AVS Forum | Home Theater Discussions And Reviews (https://www.avsforum.com/forum/)
-   Ultra Hi-End HT Gear ($20,000+) (https://www.avsforum.com/forum/86-ultra-hi-end-ht-gear-20-000/)
-   -   Isco IIIL for 3840 or 4k? (https://www.avsforum.com/forum/86-ultra-hi-end-ht-gear-20-000/3145752-isco-iiil-3840-4k.html)
sstephen 05-16-2020 08:37 PM
There is an isco iiil for sale at a reasonable price, but before I start negotiating I'd like to know how future proof the purchase is going to be, so I'm wondering how good the optics are on the isco IIIL compared to the paladin? I'm posting in this section, because this is where I expect most of the experience is. Maybe I should have posted in the >$3k section
I'd like to move to a 4k or 3840 projector sometime in the future, but not sure when that will be. I was thinking about the nx9 that was recently in the classified section. I'm not married to jvc though. The 2 projectors I've owned have both been dlp. Current is a Marantz vp 15s1.
I'm currently using a panamorph 480 and it has some problems and I've read that it won't do a 4k projector justice. The isco would be a big step up, but I'd like to know if it will be ok with a 4k or 3840. I know many would say that with a 4k the aspect ratio won't be quite correct. Either I'd lose some pixels or the screen would be too wide. Keep in mind that with the panamorph 480 I currently get some pincushion and the image is a bit compressed in the middle and a bit expanded at the sides. This is quite noticeable looking at a test pattern, but it honestly doesn't bother me much when I watch a movie. So I'm wondering if a bit of extra stretch would bother me much.
Thx in advance.
Steve Bruzonsky 05-17-2020 09:08 AM
There is a thread at this forum in the past 6 months on this very subject - do a search and you'll find it!
Killroy 05-18-2020 01:55 PM
Thx in advance.
ISCO III optics are more than capable of 4k resolution. I use one on my RS3000 and it can resolve the QBF chart perfectly.
Check eBay for used ISCO IIILs. There were three in the past 48-72 hours. Last one went for a tad over $1000. Most are averaging mid $1000. BTW, use keywords for your searches as some IIIL are also re-branded as Runco.
sstephen 05-18-2020 03:43 PM
you are much better at doing the searches than I am then. I get tons of camera lenses or runco projectors, but not just lenses for projectors. The only lens in there for < $2k I can see is someone who won't even respond to questions so I can't ask if he'd ship to Canada, and the post certainly looks like he'd rather not. :)
Killroy 05-18-2020 07:10 PM
Sent you a PM with some help.
Craig Peer 05-19-2020 08:08 AM
I just searched Ebay and found two. Here's one - https://www.ebay.com/itm/ISCO-IIIL-w...EAAOSw0i9eZQMi
Note that the 1.33 lenses will work with 3840 x 2160 projectors, but if you have a 4096 x 2160 projector, you really want a 1.25:1 lens. Isco makes those too.
sstephen 05-19-2020 12:01 PM
Thanks. I had seen that. When converted to CDN it is a bit more than the one I was looking at.
Powered by vBulletin® Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
