AVS Forum | Home Theater Discussions And Reviews (https://www.avsforum.com/forum/)
-   Ultra Hi-End HT Gear ($20,000+) (https://www.avsforum.com/forum/86-ultra-hi-end-ht-gear-20-000/)
-   -   DATASAT RS20i vs TRINNOV AMETHYST for 2 Channel bi-amp setup Comp HELP~~!!!~~~!!~! (https://www.avsforum.com/forum/86-ultra-hi-end-ht-gear-20-000/2984086-datasat-rs20i-vs-trinnov-amethyst-2-channel-bi-amp-setup-comp-help.html)
911turbojk 06-14-2018 01:04 PM
Guys ,, HELP !!!~~~
I have a RS20i in my dedicated HT room and love it , but right now I am setting up a 2 CHANNEL system that requires ( crossover + bi-amp + sub extension ) the speaker is a JBL4350 ,, and I am going to be using BOULDER Amps for this setup , ( and possible Procella 15" dual subs)
So for this setup ,,, I think a RS20i should do the job ( I am getting one unit from a project that we are taking down the RS20i from the showroom ) ,,, so I am thinking to just use the RS20i for this 2 channel setup as it will do all
the asked task above.
HOWEVER ! ,, As a 2 channel guys I am also looking at the Trinnov Amethyst as well,,, has anyone heard both unit or had similar experience using RS20i as a 2 channel , or have heard the direct comparison between the two unit ?
I know this is probably a rare comparison ,, but I am hoping the rs20i is good enough to get the job done,
so I won't have to purchase extra unit ( however Amethyst is quiet well priced too and with Roon compatible )
HELP !!!
Powered by vBulletin® Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
