Recommendations please... - AVS Forum | Home Theater Discussions And Reviews
 4Likes
  • 1 Post By Archibald1
  • 1 Post By COOKHAUS
  • 1 Post By mmiles
  • 1 Post By mmiles
post #1 of 14 Old 07-03-2019, 02:57 AM - Thread Starter
Liked: 1
Hi, I'm in the process of doing some research on projectors and how much I need to spend to achieve what I want.
I'm hoping someone on here can give me some advice or suggestions.
I need to project a 4k animated presentation from 3m distance (preferably ceiling-mounted) onto a wall which is 8m wide 3m high approx.
The space will have subdued lighting (slightly darker than you see in the attached image).
The projector will be running for 8hrs a day, 7 days a week.
It does not need to be interactive or have 3D capability.
Thanks in advance.
COOKHAUS is offline
post #2 of 14 Old 07-03-2019, 03:21 AM
markmon1's Avatar
Quoted: 5029 Post(s)
Liked: 3270
For something like this, a business class laser projector sounds like the right move. I'd look at a benq LK970 which you can still find on benqdirect.com often enough. If not an LK990 is its replacement. You need a lot of lumens. These are 5000-6000 lumens and I'm sure calibration is a non issue for you.
Video: JVC RS4500 135" screen in pure black room no light, htpc nvidia 1080ti.
Audio: Anthem mrx720 running 7.1.4, McIntosh MC-303, MC-152, B&W 802d3 LR, B&W HTM1D3 center, B&W 805d3 surround, B&W 702S2 rear, B&W 706s2 x 4 shelf mounted for atmos, 2 sub arrays both infinite baffle: 4x15 fi audio running on behringer ep4000 + 4x12 fi audio running on 2nd ep4000.
markmon1 is online now
post #3 of 14 Old 07-03-2019, 04:13 AM - Thread Starter
Liked: 1
Sorry, forgot to mention; I need it to fill the wall as much as possible. So if I need extra lenses, etc. then that's fine...
COOKHAUS is offline
post #4 of 14 Old 07-03-2019, 04:19 AM
Archibald1's Avatar
Quoted: 1905 Post(s)
Liked: 1045
The 20,000+ section *may* be the wrong place for this thread, as I think you can get ideal machines for *much* less than that that may fit your needs.
On the other hand, it entirely depends on what you want to spend too!
Do you have over 20k to spend on this project?
COOKHAUS likes this.
“Remember to look up at the stars and not down at your feet. Be curious. And however difficult life may seem, there is always something you can do and succeed at. It matters that you don’t just give up."
Stephen Hawking.
Archibald1 is offline
post #5 of 14 Old 07-03-2019, 04:34 AM - Thread Starter
Liked: 1
Hi, yes I have over 20k to spend if I really need to. But because I have no idea what I need to spend to achieve what I want, I posted this on the other forum too. thanks
Archibald1 likes this.
COOKHAUS is offline
post #6 of 14 Old 07-03-2019, 04:15 PM
mmiles's Avatar
Quoted: 925 Post(s)
Liked: 485
If you need a bright image you need to shoot for something in the 10,000 lumens range with that screen size using a unity gain screen (1.0). Less lumens with a higher gain screen however a higher gain screen could “sparkle” or have “hot sots” especially at 10 feet viewing distance.
Mike Miles
[email protected]
mmiles is online now
post #7 of 14 Old 07-04-2019, 12:37 AM - Thread Starter
Liked: 1
Thanks for the info guys.
Can anyone here suggest any projectors that I should take a look at? and whether it'll need extra lenses or not.
I need to get the image as large as poss in that 3m height. Preferably in 4k 16:9 ratio from 3m distance.
COOKHAUS is offline
post #8 of 14 Old 07-12-2019, 12:41 PM
DMark1's Avatar
Hi CookieHaus:
Yes, I can suggest and source a number of new business laser projectors for you with 20,000+ hour life and the appropriate lens for your installation. Are you in the USA? Please send me a PM (private message) and we can discuss the details of your situation. Thanks!
DMark1
Fine Music, Movies, Wine, and Friends - A Life Well Lived!
DMark1 is offline
post #9 of 14 Old 07-12-2019, 02:56 PM
mmiles's Avatar
Quoted: 925 Post(s)
Liked: 485
I’m sure others would be interested your suggestions.
Post your thoughts!
A.T.M. likes this.
Mike Miles
[email protected]
post #10 of 14 Old 07-14-2019, 08:29 PM
Bigus's Avatar
Quoted: 607 Post(s)
Liked: 575
Is that the actual space in the picture? Looks like a hallway of sorts. Will people standing and blocking the projected image be an issue?
Bigus is offline
post #11 of 14 Old 07-18-2019, 01:24 PM
DMark1's Avatar
What is behind the image wall? Is a rear projection situation possible? That could solve the problem of people walking in front of the image. Also, if there is more than 3m behind that wall, it will make it much easier to find a projector with a workable lens....
DMark1 is offline
post #12 of 14 Old 07-20-2019, 02:46 AM
donaldk's Avatar
Quoted: 629 Post(s)
Liked: 176
You best use multiple (ultra) short throw projectors side by side, blending the individual images.
Edit: Ah you only need 5.33 meters out of the 8 meters wide. Still a blend would be the obvious choice, but it might be doable with an elbow lens equiped projector. These come in 3000-30000 lumens. Given the amount of ambient light demonstrated, you'll need a lot of light to get any visable image.
donaldk is offline
post #13 of 14 Old 07-26-2019, 08:31 AM
DMark1's Avatar
I thought of this also, but it still doesn't solve the problem of people walking in front of the image. Also it doubles the price of the project (or more if you have to add a processor to do the edge blending)... In any case, this is a more difficult / expensive project than I think the OP realized, especially if he HAS to have it in 4K resolution...
DMark1 is offline
post #14 of 14 Old 07-26-2019, 12:27 PM
donaldk's Avatar
Quoted: 629 Post(s)
Liked: 176
That's where the UST projectors on the ceiling come in. Many the laser phosphor business have blending built in. Not sure if you still need a procesor to split the video, you probably do. Didn't ask Coretronic how it did this with its D40? platform, a few years ago, that were small units.
Coretronic used one of them ...static sceens for the touch.
https://www.coretronic.com/en/news/oZYzDy/detail
donaldk is offline
