Subwoofers in a dual use HT / 2 channel system - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 10-05-2019, 09:40 PM - Thread Starter
scooter_29's Avatar
Quoted: 51 Post(s)
Anyone out there run a mixed use system that has a 2 channel preamp and HT processor where the preamp runs in bypass mode for movies? What did you do for subs?
The only product I could find that seems to make sense in this scenario is REL where you could have the speaker level input used just for 2 channel music listening and the line level input driven from the HT processor for movies.
scooter_29 is offline
post #2 of 7 Old 10-06-2019, 08:39 AM
Nyal Mellor's Avatar
Quoted: 544 Post(s)
Liked: 384
JL Audio CR1
Want to learn about home theater design and acoustics? Read our blog.
Company: Acoustic Frontiers - design and creation of high performance home theaters for discerning audio/video enthusiasts.
Certifications: HAA Level I & II, THX Video Level I & II, CEDIA EST I & II.
AVS Projects: Too many to show in my signature - see here for the master list.
Nyal Mellor is offline
post #3 of 7 Old 10-06-2019, 10:08 AM
Brucemck2's Avatar
Quoted: 82 Post(s)
Liked: 41
Originally Posted by Nyal Mellor View Post
JL Audio CR1
In this setup, in the processor, would you set L/R to Full Range and have LFE routed to L/R, using the CR1 to perform crossover duties?
Brucemck2 is offline
post #4 of 7 Old 10-06-2019, 03:53 PM
The Bogg's Avatar
Quoted: 610 Post(s)
Liked: 255
I used to have a trinnov st2 as the audio preamp and a separate ssp. The st2 had 4 channels so I could use 2 of my subs for 2 channel with the mains. It is a pretty good preamp, has room correction and eq, and allows for subs for 2 channel. My subs have 2 inputs so i had separate ht and stereo inputs going into them
Design by Rives...dollars by The Bogg
Click for my build thread
The Bogg is online now
post #5 of 7 Old 10-06-2019, 10:17 PM - Thread Starter
scooter_29's Avatar
Quoted: 51 Post(s)
JL Audio CR1
It’s close but won’t quite work right as the preamp runs in bypass mode so the main outputs would still always feed into the xover. The manual says you need to turn off 1 set of inputs to the CR1 and not drive both. Watching a movie would drive both.
post #6 of 7 Old 10-07-2019, 08:15 AM
Quoted: 544 Post(s)
Liked: 384
If it were a normal sub crossover, then yes, but with the CR1 you have ability to swap between managed bass inputs (CR1 crossover bypassed) and use of the CR1 for 2 channel.
post #7 of 7 Old 10-07-2019, 08:17 AM
Quoted: 544 Post(s)
Liked: 384
It will work - you can wire the system exactly as per scenario 3 in the user manual, where the preamp is out of the HT signal path.
