Panamorph DCR Paladin Owners Thread - Page 33 - AVS Forum | Home Theater Discussions And Reviews
 347Likes
post #961 of 1027 Old 04-26-2019, 01:35 PM
thebland's Avatar
Quoted: 2175 Post(s)
Liked: 1366
So Sony (5000ES) internal software stretches ideally without use of a video processor? Any aberrations and are the crisp edges after set up?
Anyone using with a Panny 820 or 9000 - or any differences between the players?
Goodbye to a great audio and video genius and writer... JOHN GANNON. I enjoyed your friendship, wit and a nice long run we took around Indianapolis at CEDIA years back... and for buying my Runco 980 Ultra years back... you saved my ass! Rest in peace.
thebland is offline
post #962 of 1027 Old 04-26-2019, 03:02 PM
Craig Peer's Avatar
Quoted: 6553 Post(s)
Liked: 7574
The further back you can mount from minimum throw, the " crisper " the edges.
Th601 likes this.
Craig Peer is offline
post #963 of 1027 Old 04-27-2019, 08:48 PM
Th601's Avatar
Quoted: 79 Post(s)
Liked: 25
Beginner question: I’ve been reading about the Paladin DCR lens and it said that edge distortion decreases with higher throw ratios and is very difficult to see above 1.8:1. My room is 18’6” long. My projection screen is a 130” scope screen and is 120” wide. A throw ratio of 1.8:1 would be 18’ for me. Minimum throw distance is 14’ I believe. Will I see edge distortion if my projector is at 16’ throw distance? Sorry if this seems like a silly question. I’m new to all this and trying to learn as much as I can.
Th601 is online now
post #964 of 1027 Old 04-28-2019, 06:52 AM
Quoted: 172 Post(s)
Liked: 152
Yes, but you can try some zone adjustment, masking on the projector or overscan onto the felt boarder/frame to hide it if desired.
NX5 / Panamorph / SI Slate Zero Edge Pro / Salamander Designs / AQ Niagra
AV8805 / UB9000 / AppleTV 4K / PS4 Pro / Connect / Node 2i / RPM-10 C
C1100 / D1100 / MC303s / 800D3 / HTM1D3 / 702 S2 / CCM7.3 / PC4000s
RaceCarDriver is offline
post #965 of 1027 Old 04-28-2019, 11:16 AM
Craig Peer's Avatar
Liked: 7574
There was a time when any edge distortion from an A lens would bother me. But the picture looks so good on my RS4500 with the DCR lens, it just doesn't bother me at all. It's on the sides - the top and bottom are more or less perfect. This is at minimum throw even. I just don't notice it. Plus, it's in the black screen masking anyway - zoom it off a little bit.
OzHDHT and Th601 like this.
post #966 of 1027 Old 04-30-2019, 08:54 AM
Quoted: 56 Post(s)
Is anyone using a Nvidia Shield and a new JVC projector with the DCR? If so how are you playing your content? I have my whole collection ripped to an Unraid server and have been playing back via Plex. Lately I’m getting a message about my connection being too slow and I have to change anamorphic settings to see the menus and change back on widescreen movies. Also I have to change the video settings between natural or hdr depending on content. I downloaded Kodak yesterday on the Shield and it seems to be working better than Plex right now. Automatically changes color space and refresh rates. Is there anyway to set it for 2.35 aspect so the menus and everything show up so I can leave the projector set on Anamorphic C?
Tward2 is offline
post #967 of 1027 Old 05-01-2019, 03:05 PM
Craig Peer's Avatar
Liked: 7574
You might post this question in the new JVC projector thread ( if you haven't already ).
post #968 of 1027 Old 05-01-2019, 03:38 PM
Quoted: 56 Post(s)
Ok thanks.
Tward2 is offline
post #969 of 1027 Old 05-05-2019, 09:14 PM
Quoted: 26 Post(s)
Liked: 3
Minimun throw distance
I see that the minimum throw for the DCR lense is 1.4x width. Would there be a big issue if I were short of that minumum by 6 inches? I can go a bit smaller and reach the minimum if absolutely necessary.
Steezo Jay is offline
post #970 of 1027 Old 05-06-2019, 05:06 AM
Quoted: 82 Post(s)
Liked: 57
If you are shorter than the minimum why would you want to go shorter?
It is confusing how you are asking this, 1.4 is the minimum throw distance (120" wide screen = 168" min throw for example from the projector lens itself, don't add for the thickness of the dcr lens), you can go farther away all you want, you just don't want to go shorter distances away from the minimum, you may loose the ability to overscan your screen border and may not be able to correct distortion added by the lens. The farther away the less perceived distortion you will get with the lens, Note: This is why i had to go to the DCR over just the Paladin for my RS4500 i already had the mount location for an NX9/RS3000 in mind trying to avoid buying a lumagen - the Paladin lens would have caused me to have to move the mount back approx 2' more 1.6 min throw x screen width.
Steezo Jay likes this.
SSnarski is offline
post #971 of 1027 Old 05-06-2019, 08:00 AM
Quoted: 26 Post(s)
Liked: 3
Thanks, I meant to say smaller screen size. I'll keep the screen size that would be within the minimum throw distance.
Sent from my SM-G975U using Tapatalk
post #972 of 1027 Old 05-06-2019, 08:05 AM
Quoted: 82 Post(s)
Liked: 57
After i posted my response and re-read your post, i sort of figured out what you meant, but it was too late as i had already sent my response. LOL
SSnarski is offline
post #973 of 1027 Old 05-07-2019, 09:49 PM
Scott KL's Avatar
Quoted: 36 Post(s)
Could someone please PM me the best place to get a good price on this lens. I would like to increase the light output on my 2.40 screen using a JVC N7 projector. Preferably a dealer that can ship overseas but I can get it delivered to a relative in the US if required. I am no immediate rush so can wait for any sale that comes up. Thanks.
JVC DLA-N7 | Screen Research ClearPix 4K 130" 2.40 | Pioneer VSX-LX503 | Crown DCi 8|300N | 7.2.4 JBL 708i(3)+705i(4); JBL Control 328C (Atmos); Subwoofer Syzygy SLF-870 x 2 | Ferco seating
Scott KL is offline
post #974 of 1027 Old 05-09-2019, 04:51 AM
mitchlampert's Avatar
Quoted: 69 Post(s)
I installed my Paladin last night but the space where it has to be mounted is too small to fit a screwdriver, so the screws are only hand tight (using a phillips driver bit). Any suggestions about tiny drivers to get at the screws would be great! I think the lens is slightly lower on the right. Otherwise, what a difference from my previous setup using the Panamorph 480! Maybe a slight bit brighter but the clarity is so much better!
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Craig Peer and Mike_WI like this.
mitchlampert is offline
post #975 of 1027 Old 05-09-2019, 05:26 AM
Mike_WI's Avatar
Quoted: 432 Post(s)
Liked: 410
Originally Posted by mitchlampert View Post
I installed my Paladium last night but the space where it has to be mounted is too small to fit a screwdriver, so the screws are only hand tight (using a phillips driver bit). Any suggestions about tiny drivers to get at the screws would be great! I think the lens is slightly lower on the right. Otherwise, what a difference from my previous setup using the Panamorph 480! Maybe a slight bit brighter but the clarity is so much better!
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Looks good.
Many options for flexible screwdriver extensions
eg
https://www.amazon.com/Flexible-Exte...-2-spons&psc=1
HT: Oppo UDP-203 -> Lumagen RadiancePro 4446 {18 GHz input x2 & 18 GHz output x1 cards} - "new (112818 FW)" 18 GHz microcode - parallel outs to --> [Audio: Denon 5308CI] --> [Video: JVC RS520 FW v30.1]
HT Details: link
Mike_WI is offline
post #976 of 1027 Old 05-09-2019, 09:02 AM
ddgdl's Avatar
Quoted: 328 Post(s)
Liked: 297
Definitely looks like the lens is tilted though, from the photos
ddgdl is offline
post #977 of 1027 Old 05-09-2019, 05:36 PM
satfam's Avatar
Quoted: 73 Post(s)
Liked: 64
I would appreciate that info too. Of course I live in the State so overseas delivery isn’t an issue. Thanks.
H/T: Marantz 7702MK II, MM8077, MM7055, Triton 2s, SCXL, SL/SR-S50s, BL/BR-S50s, H/W-4 Sat3s, dual SB16 Ultras, JVC DLA-RS2000, Stewart Cima Neve 110", Tivo Bolt, PS-3, Apple 4K TV, GIK Acoustics treatments, Panasonic UB820
Gameroom: Denon AVR-X4500H, Emotiva 2-T1’s, C1, 2 B2’s, 4 NHT ceiling speakers, 2 Velo SPL-1000R, Sony XBR85X900F, PS4 Pro, Tivo Bolt,Oppo 203
satfam is offline
post #978 of 1027 Old 05-09-2019, 07:26 PM
ddgdl's Avatar
Quoted: 328 Post(s)
Liked: 297
I would ask @Shawn Kelly when the next B-stock sale is---that will be your best bet for lower pricing. I have a B-stock DCR and it is fantastic.
ddgdl is offline
post #979 of 1027 Old 05-10-2019, 01:00 AM
Wookii's Avatar
Quoted: 2821 Post(s)
Liked: 2016
You need a mini socket wrench set:
https://www.amazon.com/s?k=Mini+sock...f=nb_sb_noss_2
Wookii is online now
post #980 of 1027 Old 05-10-2019, 04:31 AM
Quoted: 69 Post(s)
Originally Posted by Wookii View Post
Thanks!!
I actually ended up with this (it's a little smaller):
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
post #981 of 1027 Old 05-10-2019, 06:50 AM
Quoted: 69 Post(s)
I swapped out my 480 for the DCR two nights ago and want to say the difference is incredible! I'm not a videophile so didn't take any measurements and in fact, I haven't really tweaked the DCR completely (I'm waiting for the ratchet Phillips driver linked above), but it is very close to optimum. The picture is so much more defined from my Sony 5000 and 16' 2.35, 1.1 microperf screen. The clarity is amazing! It seems brighter too but that is subtle. When I first installed the projector, I was told by the seller to not use any anamorphic lens as the projector didn't need it. For 2.40 content, the picture looked good but for 1.78 expanded to fill my 2.35 screen, I was bothered by the top and bottom overspray of light so I installed my old Panamorph 480. That made a big difference. 2.40 content was brighter and better defined. I was skeptical about the Paladin (given it's expense) but after spending so much on the projector, I decided to bite the bullet and order one. The difference between the 480 and the DCR lens is very noticeable and for me, worth the added expense. Last night, I watched Highwaymen on Netflix and wow!! I also compared my picture to our brand new iPic theater and other than their 30+ foot screen size, my picture quality was better!
I know I'm rambling but I've never had such an impressive picture in my house ever! My last projector, a Sim2 HT5000 never really impressed me. It was good and bright but the colors were always off even after calibration. Now with the Sony 5000 and Paladin DCR, I have a system that I would put up against any commercial theater. Sign me up as a fanboy!!!
Craig Peer likes this.
post #982 of 1027 Old 05-10-2019, 07:34 AM
ddgdl's Avatar
Quoted: 328 Post(s)
Liked: 297
I feel the same way about my RS2000 and DCR combination---and I haven't even tweaked all the settings and gotten it fully set up (too busy watching movies!)
ddgdl is offline
post #983 of 1027 Old 05-10-2019, 08:21 AM - Thread Starter
Ash Sharma's Avatar
Quoted: 967 Post(s)
Liked: 664
Told you so...
The DCR is magical.
Ash Sharma is online now
post #984 of 1027 Old 05-10-2019, 08:33 AM
Quoted: 69 Post(s)
Originally Posted by Ash Sharma View Post
Told you so...
The DCR is magical.
It is amazing! I haven't read any comparisons between the 480 and the DCR but I can say the DCR is the way to go with this projector. In fact, until they make high end projectors with a 2.40 aspect chip, some form of anamorphic solution is essential.
post #985 of 1027 Old 05-10-2019, 08:38 AM - Thread Starter
Ash Sharma's Avatar
Quoted: 967 Post(s)
Liked: 664
You made a very good point on light spill... people say that A Lens reduces ANSI but what about all the light spill we were getting above and below the screen?? That should cause havoc on the ANSI.
What I love about the lens is (a) The definition of the picture has vastly improved - is it higher pixel density? I don't know... but that is the end result (b) And I might get flamed for it - but this is a very economical upgrade for the price - for what it delivers in picture quality and convenience and thus the return on the spend.
Enjoy...
mitchlampert and Craig Peer like this.
post #986 of 1027 Old 05-10-2019, 10:00 AM
Craig Peer's Avatar
Liked: 7574
Enjoy...
And it will never wear out. It has been one of the best upgrades I've made in to m theater in the last few years.
post #987 of 1027 Old 05-10-2019, 10:55 AM
beastaudio's Avatar
Quoted: 5475 Post(s)
Liked: 5281
Just like the uh380 piece of glass and the uh480 piece of glass or an isco IIIL that should never wear out?
beastaudio is offline
post #988 of 1027 Old 05-10-2019, 11:28 AM
Craig Peer's Avatar
Liked: 7574
True. But the DCR lens, being optimized for 4096 x 2160 4K projectors, makes most of those less desirable in the current 4K era. IMO. Plus, vertical compression lenses are perfect for " zoomers " who want to improve their picture. I would be one of those admittedly.
post #989 of 1027 Old 05-10-2019, 12:35 PM
BondDonBond's Avatar
Quoted: 627 Post(s)
Liked: 547
Ditto, same setup and LOVE it. Kris Deering even dialed back HDR brightness a little because of it to get me down to 32FL and get better contrast.
Home Theater: JVC NX7, Stewart 120" 2:35 StudioTech 130, Panamorph DCR Lens, B&W 802 Nautilus, HTM1, 4-B&W 805's for surround, 4-Martin Logan 22's ceiling speakers ATMOS, 2- 18" Velodyn Subs, Marantz 8802A, MacIntosh 8207 AMP and Proceed AMP 5, Oppo 203, Panasonic 820, Apple TV, XBox One
BondDonBond is offline
post #990 of 1027 Old 05-10-2019, 12:53 PM
beastaudio's Avatar
Liked: 5281
I get the vertical compression part of things, and that the glass may be a LITTLE sharper than perhaps the previous gens of panamorphs, but I still find my uh380 I scooped for pennies compared to the DCR's even b-stock pricing, with a little overscan I have zero problems with, looks wonderful... To say the optics aren't good enough on the IIIL for 4K is a little suspect. You didn't say such, but I've seen it mentioned.
