Panamorph DCR Paladin Owners Thread - Page 31 - AVS Forum | Home Theater Discussions And Reviews
 366Likes
post #901 of 1051 Old 03-28-2019, 07:45 AM
ScottieBoysName's Avatar
Quoted: 1138 Post(s)
Liked: 317
Originally Posted by DLCPhoto View Post
Craig confirmed the real-world improvement of around 38%.
I've previously checked with Shawn Kelly of Panamorph, who indicated that you can tweak the adjustment when installing the DCR lens to fill a 2.35:1 screen, so you're good there.
For 16:9 content, with the lens in place, the RS1000/2000/3000 do not have the proper Anamorphic mode to properly display this content uncropped, with the original aspect ratio. Your choice is a small 6% 'squeeze', a 25% or so 'stretch', or cropping the top and bottom 10% of the 16:9 content to completely fill the 2.35:1 screen. This should be fixable, but thus far JVC has not indicated any plan to do this via firmware update.
The other alternatives are to physically remove the lens for 16:9 content, either manually (or using a CineSlide or similar device to do it automatically), or to get a Lumagen Radiance Pro to handle the anamorphic scaling (as well as get some other benefits).
And 3D content is also not handled properly with current JVC anamorphic modes, unfortunately, with the same work-arounds as with 16:9 content above.
Going with the standard Paladin lens would avoid these limitations, but limit you to about a 30% increase in brightness, and require a longer throw distance (1.6 x screen width vs 1.4 x with the DCR).
Is there a Cineslide model or part number that is recommended/suggested for the new JVCs along with the Panamorph DCR?
ScottieBoysName is offline
post #902 of 1051 Old 03-28-2019, 01:40 PM
DLCPhoto's Avatar
Quoted: 1567 Post(s)
Liked: 696
No specific model as such, but you can get in touch with them directly, and they can let you know the cost and logistics. It is a custom job, and my understanding is that they would have to make some modifications to the Lens/Mount to work with the CineSlide. So it would need to be either bought from them, or sent to them. At least that's how it worked when I last communicated with them a month or two ago.
JVC RS400, Marantz SR7010, Screen Innovations 160" 2.35:1 Screen
Front L/R: Duntech Sovereigns, powered by 2 bridged Adcom GFA-555
Center: Revel C208 powered by Cambridge Audio Azur 851W
Dolby Bed (4): Sony Core SS-CS5, Atmos (4): Ascend Acoustics CBM-170 SE
Subwoofer: DIY 8' sub with 4 18" SI Drivers, powered by iNuke 6000
DLCPhoto is offline
post #903 of 1051 Old 03-28-2019, 03:10 PM
Liked: 317
Gotcha. Thanks!
post #904 of 1051 Old 03-28-2019, 05:42 PM
Quoted: 56 Post(s)
Originally Posted by Wookii View Post
Try the NX9, that has them. Remote codes are common across all JVC PJ’s.
Good idea. The NX9 didn’t have them but the RS640U works perfect. And has quick buttons for HDR, Cinema and Natural Modes.
Tward2 is offline
post #905 of 1051 Old 03-29-2019, 07:23 AM
Quoted: 56 Post(s)
How do you change the resolution to 4096 on the JVC RS1000?
Tward2 is offline
post #906 of 1051 Old 03-29-2019, 08:13 AM
AlterBridge86's Avatar
Quoted: 56 Post(s)
Liked: 56
I'm stumbling through setup on my RS2000 right now too, but I believe setting it to Anamorphic C makes it use the full 4096 panel width. At least that's what I got out of the user manual
AlterBridge86 is offline
post #907 of 1051 Old 03-29-2019, 08:36 AM
Quoted: 56 Post(s)
That’s what I thought but I’ve seen some videos where it shows 4096 in the info section and mine doesn’t when on Anamorphic C.
Tward2 is offline
post #908 of 1051 Old 03-29-2019, 09:40 AM
Quoted: 56 Post(s)
Liked: 56
I think the info section is just reporting the input signal. Users with an HTPC can actually feed a 4096x2160 signal into the projector, but if you're using a non-htpc device you most likely can only send the 3840x2160 image. The Anamorphic C stretches the image to use those additional pixels, which the DCR then squishes back into a normal looking image. At least that's what I think is going on
post #909 of 1051 Old 04-01-2019, 08:04 AM
thebland's Avatar
Quoted: 2211 Post(s)
Liked: 1418
INSTALLATION QUESTION.
What is involved in installing this to a Sony 5000? Sony will be sitting on a shelf.
Goodbye to a great audio and video genius and writer... JOHN GANNON. I enjoyed your friendship, wit and a nice long run we took around Indianapolis at CEDIA years back... and for buying my Runco 980 Ultra years back... you saved my ass! Rest in peace.
thebland is online now
post #910 of 1051 Old 04-01-2019, 08:04 AM
thebland's Avatar
Liked: 1418
What is involved in installing this to a Sony 5000? Sony will be sitting on a shelf. You tube video?
post #911 of 1051 Old 04-01-2019, 10:44 AM
Craig Peer's Avatar
Quoted: 6736 Post(s)
Liked: 7869
I would think you could attach the included mounting plate to the bottom of the projector - or rig up a mount to the shelf using the included U bracket.
Name:	Panamorph Paladin DCR lens 1.jpg
ID:	2547430   Click image for larger version
Name:	Panamorph Paladin DCR lens 2.jpg
Craig Peer is online now
post #912 of 1051 Old 04-01-2019, 12:11 PM
thebland's Avatar
Liked: 1418
Got it. So it comes with a plate that will adapt to Sony 5000?
post #913 of 1051 Old 04-01-2019, 01:08 PM
Craig Peer's Avatar
Liked: 7869
It says " sandwich mount " for the VW5000 - https://www.panamorph.com/vpl-vw885-vw695-vw995/
You might give Shawn an email or call to clarify how to best attach to the VW5000.
post #914 of 1051 Old 04-01-2019, 04:52 PM
thebland's Avatar
Liked: 1418
Will do. Is that ‘sandwixh’ mount included in the box when purchasing the lens? Thanks!!
post #915 of 1051 Old 04-01-2019, 06:45 PM - Thread Starter
Ash Sharma's Avatar
Quoted: 996 Post(s)
Liked: 690
Ash Sharma is online now
post #916 of 1051 Old 04-01-2019, 08:28 PM
Craig Peer's Avatar
Liked: 7869
Yes. If you are shelf mounting and the lens mount requires it to be " sandwiched " between the Chief mount and the projector, you might be able to attach the mounting plate to the shelf instead, one way or another.
post #917 of 1051 Old 04-02-2019, 03:52 PM
appelz's Avatar
Quoted: 608 Post(s)
Liked: 633
Nah, that wouldn't really work. On the handful of 5000's I've installed that were shelf mounted, the lens mounting plate got tossed. I suppose if you were able to mount that plate so it extended past the front of the shelf it would work, but all of these were in projection rooms, and the shelf ended at the port glass/wall.
That mount has holes that match on smaller projectors, but unless you are clamping it between the projector and the mounting plate, not much use with the Sony 5000.
Adam Pelz ,Acoustic Mafia - Hear No Evil
JBL Master ARCOS Calibrator, CEDIA Designer, Home Acoustics Alliance Instructor LIII, THX HT1+ HT2+ Video, Level III Trinnov Altitude Calibrator
Mercenary Calibrator for Manufacturers, Integrators and System Owners
appelz is online now
post #918 of 1051 Old 04-03-2019, 09:56 AM
Craig Peer's Avatar
Liked: 7869
True - if there is a hush box / projection closet, another solution needs to be created. That's what I did - I couldn't use the plate either. Just the U bracket, which worked quite well by the way.
appelz likes this.
post #919 of 1051 Old 04-05-2019, 06:16 AM
rola's Avatar
Quoted: 43 Post(s)
Liked: 26
Hi All
I’m on a couple af days visit to Manhattan New York.
Anyone know of a Shop or installer were one can take a look at these lenses?
rola is online now
post #920 of 1051 Old 04-06-2019, 09:36 AM
tomasg's Avatar
Quoted: 16 Post(s)
Does have Paladin DCR perfectly focus in both directions? I read that prism based anamorphic lenses have problem with astigmatism. Or is there any correction element?
tomasg is offline
post #921 of 1051 Old 04-09-2019, 10:21 AM
Shawn Kelly's Avatar
Quoted: 173 Post(s)
Liked: 110
Panamorph lenses integrate both prism and cylindrical technologies. Yes, they are designed to focus perfectly in both directions throughout a broad range of home theater throw distances.
Shawn Kelly
Panamorph, Inc.
www.panamorph.com
[email protected]
Shawn Kelly is offline
post #922 of 1051 Old 04-11-2019, 12:33 PM
Stottle76's Avatar
Hi Guys,
I'm new to JVC and anamorphic lenses and after reading this thread I have a couple of questions.
I currently have a RS2000 and DCR lens on order along with a Stewart StudioTek 130 G3 2.40:1 screen 139.25" wide. The projector will be mounted about 210" from the screen for about a 1.5 throw.
My first question is about viewing 16:9 content. I understand the Anamorphic B will have about a 6% 'squeeze' and Anamorphic C will have about 10% over scan on the top and bottom of the screen. Would it be possible with Anamorphic C to zoom down the image to show the full 16:9 content on the screen without the 6% width compression?
The second question is about 3D through the DCR lens. Since JVC has stated the Anamorphic C is not compatible with 3D what is the best way to watch 2.40:1 and 1.85:1 3D content with the lens in place?
cargen likes this.
Stottle76 is offline
post #923 of 1051 Old 04-11-2019, 07:46 PM
jason4vu's Avatar
Quoted: 131 Post(s)
Liked: 218
Originally Posted by Stottle76 View Post
Hi Guys,
No, that isn't possible if I'm understanding your question correctly. I will be removing the lens when watching 16x9 content as it is noticeably narrower. Of course, you can also use anamorphic c and just crop off the top of the image and watch it in 2.40 mode. In a lot of scenes you probably won't even notice that its not 2.40 material
jason4vu is offline
post #924 of 1051 Old 04-11-2019, 08:55 PM
Liked: 317
Hi Guys,
Is this correct? Anamorphic C will over scan?
I thought with the lens in place Anamorphic C was the correct mode to watch scope content in, being that it would be presented “untouched”.
post #925 of 1051 Old 04-11-2019, 10:23 PM
Stottle76's Avatar
Having no experience with an anamorphic lens I certainly don't know how all this works together and what you can or cannot do. My first thought would be to zoom down "shrink" the 16x9 image in Anamorphic C mode to fit the 10% over scan onto the screen creating black bars on the sides. Basically just the reverse of the zoom meathead used to fill a 2.40 screen width without an anamorphic lens. There are a lot of people here that really know what they are doing so I guess that is not possible or it would have been suggested already. When projecting through an anamorphic lens does the zoom not function like it does without the lens? Is there some sort of distortion or change in light path that causes issues? Thanks.
I was just talking about 16x9 content in Anamorphic C mode. I believe that Anamorphic C perfectly matches scope content to the screen.
post #926 of 1051 Old 04-11-2019, 11:05 PM
Stottle76's Avatar
Thanks for the reply. Having no experience with anamorphic lenses so I don't know what you can and cant do. My first thought of how to handle 16x9 material through the DCR lens would be to leave it in Anamorphic C and zoom down "shrink" the image so that the 10% crop on top and bottom fit onto the screen. Basically just the reverse of the zoom method used to fill a 2.4:1 screen without an anamorphic lens. Does the zoom function not work the same when projecting through an anamorphic lens or is there some other issue I'm not aware of?
post #927 of 1051 Old 04-12-2019, 03:15 AM
DLCPhoto's Avatar
Liked: 696
Using Anamorphic C with 16:9 content will remove the top and bottom 10% of the picture, which is what it does with 2.40:1 content. In the latter case, it's removing the black bars, in the former case, it's removing actual content.
Zooming is not relevant, because the Anamorphic mode is 'stretching' the central content part of the 2.40:1 content (that is the area inside the black bars), to virtually the full height of the chip. The lens, the 'vertical compression' type, then 'squeezes' it back down to its original aspect ratio. You are therefore using the full array of pixels on your chip (increasing both pixel density and light output), whereas before you were throwing away the pixels occupied by the black letterbox bars.
The Projector doesn't "know" if this is 16:9 or 2.40:1 content. It 'throws away' the area of that letterbox area, and it can't be reclaimed.
So with 16:9 content, you either use Anamorphic B, with the result being a 6% horizontal Squeeze, or Anamorphic C, which will maintain proper anamorphic ratio, at the cost of throwing away the top and bottom 10% of content.
Without an external video processor like the Lumagen Radiance Pro, there is no way of avoiding some type of compromise here. And even the Lumagen doesn't solve the problem with 3D content, such that a 6% squeeze is unavoidable no matter what you do, when used with the DCR lens.
To avoid these compromises, you have to remove the DCR from the lens path.
I will buy the RS2000 or its successor, if and only if, JVC provides the proper Anamorphic modes for all content. Removing the lens from the path is not an acceptable option for me, while it may be for others.
DLCPhoto is offline
post #928 of 1051 Old 04-12-2019, 03:52 AM
Wookii's Avatar
Quoted: 2898 Post(s)
Liked: 2104
Why is that? I must admit I've never tested in, but I would have thought the Lumagen could scale as necessary, even for 3D content?
Wookii is offline
post #929 of 1051 Old 04-12-2019, 04:04 AM
Liked: 317
Ok whew! Yes, I remove the lens for 16:9. I use Anamorphic C for scope. Glad I’m doing that right.
post #930 of 1051 Old 04-12-2019, 04:12 AM
DLCPhoto's Avatar
Liked: 696
I don't understand the complexities of this, but have communicated with those who do. Kris Deering indicated "The Lumagen will do whatever you want, but the JVC won’t accept a 4096 3D input and it won’t scale 3D to 4096. The JVC will only accept 3D as 1080p."
Bottom line, though, is that 3D is problematic for the new JVC Projectors when used with the DCR lens. You can pursue this further on the Lumagen thread, for a more complete explanation, and to confirm that this is the case. But this is my understanding, which was also confirmed by Shawn Kelly of Panamorph.
DLCPhoto is offline
