Anyone using room connection software for two channel stereo - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By audioguy
  • 1 Post By J.Mike Ferrara
post #1 of 8 Old 02-01-2020, 04:39 PM - Thread Starter
J.Mike Ferrara's Avatar
Quoted: 215 Post(s)
Liked: 220
Hi, I've got on order the McIntosh MEN200 Room Correction system. Based on the Lyndorf-Steinway room correction system, I'm anticipating that it will cleanup the muddy bass from my KEF Blade speakers.
Any comments would be appreciated.
J.Mike
Those who die with the most toys ... are still dead!
J.Mike Ferrara is offline
post #2 of 8 Old 02-02-2020, 10:04 AM
b curry's Avatar
Quoted: 1179 Post(s)
Liked: 759
Try it. I think you'll like it.
If not, you can turn it off.
b curry is offline
post #3 of 8 Old 02-03-2020, 06:17 AM
audioguy's Avatar
Quoted: 5523 Post(s)
Liked: 4624
Prior to my current processor, I used Dirac that was housed in my Music Server. It is great since it allows so much control over target curves, how much of the signal you correct, etc. Other than something like a 2 channel Trinnov, nothing comes close. HIGHLY recommended.
Montucky likes this.
audioguy is offline
post #4 of 8 Old 02-07-2020, 12:36 PM
DreamWarrior's Avatar
Quoted: 1227 Post(s)
Liked: 751
May I at least throw out there that the "muddy bass" you experience could be the result of poor room integration (because you should have subs)?
I have had a 2.x system (three pairs of subs) for a while. Being able to move the subs independently of my (very capable) mains has made things sound many times better (even without room correction, just by tweaking each sub's location, level and delay).
I'm not saying that there's no way to do 2 channel sans subs well (indeed, I just posted as much somewhere else, recently), but it's much harder in normal rooms, requiring a room which allows ideal positioning (for both imaging and bass) of the two mains. Adding subs eases those requirements; place your mains for best imaging (tweak for sub integration if needed) and then place your subs for best bass response (preferably multiple, at least two; try an initial position at your room's corners or its quarter-wall points).
Moreover, IMO, the biggest thing the room correction software will help with, if you get the right one (and McIntosh MEN200 uses Room Perfect which is supposedly excellent), is the integration between your mains and subs. So, the hardest part of the whole thing, that which most people complain about when adding subs to a 2-channel system, is, with the right RC solution, done for you. However, I don't know if your McIntosh unit can blend multiple subs -- perhaps await a unit that integrates the upcoming Dirac Bass Management solution (or spend on Trinnov, which is very likely to be a very long-term solution if you can afford it).
Best of luck!
DreamWarrior is offline
post #5 of 8 Old 02-29-2020, 02:40 PM - Thread Starter
Quoted: 215 Post(s)
Liked: 220
Well, I have been living with RoomPerfect for a week now. Never in the 30+ years has the sound of my system been so glorious. Really. The KEF Blade 2s shine. The soundstage is extended both left/right and back/forwards. Muddy bass is gone forever - it's now musical and provides a spine-tingling experience. Just wow. To sonically pick out instruments and background voices is a new thing in my listening room.
HIGHLY RECOMMENDED.
Name:	IMG_1094 (Edited).jpg
J.Mike
post #6 of 8 Old 02-29-2020, 02:43 PM - Thread Starter
Quoted: 215 Post(s)
Liked: 220
PS - you do not need subs with the Blade 2s.
J.Mike
post #7 of 8 Old 02-29-2020, 04:06 PM
Brucemck2's Avatar
Quoted: 83 Post(s)
Liked: 41
I’ve used Trinnov, Dirac, and Acourate. All three work really well for two channel (and two channel with subs) applications - even in a purpose built room with extensive room treatments. At some point I’ll likely try RoomPerfect too.
Brucemck2 is offline
post #8 of 8 Old 02-29-2020, 05:11 PM
The Bogg's Avatar
Quoted: 656 Post(s)
Liked: 292
Very true. In many purpose built rooms (including mine) at least one of the dimensions is fixed. For me it was height. The ratio of the room dimensions makes a significant difference to the bass balance. I spent $$$ on the room itself and when I first added the ARC room correction to my Anthem D2 for $ it was a revelation. Subsequently tried the Trinnov ST2 and then Dirac and it really is true that room correction takes things to the next level. I'm sure there are a few rooms that don't need it but I've yet to hear them.
Design by Rives...dollars by The Bogg
Click for my build thread
The Bogg is offline
