For all D-Box enthusiasts ! - Page 275 - AVS Forum | Home Theater Discussions And Reviews
 450Likes
post #8221 of 8243 Old 07-27-2019, 07:27 AM
Quoted: 183 Post(s)
Liked: 76
Originally Posted by SOWK View Post
What was the best way to get the HEMC to update the motion codes?
I am stuck on July 19 Update
I keep it always ON so every so I am updated and never be late
A7mad78 is online now
post #8222 of 8243 Old 07-29-2019, 06:01 AM
Home Theater Enthusiast
SOWK's Avatar
Quoted: 1437 Post(s)
Liked: 483
I leave mine ON as well. But it is still stuck on the July 19th update.
Wisconsin Home Theater Enthusiasts Meet: Main Thread
Home Theater: SOWK Home Theater
SOWK is online now
post #8223 of 8243 Old 07-29-2019, 06:13 AM
Quoted: 183 Post(s)
Liked: 76
Should try with the support it should be updated
post #8224 of 8243 Old 07-29-2019, 10:31 AM
SOWK's Avatar
Liked: 483
Apparently it was a problem for many and they said it should be fixed. Mine is fixed.
A7mad78 likes this.
SOWK is online now
post #8225 of 8243 Old 08-05-2019, 06:42 AM
SOWK's Avatar
Liked: 483
I have an additional New un-used D-Box SRP-230 (4250C) 3-Axis Left&Right - 250Lbs, that I may be willing to sell for dealer cost.
PM if interested.
But otherwise I will be using it for a back up in case one of my current chair D-Box systems break.
SOWK is online now
post #8226 of 8243 Old 08-07-2019, 11:39 AM
Liked: 0
Hello, everyone, I'm looking to buy a KCA-T or Kinechain Adapter with Termination at a reasonable cost (below retail). If you have one lying around that you don't foresee a use for, I will gladly pay for it. Thank you.
blinkrhythm is offline
post #8227 of 8243 Old 08-10-2019, 06:41 AM
Sandel's Avatar
Quoted: 38 Post(s)
As the HEMC can only deal with analog 2 channel audio in, I ran into trouble with Apple recently going the "Dolby MAT" way for Atmos streams which my Atlona can't decode. I talked to the Atlona support and they said it's hardware related so no firmware update will help in this case.
So, my question is: How do you get AppleTV 4k Atmos movies into your HEMC?
Sandel is offline
post #8228 of 8243 Old 08-11-2019, 08:17 AM
Gatorknight's Avatar
Liked: 0
I'm hoping for a little help. My Series IV stopped working last night. When I power it up, you can hear it turn on and begin to start, but then the green power light does not come on and the controller does not go through its normal start up cycle (board detection, loading library code, etc.) I've tried unplugging the controller and restarting it, but this doesn't fix the problem. Any suggestions short of contacting D-Box? I didn't know if there were any other kind of resets or fixes one can try first. Thanks in advance for any advice or if anyone else has encountered this problem.
Gatorknight is offline
post #8229 of 8243 Old 08-11-2019, 11:07 AM
SOWK's Avatar
Liked: 483
Work around that will work.
Apple TV to HDMI splitter
One HDMI to your current processor
One HDMI to a second Dolby MAT capable processor and use the L/R pre outs to 3.5mm
SOWK is online now
post #8230 of 8243 Old 08-11-2019, 01:03 PM
SOWK's Avatar
Liked: 483
I would call D-BOX for sure.
Otherwise the switch to the HEMC might be worthwhile, if it is in the budget.
SOWK is online now
post #8231 of 8243 Old 08-11-2019, 02:07 PM
Sandel's Avatar
Quoted: 38 Post(s)
Sounds good. But I've yet to find a Dolby MAT capable processor... Could you recommend one?
Sandel is offline
post #8232 of 8243 Old 08-11-2019, 02:26 PM
SOWK's Avatar
Liked: 483
Would a current year 2019 Denon or Marantz not support the format?
Basically you can use a dedicated AV receiver with pre/outs as the Atmos/DTS X processor and convert to 3.5mm stereo.
SOWK is online now
post #8233 of 8243 Old 08-11-2019, 02:35 PM
Sandel's Avatar
Quoted: 38 Post(s)
I suppose you're right. But isn't there a smaller solution? I think buying a receiver just to get stereo out, seem's a bit too much, I'd say.
Sandel is offline
post #8234 of 8243 Old 08-11-2019, 02:36 PM
SOWK's Avatar
Liked: 483
Sometimes you got to do what you got to do.
That way you know it will always work.
SOWK is online now
post #8235 of 8243 Old 08-11-2019, 06:30 PM
SOWK's Avatar
Liked: 483
Another cheap way is to connect a microphone to the 3.5mm jack as well and just have it listen to the audio in your room.
SOWK is online now
post #8236 of 8243 Old 08-11-2019, 11:37 PM
Sandel's Avatar
Quoted: 38 Post(s)
That's really something I could try, thanks!
Sandel is offline
post #8237 of 8243 Old 08-12-2019, 11:44 AM
SOWK's Avatar
Liked: 483
Please let me know if that works for you.
SOWK is online now
post #8238 of 8243 Old 08-12-2019, 12:54 PM
Sandel's Avatar
Quoted: 38 Post(s)
Will do.
SOWK likes this.
Sandel is offline
post #8239 of 8243 Old 08-13-2019, 05:57 PM
xhonzi's Avatar
Quoted: 44 Post(s)
Liked: 24
My 340c did something like this a few years back. Basically, the motherboard capacitors went bad, and I had a local bloke replace them for under $10. Your mileage may vary.
xhonzi is offline
post #8240 of 8243 Old 08-13-2019, 05:58 PM
xhonzi's Avatar
Quoted: 44 Post(s)
Liked: 24
Anyone want to place bets on when Endgame debuts?
Or Shazam for that matter?
xhonzi is offline
post #8241 of 8243 Old 08-14-2019, 02:54 AM
SOWK's Avatar
Liked: 483
Shazam D-Box code is out already.
End Game will likely be this Friday.
SOWK is online now
post #8242 of 8243 Old 08-14-2019, 09:05 AM
Sandel's Avatar
Quoted: 38 Post(s)
It seems to work! I'm using a CCTV surveillance microphone and it works pretty good!
SOWK likes this.
Sandel is offline
post #8243 of 8243 Old 08-14-2019, 09:15 AM
SOWK's Avatar
Liked: 483
You are welcome.
Sandel likes this.
SOWK is online now
