Soliciting Advice on new HT Setup - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 06-27-2020, 09:46 AM - Thread Starter
RS3771's Avatar
Quoted: 334 Post(s)
Liked: 91
A buddy of mine has requested comments/recommendations on his proposed HT Setup. And I'm posting it here on his behalf. Thanks in advance for your valuable inputs.
1. Mission Audio-SX5 (Quantity: 2)
3-way Bass Driver : 3x160mm Aluminium Cone: Bass/Mid Driver : 160mm Aluminium Cone; Treble Driver : 25mm Titanium Dome; Peak SPL -110dB: Sensitivity : 90dB
2. Mission Audio SX C2 (Quantity: 1)
Center Channel – Bass Driver : 2x130mm Aluminium Cone; Mid Driver : 2x130mm Aluminium Cone; Treble Driver : 25mm Aluminium Cone; Sensitivity : 90dB
3. Mission Audio SX2 (Quantity: 4)
2 Way Bass Driver : 160mm Aluminium Cone; Treble Driver : 25mm Titanium Dome
4. Mission Audio MS-450 Mission MS-450 (Quantity: 2)
- 450W Active Subwoofer. The MS Series can radically improve any home cinema or stereo system from flat, mundane audio to a bass-rich cinematic sound. 1x(15”)380mm cone long-throw; Peak power output : 850W; Avg Max [email protected]
5. KLIPSCH DS-180 CDT In-Ceiling Speakers (Quantity 4)
Frequency Response 60Hz-23KHz ± 3dB Sensitivity 94dB @ 2.83V / 1m Nominal Impedance 8 ohms compatible Crossover Frequency 2440Hz Power Handling 50W RMS / 200W Peak Recommended Amplifier Power 100 W High Frequency Driver 1” (2.54cm) Aluminum diaphragm compression driver mated to a swiveling 100° round Tractrix® Horn Low Frequency Driver 6.5" (16.51cm) pivoting Cerametallic™ cone woofer Enclosure Material/Type ABS/Infinite baffle, front flush with wall Wire Gauage
Accommodated 12 ga Diameter 9.5" (24.13cm) Cutout Dimensions 8.3" (21.08cm) Mounting Depth 4.5" (13.72cm) Weight 7 lbs. (3.18kg)
6. Marantz AVR SR-7013 (Quantity 1)
9.2 channel AV Receiver with 8 Ohms driven per channel; 8 HDMI inputs (incl. 1 front) with full HDCP 2.2 support; 3 HDMI outputs (incl. Zone 2); Advanced
video processing with analog to HDMI, SD to HD/4K Upscaling; 4K/60 Hz fullrate pass-through, Dolby Vision compatibility, HDR, HLG and BT.2020; Threedimensional
audio formats IMAX Enhanced, Dolby Atmos, DTS:X (up to 7.1.4 with an external 2ch amplifier), Auro-3D and DTS Virtual:X for height virtualization effects; eARC (Enhanced Audio Return channel) supports the transmission of 3D audio from your TV apps with a single HDMI connection; Stream music from Internet Radio, Spotify Connect, Pandora, SiriusXM, Amazon Music, TIDAL, Deezer and more with Bluetooth, Airplay 2 or HEOS built-in; Built-in Wi-Fi with 2.4GHz/5GHz dual band support; Enjoy multi-room whole-home audio streaming with HEOS technology
7. Marantz AV separates MM7055 (Quantity 1)
Power Output : 140W (20Hz-20kHz, 0.08%); S/N Ratio : 105dB; Freq. Response
(Analog In) : 8Hz-100kHz (+/- 3dB)
8. Elite curve Fixed frame acoustic pro 4k screen (16:9 format)
Satin Premium fabric make screen of size 10ft Height 5.7ft diagonal 138”
9. JVC LX-UH1B 16:9 format)
The LX-UH1 is a high-performance 4K UHD/HDR home theatre projector with compact design and wide lenses shift for easy installation; 2000 lumen output; Compatible with HDMI Standards(4K/60P 4:4:4) and HDCP 2:2 Dynamic contrast Ratio: 100000:1; Brightness : 2000lm
10. Bluray Player - Panasonic BDP-380
11. Profi Gold Speaker Cable – 99.96% OFC cable with silver coating – 2.5 sq mm
12. Profi Gold HDMI Cable version 1.4a –– 10 meters length
13. Profigold Subwoofer Cable – 10mtrs
14. Custom Projector Bracket
RS3771 is offline
post #2 of 2 Old 06-29-2020, 02:03 PM
CP850-CLED's Avatar
Quoted: 74 Post(s)
Liked: 145
Mission has been around for decades. The review of the mains seems good and has enough bass for movies, rock and hip hop. The only thing that strikes me is that that this sx series has been discontinued.
The surround receiver could be improved to separates budget permitting.
"I have spoken."
CP850-CLED is online now
