What SPL level have you calibrated your setup to? - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 11Likes
post #31 of 39 Old 06-28-2020, 04:34 PM
Russell Burrows's Avatar
Quoted: 158 Post(s)
Liked: 54
Red face
What about bone conduction of bass?I.E. I wonder if my risk of hearing loss will be less if i turn down my ib subs to a lower level but supplement with bone conduction from a boss system for frequencies of four hertz to sixty hertz?
Denon 4k avr, diy tla Behringer nx3000 dsp Fi car audio ib318 v2 310 cubic foot concrete ib lg 4k hu70la projector.steren projector mount upgraded at diy 135 inch screen sixteen subwoofers ten inch diameter boss build .
Pending buy quality dome midrange 1240 cubic foot ib for 16 fi car audio ib318 v2 subwoofers 4 nx3000 dsp
Russell Burrows is offline
post #32 of 39 Old 06-29-2020, 04:45 AM
Brucemck2's Avatar
Quoted: 86 Post(s)
Liked: 41
Originally Posted by CptSpig View Post
The seven series speakers are amazing but need to have the DSP files to sound right.
Do the self-powered versions of these also need the DSP files?
Brucemck2 is offline
post #33 of 39 Old 06-29-2020, 05:50 AM
Azekecse's Avatar
Quoted: 288 Post(s)
Liked: 306
75db for me, utilizing Radio Shack Analog Meter, after performing the Audyssey MultEQ® XT32 setup.
Peace and blessings,
Azeke
markrubin likes this.
Marantz SR7011: 7.4.4 Martin Logan Edges (4: FR/FL/SR/SL) Martin Logan Axis (2: SBL/SBR) Martin Logan Stage X (Center) Martin Logan 1500X Sub (2) Martin Logan 1100X Sub (2) Sonance VP86R SST/SUR (4: Dolby Atmos) JVC NX-7/DaLite 125" 2:35:1 Scope Screen; Paladin DCR
Azekecse is online now
post #34 of 39 Old 06-29-2020, 05:52 AM
CptSpig's Avatar
Quoted: 296 Post(s)
Liked: 112
No, the tuning files are in the amps.
CptSpig is online now
post #35 of 39 Old 06-29-2020, 10:17 AM - Thread Starter
Kain's Avatar
Quoted: 2156 Post(s)
Liked: 1037
Originally Posted by appelz View Post
No, I don't follow anything close to that. I'd need to look at more of that document, beyond just a chart to determine it's purpose, but I don't think it would apply to home theaters. We *have* an industry accepted guideline for how to set Reference Level.
Reference Level is a simple concept. First, Main speakers must be capable of hitting 105dB peaks at the listening position, and subs are required to attain 115dB peaks. I've seen some Dolby references for commercial theaters that suggest slightly lower requirements for surrounds, but those rooms often have arrays of surrounds. In a state-of-the-art private cinema, we have many discrete channels, so I design systems for 105dB all around. That said, many consumer rooms don't reach that criteria. Soft dome tweeters are rarely capable of that SPL without distortion. Such systems need high sensitivity speakers with high power handling capabilities, and large amplifiers to match, and I like to have some headroom above that.
Our hearing isn't linear, so we need a reference level to make sure that we have a consistent playback level among different systems. In the professional world, a test signal (pink noise, usually bandwidth limited) is recorded at -20dB relative to full scale (0dB) and is noted as -20Dbfs. That signal is played back through the system with the Volume set to 0 or whatever the appropriate reference level is for the audio processor. Then, each channel is individually adjusted to read 85dB at the listening position. Then, when a movie is played back, with the Master Volume set to 0, the Left channel peaks at 105dB. (85+20=105)
In the consumer world, 85dB was considered too loud, so the pink noise is recorded at -30dBfs, so we set our individual speaker levels to measure 75dB.
Note : Very few people actually listen at Reference. First, if their system isn't capable, it just sounds really really bad. Second..yup, that is loud, although in an well-engineered system volume levels can sneak up on you. And in a full Atmos system, with a dozen or more speakers all firing near Reference... I have some software that measures my noise level exposure over time during calibration sessions.
So now back to the problem; our hearing isn't linear. We don't hear all of the same frequencies equally at different volume levels. Most of my clients are enthusiasts, and listen to content at roughly the same volume, but if I have a client who listens at lower levels, I will make a compensation in the frequency response, but none of that has anything to with what is Reference Level. That is also part of the reason why I will set up a Movies Preset and a Movies Action Preset, along with a Music Preset. Typically different volume levels for each of those, so the frequency response may need to be tweaked.
Would you say a 105 dB peak at the MLP in a large room will sound the same as a 105 dB peak at the MLP in a small room?
Kain is offline
post #36 of 39 Old 06-30-2020, 09:17 AM
appelz's Avatar
Quoted: 855 Post(s)
Liked: 1009
I think we would want to make a distinction between what is a large room compared to a small room, but I would absolutely expect it to sound different. A couple things are happening. First, we have the dissipation from the air, which is actually two components, comprising the damping of SPL over distance along with the attenuation/dissipation of frequencies. The first is non-frequency dependent while the second case is. In small rooms, we are also dealing with a very different acoustical energy with all of the shorter reflection times which affect decay rate, and our brain knows the difference.
So if we are talking about sound with a large spectral component, say generated noise or music/movies, I would expect to hear a substantial difference between rooms of greatly differing size, acoustical treatments, quantity of large salt water based absorbers (humans), seats etc. The concert hall where I was the Technical Director for 12 years was designed to have periaktoi built into the walls so panels with different acoustical properties could be configured quickly for different shows (symphony, organ, plays, concerts, spoken word etc), as well as seats designed to be acoustically similar to a body if a show was lightly attended.
So yes, spectrally I would expect to hear a difference, and our earsbrain will recognize large vs small, but 105dB is 105dB, so I don't think it would sound louder or quieter.
Adam Pelz ,Acoustic Mafia - Hear No Evil
Level III Trinnov Altitude Calibrator, JBL Master ARCOS Calibrator, CEDIA Designer, Home Acoustics Alliance Instructor LIII, THX HT1+ HT2+ Video
Mercenary Calibrator for Manufacturers, Integrators and System Owners
appelz is offline
post #37 of 39 Old 07-06-2020, 03:51 AM - Thread Starter
Kain's Avatar
Liked: 1037
Nearly everywhere I read, they say that larger rooms are usually always preferred over smaller rooms. Would you agree with this? Are there any advantages that smaller rooms have over larger ones (maybe other than the fact that you can get away with smaller/lower SPL speakers as the listening distances are shorter/closer)? Also, I've read that small square or small almost square rooms are a big "no no" for audio. Would you agree with this too?
Kain is offline
post #38 of 39 Old 07-06-2020, 07:42 AM
appelz's Avatar
Quoted: 855 Post(s)
Liked: 1009
I would agree that larger rooms are preferred. SPL is more even across the listening area in larger rooms. There is a sense of space that in my experience really helps with immersion. Off the top of my head, the primary benefit to smaller rooms is cost, as you mentioned. Bigger rooms need more horsepower for audio and video, along with the other build-out costs that increase.
Square rooms, or even just rooms where dimensions are multiples (such as 16x24x8) end up having room modes that stack. Proper placement of subs and judicious use of PEQ can mitigate some of the problems though, so I wouldn't say a square room is a death sentence for room acoustics, although that was once considered to be the case.
appelz is offline
post #39 of 39 Old 07-06-2020, 06:17 PM
Reddig's Avatar
Quoted: 610 Post(s)
Liked: 1249
I love the larger sense of scale that a big room bring can bring to the table. As said that sense of space.
appelz likes this.
JTR/JBL/JVC/Denon/Oppo/Monolith/Silver Ticket/Furman/Seatcraft/Acoustimac/AudioQuest/Harrison Labs/Roku
Reddig is offline
