AVS Forum | Home Theater Discussions And Reviews (https://www.avsforum.com/forum/)
-   Ultra Hi-End HT Gear ($20,000+) (https://www.avsforum.com/forum/86-ultra-hi-end-ht-gear-20-000/)
-   -   Ken Whitcomb Sony 5000es Stack Sonneborn Theater (https://www.avsforum.com/forum/86-ultra-hi-end-ht-gear-20-000/2944060-ken-whitcomb-sony-5000es-stack-sonneborn-theater.html)
Art Sonneborn 12-22-2017 12:37 PM
Through the preliminary work side by side Sony 5000 stack in my theater. Demolition and electrical move on Monday , installation of enclosure on Tuesday, larger opening velvet covering into theater and clean including trim on Wednesday. Ken started to work on Thursday afternoon getting alignment mechanically (very precise leveling indeed).
I've had one 5000 since May of 2016 so with a little chat with Chris Cooley I'm on my way to another level. Chris has the same thing in progress in his theater.
Saw a foretaste yesterday !!!
We are hoping to watch some HDR etc this evening.
Stay tuned more to come !
http://i127.photobucket.com/albums/p...psr8rlj2r6.jpg
thebland 12-22-2017 12:38 PM
[golf clapping]
See you sometime next year!
Art Sonneborn 12-22-2017 01:13 PM
http://i127.photobucket.com/albums/p...pscg8axlbh.jpg
Enclosure from bathroom side. Enclosure is suspended from the roof trusses with anti-vibration bushings interposed .
Art Sonneborn 12-22-2017 01:15 PM
Art Sonneborn 12-22-2017 01:18 PM
Originally Posted by thebland (Post 55366562)
[golf clapping]
I hope so ! I think this may factor into your considerations for the projection in your new theater.
Art
Art Sonneborn 12-22-2017 01:31 PM
Ash Sharma 12-22-2017 04:31 PM
Pretty Cool..
Merry X Mas Y'all
Steve Bruzonsky 12-22-2017 05:31 PM
EGADS!!! Very impressive. I am most jealous! Congrats!!!!
Ash Sharma 12-22-2017 08:18 PM
I love the way the projectors look 'Drooling'....
mani 12-22-2017 11:23 PM
Hi Art
Can you please check the power used with both projectors combined at 70,80 and 90 % laser
mmiles 12-23-2017 05:12 AM
Curious what is the best stacking layout?
Side by side, side by side at a slight inward angle or stacked vertically?
joerod 12-23-2017 06:16 AM
This is really cool. Proof again that two is better than one.
Maybe we should have this thread merged into the one that Ken already started so we can have a “master” stacked 5000 thread?
Art Sonneborn 12-23-2017 07:47 AM
Ken can answer this better but I think he will say that vertically is probably better since the lenses are significantly closer together than when stacking horizontally. My room could have been modified for the vertical configuration but it would have changed the architecture more than I wanted . Sony , however, has designed them to be used in a quad stack which obviously has two side by side and two sitting on top of them so either works as evidenced by how unbelievable Hacksaw Ridge looked last night.:D
Art
ccool96 12-23-2017 08:11 AM
Art
I would say that’s exactly right, from my experience in testing both scenarios with Ken.
Over/under is slightly easier because the lens are quite a bit closer than side by side.
But like Art said, they were designed to quad stack, and side by side works equally well.
Side by side configuration is just a little more time consuming on set up.
Like Art’s room, my room’s design makes a side by side setup the best choice.
Sent from my iPhone using Tapatalk Pro
Art Sonneborn 12-23-2017 11:50 AM
Originally Posted by mani (Post 55368558)
Hi Art
Sorry Mani,
I don't have a way ,at present ,to check that.
Art
donaldk 12-23-2017 03:44 PM
Quad stack? You are sure that would not be a quad blend or mix of vertical stack with side by side blend?
mani 12-23-2017 04:35 PM
1 Attachment(s)
Hi Art
Sorry Mani,
Art
Hi Art
Something like this will take a quick measurement ( attached pic) . Whenever you get a chance in future .
Also very interested to know how much higher does black level go up with the stack - both measured and perceived
Mani
ccool96 12-23-2017 04:57 PM
Originally Posted by mani (Post 55371952)
Hi Art
Mani
Hey Mani,
I have a Kill-a-watt meter. I can measure mine. I measured mine a while back but can’t remember if I took notes.
You would certainly need to have two separate circuits to run them both at full power.
ccool96 12-23-2017 05:00 PM
They support multiple configurations but they certainly support a quad stack. All 4 creating the full image, and all 4 perfectly overlaid.
Art Sonneborn 12-23-2017 05:07 PM
Watching some familiar material here tonight. The Martian....I love this movie ! Anyway , just spectacular ! Only time will tell but so far this is quite a move up. The black floor looks interestingly unaffected this is subjectively only at this point ; I'm looking at space etc. next to the Velux screen and masking borders while highlights cause my iris to clamp down.
Art
mani 12-23-2017 05:17 PM
25 Attachment(s)
Hi Art
Mani
Hey Mani,
I have a Kill-a-watt meter. I can measure mine. I measured mine a while back but can?t remember if I took notes.
That is what I want to know . If you go by the Sony specs both projectors combined should consume 2.4 KW which should be max capacity for 20 amp circuit which I have in my hush box . So If both projectors run at 60-70% , I am assuming one dedicated 20 amp circuit should be enough ? . To run a new circuit in my hush box will be impossible , as all my dedicated theater circuits come from 240V 100 amp panel from Ground1 with isolation transformer built in . I don?t want to put any theater equipment on the circuits from the rest of the house to keep the grounding completely separate .
mani 12-23-2017 05:24 PM
25 Attachment(s)
Art
You mean your Iris , not projectors [IMG class=inlineimg]https://www.avsforum.com/forum/images/smilies/smile.gif[/IMG] [IMG class=inlineimg]https://www.avsforum.com/forum/images/smilies/smile.gif[/IMG]
thebland 12-23-2017 05:40 PM
This sounds like stacked CRT performance.
D6500Ken 12-23-2017 07:40 PM
So here are some numbers to feast your eyes on:
39 fL in SDR at 50% laser drive
71 fL in HDR at 100% laser drive
Reference picture mode is used for SDR, and it’s settings were copied to User 1 for HDR. Direct access to these modes was added to the iRule system (manually for now). I call the Reference mode in a macro when any non-UHD source is selected.
Currently the projectors are doing HDR mapping, but Lumagen’s HDR Intensity Mapping will be added on the next visit. Art will have multiple options for viewing HDR content.
Ken Whitcomb
mani 12-23-2017 08:15 PM
Reference picture mode is used for SDR, and it?s settings were copied to User 1 for HDR. Direct access to these modes was added to the iRule system (manually for now). I call the Reference mode in a macro when any non-UHD source is selected.
Currently the projectors are doing HDR mapping, but Lumagen?s HDR Intensity Mapping will be added on the next visit. Art will have multiple options for viewing HDR content.
Ken Whitcomb
Hi Ken
How about the black level
Art Sonneborn 12-24-2017 06:13 AM
When Ken left we had remote functionality both projectors switching from input to input predictably and alignment as the priorities ;
I don't remember him saying he measured black level.
Art
Art Sonneborn 12-24-2017 07:30 AM
Art Sonneborn 12-24-2017 07:34 AM
Art Sonneborn 12-24-2017 07:35 AM
Powered by vBulletin® Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
