Official JTR speaker thread - Page 1217 - AVS Forum | Home Theater Discussions And Reviews
 9733Likes
post #36481 of 39154 Old 01-16-2017, 12:35 PM
RMK!'s Avatar
Quoted: 1712 Post(s)
Liked: 1661
Originally Posted by appleseed View Post
I switched out the RCA's with the only ones I have around. No change that I can discern. Did a polarity check and everything is as it should be and also switched them to double check. The only difference I can hear is changing from receiver amp to outboard amp. Also noticed while being closer to the speakers that the amp has a low hiss even with no RCA's plugged in. Whereas connected to the receiver it's dead silent. It's very low and can't hear it from normal listening distance so I'm not worried about it. What I am worried about is that the receiver seems to get hotter even though the onboard amps are not being used and it's not sitting on top of the outboard amp. One curiosity after another. lol
If you haven't re-run Audyssey since the speaker switch you need to do that. If it still sounds off to you then it must be the amp. With the T12's you probably don't need the amp anyway.
Anxiety is contagious, please keep yours to yourself.
RMK! is offline
post #36482 of 39154 Old 01-17-2017, 03:29 PM
Peterc613's Avatar
Quoted: 666 Post(s)
Liked: 1108
Originally Posted by DRC3 View Post
Had business up in Milwaukee and dropped by to see Jeff's new digs.
I was with a couple of coworkers, but Jeff was kind enough to show us around and briefly test drove the dual Cap 4000 ULF's. He decided to play Bass I Love You and everything on the floor within 20 was literally blown away from the air movement. Just an amazing amount of output. The entire building was shaking and this is a big warehouse, LOL. He must have very understanding neighbors.
Jordan and Michael, my colleagues, not being familiar with anything but Sonos or HTIB stuff were stunned. They couldn't stop talking about the intensity. Definitely a fun time.
Thanks Jeff!
Silly me, I'm still trying to convince my wife to put two of these behind the sofa for tactile near-field response.
DRC3 likes this.
Peterc613 is offline
post #36483 of 39154 Old 01-17-2017, 05:45 PM
DRC3's Avatar
Quoted: 166 Post(s)
Liked: 173
LOL- Just be careful for wall art, china, drywall, trim, and grout...and that doesn't include the hurricane force winds from the ports.
4D audio!!
DRC3 is offline
post #36484 of 39154 Old 01-18-2017, 02:17 PM
Gorilla Killa's Avatar
Quoted: 1331 Post(s)
Liked: 1839
Dont post much in here but always enjoy the read. Just wanted to thank @Jeff Permanian for helping me out. I had exchanged a few emails inquiring about purchasing a Growler and he spent the time telling me how to get more out of my Triple 12's than selling a product. After hours of searching on AVS I was under the impression that 80hz was a good crossover point and had actually set it at 90hz and have been looking for punch, hence wanting a Growler.
Jeff suggested dropping cross to 60hz and set a low shelf filter at 100hz. I didnt have the dsp at the time to implement it, but I do now and glad I did. Huge difference, wish I had bothered him sooner. I liken it to putting a chip in my F350 7.3 P Stroke, it had the ability to smoke the tires, I just had to pull it out
Thanks again Jeff, I still want a Growler, but I may be satisfied until summer.
Gorilla Killa is online now
post #36485 of 39154 Old 01-18-2017, 06:49 PM
sherr127's Avatar
Quoted: 100 Post(s)
Sorry,noob here...how to set a low shelf filter at 100hz with avr?
sherr127 is offline
post #36486 of 39154 Old 01-18-2017, 07:10 PM
Skylinestar's Avatar
Quoted: 1308 Post(s)
Liked: 268
AVR can't do that. You need something with DSP.
sherr127 likes this.
Skylinestar is offline
post #36487 of 39154 Old 01-18-2017, 07:41 PM
desertdome's Avatar
Quoted: 1527 Post(s)
Liked: 1856
Almost all receivers have a low shelf filter. It is called the tone control and starts increasing the bass like a shelf filter at around 100-125 Hz.
Ponderosa Theater
High Impact AV
- ISF Level III Video Calibrator, THX-HAA HT3 Audio Designer/Calibrator
desertdome is offline
post #36488 of 39154 Old 01-18-2017, 09:50 PM
Liked: 268
Post #75101 of Audyssey thread from @batpig
https://www.avsforum.com/forum/90-rec...l#post33246169
post #36489 of 39154 Old 01-19-2017, 03:26 AM
coolgeek's Avatar
Quoted: 1620 Post(s)
Liked: 892
What is this low shelf filter and how does it help with bass?
coolgeek is offline
post #36490 of 39154 Old 01-19-2017, 07:34 AM
beastaudio's Avatar
Quoted: 5507 Post(s)
Liked: 5324
Click on the link skylinestar posted just above your post, duh.
beastaudio is offline
post #36491 of 39154 Old 01-21-2017, 08:41 PM
d_c
d_c's Avatar
Quoted: 1134 Post(s)
Liked: 1543
d_c is offline
post #36492 of 39154 Old 01-21-2017, 08:55 PM
rcohen's Avatar
Quoted: 1413 Post(s)
Liked: 652
I'd recommend taking measurements at different crossover points. The crossover is below the Schroeder frequency, so placement counts a lot. By changing the crossover frequency, you are choosing between your LCR placement and your sub placement for those frequencies. Which one works better will be very room specific. The frequency extension of the sub and mains also matter, but the room could be a bigger factor.
Since you are looking for punch, key aspects are your frequency response curve and minimizing nulls in the 60-120hz range.
rcohen is online now
post #36493 of 39154 Old 01-21-2017, 09:29 PM
raynist's Avatar
Quoted: 2065 Post(s)
Liked: 2223
Originally Posted by d_c View Post
So, what do you guys with the 210rt use for power?
Do you use an hpf?
I had a bridged inuke 3000 dsp on each with the steepest filter it could do at 30hz.
I sold them and bought 215 RT's. Used the inukes for a while and now use one crest cc4000 per speaker.
d_c likes this.
raynist is online now
post #36494 of 39154 Old 01-22-2017, 05:24 AM
d_c
d_c's Avatar
Liked: 1543
Did you get any pops or hum with the 3000dsp?
d_c is offline
post #36495 of 39154 Old 01-22-2017, 05:49 AM
raynist's Avatar
Liked: 2223
None at all. I know the 6000 DSP pops when turn off.
Honestly I could not tell the difference between the inuke and the crest as far as sound quality goes.
d_c likes this.
post #36496 of 39154 Old 01-22-2017, 07:16 AM
Jeff Permanian's Avatar
Quoted: 886 Post(s)
Liked: 1965
Do you use an hpf?
For the best sound quality, I would minimize da and ad conversions (amplifiers with dsp). Most AVRs have a 40hz highpass however a 30hz would be better. You could use a something like a NanoAVR which would allow you to install a highpass and adjust the response.
Jeff Permanian is offline
post #36497 of 39154 Old 01-22-2017, 08:16 AM
rcohen's Avatar
Liked: 652
Huh...I guess that HPF could be a concern running 215RTs without subs on some AVRs. I guess that would show up in measurements, though.
post #36498 of 39154 Old 01-22-2017, 11:45 AM
d_c
d_c's Avatar
Liked: 1543
I plan to run them direct for 2ch, or 2.1 with the sealed hs24. Carp is going to let me try out the Crown 4002 xti so I could give the 210s a HP at 30hz full range and 40hz if I cross with the sub.
d_c is offline
post #36499 of 39154 Old 01-22-2017, 07:49 PM
raynist's Avatar
Liked: 2223
To eliminate da/ad conversions I switched from the inukes to the crest amps. Also added a NanoAVR to implement the hpf.
post #36500 of 39154 Old 01-22-2017, 08:10 PM
carp's Avatar
Quoted: 3513 Post(s)
Liked: 3196
How noisy is the Nano? Seems that all minidsp products I've tried add quite a bit of noise.
carp is offline
post #36501 of 39154 Old 01-22-2017, 08:56 PM
raynist's Avatar
Liked: 2223
I haven't noticed any noise at all. The Nano does all of the processing to the HDMI signal before it even gets to the receiver. I even have one in my living room system with the 212's and no noise at all.
You have to send a PCM signal to it as it doesn't decode anything. You have atmos right? It wouldn't work with those movies, you would have to bypass it. Works with 7.1 though.
post #36502 of 39154 Old 01-22-2017, 08:59 PM
carp's Avatar
Liked: 3196
Ahh that's right, I forgot it was before the AVR in the chain. Yes, I have Atmos now but was asking more for d_c. He will have Atmos too, but that wouldn't matter for 2 channel using the 210's.
carp is offline
post #36503 of 39154 Old 01-25-2017, 01:10 PM
desertdome's Avatar
Liked: 1856
This isn't JTR related, but I thought some here would be interested in the live sound system that was used for the Presidential Inauguration. Note that the President and President-elect do not have lavalier wireless mics. This is probably so they wouldn't have any tracking devices on their body - especially if they had to bug out.
The contract for this was awarded to Maryland Sound International (MSI) for $294,500.
dwaleke and GIEGAR like this.
Ponderosa Theater
High Impact AV
post #36504 of 39154 Old 01-25-2017, 08:21 PM
powerlifter405's Avatar
Quoted: 117 Post(s)
Liked: 199
I have a single CAP 218HT about 10 feet away and even w/ the ICE amp turned down and my AVR at -6, many movies give the couch a nice rumble. Guest are aways amazed that the couch has a shake(on concrete btw). Jeff sure knows his stuff.
Stereo Noob, Sherbourn SR-120 pushing 5ch Arx/Chane. JTR 218HT prototype
powerlifter405 is offline
post #36505 of 39154 Old 01-26-2017, 08:50 PM
Quoted: 162 Post(s)
Liked: 219
Originally Posted by BassMojo View Post
Here's an update on my road to my complete JTR build. As previously mentioned, I received my Cap 1400 and three (3) 228HTRs. I installed the Cap last week and then last night I placed and hooked up the 228s. They sound amazing, such an upgrade! Due to size restraints, I had to place the center 228 on top of my entertainment cabinet and then plasma on top of it. It makes for a very high monitor (almost to my front heights/Atmos), but the front stage sound is such an improvement. When I receive the four Slanted 8-LPs, I will complete the set up and provide additional updates.
With the holidays and being out of town for work, my review of my system has been somewhat tardy. Anyways, I recieved the four (4) Slanted 8-LPs and have installed them as my rears and Front ATMOS. I experienced a tricky install for one of the front ATMOS as it sits on a high shelf as opposed mounting it to the wall. After calibration I have devoted time listening to them and am thoroughly pleased. I an still running rear the in-ceiling speakers that were previously installed in my home when I purchased it as the rear ATMOS and may have to step up up to another pair of JTRs to complete my entire system to 100% JTR. I cannot say how much I am enjoying this set up! Movies are compeluely amazing, with incredible detailing. But the biggest improvement that I am continuing to be blown away with is the two channel music that is provided by the two 228HTRs and the CAP 1400. Simply amazing! Almost every night that I am home and not traveling, and after my small children are in bed and asleep, I am able to sit and enjoy some critical listening without being disctracted. I am reminded each time how detailed the HTRs are and am so happy that I stretched a little further tor the HTRs. I would recommend these speakers to anyone considering an upgrade to their current system as you won't be disappointed. I now experience incredible levels of details that I never heard previously. It's completely obvious how much of the music (and movies) that I was missing before. Oh yeah, and they stay crystal clear no matter how loud you play them. They can easily push me right out of the room. Thanks again Jeff! You are a true craftsman.
rcohen, staaled and Jeff Permanian like this.
BassMojo is online now
post #36506 of 39154 Old 01-26-2017, 10:38 PM
Quoted: 886 Post(s)
Liked: 1965
From the subwoofer thread:
Originally Posted by cannga View Post
Porsche Carmona Red is a dark red metallic color. Up close you could see the nice metallic fleck that makes it quite beautiful. The finish is STUNNING & mirror like. It looks similar to a black lacquer, but here dark red.
BTW for the hard core shutterbugs out there: camera is Canon 1D, lenses are either Canon 35mm 1.4L or Contax Zeiss Distagon 21mm 2.8. Shot in RAW, developed by Capture One. Color temp has not been adjusted yet.
PS the "thing" to the right is my VPI record cleaner. Told you I am a picky audiophile :-). For the young ones out there, a record is that black thing you plaY with a stylus and turntable; used to be popular 40 years ago .
carp, dlbeck, dwaleke and 3 others like this.
post #36507 of 39154 Old 01-26-2017, 11:28 PM
GIEGAR's Avatar
Quoted: 987 Post(s)
Liked: 1675
Oh my giddy aunt... That is stunning. ^
Jeff Permanian likes this.
GIEGAR is online now
post #36508 of 39154 Old 01-28-2017, 06:56 AM
Quoted: 18 Post(s)
Liked: 7
Hi All,
Is there a kind owner of a noesis 228ht or htr in the Washington, DC area that would open up their home for a demo . A six pack of your choosing will be provided and no Taylor Swift songs will be requested...
Enlai
cheapeats is offline
post #36509 of 39154 Old 01-29-2017, 03:52 AM
acommonsoul's Avatar
Quoted: 43 Post(s)
a question for everyone that owns the 212s or 228s....how is the soundstage and imaging of these speakers? I was originally considering the Focal Electra series for my HT, but i stumbled across JTR in my search for a quality subwoofer, which has led me to considering the JTRs for all my speakers. I worry about the sound quality, soundstage and imaging, due to the fact that I cannot demo them anywhere first. Any advice would help.
acommonsoul is offline
post #36510 of 39154 Old 01-29-2017, 06:42 AM
raynist's Avatar
Liked: 2223
Where are you located? There are JTR owners all over the country that would likely be willing to demo the for you.
Reply Speakers
215RT , 228ht , captivator , Jtr , Jtr Noesis 212ht 212ht Lp , noesis
