I set as DE. It's using LTF, RTF, LTR, RTR outs. It sounds better for Dolby Atmos, Dolby upmixer, and DTS-X. The Neural-X upmixer isn't using them though for some reason.
cn256 is offline
post #3180 of 3442 Old 08-18-2018, 11:40 AM
Liked: 0
MX 160 Bi-Amping
New MX160 owner and new to AVS Forum. Having a bi-amping problem and couldn't find anything to help me when searching in this thread......
My MX160 is pared with a MC207 Amp. Trying to setup bi-amping for my front speakers. Configured the speakers for bi-amping in speaker setup which enabled the aux 1 & aux 2 icons in the speaker setup. Saved the setup and verified it's saved. Hooked up aux 1 and 2 from the MX160 to the 2 open amp inputs I have on the MC207 and hooked up the bi-amp speaker wires to the MC207 outputs. So believe everything is good to go but am getting nothing out of the added bi-amp amp outputs. Only the man LF and RF outputs from the MC207 are active. Is there anything I'm missing? I have the latest firmware - v3.04.
Any help appreciated.
Craig
[email protected] is offline
