Official JVC RS4500/Z1 Owner's Thread - Page 132 - AVS Forum | Home Theater Discussions And Reviews
 3174Likes
post #3931 of 4557 Old 02-18-2020, 10:45 PM
blake's Avatar
Quoted: 1036 Post(s)
Liked: 155
Originally Posted by ccool96 View Post
If you are zooming and not using an A-lens then you figure the screen size width but with an aspect of 16:9, matching the projector panel.
So with a 140” wide screen (scope or 16:9) doesn’t matter with the zoom method. With a .8 gain and 2500 lumens gives you 26fL to fill the entire 140” screen width. You would have the same 26fL if you had a 140” wide screen that was 16:9 aspect ratio as well.
You really won’t be able to clamp down on the iris at all.
Even with the Lumagen DTM, personally I consider 30fL the bare minimum for HDR content. ...
My screen will be CIH (side) masking. So as 2.40 it is 140" x 58.3"=56.6 sq ft native. As 16:9 , it shrinks to 104" x 58.3"=42 sq ft. The native JVC panel is 17:9 ratio. Lumens to work with = 2000 lumen (2500 calibrated in high laser * 0.8 gain).
Sorry, I do not understand how you calculated 26 fL for both the 16:9 image and 2.40:1 image (latter with JVC zoom to scope function).
My calculation for a 16:9 image is 2000 lumens/42 sq ft= 47.7 fL.
I do not know how to calculate for 2.40, as I cannot conceptualize the light loss using ZOOM. I assume 2000/56.6=35 fL is not accurate?
Sorry guys, tried to google this stuff but still cannot find clear explanation of the math.
Originally Posted by MDesigns View Post
Did you use the whole 17:9 panel area when calculating by hand? The projector illuminates the whole 17:9 area even though your screen is scope. With the DCR you could get all of the lumens to scope format.
Also, throw distance is measured from the lens. How long is your room from the screen to the back wall?
Not sure how to alter the above calculation to reflect its native 17:9 panel, projected to 16:9 and 2.40 ratios?
I realize throw is lens to screen. My room is 19' 9" long (237"). I will lose 4" (front wall to screen surface), 8" (behind projector for connections), and 28" (projector length itself) = 197" throw distance.
Originally Posted by markmon1 View Post
Why not dump the 0.8 screen and go with a st100 or even st130?
I need an acoustically transparent screen. My front/main seating is 10' away from screen (2 x screen height). The Stewart ST100 and ST130 only have microperf available, which will be visible from my seating distance and degrade the picture. The Seymour screen Enlightor Neo is a woven fabric, and also will offer better contrast.
blake is offline
post #3932 of 4557 Old 02-18-2020, 11:02 PM
ccool96's Avatar
Quoted: 857 Post(s)
Liked: 1206
I didn’t say If you reduced your 16:9 imagine to 104” wide it would be the same fL. Yes if you zoom down to 104” wide 16:9 image you would have 47fl. That is correct.
I said with the zoom method you calculate your screen size based on a 16:9 screen at your full image width, even if you are using a scope screen, because your projector is projecting that 16:9 image, it’s just projecting black above and below the screen.
So to calculate for a 140” scope screen using zoom method you would calculate the screen area not as 140” x 58.3” but 140” x 78.75” because that’s the size of the image the projector is projecting.
Sent from my iPhone using Tapatalk Pro
ccool96 is offline
post #3933 of 4557 Old 02-18-2020, 11:14 PM
MDesigns's Avatar
Quoted: 294 Post(s)
Liked: 148
Also with the 17:9 panels you lose about 6% of brightness to the side black bars when using only the 16:9 width of the panels. That has to be subracted from the final numbers. I think there is no "zoom"-mode in the RS4500 to use the whole panel width, like in the newer 4K series? *****Edit: RS4500 does have the zoom-option, so you can use the whole panel width for wider aspects.
Also the DCR lens can't be used with the RS4500 without Lumagen or MadVR Envy. It doesn't have the proper anamorphic scaling modes to use the whole panel.
JVC DLA-RS500
MDesigns is offline
post #3934 of 4557 Old 02-18-2020, 11:50 PM
woofer's Avatar
Quoted: 1826 Post(s)
Liked: 2809
@blake
just for your info.
I run my Z1/RS4500 at 21ft throw onto a 143" Scope screen 1.26 gain
I use a HTPC with madVR ..i use MED Laser for HDR and SDR. before madVR i had to use HIGH Laser for HDR.
I gave up obsessing/chasing "ft/l" fiqures and now just thoughourly ENJOY the image projected...
Either madVR or the Lumagen is IMHO "Mandatory" in order to achieve stunning results with HDR..
OzHDHT, Craig Peer and markmon1 like this.
woofer is online now
post #3935 of 4557 Old 02-19-2020, 01:01 AM
blake's Avatar
Liked: 155
Can anyone confirm this ? Seems like a waste to have a 17:9 panel when all content will essentially be using only 16:9.
I don’t believe there is even cinema 4K (17:9) content even available for home use !
blake is offline
post #3936 of 4557 Old 02-19-2020, 02:00 AM
MDesigns's Avatar
Quoted: 294 Post(s)
Liked: 148
I really think you should wait for the Envy or if in a hurry get the Lumagen. Those can sort also this "feature", give you awesome tone mapping and upscaling(Envy) and scale with the DCR if you decide to get that later.
JVC DLA-RS500
MDesigns is offline
post #3937 of 4557 Old 02-19-2020, 02:51 AM
ccool96's Avatar
Quoted: 857 Post(s)
Liked: 1206
Doesn’t even matter. It is what it is.
All 4K projectors from Sony and JVC are this way.
With a DCR lens and a Lumagen you are able to make use of the full 17:9 panel.
OzHDHT and Craig Peer like this.
ccool96 is offline
post #3938 of 4557 Old 02-19-2020, 02:56 AM
ccool96's Avatar
Quoted: 857 Post(s)
Liked: 1206
Very true. And agree you can’t use the DCR without the Lumagen or Envy because the projector doesn’t have the correct aspect modes built in, but I don’t even consider those VPs as optional.
DTM is a must for 4K projection. So for anyone buying the 4500, one of these devices, typically the Lumagen, is really mandatory.
ccool96 is offline
post #3939 of 4557 Old 02-19-2020, 05:56 AM
audioguy's Avatar
Quoted: 5774 Post(s)
Liked: 4876
But the Panamorph Paladin lens can be used without the Lumagen and while it won't give the full 38% increase, it will provide 30+% --- still much better than without a lens!!
audioguy is online now
post #3940 of 4557 Old 02-19-2020, 10:05 AM
Craig Peer's Avatar
Quoted: 8050 Post(s)
Liked: 10615
I couldn't agree more. DTM has transformed 4K HDR completely. I couldn't be without my Lumagen. If I couldn't afford both, I'd get the Lumagen first, and add the DCR lens down the road.
OzHDHT likes this.
Craig Peer is online now
post #3941 of 4557 Old 02-19-2020, 10:17 AM
audioguy's Avatar
Liked: 4876
+1
post #3942 of 4557 Old 02-19-2020, 11:59 PM
woofer's Avatar
Liked: 2809
@blake in regards to your query in the Lumagen thread...
i have posted info on this several times....... i have a friend who has in exccess of 6000hrs on his Z1/RS4500 .. no loss of light output .. he has done regular measurments form new...
The 20,000 hr "Half Life" is for 100% output in HIGH Laser 100% of the time.......this never occurs unless you were to project a full static white screen . Dispaying real world dynamic content combined with the Laser dimming the Laser is not operational at 100% output 100% of the time..
OzHDHT likes this.
post #3943 of 4557 Old 02-20-2020, 12:05 AM
markmon1's Avatar
Quoted: 6779 Post(s)
Liked: 4888
Zoom works fine on the RS4500. I use it for all content that's not 16x9 and zoom to the whole 17x9 panel. You can set two separate installation memories, one zoomed one not and one button between the two. My automation software I wrote automatically selects the right preset via IP control based on the software detected aspect ratio of my content I play.
MDesigns likes this.
JVC Control - my software for controlling JVC projector via IP control.
Smart Masking - See my automatic smart screen masking system.
JVC IR Codes - free online pronto code converter for JVC IR codes.
markmon1 is offline
post #3944 of 4557 Old 02-20-2020, 12:41 AM
blake's Avatar
Liked: 155
Thanks for moving this over from the Lumagen thread. Very Interesting. I wonder if the deterioration in laser diode brightness over time relates more to heat issues or “sustained high brightness” type stress you may not necessarily induce in all use-cases. Has anyone actually documented light loss yet at 5000 or 10,000 hours ? Maybe if you keep this particular projector cool enough for example , the laser will last forever !
blake is offline
post #3945 of 4557 Old 02-20-2020, 01:00 AM
woofer's Avatar
Liked: 2809
Please PM me your email address and i will forward you some private info...thanks..
Email sent...
tigerhonaker likes this.
post #3946 of 4557 Old 02-20-2020, 01:55 AM
MDesigns's Avatar
Quoted: 294 Post(s)
Liked: 148
Thanks for correcting the wrong info I gave. It is just the DCR anamorphic features missing.
Lähetetty minun MRD-LX1 laitteesta Tapatalkilla
markmon1 likes this.
JVC DLA-RS500
MDesigns is offline
post #3947 of 4557 Old 02-20-2020, 04:09 AM
markmon1's Avatar
Liked: 4888
6000 hours? I am just a panty waist I guess at a mere 2038 hours on mine.
markmon1 is offline
post #3948 of 4557 Old 02-20-2020, 06:48 AM
tigerhonaker's Avatar
Quoted: 1069 Post(s)
Liked: 1320
Post
I thought I was a really-really high user but 6,000 hours, Wow !!!
I'm at something like 3,200 hours .............
Terry
tigerhonaker is offline
post #3949 of 4557 Old 02-20-2020, 08:25 AM
Craig Peer's Avatar
Liked: 10615
I'm at 1700 and change. Although I feel some movie marathon weeks coming soon !
post #3950 of 4557 Old 02-20-2020, 11:14 AM
woofer's Avatar
Liked: 2809
Yeah, his family basically just uses it as their main "TV" ...goes on in the morning and runs till late evening most days!..
post #3951 of 4557 Old 02-20-2020, 08:41 PM
markmon1's Avatar
Liked: 4888
So I got my ST130 G4 installed today. It's so much brighter than what I had. And I can't see any sparkles at all. I'm able to run the majority of my content on LOW LASER! HDR might need mid laser. Have to test where games will fall.
markmon1 is offline
post #3952 of 4557 Old 02-21-2020, 12:20 AM
woofer's Avatar
Liked: 2809
Hi Mark,
What is the "Real World" gain of this screen ?
I feel my bank balance dropping again.......
post #3953 of 4557 Old 02-21-2020, 12:51 AM
aka jfinnie
Quoted: 3357 Post(s)
Liked: 2604
Or keep it on the original laser setting that it seems you could live with and close the iris down for more contrast?
bobof is offline
post #3954 of 4557 Old 02-21-2020, 02:29 AM
markmon1's Avatar
Liked: 4888
Hi Mark,
I dont think I have the ability to measure this. But rumor is stewart's numbers are suppose to be reliable. I could send you my G4 screen sample material. I'm not sure how long it will take to get to AU. What screen do you have now? The other thing is that, on a pure white image, the pixel grid is sharper than it ever has been before. I feel like I have a new projector. And after adding that IB 12 in my seating for tactile in your back feeling I feel like i have a whole new theater haha.
This is certainly why I bought the 1.3 gain screen in the first place. But getting very satisfying results on low laser is temping since it uses up the light source slower. And on some stuff it looks perfect.
tigerhonaker and bobof like this.
markmon1 is offline
post #3955 of 4557 Old 02-21-2020, 03:05 AM
woofer's Avatar
Liked: 2809
My screen is an Oz Theatre screen https://www.projectorscreens.com.au ... its supposed to have a gain 1.26 BUT a few who have measured it say it smore like 1.1 real world.
I may take you up on the offer ( thanks ) of sending the G4 Sample......let me know for sure and i can give you postal details and pay freight costs..
post #3956 of 4557 Old 02-21-2020, 07:31 AM
blake's Avatar
Liked: 155
Did you get it microperf? Would that affected gain ?
blake is offline
post #3957 of 4557 Old 02-21-2020, 07:38 AM
Liked: 1320
Question
Mark,
Since this is the RS4500 thread do you mind elaborating more on the New screen buddy ???
(Meaning, I don't think any of us will get all that Up-Set)
If you did more Post about it on other threads please post those Links if you don't mind.
I'm interested .................
I wonder what would be the Real-World "Advantage" between my Stewart Firehawk 1.35-Gain and your New ST130 G4 ???
Would your's be BRIGHTER if I had it in my exact same size 16x9, 123" ???
Terry
post #3958 of 4557 Old 02-21-2020, 11:21 AM
Craig Peer's Avatar
Liked: 10615
Originally Posted by tigerhonaker View Post
Mark,
Terry
Yes. I went from a Firehawk to a StudioTek 130. Brighter, truer color. The key is making your room dark to use the ST130. You did that. You could probably just change out the material in your existing Stewart screen.
OzHDHT and tigerhonaker like this.
post #3959 of 4557 Old 02-21-2020, 12:32 PM
Liked: 1320
Post
Mark,
Terry
Craig,
When the guys lowered my screen I looked and it does have Buttons to hold the actual material to the frame.
So I think your correct just the actual Screen-Material could be switched.
Terry
post #3960 of 4557 Old 02-21-2020, 12:42 PM
Craig Peer's Avatar
Liked: 10615
Terry
Craig,
Terry
Un-snap the old material, snap in the new material. If you ever plan on getting Chad B back, do this first so he can re - calibrate with the new material.
