Official Selah Audio Owner's Thread - Page 12 - AVS Forum | Home Theater Discussions And Reviews
 47Likes
post #331 of 352 Old 04-25-2019, 06:03 AM
Rick Craig's Avatar
Quoted: 147 Post(s)
Liked: 244
Originally Posted by Russdawg1 View Post
Quite a speaker Rick. Got any pointers for someone who’d be interested in designing their own speaker from the ground up?
I’d like to build my own towers or line array in the near future, that’s why.
The best way to learn is by starting with a kit. After that comes reading all that you can (such as Vance Dickason's book) and acquiring crossover design software and measuring equipment.
BluesDaddy56 likes this.
Selah Audio
Thinking Inside the Box...
Rick Craig is offline
post #332 of 352 Old 04-25-2019, 02:59 PM
Rick Craig's Avatar
Quoted: 147 Post(s)
Liked: 244
Here's a center channel I recently deigned to match a a pair of Adam L/R speakers. Due to space constraints (7" maximum height) and the desire for a high quality AMT or ribbon driver I chose one that would cross low. The mids are Eton Hexacone 3" drivers which is what many of the Adam speakers use. With a horizontal MTM layout the spacing of the mids and tweeter becomes very important.
I've attached horizontal and vertical off-axis plots. The first graph is on-axis with the tweeter and fifteen degrees off-axis horizontally. With the low crossover point, steep acoustic crossover slopes, and close driver spacing the response stays very uniform. The next graph adds the thirty degree horizontal curve and it shows some changes due to the delayed signal of the midrange that's further away as well as the woofer on that side. Due to the symmetrical layout both sides will have the same coverage which is a good thing as that's what the movie sound engineer intended.
Vertically the coverage remains uniform out to 10K at ten degrees and remains uniform at seventeen degrees but starts to roll off more at 4K and above due to the 76mm length of the ribbon. How important this is depends on your listening angle but dialogue should still be in good shape.
This represents what I feel is the limit of a horizontal MTM layout and if you don't need a ribbon/AMT/planar driver a good low profile option is a small neo dome and 3"-4" mid vertically arranged or a concentric driver (Elac, KEF, etc.). If height permits a WMTW layout has better coverage than the horizontal MTM arrangement. The WMTW also works well behind a screen if a vertically placed center isn't possible.
ID:	2558166   Click image for larger version
Name:	AJCC 0-15 deg horizontal 1-12 oct 1M 5 msec blend.jpg
ID:	2558168   Click image for larger version
Name:	AJCC 0-15-30 degrees horizontal 1-12 oct 1M blend 5 msec.jpg
ID:	2558170   Click image for larger version
Name:	AJCC 0-10-17 degrees vertical.jpg
Selah Audio
post #333 of 352 Old 04-28-2019, 07:36 PM
Rick Craig's Avatar
Quoted: 147 Post(s)
Liked: 244
Our version of "modern rustic"...
ID:	2559680   Click image for larger version
ID:	2559682   Click image for larger version
Selah Audio
post #334 of 352 Old 04-28-2019, 08:05 PM
canyoncreek's Avatar
Quoted: 65 Post(s)
Liked: 87
Iluminismo - scanspeak illiminators? Be tweet? Active bass or passive?
Sent from my SM-G955U using Tapatalk
canyoncreek is offline
post #335 of 352 Old 04-28-2019, 11:26 PM
Quoted: 89 Post(s)
Liked: 35
Hmm, is that a cabinet available from OEM sites or is that a custom cab? It looks almost exactly like the one used in the Joseph Audio Pulsar. I wonder if you could take that cab, use the Seas T25CF002 and W15CY and just make a clone for like half the price, lol.
driedmango is offline
post #336 of 352 Old 04-29-2019, 06:32 AM
Rick Craig's Avatar
Quoted: 147 Post(s)
Liked: 244
SB Acoustics Satori woofers and beryllium tweeter. The bass section is passive; however, an active version is a great option.
Selah Audio
post #337 of 352 Old 04-29-2019, 06:41 AM
Rick Craig's Avatar
Quoted: 147 Post(s)
Liked: 244
A custom cabinet. Faceted designs of course go back several years and there's only a few ways to make them. Jeff Joseph is a nice guy and the Pulsar is a good speaker.
Selah Audio
post #338 of 352 Old 04-29-2019, 07:11 AM
dbissett's Avatar
Quoted: 45 Post(s)
Liked: 51
I'm planning to be at the Dallas show this weekend and was wondering what you'll be showing there. Can you say?
David
dbissett is offline
post #339 of 352 Old 04-29-2019, 07:59 AM
Rick Craig's Avatar
Quoted: 147 Post(s)
Liked: 244
David
Yes, the Ritorno 2-way monitosr and the Omaggio line arrays. Looking forward to meeting you!
ID:	2559808   Click image for larger version
Name:	The Omaggios.gif
BluesDaddy56 and Russdawg1 like this.
Selah Audio
post #340 of 352 Old 04-29-2019, 08:35 AM
BluesDaddy56's Avatar
Quoted: 549 Post(s)
Liked: 739
Those are quite beautiful, Rick.
overg likes this.
Display: Vizio P55-E1l Pre-pro: Marantz 7703; Amps: Emotiva XPA-2 Gen 2, Emotiva XPA-3 Gen 1, H/K AVR 520 (direct in to amps); Sources: Sony UBP-X700; X-box 1 S; Technics 1200 Mk II; Win10 PC for digital; Phono Preamp: Emotiva XPS-1; Speakers - LR: Philharmonic BMR LR, Center: Emotiva Airmotiv C2; Surrounds: Wharfedale Reva-2; Rear Surrounds: Wharfedale Diamond 220; Atmos: TF - Monoprice Alpha 8; TR - BIC VI-38; Subwoofers: dual Rythmik L22s
BluesDaddy56 is offline
post #341 of 352 Old 05-14-2019, 12:27 PM
dbissett's Avatar
Quoted: 45 Post(s)
Liked: 51
Really enjoyed seeing Rick and these speakers at the show....they look even better in person, and sound better than that.
David
dbissett is offline
post #342 of 352 Old 05-15-2019, 12:43 PM
Quoted: 549 Post(s)
Liked: 739
Rick designed a center for me to go with the Philharmonic BMRs, roughly based on the Ceramica center. It's using the SB Acoustics woofers, but with the RAAL 64-10 tweeter and the BMR driver as the midrange. My daughter and I will be building the cabinet, but I went ahead and got the prototype baffle from Rick since the BMR has a little tricky recess. Got the baffle yesterday. Not sure when the rest of the kit is coming, but should not be too much longer. I've an out of town family wedding this weekend, so won't get to start cobbling the cabinet together for awhile anyway.
Edit: Oh, I went with the black cones on the woofers rather than the white to more closely match the BMRs, which I typically listen to with the grills off.
post #343 of 352 Old 05-18-2019, 10:29 AM
Rick Craig's Avatar
Quoted: 147 Post(s)
Liked: 244
Here's the test cabinet. I will post more later today.
rec head likes this.
Selah Audio
post #344 of 352 Old 05-18-2019, 12:30 PM
Quoted: 549 Post(s)
Liked: 739
Very nice!
post #345 of 352 Old 05-18-2019, 06:23 PM
Rick Craig's Avatar
Quoted: 147 Post(s)
Liked: 244
On-axis curves for the BMR-CC drivers (no crossover). I also have 15 and 30 degree curves that I use for entering into my crossover software. This gives a good comparison for determining the output /sensitivity of the three driver sections. Room effects are creating the peak and dip below 200hz. The ribbon's response changes in the lower frequencies because of the room's noise floor being higher than the output of the tweeter.
The second graph is the nearfield bass curve for the sealed box woofers.
Name:	BMRCC LP-BP-HP On-Axis.jpg
ID:	2568446   Click image for larger version
Name:	BMRCC Nearfield Bass Response.jpg
Selah Audio
post #346 of 352 Old 05-22-2019, 07:07 PM
Rick Craig's Avatar
Quoted: 147 Post(s)
Liked: 244
BMRCC Response Graphs
On the tweeter axis height @1M distance, 0-15-30 degrees horizontally, 1/12 octave smoothing, 5msec blended sine signal.
The second graph has the vertical response curves from V1 (midranges axis), V2 (midpoint of tweeter / midrange, V3 (tweeter axis), and V4 (slightly above the top edge of the cabinet).
Name:	BMRCC 0-15-30 degree horizontal response.jpg
ID:	2570442   Click image for larger version
Name:	BMRCC Vertical Response.jpg
Selah Audio
post #347 of 352 Old 05-23-2019, 03:10 AM
Quoted: 549 Post(s)
Liked: 739
Nice!
post #348 of 352 Old 05-23-2019, 12:15 PM
Rick Craig's Avatar
Quoted: 147 Post(s)
Liked: 244
Here's the BMR-CC impedance. Easy to drive 6 ohms nominal and 4.6 ohms minimum.
Name:	BMRCC Impedance.jpg
Selah Audio
post #349 of 352 Old 05-24-2019, 07:38 PM
Rick Craig's Avatar
Quoted: 147 Post(s)
Liked: 244
The BMR-CC kit has shipped and i look forward to hearing back on the performance. Here's the revised vertical response curve with the angles listed. The dip below 200hz is the floor reflection and peak at 100hz a room mode. The sensitivity is 86dB / 2.83v / 1M.
Selah Audio
post #350 of 352 Old 05-25-2019, 05:13 AM
Quoted: 549 Post(s)
Liked: 739
Thanks so much, Rick. I'm excited to get it put together! We've not started on the cabinet yet as life has intervened but I hope to this weekend. I'll try to document the process as much as possible.
post #351 of 352 Old 05-25-2019, 08:43 AM
Quoted: 549 Post(s)
Liked: 739
I wanted to expand a bit on my comments regarding the BMR-CC Rick has designed for me. I reached out to Rick when it seemed that Philharmonic BMRs might never be produced again and, to be honest, I didn't really just want another BMR to lay on its side with the tweeter rotated. So I asked Rick if he could modify the Ceramica center design and as we talked through it it turned out he could get the BMR driver AND the same RAAL tweeter that the Philharmonic BMR uses. We could have also gone with the Scanspeak woofers, but he convinced me the SB Acoustics woofers would work as well (if not better) and the $150 price difference didn't hurt, either. Rather than ported, we're going with a sealed design for the center as I run dual Rythmik subs in my system. The cabinet is pretty simple, but I went ahead and got the baffle cut and routed for the drivers from Rick as the BMR driver is a little tricky and the price was quite reasonable. My only concern is my finishing skills as I will ATTEMPT to emulate a piano black finish. Fortunately, as the center speaker, it will be almost impossible to really see the sides and top of the cabinet once placed in position, so I'm not OVERLY worried. I'll be doing a thread on the build (which will be quite simple compared to some here, especially recently) but I've not even started on the cabinet yet, so it will be awhile. As everyone has said, Rick has been great to work with, especially given that he's done a couple of Audio Shows (you were at Axpona as well, right Rick?) during this whole period. Happy to be joining the Selah family!!
Nick V and Soulburner like this.
post #352 of 352 Old 06-29-2019, 10:02 AM
Rick Craig's Avatar
Quoted: 147 Post(s)
Liked: 244
California Audio Show
Come hear us along with Musica Pristina and Benchmark in room 5108!
https://www.caaudioshow.com/
Nick V and BluesDaddy56 like this.
Selah Audio
Reply Speakers
