Panamorph DCR Paladin Owners Thread - Page 36 - AVS Forum | Home Theater Discussions And Reviews
 420Likes
post #1051 of 1106 Old 08-22-2019, 06:17 AM
Th601's Avatar
Quoted: 97 Post(s)
Liked: 26
Originally Posted by Craig Peer View Post
Ideally you aren't closer than 1.4 screen widths - projector lens to screen.
I gotcha. I saw a video explaining anamorphic lens and the sides were stretched horizontally and vertically to fill the ultra wide format screen.
Th601 is offline
post #1052 of 1106 Old 08-27-2019, 05:49 AM
cappy1's Avatar
Quoted: 36 Post(s)
Liked: 26
Use Projector or Lumagen Scaler?
I have a DCR Paladin on the way to replace the UA480 and trying to determine the optimum setup. I see that a number of Sony owners on this Thread that have a Lumagen Radiance Pro are using the Sony to upscale to 4096x2160. I mentioned this to Jim Peterson at Lumagen and he indicated the Pro would do a better job. He referred me to a test report on the Lumagen home page titled "Polishing your Pixels" that says in part:
"Sony's VPL-VW5000ES uses the company's proprietary video scaler, dubbed the Reality Creation engine. It's good, but it's not great. The projector does an efficient job of mapping the image to 4K.... However, once put through the Lumagen, the Sony's own scaling seems, by comparison, coarse and harsh. It's as if each pixel has been hand-crafted by the external scaler, and the Sony now is shining as you would expect from such a big-ticket projector".
Are there some other considerations that would favor using the Sony for 4096x2160 conversion?
cappy1 is offline
post #1053 of 1106 Old 08-27-2019, 06:03 AM
Mike Garrett's Avatar
Quoted: 12327 Post(s)
Liked: 9950
Scaling by the Lumagen would be the better way to go. No Sony owner that has a Lumagen should be using the projector for the scaling.
Mike Garrett is online now
post #1054 of 1106 Old 08-27-2019, 06:22 AM
thrang's Avatar
Quoted: 2569 Post(s)
Liked: 2066
If you watch a fair amount of sports, using motionflow interpolation is beneficial - this is disabled when the 5000 is presented with a 4096 signal
cappy1 likes this.
UPDATED 4/29/17 Thrang's Home Theater (for now...)
Sony VPL-VW5000es • Panamorph Paladin DCR • Trinnov Altitude 16 • Crown DCIn amplifiers • JBL M2 (LCR-LW-RW) • JBL S2S-EX subwoofers x2 • JBL SCL-4 (side/rear surrounds) • JBL SCS12 (x4) SCS8 (x2) TH/RH/TM • Lumagen Radiance Pro • Panasonic UB820 • Apple TV 4k • Synology RAID (45 TB total storage) • RTI control system
thrang is offline
post #1055 of 1106 Old 08-27-2019, 08:25 AM
cappy1's Avatar
Quoted: 36 Post(s)
Liked: 26
Hmm, good to know. We rarely watch sports in the theater, so will use the Lumagen. Thanks!
cappy1 is offline
post #1056 of 1106 Old 08-28-2019, 03:19 PM
Th601's Avatar
Quoted: 97 Post(s)
Liked: 26
Hello. What’s the best thing to use to clean the DCR lens? I have a lot of dust and smudges on the glass.
Th601 is offline
post #1057 of 1106 Old 08-28-2019, 03:54 PM
Shawn Kelly's Avatar
Quoted: 174 Post(s)
Liked: 124
Standard quality camera lens cleaning supplies work fine.
Shawn Kelly
Panamorph, Inc.
www.panamorph.com
[email protected]
Shawn Kelly is offline
post #1058 of 1106 Old 08-28-2019, 04:43 PM
Steve Bruzonsky's Avatar
Quoted: 1543 Post(s)
Liked: 761
Finally a DCR lens is on its way for my Sony VW5000!
https://www.avsforum.com/avs-vb/show....php?t=1158431 No dealer is authorized to tell you I refer to them - any referrals I make will be done personally by me. Over the years I have found certain dealer(s) who I cannot recommend for good reason.
! 9.4.13 Trinnov Altitude 32 Theatre renovation/upgrade starts end of July 2019!
Steve Bruzonsky is online now
post #1059 of 1106 Old 08-28-2019, 05:36 PM
Craig Peer's Avatar
Quoted: 6866 Post(s)
Liked: 8099
You'll be wide eyed in amazement after you install it - just like Alita !
mikela, OzHDHT and llang269 like this.
Craig Peer is online now
post #1060 of 1106 Old 08-28-2019, 09:09 PM
Liked: 761
You mean my imagination will run wild with Alita actually in my [email protected]@@
Craig Peer and llang269 like this.
post #1061 of 1106 Old 08-29-2019, 05:07 AM
RickAVManiac's Avatar
Quoted: 345 Post(s)
Liked: 441
The Paladin DCR b-stock sale end soon and I am really temp to buy one.
Anyone here who buy a b stock DCR in the past? Satisfied?
Something I should know or worries about b stock?
Thanks for any tips on this one
RickAVManiac is online now
post #1062 of 1106 Old 08-29-2019, 09:29 AM
Craig Peer's Avatar
Liked: 8099
Should not be a problem. I've heard no complaints. The actual lens should be 100% good.
post #1063 of 1106 Old 08-29-2019, 09:31 AM
Craig Peer's Avatar
Liked: 8099
Along with the Lumagen Radiance Pro's dynamic tone mapping, the DCR lens is the best thing I've added to my RS4500. The combination of the two have really improved the overall picture quite a bit. You are going to love it !
Ash Sharma, mikela and llang269 like this.
post #1064 of 1106 Old 09-01-2019, 07:21 AM
ddgdl's Avatar
Quoted: 333 Post(s)
Liked: 309
I have a b stock and I honestly cannot see anything wrong with it at all
ddgdl is offline
post #1065 of 1106 Old 09-05-2019, 07:48 AM
Craig Peer's Avatar
Liked: 8099
JVC is adding Anamorphic D mode to the RS 1000 / 2000 / 3000, for DCR users !
http://pro.jvc.com/pro/pr/2019/consu...re_update.html
post #1066 of 1106 Old 09-05-2019, 07:54 AM
ShadeRF's Avatar
Quoted: 62 Post(s)
Liked: 84
Any chance they'll include a fix for 3D and the DCR?
Theater Equipment list:
JVC RS3000, Panamorph Paladin DCR, 138", Lumagen Pro, Stewart 138" 2:35:1 Screen, Oppo UDP-203, DirecTV Genie, Marantz SR-6011, Emotiva XPA-5 Mains: Paradigm Prestige 85F, Center: Paradigm Prestige 55C, Sides: Paradigm Prestige 15B, Rears: Paradigm Atom V6 Atmos: Paradigm P65-R Sub: Rhythmik FV18, GIK Acoustic Room Treatments
ShadeRF is online now
post #1067 of 1106 Old 09-05-2019, 08:31 AM
Craig Peer's Avatar
Liked: 8099
That I don't know.
post #1068 of 1106 Old 09-06-2019, 05:49 AM
dbochniak's Avatar
Quoted: 20 Post(s)
Liked: 36
I saw this in the projector thread as well. Great news!
Craig Peer likes this.
dbochniak is offline
post #1069 of 1106 Old 09-06-2019, 08:39 AM
Liked: 761
The $$$$$$$million dollar question - which demo(s) at CEDIA 2019 next week will use a DCR anamorphic lens?
post #1070 of 1106 Old 09-06-2019, 08:46 AM
Lygren's Avatar
Quoted: 290 Post(s)
Liked: 461
Alcons @sr-13 will have it installed on the vw5000, shooting at a 11 1/2 ft wide UltraWeave v6...
Proudly Representing DreamScreen.no // ScreenAcoustics.com // AT screens & more!
Founder AVforum.no // Norway´s leading AV community since 2002
Lygren is offline
post #1071 of 1106 Old 09-07-2019, 10:26 AM
Sittler27's Avatar
Quoted: 1243 Post(s)
Liked: 112
Currently have a JVC x970R (RS620). Considering getting an JVC NX9+ DCR lens.
I sit 12' away from a 127" wide (138" diagonal) 2.35:1 screen.
If we ignore brightness for a minute and only think about resolution, does my seating distance negate any resolution benefits that the DCR lens adds?
I mean, am I just too far away to see the added resolution the DCR lens provides over and above what the NX9 would provide over my x970R on it's own?
With all the complexities and expense of DCR lens and then having to move it aside for 16:9 content (I'm about 50/50 scope vs. HDTV), I'm thinking if I don't see any benefits anyways for resolution I'll take the hit on brightness for scope and just get an NX9 without the DCR.
Sittler27 is online now
post #1072 of 1106 Old 09-07-2019, 04:20 PM
Craig Peer's Avatar
Liked: 8099
You are going to see the added brightness for HDR for sure. You may find you want to move your seating closer. One screen width away seems good - that's about 17" closer than you are now.
post #1073 of 1106 Old 09-07-2019, 04:50 PM
Quoted: 78 Post(s)
Liked: 84
You don't *have* to move the lens for 16:9 content - only for 3D content. Granted, you will gain brightness if you move the lens but keep in mind with the lens you will have the same brightness (fL) for 2.40 and 16:9. It is true that you will lose some resolution for 16:9 for 4K source material if you keep the lens in place. I wouldn't worry too much about that though - I see a far greater difference in how various source material is produced and mastered than I do from even the difference between HD (upscaled) and 4K.
For what it is worth - I went through the same decision path as you (including considering the RS4500) and decided to get the NX9 with no anamorphic lens for now (I am coming from an RS600). What put me over the top is the NX9 firmware upgrade that includes dynamic tone mapping. I calculated that in worst case I will have 27 fL - and that is enough for good HDR when there is dynamic tone mapping. Much more in brightness and I would start elevating the black floor. For me - I know the brightness will be fine as I have the same 27 fL brightness today - with static tone mapping and it is very watchable. The only downside I see is I will need to use high lamp for 2.40 HDR.
I figure I have the option to add the anamorphic lens later and meanwhile I am looking forward to learn more about DTM in the JVC vs. Lumagen vs. Envy.
mikela likes this.
MovieRAV is offline
post #1074 of 1106 Old 09-07-2019, 09:05 PM
Sittler27's Avatar
Liked: 112
I was sitting 13.5' away, so my move to about 11.5' now is as close as I can get it.
post #1075 of 1106 Old 09-07-2019, 09:10 PM
Sittler27's Avatar
Liked: 112
Yes, the new JVC DTM looks quite promising. I however already run madvr with astounding results, so that likely negates any benefit from the new JVC DTM in the NX9 (making me again think of the RS4500).
post #1076 of 1106 Old 09-08-2019, 09:54 AM
Quoted: 78 Post(s)
Liked: 84
Sounds like you are honing in on your decision. I have been following the RS4500 for quite a while and the owners seem very happy (and helpful). If it's within your budget sounds like a great option!
I use a lot of non-disk sources (AppleTV, Playstation, Kaleidescape) so madVR is not an option for me. I do think I will ultimately end up with the DCR A-lens. By all accounts it is also an outstanding product - and I like the idea of improving brightness for 2.40 content.
MovieRAV is offline
post #1077 of 1106 Old 09-09-2019, 05:48 AM
audioguy's Avatar
Quoted: 4919 Post(s)
Liked: 3738
And to add to the discussion, the Panamorph lens' can move to your next projector(s). I had my previous Panamorph for 15 years and I can't recall how many projectors. My new one will outlast me - as, I suspect, will my Lumagen.
mikela, Craig Peer and llang269 like this.
audioguy is online now
post #1078 of 1106 Old 09-09-2019, 11:23 AM
roxiedog13's Avatar
Quoted: 2782 Post(s)
Liked: 1459
I have purchased used Panamorph product from others and Sean has still helped me resolve some minor issues with the same. A B-stock from him is as good as a new one IMHO. This company is small but his service is huge, don't even hesitate, at least not for
warranty or quality issues.
thrang, RickAVManiac and llang269 like this.
Dedicated Theater: Sony VPL VW 885ES , Panamorph DCR & ISCO III L Anamorphic Lens, Draper TecVision XT1800X Screen, 2.40:1 134" diagonal curved , Denon AVR-X8500 , 9.2.6 Atmos, Panasonic UB900, Oppo 203, Lumagen Pro 4440 , (3) Paradigm CI Elite E7-L+C+R fronts, , (2) CI Pro P80-IW Rear, (2) Paradigm SA-ADP In-wall Surround, (6) SIG-1.5R-30 v.3 In-Ceiling, Subwoofers: (2) SVS SB-16 Ultra , SVS PC13-Ultra .
roxiedog13 is online now
post #1079 of 1106 Old 09-12-2019, 10:54 AM
Quoted: 174 Post(s)
Liked: 124
Paladin DCR Wins CEPro Best Product for 2019
With many thanks for all the support and encouragement from AVS Forum members!
Shawn Kelly
Panamorph, Inc.
www.panamorph.com
[email protected]
post #1080 of 1106 Old 09-12-2019, 09:54 PM
Liked: 761
Shawn congrats! You deserve this award! Was your DCR lens installed on any other setups than the Alcons with a Sony 5000 which looked great?
