The OFFICIAL Emotiva Speaker Owner's thread! - Page 27 - AVS Forum | Home Theater Discussions And Reviews
 122Likes
post #781 of 806 Old 05-16-2019, 07:05 PM
tonybradley's Avatar
Quoted: 521 Post(s)
Liked: 195
Originally Posted by Soulburner View Post
12 awg is not beneficial until you are approaching wire runs of 50 feet. And, as others noted, it gets hard to get behind the speaker when flat against the wall. I'm using 14 awg.
I ran 12 in my HT 14 years ago to all the speakers. I will be fine with the wire behind the speaker as I only have a little coming out of the wall, so the cavity around the binding posts will take the excess just fine. My current bookshelf speakers are mounted flat now.
I've been fine with 12s all these years until I purchased some Monoprice Banana Plugs that said they work up to 12. Well, I guess they did, but only with hours spent and bloody fingers for all 7 speakers in the back of the receiver. Trying to separate the strands on 12, and fold over just a tiny bit over the plug, but not too much as the other part can't screw down and clamp it, was near impossible with 12. Was wishing I had run 14. I watched a video of someone else installing with those banana plugs with 12 gauge and it looked simple. His wire looked no bigger than 14 and not even quite that. At least compared to my 12 that I used. That stuff is stiff!!!
Tony
tonybradley is offline
post #782 of 806 Old 05-17-2019, 04:17 AM
Quoted: 49 Post(s)
Liked: 24
What 12ga speaker wire are you using? All the ones i have used have been very flexible. I used amazon banana plug that are the same type and amazon wire. It was pretty quick and easy.
Gold87 is offline
post #783 of 806 Old 05-17-2019, 06:31 AM
Baff's Avatar
Quoted: 89 Post(s)
Liked: 76
I believe he is using solid core instead of stranded wire. Certainly a pain in the butt to use at that size, and might be an issue getting into the E1s. Rather than rewiring everything through walls or shaving down the solid 12s, it might be easier to just splice on the some stranded wire for the last few inches to connect to the speakers?
Lp85253 likes this.
LG 65" C9; Denon AVR-S750H
5.1.2: Emotiva Airmotiv C2, T-Zero (x2), E1 (x4); HSU VTF-2
Baff is online now
post #784 of 806 Old 05-17-2019, 01:01 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 1158
Calculator number 5:
https://www.crownaudio.com/en/tools/calculators
Also:
https://www.electrovoice.com/cableloss.php
With 100 watts going into the wire, you tend to lose about 1 watt (1%) as you approach 50 feet with 14 awg copper wire. This results in about 0.10dB less output. 100 watts into the wire is about 30 volts, or so I found in my research.
Most of us aren't putting 100 watts into surrounds, especially not with an AVR!
Baff likes this.
HT: Samsung PN64H5000 (recommended settings) | NAD T758 V3 | Buchardt S400 (2) | Emotiva E2 (2) | Rythmik Audio F12 (2)
Soulburner is online now
post #785 of 806 Old 05-17-2019, 04:13 PM
krauley's Avatar
Quoted: 69 Post(s)
Liked: 65
Are either of you two using 12 gauge wire for your surrounds? Wondering if 12 works well for the E1s since the posts are spring loaded.
Im using 12 gauge all around, didnt seem like having multiple sizes of speaker made sense. On my E1s i had to add a connector to get them connected as i couldnt get the bare wire through the hole in that spring loaded thing. My eyes and not the size of the wire was why. i used something like these
but not so big lol
Lg G6
Oppo 203, Ps4Pro
Emotiva, XMC-1 V3, Xpa-2, Xpa-5
PSA V1801
Airmotiv T2(front), C2(Center), T1(surrounds), E1(surround backs)
krauley is offline
post #786 of 806 Old 05-17-2019, 04:19 PM
krauley's Avatar
Quoted: 69 Post(s)
Liked: 65
Ok so i got my T2s, T1s, C2 connected and the E1s hung. I had too many power strips and too much extra lengths of speaker wire tucked away so i straightened all that out and it took me most of the day. The polks i had hanging used a different bracket than the one the E1s used so i had to reconfigure that out also. But all of that is behind and im listening to the new speakers now. All i have to say is WOW what a difference. The T2s are bad ass. So much better than the polk mon 70s i had hooked up. So full and clear. Everything is sounding so much better and i havent run Dirac on the system yet. I will run it tomorrow but right now im a happy man.
gajCA, Lp85253 and mpk1970 like this.
Lg G6
Oppo 203, Ps4Pro
PSA V1801
krauley is offline
post #787 of 806 Old 05-18-2019, 08:52 PM
Quoted: 92 Post(s)
Liked: 41
Just recieved my T1/C2/E1 today. People are not kidding when they say the C2 is massive.
One thing i am not sure of is the E1 mounting. It looks like it can be mounted with tweeter on top or bottom. Does it matter? If i outt the tweeter on top at ear lvl the woofer will sit below the couch for the most part.
surrounds should be a bit above ear level to ensure direct line of sight to all listening positions
8KCRT is offline
post #788 of 806 Old 05-18-2019, 08:53 PM
Quoted: 92 Post(s)
Liked: 41
Which AVR?
8KCRT is offline
post #789 of 806 Old 05-19-2019, 04:36 AM
Quoted: 521 Post(s)
Liked: 195
I'm not using Solid Core or wouldn't be able to spread out the strands on the banana plugs I installed
I can't remember the brand. I installed it 14 or so years ago. It was either Monoprice or I purchased it from Lowes. I am not sure. But, it's stout.
I haven't installed my E1s yet. I spent all day working out side yesterday and running REW for sub placement last night.
Tony
post #790 of 806 Old 05-19-2019, 07:27 AM
Quoted: 36 Post(s)
Liked: 9
I hope to put to rest, what I believe to be a myth. Many people, including myself, hesitate due to the 4 oms. With all the opinions I have read, it sounds like this shouldn’t stop anyone from buying.
Has anyone ever had an issue driving these or with overheating? I haven’t seen any post where anyone made that claim, but I could have missed it somehow.
Also, I can set my receiver (Onkyo 686) to 4 oms. Then I saw articles saying not to waste your time doing that, that things will run just fine without making that adjustment. Should I make that adjustment to be on the safe side or follow that advice?
I
wnydel2 is offline
post #791 of 806 Old 05-19-2019, 08:04 AM
Quoted: 49 Post(s)
Liked: 24
I
I have an onkyo 830, upgraded from the 686, and it has no issues with the 4 ohm speakers. From what i have read up on them 4 ohms is the lowest they go but alot ore running these speakers on older recievers not even stating a they will run 4 ohm but the onkyo state you can.
I did run 4 ohm speakers on the 686, monoprice atmos speakers, set at 4 ohms for 2 weeks with no issues. Replaced the 686 just due to the good deal on the 830 i got.
I also followed the recomedarion online and did not set the speakers for 4 ohms i left it at 6 and have not had an issue.
Gold87 is offline
post #792 of 806 Old 05-19-2019, 08:40 AM
Quoted: 49 Post(s)
Liked: 24
I was looking at the E2 to replace the E1 i purchased. I have the E1 behind the couch and the couch is just 1 ft from the wall. I can angle the E1 in like i did with the book shel speaker i had and it does not seem to surround me as it used to. I was thinking of moving the e1 into the center to do 7.2.4 set up eventually. I have a 5.1.2 at the moment. I could also try and use the E1 as refective atomos speakers as they are cheap anyways
Gold87 is offline
post #793 of 806 Old 05-19-2019, 09:04 AM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 1158
If you are referring to using them as an upfiring speaker, don't bother. Upfiring speakers have their frequency response modified so it reaches your ears "correctly" after augmentation by the ceiling bounce.
I'm a bit confused about your setup. If you have a 5.1 system, you'd have surround speakers at the sides but not at the back.
post #794 of 806 Old 05-19-2019, 09:42 AM
Quoted: 49 Post(s)
Liked: 24
With my room set up i cant put side speakers. Only against the back wall ( making the best of the room)Good to know they wont work reflecting the e1. I might just try to ceiling mount them as i have seen others do before.
I also pulled the couch away from the wall so the speakers would not be mounted on my head. I was thinking the E2 would atleast fill out the sound more since the tweeter are angled
Gold87 is offline
post #795 of 806 Old 05-20-2019, 05:35 AM
Quoted: 1284 Post(s)
Liked: 1427
T2s are so good. Enjoy!!
Lp85253 likes this.
Set up #1 Speakers LRC: Emotiva T2 & C2, Rears: Emotiva B1, Subs (2) 2019 JTR 118HTs, Receiver: Marantz SR5012, 7.2,100 Watt, AMP: Outlaw5000
Set up #2 Son's Room: QA3020i LR, Emotiva C1 Center, Denon AVR, Subs (2) HSU VTF2 MK5,
Set up #3 Elab B6 2.0 Debut w Fosi Audio amp 50W Set up #4 QA3020 w Fosi Audio amp 50W Set up #5 Chane's A1.4 w Fosi Audio 50W amp
mpk1970 is online now
post #796 of 806 Old 05-20-2019, 02:13 PM
shortstack31489's Avatar
Quoted: 27 Post(s)
Has anyone used (3) C1 centers in an LCR configuration. Looking to change speakers and these have caught eye as I have enjoyed my current atmos speakers from emotiva. How is the imaging and soundstage? Looking for dynamic soundstage strictly for home theater usage.
5.2.2. Display: Sony XBR74X940e, Speakers: Monitor Audio RS6, RSLCR, RS-FX, Atmos: Emotiva E2, Subs: SVS PB-12NSD x 2, Receiver:Denon AVR-X3300, Amp: Rotel RMB-1075, Sources: Xbox One X, PS4 Pro, Nintendo Swith, Denon DBP-1610, Roku, Toshiba HD-A3, Power Conditioners:Monster HTS-2600, HDP1800, Remote: Harmony Touch. Desktop: MA BR1, Dayton Sub800, Klipsch Powergate, Sennheiser HD58X, JDS Atom. PC: Ryzen 2700x, EVGA RTX 2080, 32gb DDR4
shortstack31489 is offline
post #797 of 806 Old 05-20-2019, 03:19 PM
Quoted: 1907 Post(s)
Liked: 1620
i think you are on to something , but , i think that a pair of t1's and a c2 do the same thing at less $$ (with close out prices)....
mpk1970 likes this.
YAMAHA TSR 5790.. front l/r emotiva b1's and /or kef q100's ..BIC v1220.....Emotiva basx10.... ascend cbm 170 center.. polk t15 rears..samsung 55" j620d
bedroom .. YAMAHA r-xv 383... front l/r.. wharfedale 10.1s... ascend cbm 170 center ... Emotiva basx8... samsung ku6300 50 in
Lp85253 is offline
post #798 of 806 Old 05-20-2019, 07:20 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 1158
Do you have room to mount all 3 horizontal?
post #799 of 806 Old 05-20-2019, 08:16 PM
Dan Hitchman's Avatar
Quoted: 4431 Post(s)
Liked: 2497
Any word on when these updated Airmotivs with additional models that support better Atmos "friendliness" (supposedly) will get released?
Dan Hitchman is online now
post #800 of 806 Old 05-21-2019, 02:09 AM
Quoted: 27 Post(s)
Although I could, I would prefer to mount two of them vertically given my room dimensions
post #801 of 806 Old 05-21-2019, 04:09 AM
krauley's Avatar
Quoted: 69 Post(s)
Liked: 65
than the t1 pair + c2 would be cheaper than 3 c2 centers.
Lg G6
Oppo 203, Ps4Pro
PSA V1801
krauley is offline
post #802 of 806 Old 05-21-2019, 05:50 AM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 1158
Dispersion will be negatively affected mounting a center channel vertically. You'll get uneven response as you move side to side.
Lp85253 likes this.
post #803 of 806 Old 05-21-2019, 09:25 AM
Liked: 1620
that's the part i thought might end up being expensive .. or a diy effort.. or not doable at all , i don't know what is involved with flipping those tweeters around...
Lp85253 is offline
post #804 of 806 Old 05-21-2019, 12:47 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 1158
It's not the orientation of the tweeter, it's the placement of all of the drivers. The design is intended to create a horizontal dispersion pattern that is even, when used in its designed, horizontal placement. If you flip it vertically, you'll end up with that dispersion changing to vertical, with poorer horizontal performance. You would need to move all of the drivers to change that.
Much better to get speakers designed to be vertical if that's the intended placement.
Lp85253 likes this.
post #805 of 806 Old 05-21-2019, 04:03 PM
Liked: 1620
i thought i saw something somewhere that said about July, that's just going from memory though, i can't remember if it was even what i would consider a good source..
Dan Hitchman likes this.
Lp85253 is offline
post #806 of 806 Old Today, 05:49 PM
Quoted: 121 Post(s)
Liked: 119
Rockin out to the emotiva t1's with some Metallica black album.....sound good playing it.
Lp85253 likes this.
stngray72 is offline
Reply Speakers
Emotiva , Emotiva Audio Corporation
