Quoted: 1658 Post(s)
Liked: 842
Originally Posted by
AV Doogie
$30K for a UPS? Yikes.
Not a unit I would use or recommend.
Now I wouldn't spend $30k for it, simply can't afford it right now.
Please explain your reasoning why you wouldn't use or recommend this unit, other than the price. Thanks.
No dealer is authorized to tell you I refer to them - any referrals I make will be done personally by me. Over the years I have found certain dealer(s) who I cannot recommend for good reason! 9.9.13 Trinnov Altitude 32 Theatre renovation/upgrade still in process!
