Official Sony VW885ES / VW760ES Owner's Thread - Page 168 - AVS Forum | Home Theater Discussions And Reviews
 3564Likes
post #5011 of 5642 Old 09-22-2019, 02:46 AM
Archibald1's Avatar
Quoted: 2098 Post(s)
Liked: 1142
Originally Posted by mobiousblack View Post
I heard rumors that the new firmware will enable proper laser dimming for those smokey black scenes. Has this been officially confirmed?
They are altering their curves to give better shadow detail, and I hope the dimming will be improved.
A question I have that 870 owners may be able to answer (assuming the new firmware doesn't add extra functionality) and that is: Can you manually control the iris or turn it off independent from the laser dimming?
“Remember to look up at the stars and not down at your feet. Be curious. And however difficult life may seem, there is always something you can do and succeed at. It matters that you don’t just give up."
Stephen Hawking.
Archibald1 is offline
post #5012 of 5642 Old 09-22-2019, 03:24 AM
Franin's Avatar
Quoted: 3316 Post(s)
Liked: 2174
This is all we can do
Cinema Black Pro Advanced Iris and Laser Setting
[ADVANCED IRIS] Dynamic Control: Adjusts the range of the laser light and iris (diaphragm). Full: Automatically adjusts the laser light, iris (diaphragm), and signal processing according to the brightness level of the input source and optimizes the amount of light. This results in a bright and high contrast image. Limited: Compared to “Full,” it suppresses the movement and brightness of the laser light and iris (diaphragm). This is suitable for viewing a picture in a dark room. Off: The “Dynamic Control” function is not applied. Laser Light Output: The higher the setting, the brighter the picture. The lower the setting, the darker the picture. Tip Contrast Enhancer [CONTRAST ENHANCER] Adjust “Laser Light Output” according to the brightness of the picture.
Sent from my iPhone using Tapatalk Pro
_________________________
God Bless!
Equipment: Bose Soundbar; 1951 Philco Model 50-T701 Black and White tabletop TV;Projection :HANIMEX ZOOM 8 MM PROJECTOR
Franin is offline
post #5013 of 5642 Old 09-22-2019, 03:29 AM
Archibald1's Avatar
Liked: 1142
Cheers.
That is a shame.
Lack of manual iris control I still find puzzling.
How often does your iris operate when set to full? I think I read somewhere it only really gets used below 1.5%ADL.
Is that correct or does it move fairly often?
Stephen Hawking.
post #5014 of 5642 Old 09-22-2019, 03:31 AM
Franin's Avatar
Liked: 2174
Cheers.
That is a shame.
Because my room is a dark room it set too limited Ive never done full too be honest
God Bless!
Franin is offline
post #5015 of 5642 Old 09-22-2019, 03:34 AM
Archibald1's Avatar
Liked: 1142
If you an have a little look at some point to see how often it actually does anything I would aporeciate it.
I can't imagine it moves at all except for very dark scenes.
Stephen Hawking.
post #5016 of 5642 Old 09-22-2019, 03:39 AM
Franin's Avatar
Liked: 2174
Will do, Ive never played around with it. Might do it soon try it on my ghost in the shell dark scene ( very low light scene ) to see how it goes. Will report back
God Bless!
Franin is offline
post #5017 of 5642 Old 09-22-2019, 04:03 AM
Archibald1's Avatar
Liked: 1142
Cheers.
Stephen Hawking.
post #5018 of 5642 Old 09-22-2019, 04:57 AM
Franin's Avatar
Liked: 2174
Cheers.
I’m trying it now and Full setting is actually better. I was actually going by the manual. Need to do more testing but so far so good
God Bless!
Franin is offline
post #5019 of 5642 Old 09-22-2019, 05:14 AM
Archibald1's Avatar
Liked: 1142
Cheers.
I’️m trying it now and Full setting is actually better. I was actually going by the manual. Need to do more testing but so far so good
Cool. How much is the iris actually doing though? Does it move a lot, or only on really dark scenes?
Stephen Hawking.
post #5020 of 5642 Old 09-22-2019, 05:47 AM
Franin's Avatar
Liked: 2174
To be honest I don’t notice it moving. When I tried limited to full I noticed the difference but I still have to try some more. Something that is bright than straight to dark.
God Bless!
Franin is offline
post #5021 of 5642 Old 09-22-2019, 05:50 AM
Archibald1's Avatar
Liked: 1142
Cheers
Stephen Hawking.
post #5022 of 5642 Old 09-22-2019, 09:30 AM
Franin's Avatar
Liked: 2174
Cheers
Ive tried another where a scene changes from dark too light straight away and seems to be very quick.
God Bless!
Franin is offline
post #5023 of 5642 Old 09-22-2019, 10:41 AM
Archibald1's Avatar
Liked: 1142
By that, you mean the iris operates quickly I assume?
Stephen Hawking.
post #5024 of 5642 Old 09-22-2019, 01:59 PM
SJHT's Avatar
Quoted: 1131 Post(s)
Liked: 756
Cheers.
That is a shame.
I believe the reason stated in the 5000 forum was heat related. Although these units are likely lower temp, but still maybe the same reason. SJ
SJHT is offline
post #5025 of 5642 Old 09-22-2019, 02:30 PM
Franin's Avatar
Liked: 2174
Yes
Archibald1 likes this.
God Bless!
Franin is offline
post #5026 of 5642 Old 09-22-2019, 03:02 PM
Archibald1's Avatar
Liked: 1142
Yes
Cool.
If you pause it on the dark scene, does the iris stay closed?
Stephen Hawking.
post #5027 of 5642 Old 09-22-2019, 04:49 PM
Franin's Avatar
Liked: 2174
Cool.
I never tried that will have too tonight.
God Bless!
Franin is offline
post #5028 of 5642 Old 09-23-2019, 01:19 AM
Franin's Avatar
Liked: 2174
Started reading an article about the dynamic iris on Sony projectors they wrote Dynamic Full Brightness : N/A and Limited brightness 0-99. While having it off reverts to iris manual control using Brightness 0-99. Is that true ?
God Bless!
Franin is offline
post #5029 of 5642 Old 09-23-2019, 02:33 AM
Slinkywizard's Avatar
Quoted: 72 Post(s)
Liked: 57
Originally Posted by Dan Howdle View Post
After one day with this projector I thought I'd share my initial impressions as so many new owners have done earlier in the thread. My basis for comparison is my previous projector, a VW260/285ES.
Pros:
* Well, it's a lot brighter, isn't it. And that extra brightness really can be put to some good uses: HDR and 3D benefit expecially, but games also take on a far more vibrant, rich and solid-looking quality than my previous projector
* Image stability is also very noticeble. I wasn't sensitive to lamp microflicker, but I do notice when it's not there
* 3D is astonishing once properly tweaked – Avatar is still the gold standard and I've never seen it looking like that. Absolutely mesmerising
* It does really very well indeed with HDR. It's very noticeable running HDR versus SDR where it all felt pretty much the same with my previous projector. Nice not to have to fall back on external mapping of any kind. I know some of you swear by it, but I'm genuinely happy with the internal HDR curves right now – at least until its calibrated
* This thing does colour like nothing I've ever seen in a projector. Absolutely eye-melting colour reproduction (albeit a lot of red push at the mo as not yet calibrated)
* Decent enough blacks in MOST situations
* It's quiet enough I don't notice it so long as there are other sounds in the room
Cons:
* I know there was a lot of back and forth in this thread and the other regarding its black performance in near-dark scenes and I totally concur with @Bandyka on this. Perceived contrast in low light scenes is pretty awful. Just try watching a dark show like Sabrina or Carnival Row and this PJ does not do well at all. Obviously, the new firmware is looking to address precisely this, so I will leave that there
* The OOTB colours are quite a long way off. Like, I'm an amateur/enthusiast with an amateur's eye and yet I can see how far off it is
Other than that, looking forward to the weekend. The Mrs and I are going to watch the Hobbit trilogy in 3D – she hasn't seen it. So a bit of a marathon. I've no doubt this will be my projector for the next five years or so. Roll on the firmware!
I take back some of this. Turns out that both those shows, especially Carnival Row, were graded poorly and have a widely reported elevated black floor at the source. Have since watched a fair amount of low-light stuff that looks great.
VISION: Sony VPL-VW760ES, 133" 1.9:1 screen | AMPLIFICATION: Denon AVC-X8500H, 7.5.6; two subs, plus Earthquake XJ-300ST and 3xADS Maximus Shakers | DEVICES: Oppo 203 UHD BD player, Apple TV 4K, Gaming PC w/i7700k CPU, NVIDIA RTX 2080ti | SPEAKERS: 6xSVS Prime Bookshelf, 2xSVS PB-2000 subs, SVS Prime Centre, 6xSVS Prime Elevation
Slinkywizard is offline
post #5030 of 5642 Old 09-23-2019, 03:06 AM
Archibald1's Avatar
Liked: 1142
I think that will only apply to the lamp based projectors, who's only control over dimming is the iris. They have no direct light source control.
Stephen Hawking.
post #5031 of 5642 Old 09-23-2019, 03:11 AM
Archibald1's Avatar
Liked: 1142
You will find that these laser projectors do one thing exceedingly well and that is to show up poor source content in all it's glory!
It is the same as Hi-Fi. Rubbish in, rubbish out. Which gets made all the worse if you have kit that shows up all flaws in bad source material.
Stick on a well mastered 4k DI UHD disc, using the same settings, straight afterwards (say Mortal Engines) and you will see what superlative images these can produce with decent source material.
Dan Howdle likes this.
Stephen Hawking.
post #5032 of 5642 Old 09-23-2019, 03:13 AM
Quoted: 72 Post(s)
Liked: 57
Mortal Engines, though... *shudders*
post #5033 of 5642 Old 09-23-2019, 03:53 AM
Archibald1's Avatar
Liked: 1142
Not the best movie no, but you know what, I found it entertaining enough and it makes for excellent demo material.
Stephen Hawking.
post #5034 of 5642 Old 09-23-2019, 04:49 AM
Archibald1's Avatar
Liked: 1142
Hi @Kris Deering .
Just wondering if you will be updating your S&V review of the 885/760 at some point after the new firmware hits?
Stephen Hawking.
post #5035 of 5642 Old 09-23-2019, 05:33 AM
Franin's Avatar
Liked: 2174
Oh okay
God Bless!
Franin is offline
post #5036 of 5642 Old 09-23-2019, 05:43 AM
Archibald1's Avatar
Liked: 1142
Oh okay
Where did you find this article BTW, as I wouldn't mind a read myself....
Stephen Hawking.
post #5037 of 5642 Old 09-23-2019, 05:48 AM
Franin's Avatar
Liked: 2174
I was at work and had a bit time. I googled Sony Projector Dynamic iris limited vs full. I’ll have to check the history on the computer to get the link tomorrow. But being its only for bulb ( silly me I was under the impression it worked for laser as well ) well then it doesn’t apply for us anyway.
God Bless!
Franin is offline
post #5038 of 5642 Old 09-23-2019, 05:49 AM
Franin's Avatar
Liked: 2174
Too be honest i would like to get a good understanding how it all works for laser
God Bless!
Franin is offline
post #5039 of 5642 Old 09-23-2019, 06:10 AM
Archibald1's Avatar
Liked: 1142
Would still like a read anyway as these things are always interesting.
Stephen Hawking.
post #5040 of 5642 Old 09-23-2019, 06:13 AM
Archibald1's Avatar
Liked: 1142
From what I can make out they have just enlisted the help of the iris below 1.5% ADL to give black levels a bit of help.
And from what you have said so far, it seems like the iris doesn't even come into play except for the darkest scenes and the laser dimming is still responsible for the lions share of the work.
I hope the new firmware 'tones and tucks' the operation of the laser dimming so it is a bit more effective. A bit like JVC did with the Z1.
Separate controls for the iris and laser would be even better mind you......
Stephen Hawking.
