The Official 5000ES 4K Laser Sony Owner's Thread - Page 101 - AVS Forum | Home Theater Discussions And Reviews
 1283Likes
post #3001 of 3028 Old 09-19-2019, 09:04 AM
roxiedog13's Avatar
Quoted: 2797 Post(s)
Liked: 1485
Originally Posted by G-Rex View Post
The lens would be huge and this would no doubt be a very tricky install, with how my projector is mounted. If I ever go forward with it I certainly will post. I would be more interested if a DCR variant model came out someday with an alternate install position/flexibility... I.e a shorter throw with middle of screen mount capability.
The 1.25X ISCO is huge , it actually dwarfs the ISCO IIIL 1.33X which by anamorphic lens standards is already big and heavy. You'll want a separate dedicated mount for the lens without question. The 1.25X would be necessary if you want to utilize the full 17:9 panel like the DCR but it's also intended to be used on a curved screen whereas the DCR is intended for a flat screen. The DCR is by comparison very small, extremely light, in fact, I hung mine off the mounting plate of my current projector without issue . I did not have a electric sled as the lens remains fixed in place, that saves a lot of weight too. Luckily the Sony have stretch and shrink modes, it's not necessary to move the anamorphic lens at all .
Dedicated Theater: Sony VPL VW5000 , Panamorph DCR & ISCO III L Anamorphic Lens, Draper TecVision XT1800X Screen, 2.40:1 134" diagonal curved , Denon AVR-X8500 , 9.2.6 Atmos, Panasonic UB900, Oppo 203, Lumagen Pro 4440 , (3) Paradigm CI Elite E7-L+C+R fronts, , (2) CI Pro P80-IW Rear, (2) Paradigm SA-ADP In-wall Surround, (6) SIG-1.5R-30 v.3 In-Ceiling, Subwoofers: (2) SVS SB-16 Ultra , (1) SVS PC13-Ultra .
roxiedog13 is offline
post #3002 of 3028 Old 09-19-2019, 09:09 AM
mani's Avatar
Quoted: 339 Post(s)
Liked: 152
[QUOTE=roxiedog13;58580164]
I think ideally all A lenses will work best with curved screens as distance from lens to center of screen is different than the edge of screen . However with long enough through ( mine is 25’) , it becomes a non issue visually . On test pattern I don’t see much geometric distortion or lack of sharpness from center to the edge . Some is expected obviously but it is minimal and while watching actual content , you can’t perceive it .
roxiedog13 likes this.
mani is offline
post #3003 of 3028 Old 09-19-2019, 10:08 AM
roxiedog13's Avatar
Liked: 1485
[quote=mani;58580180]
You are correct, the longer the throw the less the anamorphic lens distortion effect . Now, not ALL anamorphic lens require a curved screen, the Paladin DCR is actually designed for a flat screen . So to be clear, most A-lens like the ISCO and all previous Panamorph before the paladin have vertical compression the image has a pincushion shape whereas the Paladin DCR has horizontal compression, the image will have barrel distortion. The closer to the screen the greater the distortion, both will essentially need
a little over scan .
post #3004 of 3028 Old 09-28-2019, 07:30 AM
Quoted: 123 Post(s)
Liked: 30
Today I was trying to watch a DVD (MKV) with Oppo 203 but signal wasn't detected and after a while projector went off and red light was flashing four time. In the user's manual there's no mention about four red flashes. Does anybody know what's happened?
After a power cycle projector went on.
P.S. Radiance is set to output 4:2:2 and Auto 18GHz
With Dune Pro 4K DVD MKV Playback is ok.
stefanop is offline
post #3005 of 3028 Old 09-28-2019, 07:35 AM
Archibald1's Avatar
Quoted: 2031 Post(s)
Liked: 1099
Could it be that it flashed 8 times? I have read that code means the lens is not securely attached.
Other than that, curious to know what 4 flashes means.
“Remember to look up at the stars and not down at your feet. Be curious. And however difficult life may seem, there is always something you can do and succeed at. It matters that you don’t just give up."
Stephen Hawking.
Archibald1 is offline
post #3006 of 3028 Old 09-28-2019, 07:52 AM
Quoted: 123 Post(s)
Liked: 30
No. 4 flashes, long pause, 4 flashes, long pause, 4 flashes and so on...
stefanop is offline
post #3007 of 3028 Old 09-28-2019, 08:02 AM
mani's Avatar
Quoted: 339 Post(s)
Liked: 152
I was having HDMI sync issues and got worse that I stopped getting any Hidef picture including Lumagen onscreen menu even . Tried rebooting whole chain several times , changed cables , even brought Lumagen right next to projector with 6” brand new cable . It works fine when attached to my Sony 4K TVs with same cables . I get the Sony menu fine which is sharp and crisp . Called Sony ES customer service . It was still under warranty (2.5 yes out) . I have to say customer service was great . No wait time on the call and immediately offered that they will be shipping a crate to send the projector to service center .
On that topic , can any one tell me how to save current configuration and when I get the projector back how to reload it . Please feel free to PM me if you are not able to post here
mani is offline
post #3008 of 3028 Old 09-28-2019, 08:40 AM
Quoted: 123 Post(s)
Liked: 30
Ok! DVD playback solved! Just needed to shutdown and restart Radiance.
It still remains the mistery of the 4 red flashes
stefanop is offline
post #3009 of 3028 Old 09-29-2019, 06:52 AM
Art Sonneborn's Avatar
Quoted: 1266 Post(s)
Liked: 1695
Anxious to hear the first reviews of the dynamic contrast update for the 5000.
Art
Craig Peer likes this.
Art Sonneborn is offline
post #3010 of 3028 Old 09-29-2019, 07:08 AM
thrang's Avatar
Quoted: 2616 Post(s)
Liked: 2119
Art
Isn’t the firmware being released in November?
thrang is offline
post #3011 of 3028 Old 09-29-2019, 08:14 AM
Liked: 1695
My understanding but any new 5000s will have it active out of the box in October.
Art
post #3012 of 3028 Old 09-29-2019, 08:28 AM
thebland's Avatar
Quoted: 2244 Post(s)
Liked: 1462
Is the firm aware update process in this projector simple, bulletproof? Haven’t done it.
Goodbye to a great audio and video genius and writer... JOHN GANNON. I enjoyed your friendship, wit and a nice long run we took around Indianapolis at CEDIA years back... and for buying my Runco 980 Ultra years back... you saved my ass! Rest in peace.
thebland is offline
post #3013 of 3028 Old 09-29-2019, 08:32 AM
thrang's Avatar
Liked: 2119
There was an issue a few firmware's ago that bricked a small number of projectors! Before and after that, there have been no reported incidents.
In terms of procedure, Sony includes the instructions on the firmware download page, but since this is not released yet, unsure of the process has changed or not. Top level - you extract the firmware, put it on a USB stick, insert in a powered down 5000, turn the projector on, and wait several minutes as it updates, paying attention to the led status lights for progress and completion.
thebland and roxiedog13 like this.
thrang is offline
post #3014 of 3028 Old 09-29-2019, 08:52 AM
wjchan's Avatar
Liked: 30
Art
November for the 5000 according to the slide posted below. The 760 firmware still isn't available on their website.
wjchan is online now
post #3015 of 3028 Old 09-29-2019, 09:35 AM
Liked: 1695
Stand corrected thanks,
Art
post #3016 of 3028 Old 09-30-2019, 07:34 AM
Archibald1's Avatar
Liked: 1099
The 760 update was available as of earlier today and the features list for the 760 has also been updated.
Of more interest to you guys, is that the feature list for the 5000 has also been updated to show the new features, but no firmware update as yet of course.
Stephen Hawking.
post #3017 of 3028 Old 09-30-2019, 05:37 PM
thebland's Avatar
Liked: 1462
Lumagen 444x question
Any Lumagen / 5000ES users have a second monitor connected to the Lumagen 2nd HDMI output (for equipment room, etc?) Any sync issues? What brand monitor?
thebland is offline
post #3018 of 3028 Old 10-01-2019, 05:37 AM
roxiedog13's Avatar
Liked: 1485
Thanks for the update @archibald . Can you elaborate what are the new features or provide a link to the same.
post #3019 of 3028 Old 10-01-2019, 05:51 AM
Archibald1's Avatar
Liked: 1099
Hi.
Product page here:
https://pro.sony/en_GB/products/4k-h...k-vpl-vw5000es
Cheers.
Stephen Hawking.
post #3020 of 3028 Old 10-01-2019, 07:07 AM
SJHT's Avatar
Quoted: 1117 Post(s)
Liked: 745
I think is a pretty normal setup for folks with screens that drop in front of a smaller displays. Are you going to run both displays at the same time? I have a second monitor, but it is only 1080P in an adjacent room to our theater (using Sony 995). I use Mem D to change all the outputs to 1080P. We never use at the same time, but does work with my 995 receiving a 1080P signal. Not sure about 4K, but a quick note to the folks at Lumagen would give you info as they deal with this in many installations. SJ
SJHT is online now
post #3021 of 3028 Old 10-03-2019, 09:12 AM
Steve Bruzonsky's Avatar
Quoted: 1588 Post(s)
Liked: 786
Originally Posted by Mike Garrett View Post
Today Sony sent out an email with an exchange offer.
Sony FPJ Trade in Program 9/30 – 12/29
"A customer can trade in any Barco, BenQ, DPI, Epson, Hisense, JVC, LG, Optoma, Runco, SIM2 or Sony consumer projector and get 10% off the purchase of the Sony projectors on the left."
This applies to:
VW5000
VW995
VW695
VZ1000
Note
• Trade in Projectors must be Consumer/Home Projectors, not professional models.
• Sony reserves the right to end the promotion early with two weeks advanced notice.
Gee, my old Sim2 C3X1080p projector has been sitting in storage for 2 years as I have my Sony VW5000. Projector works but on left side screen gets some speckles on dark scenes sometimes - don't know what the issue is. Anyone needing a trade-in should AVS PM me, preferably close to where I am in Phoenix, Az area!
https://www.avsforum.com/avs-vb/show....php?t=1158431 No dealer is authorized to tell you I refer to them - any referrals I make will be done personally by me. Over the years I have found certain dealer(s) who I cannot recommend for good reason.
! 9.4.13 Trinnov Altitude 32 Theatre renovation/upgrade starts end of July 2019!
Steve Bruzonsky is online now
post #3022 of 3028 Old 10-04-2019, 06:58 PM
tcramer's Avatar
Quoted: 395 Post(s)
Liked: 192
Anybody ever had an issue where the 5000 doesn't display an image, only the yellow HDMI notification?
I bypassed the Lumagen and tried a couple sources directly into the 5000 and nothing. I then removed power, gave it a few minutes and the sources displayed. Came back a bit later and same thing, only this time power cycling is not helping. Then it was on for about 5 minutes before it turned off, giving the 4 blinking red lights.
Getting anxious that I may have a problem here. I'll mess around with a bit more before contacting support but wanted to check here first.
tcramer is offline
post #3023 of 3028 Old 10-04-2019, 07:24 PM
carguy84's Avatar
Quoted: 21 Post(s)
On both HDMI inputs, no. One one, yes. Sent it in to get repaired and they replaced the HDMI board. But it came back way out of color.
carguy84 is offline
post #3024 of 3028 Old 10-09-2019, 03:44 AM
Archibald1's Avatar
Liked: 1099
According to 870 SM 4 flashes has a couple of meanings but as you restarted your VP, I would guess it is the one that means:
System error:
4 Flashes.
The communication between CPUs cannot be
performed after the power is turned on, or each
CPU cannot operate correctly.
Glad it sorted itself.
Hard power cycle will mostly cure a number of ills.
Stephen Hawking.
post #3025 of 3028 Old 10-09-2019, 03:47 AM
Archibald1's Avatar
Liked: 1099
Lights blinking 4 times can mean one of three things:
System error
Firmware update error
Wheel error.
stefanop likes this.
Stephen Hawking.
post #3026 of 3028 Old 10-09-2019, 06:59 AM
Quoted: 123 Post(s)
Liked: 30
System error:
4 Flashes.
Thank you @Archibald1 , it seems the right answer because before powering off, the projector remote commands were processed very slowly.
Archibald1 likes this.
stefanop is offline
post #3027 of 3028 Old 10-09-2019, 07:10 AM
Quoted: 123 Post(s)
Liked: 30
System error
Wheel error.
What is the Wheel in Sony projector?
stefanop is offline
post #3028 of 3028 Old 10-09-2019, 07:26 AM
Archibald1's Avatar
Liked: 1099
Phosphor wheel for the laser I believe.
Stephen Hawking.
