AVS Forum | Home Theater Discussions And Reviews (https://www.avsforum.com/forum/)
-   Ultra Hi-End HT Gear ($20,000+) (https://www.avsforum.com/forum/86-ultra-hi-end-ht-gear-20-000/)
-   -   Alcons sentinel amp , Control4 automation (https://www.avsforum.com/forum/86-ultra-hi-end-ht-gear-20-000/3080076-alcons-sentinel-amp-control4-automation.html)
mani 07-22-2019 10:49 AM
Just trying to find out if anyone has successfully been able to integrate Sentinels in Control4 automation . What I mean is , to be able to put them in standby mode when you turn the theater off and turn them on when you turn the room on. I did get IP commands from Alcons but my C4 dealer says that there needs to be a driver for that device , they can’t send just an IP command to a specific IP address .
Steve Bruzonsky 07-22-2019 07:12 PM
My ATI Multi-channel amp (NCore 500 modules) and my new Trinnov 8 and 8m multi-channel amplifiers (NCore 1200 and 500 modules) all built by ATI have "sleep" circuits, so once powered on, they go on stqndby once their is no audio signal for 10 minutes. No need to worry about turning them on or off, just leave on standby and they wake up with signal.
Are your Alcons NCore amps bullt by ATI? If so, do they have this "sleep" circuit? If so no need in my book to worry about remote turn on or off.
mani 07-23-2019 08:08 AM
Hi Steve
From what I have learnt from talking to Alcons and to Walter , Alcons make their own amps ( they of course get the ncore modules from the source ) . I don’t know of any ATI amp that has SIS ( signal integrity sensing ), so I doubt they are making amps for Alcons - they use four conductors per speaker - 2 for audio signal and 2 for SIS . Alcons has a desktop app to control multiple sentinels at once and it works like a charm , and I can put them in standby mode through that app . That of course is not desirable if I can do that via C4 remote
Steve Bruzonsky 07-23-2019 09:39 AM
Originally Posted by mani (Post 58330654)
Hi Steve
Interesting!
From Alcons website:
https://www.alconsaudio.com/product/sentinel-10/
"The Signal Integrity Sensing™ circuit dynamically compensates the effects of long speaker cables; This results in a tight sub and bass response regardless of cable length or impedance (system damping factor of 10.000) and without the need for manually entering cable parameters. SIS™ also caters for futher reduced distortion (optimized cross-over drive)."
Powered by vBulletin® Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
