Boston VR970: Popping Noise. Please help me troubleshoot. - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By Jeff D
post #1 of 9 Old 03-22-2009, 08:46 PM - Thread Starter
Klinsek's Avatar
Hey all.
My VR970 floor speakers have been serving me well for many years, however recently one of the speakers started acting up.
There is a powered sub in each speaker, which have a power saving feature causing them to only kick on when there is a sufficient bass hit.
At lower volume levels, I get this constant popping like the speaker wants to come on. If I turn up the volume and it gets a good hit the sub stays on and the popping stops.
I swapped speaker inputs on the amp to make sure it wasn't the amp channel. It's the speaker.
Any ideas what the issue could be? Hoping this is something I can have repaired but no clue where to begin.
Klinsek is offline
post #2 of 9 Old 03-22-2009, 11:42 PM
The Village Idiot
Knucklehead90's Avatar
Quoted: 851 Post(s)
Liked: 795
It sounds like you've already narrowed it down to the subwoofer amp. Take your speaker to a competent repair shop.
Yamaha A-S1000 - Salk Song Towers - HTPC (Linux) - Oppo 103 - Marantz TT42 (WWG1WGA) --- Twas a woman who drove me to drink. I never had the decency to write and thank her ~ WC Fields
Knucklehead90 is offline
post #3 of 9 Old 09-22-2011, 09:52 AM
atl001's Avatar
Did you ever get this resolved? I have the same problem with the same speakers.
Drew
[quote=Klinsek;16101740]Hey all.
Thanks![/QUOTE
atl001 is offline
post #4 of 9 Old 10-28-2014, 09:36 PM
Jeff D's Avatar
Checking to see if anyone ever found a cause for their problem. I've got a similar issue with my left speaker. With low volume the power to the sub cuts in/out (LED doesn't stay on) and when it comes on there's popping. Cranking the volume brings everything online for a while.
I've been on the fence if it's power supply, source, or cabling.
I think I'm going to tear it apart soon and inspect the power supply components, the caps would be my first guess, but power supplies are outside of my EE experience. Time to grab the tools and do some investigating.
Jeff D is offline
post #5 of 9 Old 10-29-2014, 09:30 AM
Weazy's Avatar
Quoted: 18 Post(s)
Wow, what is it with the BA speakers?? My right VR975 just had the sub go out on it. Called BA and they don't make that style sub anymore nor do they have a comparable replacement.
Really sucks, but now I can get the set of Philharmonic Slims I've always wanted along with a separate sub.
Weazy is offline
post #6 of 9 Old 01-07-2015, 07:03 PM
Jeff D's Avatar
I finally got around to checking out the sub's circuits. I started easy and swapped the input boards between the FR and FL speakers, the FL continued to show the problem so I moved onto the sub's power circuit.
This is the input board, nothing too crazy here.
I checked with BA to see if there's a schematic or any know components to fail which I wasn't surprise to find everyone at BA has no idea about these speakers. I was still thinking the problem was a capacitor, luckily there are only a few on the board. I focused two large 63V 4700uF caps (labeled C4 and C5) and the 3 25V 100uF caps (labeled C3, C7 and C8).
Here is the power board with the large caps and wires to the sub speaker removed. The two thick red wires in the upper left are 50V power input and the yellow wire going to the right side is a 25V power input. The red/black pair is for the LED on the front of the speaker. The ribbon connector on the right goes to the input board. You can see the three 100uF caps in the middle and middle right of the board.
I started with the large caps which were a bear to get off the board (time to consider a in-circuit cap tester!) I constructed a simple RC circuit to test the charge/discharge characteristics. I only had my 5/15V power supply so these charged pretty quick, but the discharge curve looked good.
Checking the three smaller caps I found the following charge/discharge curves for the caps:
These two have similar charge and discharge curves and they look good.
This one reached max voltage nearly instantly, obviously the last isn't right.
Sadly I didn't keep track of which capacitor this was, but my guess is it's the C3 capacitor. I replaced it with one I had laying around which has a charge/discharge matches the other two, must be good!
Hooking everything back up and the speaker works like expected!!! Now I just need to figure out if this random cap I used is good enough. I'm half tempted to replace all those caps but I need to find a better way to get these parts off the board!
Hope it helps someone else keep these speaker working. I know my wife isn't too happy we can't "upgrade" to tiny speakers!
ID:	465985   Click image for larger version
ID:	465993   Click image for larger version
ID:	466001   Click image for larger version
ID:	466009   Click image for larger version
ID:	466033   Click image for larger version
wwinkler likes this.
Jeff D is offline
post #7 of 9 Old 10-31-2016, 03:52 PM
Liked: 0
help!!!!
thank you for that it very help full for me .
but i have a little question
When I pulled the card I forgot to mark the wire
So I forgot the white and black cable position .
if you can help me or send me a message it will be helpful for me
wsabbagh is offline
post #8 of 9 Old 04-06-2020, 05:36 PM
reedl's Avatar
Here is a picture of the wires.
https://drive.google.com/open?id=1Dc...6EloxzcMx9NN1f
I replaced the three smaller capacitors with new ones, and my speaker now works as it should.
The wire with the two wires attached attaches to the board. The white wire goes on the right hand connector.
Check out my theater! My Theater
Here is the Arcade: The Arcade
reedl is offline
post #9 of 9 Old 04-06-2020, 05:42 PM
tonygeno's Avatar
Quoted: 505 Post(s)
Liked: 189
I love a thread with eight posts over 11 years!! This has to be some sort of record.
Tony
tonygeno is offline
Reply Speakers
