Panamorph DCR Paladin Owners Thread - Page 48 - AVS Forum | Home Theater Discussions And Reviews
 603Likes
post #1411 of 1445 Old 05-29-2020, 12:56 PM
Mike Garrett's Avatar
Quoted: 14048 Post(s)
Liked: 11723
Originally Posted by hamster71 View Post
Hello everyone, what's the point of using an anamorphic lens?
Current projectors are quite bright so I don't see the point of such a device anymore ...
But I'm still interested in it and I'm trying to understand why we still use it?
For most people here in the US, more brightness is wanted, due to large screen sizes. For myself, more brightness is always wanted, because I use a low gain woven AT screen. The other advantages of an A-lens besides brightness are; nearly instant aspect ratio changes, more accurate aspect ratio changes and increased pixel fill.
llang269 likes this.
Mike Garrett is offline
post #1412 of 1445 Old 05-29-2020, 11:09 PM
stinkyonion's Avatar
Quoted: 56 Post(s)
Liked: 34
I want one because i cant back my projector away from the screen enuf. The a lens would help widen my image. My throw ratio is 1.3. Might be to small for a lens tho, dunno. Msrp is $9000. I need dramatc price drop. I understand they were half off prerelease. I would do that if ever comes up again.
stinkyonion is online now
post #1413 of 1445 Old 05-30-2020, 04:31 AM
DLCPhoto's Avatar
Quoted: 1842 Post(s)
Liked: 944
Unfortunately, that's not how an Anamorphic Lens. It doesn't add to the maximum screen size you can achieve, which is determined only by the Projector's specs, and Throw Distance.
Panamorph's recommendation is having a throw distance of 1.4 x screen width (of your scope screen). But if you can't even fill the scope screen from that distance, the DCR lens won't change that.
Or am I missing what you're saying?
JVC NX7, DCR Lens, Marantz SR7010, Screen Innovations 160" 2.35:1 Screen
Front L/R: Duntech Sovereigns, powered by 2 bridged Adcom GFA-555
Center: Revel C208 powered by Cambridge Audio Azur 851W
Dolby Bed (4): Sony Core SS-CS5, Atmos (4): Ascend Acoustics CBM-170 SE
Subwoofer: DIY 8' sub with 4 18" SI Drivers, powered by iNuke 6000
DLCPhoto is online now
post #1414 of 1445 Old 05-30-2020, 09:12 AM
Kris Deering's Avatar
Quoted: 4413 Post(s)
Liked: 8061
And remember, the 1.4x is the MINIMUM recommendation. You're far more likely to see some visible artifacts (bowing near the edges of the image) at that kind of throw distance than a longer throw. I would recommend a 1.6x or higher if possible to eliminate any possible image artifacts that may distract (obviously you can use some overscan to help with this as well).
DLCPhoto and Azekecse like this.
My Home Theater UPDATED JUNE 2020
Deep Dive AV - Calibration, Consulting and Education
Kris Deering is online now
post #1415 of 1445 Old 05-30-2020, 10:14 AM
Craig Peer's Avatar
Quoted: 8057 Post(s)
Liked: 10652
You would need a horizontal expansion lens. The DCR lens is a vertical compression lens.
Craig Peer is online now
post #1416 of 1445 Old 05-30-2020, 01:00 PM
DLCPhoto's Avatar
Liked: 944
Good point, Craig. I should have clarified that in my reply. I've only been thinking in terms of the DCR lens, and forgot about the HE lenses.
post #1417 of 1445 Old 05-30-2020, 01:33 PM
Craig Peer's Avatar
Liked: 10652
Mike was using an HE lens if I recall correctly for this very purpose at one point.
post #1418 of 1445 Old 05-31-2020, 12:20 AM
telem's Avatar
Quoted: 119 Post(s)
Liked: 75
Thank you for your answers despite my very basic English.
You have convinced me and I will take the plunge .
Last question, what do you use as a cart to remove the anamorphic lens during 16: 9 movies? Do you have a link or reference to give me?
Best choice ! I am personally not using a cart, it's fixed. I use either the Lumagen to 16:9 NLS or just open the L&R masks of my screen. If you live close to Geneva or travel here(guess not now), PM me and we could meet for a demo.
mikela likes this.
Trinnov Altitude 32 & Amplitude*2 - Sony VW-5000ES - Panamorph Paladin DCR- Lumagen Radiance Pro 4449 - Screen Research 173" ClearPix 4K White 1.0 - Wisdom Audio speakers: L8i (LCR) - P6i (SL, SR) -P4i (SBL, SBR - LW, RW(wide for Atmos)) - 6* B&W CCM7.4 (Ceiling Atmos) - Paradigm SUB2 - Kaleidescape Encore & Premiere - Oppo 205 - SKY Q - Apple TV 4K - Technics MK2 SL-1200GAE Limited Edition
telem is offline
post #1419 of 1445 Old 05-31-2020, 08:03 AM
hamster71's Avatar
Quoted: 24 Post(s)
Liked: 1
I cracked faster than expected, the lens is ordered. I am now impatient
I also have a Lumagen pro in the system, can it automatically recognize the image format and adapt it automatically or do I have to do the manipulation manually?
So for 16: 9 you use the 16: 9 NLS function and for the 2:35 format ?
I don't have the number of messages required to send private messages yet, but I'm getting there soon
hamster71 is offline
post #1420 of 1445 Old 05-31-2020, 08:16 AM
Craig Peer's Avatar
Liked: 10652
The Lumagen Pro has auto aspect ratio - you will be all set !
OzHDHT likes this.
post #1421 of 1445 Old 05-31-2020, 08:52 AM
telem's Avatar
Quoted: 119 Post(s)
Liked: 75
Looks like we live 20' away from each other so looking forward to explaining you in person.
Absolutely!
telem is offline
post #1422 of 1445 Old 06-04-2020, 09:44 AM
hamster71's Avatar
Quoted: 24 Post(s)
Liked: 1
I have already received my Paladin lens and I plan to install it this weekend .
I ask myself this question, at what ideal distance from the lens of the projector should I place it? Or as close as possible is ideal?
post #1423 of 1445 Old 06-04-2020, 10:00 AM
DLCPhoto's Avatar
Liked: 944
Congrats! Yes, as close as possible. Enjoy!
Craig Peer and Azekecse like this.
post #1424 of 1445 Old 06-08-2020, 09:06 AM
Azekecse's Avatar
Quoted: 287 Post(s)
Liked: 305
So, hamster71, did you complete the DCR lens installation? What are your thoughts? Just curiosity getting the better of me.
Peace and blessings,
Azeke
Marantz SR7011: 7.4.4 Martin Logan Edges (4: FR/FL/SR/SL) Martin Logan Axis (2: SBL/SBR) Martin Logan Stage X (Center) Martin Logan 1500X Sub (2) Martin Logan 1100X Sub (2) Sonance VP86R SST/SUR (4: Dolby Atmos) JVC NX-7/DaLite 125" 2:35:1 Scope Screen; Paladin DCR
Azekecse is offline
post #1425 of 1445 Old 06-08-2020, 01:32 PM
Tom Bley's Avatar
Quoted: 979 Post(s)
Liked: 957
The DCR-C is in the house!
Tom Bley is online now
post #1426 of 1445 Old 06-08-2020, 01:40 PM
Azekecse's Avatar
Quoted: 287 Post(s)
Liked: 305
Nice Tom...Did it come with the coffee mug? Tell us what you think after the install.,
Azeke
Tom Bley likes this.
Azekecse is offline
post #1427 of 1445 Old 06-08-2020, 01:40 PM
hamster71's Avatar
Quoted: 24 Post(s)
Liked: 1
First note, I bought the paladin and not the DCR paladin, but I think the benefits should be the same.
I just installed it so I don't really have any perspective to get a final opinion but for the moment I'm happy with my purchase.
The advantages are: the gain in brightness, the black bands which are really black now (I currently have a 16: 9 screen) and a better definition.
The only disadvantages in my opinion are: the fact of having to ideally remove the lens during films in 16: 9 and of course its very high purchase price.
Azekecse likes this.
post #1428 of 1445 Old 06-08-2020, 01:53 PM
Tom Bley's Avatar
Quoted: 979 Post(s)
Liked: 957
Azeke
Yes! Came with the coffee mug and the XM2 attachment kit (not pictured).
llang269 and Azekecse like this.
post #1429 of 1445 Old 06-08-2020, 01:59 PM
Azekecse's Avatar
Quoted: 287 Post(s)
Liked: 305
Hmmm, I didn’t get one with my DCR lens, must be a part of the promotion. Enjoy.
Azeke
Azekecse is offline
post #1430 of 1445 Old 06-09-2020, 01:04 PM
Craig Peer's Avatar
Liked: 10652
Nice ! I want a coffee mug now.
Tom Bley, llang269 and Azekecse like this.
post #1431 of 1445 Old 06-09-2020, 02:51 PM
ckgolf's Avatar
Quoted: 143 Post(s)
Liked: 155
What is that glass box thing next to that awesome coffee cup? JK. My DCR-C is waiting to be picked up at the FedEx location. I’ll try to install it tonight.
Tom Bley and Craig Peer like this.
ckgolf is offline
post #1432 of 1445 Old 06-14-2020, 12:31 PM
ckgolf's Avatar
Quoted: 143 Post(s)
Liked: 155
After after a few failed attempts of installing the DCR-C it’s finally up. In my haste, I was putting the lens mount that attaches to the plate, backwards. That was putting the lens too far from the PJ. Now it’s as close as possible. It’s not perfect yet, I only fiddled with it enough to fit the picture to the screen. So far I’m very happy with the improvement it provides. Takes my RS2000 to the next level.
Craig Peer, 12GAGE and Azekecse like this.
ckgolf is offline
post #1433 of 1445 Old 06-14-2020, 01:49 PM
12GAGE's Avatar
Quoted: 364 Post(s)
Liked: 410
I think a panamorph lens is a must if you want the most out of your 4k projector. Honestly, it has been on of my best home theater purchases over the years.
Craig Peer, llang269 and Azekecse like this.
12GAGE is online now
post #1434 of 1445 Old 06-28-2020, 07:30 AM
Azekecse's Avatar
Quoted: 287 Post(s)
Liked: 305
Bump: DCR-C users, so what do you think of your new lens? Don't be shy
Azeke
Craig Peer likes this.
Azekecse is offline
post #1435 of 1445 Old 06-28-2020, 10:23 AM
cxwingav's Avatar
Quoted: 42 Post(s)
Liked: 29
Design for my future room has a 2.35 screen, and a fully enclosed (with proper ventilation of course) box for the PJ, so I'm still on the fence about whether I'd want to go for it due to the loss of horizontal resolution on 16:9. In other threads I was surprised by the number of people who remove their lens for non-scope content. Panamorph obviously avoids the issue on their site, and has no easy solution for doing that AFAIK, and sleds seem custom and expensive. Arg.
cxwingav is offline
post #1436 of 1445 Old 06-28-2020, 12:12 PM
DLCPhoto's Avatar
Liked: 944
I don't remove the lens for 16:9 content, and honestly, if I don't know there were some technical compromises, I wouldn't be aware of it, as it seems just fine.
If you can find someone near you that has one, you could check it out for yourself, and see what you think.
Ash Sharma, mikela and Azekecse like this.
post #1437 of 1445 Old 06-28-2020, 12:25 PM
12GAGE's Avatar
Quoted: 364 Post(s)
Liked: 410
If I had a 2.35:1 screen I would most likely leave the lens in place and mask the sides. My setup is 16:9 so I remove the lens for 16:9 content. It is not a picture quality issue just sizing in my case.
cxwingav likes this.
post #1438 of 1445 Old 06-29-2020, 10:43 AM
cxwingav's Avatar
Quoted: 42 Post(s)
Liked: 29
Oh yes I don't doubt it. And if there were any comparisons to be made, they'd have to be on 16:9 / 1.85 content with a 4K DI.
I may not be looking the right way, it's been hard finding other HT enthusiasts in the SF Bay Area. There was a nice invitation from Mike though... a bit of a drive ;-)
DLCPhoto likes this.
cxwingav is offline
post #1439 of 1445 Old 06-29-2020, 12:00 PM
mikela's Avatar
Quoted: 507 Post(s)
Liked: 745
Same here...non issue.
mikela is offline
post #1440 of 1445 Old 07-06-2020, 06:59 PM
Liked: 8061
Not sure why you are removing the lens. You mentioned you had a Lumagen Pro, so you should be able to leave the lens in place and have full support of ALL aspect ratios. If you are struggling with this, shoot me a PM.
