Alcons Audio Official Thread - Page 5 - AVS Forum | Home Theater Discussions And Reviews
 82Likes
post #121 of 131 Old 02-23-2020, 08:47 AM
CP850-CLED's Avatar
Quoted: 22 Post(s)
Liked: 91
Originally Posted by ece2k2 View Post
But the specs (https://www.alconsaudio.com/wp-conte...ech-spec-1.pdf) say there are 2x RJ45 etherCON (networked audio) connectors provided on the rear. Just trying to understand how future proof the Sentinel3 amp is. Thank you!
Just like Trinnov, the connectors are there for future expandability. The plugin module has not been designed yet in Alcons case.
But the intention is to add this feature in the future.
ece2k2 and ReTrOToo like this.
"I have spoken."
CP850-CLED is offline
post #122 of 131 Old 02-23-2020, 07:38 PM
Quoted: 127 Post(s)
Liked: 53
Are there user presets in sentinel? If there are 2 different rooms, only one being used at any given time, is it possible to change presets based on room usage?
Tuning is offline
post #123 of 131 Old 02-24-2020, 02:22 AM - Thread Starter
Lygren's Avatar
Quoted: 325 Post(s)
Liked: 512
The Sentinels are not used for room correction, you would need an external processor such as a Storm or Trinnov unit to do that. The Sentinels, however, uses presets, available for all Alcons speaker models, that normalises the basic frequency response as well as phase / time (using FIR filters).
Proudly Representing DreamScreen.no // ScreenAcoustics.com // AT screens & more!
Founder AVforum.no // Norway´s leading AV community since 2002
Lygren is offline
post #124 of 131 Old 02-24-2020, 02:35 AM
Quoted: 127 Post(s)
Liked: 53
Thanks for your response. I think I could have phrased my question better. Given below is the scenario I am thinking about.
If I have a theater with 7.1.4 with CRMS speakers, I know there are presets for these on the sentinel. If I have a living room where I want another setup with say 5.1.4 CRMSC speakers. At any given time, only one of the venues will be used.
In this case, is it possible switch between presets so the correct presets are used based on room usage?
Tuning is offline
post #125 of 131 Old 02-24-2020, 04:00 AM - Thread Starter
Lygren's Avatar
Quoted: 325 Post(s)
Liked: 512
Ah, got it... Several reasons why that won´t be possible, some of which are the fact that you will physically connect the CRMS´s differently being bi-amped as opposed to single amped on the CMRSC´s... So, I guess you would just have to keep the speakons for the CRMSC´s laying there ready for connection when needed, manually alter the preset and vice versa when connecting back to the CRMS. Lucky guy btw, Alcons in TWO rooms!!
Tuning likes this.
Lygren is offline
post #126 of 131 Old 02-27-2020, 07:57 PM
Quoted: 127 Post(s)
Liked: 53
I think ahead, not getting 2 sets together
Lygren likes this.
Tuning is offline
post #127 of 131 Old 03-07-2020, 02:30 PM
Quoted: 127 Post(s)
Liked: 53
Has anyone listened to CR3 and CRMS? How does it compare to CRMS?
Tuning is offline
post #128 of 131 Old 03-09-2020, 05:28 AM - Thread Starter
Lygren's Avatar
Quoted: 325 Post(s)
Liked: 512
We used CR3´s at CEDIA 2016... Peter was a bit heavy on the volume knob and all that year, but yeah, in general they did sound fantastically good - albeit I really don´t think those beasts are required for even the very very lage home cinema installs...
Tuning and ReTrOToo like this.
Lygren is offline
post #129 of 131 Old 03-09-2020, 09:57 AM
mani's Avatar
Quoted: 379 Post(s)
Liked: 193
What “one requires “ and what “one can “ shouldn’t be compared on an audiophile forum ...😀.... 🙂
If OP can fit in and afford CR3s , I am sure he will enjoy them 🙂
Tuning and Lygren like this.
mani is offline
post #130 of 131 Old 03-09-2020, 11:08 AM
Lasalle's Avatar
Quoted: 628 Post(s)
Liked: 514
I would agree, at CEDIA they overpowered the surrounds and heights. I think you need to be sitting further back and have plenty of surround firepower. They are designed to handle up to 350 seat theaters.
Tuning likes this.
Lasalle is online now
post #131 of 131 Old 03-09-2020, 02:55 PM - Thread Starter
Lygren's Avatar
Quoted: 325 Post(s)
Liked: 512
Well, don´t let me be the party pooper for sure; but if I´d go all overboard I would have considered running with a full line-array instead! One of those micro ones might be cool to try out, LR7´s for example: https://www.alconsaudio.com/product/lr7/... They´re even available in 120 degrees horizontal coverage versions, and after having heard the LR24´s in that theatre in Amsterdam I am quite confident those smaller ones might work perfectly in a (large) home cinema setting as well...
audiovideoholic and Tuning like this.
Lygren is offline
