Official JTR speaker thread - Page 1302 - AVS Forum | Home Theater Discussions And Reviews
 9723Likes
post #39031 of 39143 Old 05-10-2019, 03:59 PM
jlpowell84's Avatar
Quoted: 2018 Post(s)
Liked: 987
Hey all. I'm in transition with gear, setup, etc. Def going to finally do the Atmos transition with 4 overheads. My question lies with heights and wides with Atmos. Is it necessary? I imagine heights no but wides could still have benefit just not sure how much if setup, room treatment is spot on.
Looking for any of your experiences with such thus far. with wides mainly and Atmos...
jlpowell84 is offline
post #39032 of 39143 Old 05-13-2019, 10:59 AM
QuadMersed in bass!
giomania's Avatar
Quoted: 600 Post(s)
Liked: 417
I have had Wide speakers since 2010. I was previously using them with Audyssey DSX.
Now I have a Dolby Atmos / DTS:X processor and the wides are not used very much with native Atmos content, even though they can be used.
Native DTS: X content does not use the wide speakers either, because there is an 11 channel limit (7 bed / 4 heights), and Wide speakers are not included in the bed channels.
For up-mixing, the Dolby Surround Upmixer (DSU) currently will not “map“ to the Wide channel speakers
The forthcoming sound format DTS: X Pro will eliminate the current DTS 11-channel limit, so the wide speakers might see more “widespread “use. We just have to wait and see.
Mark
Sent from my iPhone using Tapatalk Pro
giomania is offline
post #39033 of 39143 Old 05-17-2019, 04:16 PM
imureh's Avatar
Quoted: 2680 Post(s)
Liked: 3220
Any one know what is the dispersion angle for the Slanted 8LPs? I am looking for something around 120 degrees. The obvious choice seems to be bipole but can't find anything with high efficiency...
Subwoofers: Dual Rythmik FV18s Rev2 with Paper cone, BOSS Platform mini riser
Speakers: PSA MTM-210 L/C/R - Klipsch 250S Surrounds, PSA MT 110sr Rear Surrounds, 4 x SVS Prime Elevation for Atmos
Video: Epson PowerLite Home Cinema 6500 UB; Room: 2100 cuft sealed on suspended floor
Receiver & Players: Denon X4400H, Oppo UDP-203, Roku Ultra. Apple TV, Minidsp 2X4 HD
imureh is offline
post #39034 of 39143 Old 05-17-2019, 07:05 PM
pitchcut29's Avatar
Quoted: 13 Post(s)
I believe all of the s8 speakers are 180 degrees.
pitchcut29 is online now
post #39035 of 39143 Old 05-17-2019, 07:44 PM
juanchibiris's Avatar
Quoted: 45 Post(s)
Liked: 35
Looking at some post before I found this info
"The JTR 8's use a custom version of the BMS 8CN552 and have a 90 degree dispersion pattern"
The JBL Control 328 have a dispersion pattern of 120 degrees if you're looking for some atmos speakers with high efficiency and wide dispersion pattern.
Enviado desde mi SM-N9600 mediante Tapatalk
juanchibiris is offline
post #39036 of 39143 Old 05-17-2019, 07:49 PM
jlpowell84's Avatar
Liked: 987
I thought 120, either way coaxials cast a WIDE pattern. Is there a scenario where that wouldnt work?
I can't believe how dead this thread is!
The Volt good cheaper option...
post #39037 of 39143 Old 05-17-2019, 08:03 PM
imureh's Avatar
Liked: 3220
I thought 150, either way coaxials cast a WIDE pattern. Is there a scenario where that wouldnt work?
The slanted 8 have a 150 degree dispersion? Where do you see that posted? I have tried to reach out to Jeff a few times but have had no response
imureh is offline
post #39038 of 39143 Old 05-17-2019, 08:16 PM
imureh's Avatar
Liked: 3220
This is the application as side surrounds I need it for.
imureh is offline
post #39039 of 39143 Old 05-20-2019, 08:12 AM
beastaudio's Avatar
Quoted: 5507 Post(s)
Liked: 5324
Haha, this is funny all the numbers being thrown around. It may be due to the fact that true dispersion of a coax is going to be frequency dependent and you have to look at it really as an average over the higher FR of the driver to even quote a singular number, albeit, this is exactly what most speaker manufacturers do to derive their one-off number for dispersion.
beastaudio is offline
post #39040 of 39143 Old 05-20-2019, 08:16 AM
imureh's Avatar
Liked: 3220
Looking at my pictures above, do you think the single 8 LP work in that application? Wish i could just ask Jeff.
imureh is offline
post #39041 of 39143 Old 05-20-2019, 09:30 AM
beastaudio's Avatar
Liked: 5324
While some wider dispersion would be nice, they should be fine. If you get down the road a little and really want to do it right, get a pair for each row.
post #39042 of 39143 Old 05-20-2019, 09:46 AM
imureh's Avatar
Liked: 3220
Thanks. Since I can’t get a response from Jeff, I am going to compare my current PSA 110SR in that spot and a couple of bipole speakers and see.
imureh is offline
post #39043 of 39143 Old 05-21-2019, 06:27 AM
Sweet Jimmy's Avatar
Quoted: 72 Post(s)
Liked: 120
Favorite JTR speaker for two-channel listening?
2-Channel:
Wharfedale Opus 2-3, Jolida JD1502, Arcam irDAC
3.2 Home Theater:
Marantz SR7013, Klipsch RP-160 piano black X 3, JTR 2400 ULF X 2
Sweet Jimmy is offline
post #39044 of 39143 Old 05-21-2019, 06:56 AM
raynist's Avatar
Quoted: 2059 Post(s)
Liked: 2215
215RT for me with 210RT right behind.
I bet the 215RM and 212RT are amazing as well. Basically any of the ‘R’ line of speakers with the exception of the 210RM.
dwaleke and Sweet Jimmy like this.
raynist is offline
post #39045 of 39143 Old 05-21-2019, 08:03 AM
Quoted: 72 Post(s)
Liked: 120
Thank you. I've been thinking about the 210RT recently and wondered how that might sound in a medium-sized room. The 215RT is a monster and might overwhelm me. The JTR speakers are intriguing.
post #39046 of 39143 Old 05-21-2019, 08:26 AM
raynist's Avatar
Liked: 2215
I had the 210RT’s as LCR and upgraded to the 215RT’s. For the majority of music I probably couldn't tell the difference. The 215RT’s go down to 12hz or so in my room so they have a deeper bottom end, but the majority of music doesn’t go that low. The 210RT’s went to about 30hz in my room.
Sweet Jimmy likes this.
raynist is offline
post #39047 of 39143 Old 05-21-2019, 09:02 AM
Home Theater Enthusiast
SOWK's Avatar
Quoted: 1373 Post(s)
Liked: 2138
212RT/210RT currently. Only because the horn/compression driver is closer to ear level than the 215RT. Ultimately the 215RT's can outperform the 212RT's. But the 212RT's can get louder if you care to have blood coming out of your ears.
Wisconsin Home Theater Enthusiasts Meet: Main Thread l Gear For Sale
SOWK Home Theater
SOWK is online now
post #39048 of 39143 Old 05-21-2019, 09:04 AM
SOWK's Avatar
Liked: 2138
@Sweet Jimmy
Were do you live? You might be able to get a member of the JTR thread to demo them for you in their home.
If you are close to WI, Jeff or I could demo for your personally.
llang269 and Sweet Jimmy like this.
SOWK Home Theater
SOWK is online now
post #39049 of 39143 Old 05-21-2019, 12:37 PM
Quoted: 72 Post(s)
Liked: 120
Originally Posted by SOWK View Post
@Sweet Jimmy
Wonderful offer and I appreciate that. I'm in Ann Arbor, Michigan. I've driven to Madison before and it was a wild ride. Very exciting tolls around the Chicago area. I doubt I'll make it over there but thank you.
I'm very confident that I would enjoy the 210 & 212 in the RT format. I feel good about that. This could happen.
post #39050 of 39143 Old 05-21-2019, 01:06 PM
Mike_WI's Avatar
Quoted: 434 Post(s)
Liked: 411
https://www.lake-express.com/
hogues likes this.
HT: Oppo UDP-203 -> Lumagen RadiancePro 4446 {18 GHz input x2 & 18 GHz output x1 cards} - "new (112818 FW)" 18 GHz microcode - parallel outs to --> [Audio: Denon 5308CI] --> [Video: JVC RS520 FW v30.1]
HT Details: link
Mike_WI is offline
post #39051 of 39143 Old 05-21-2019, 01:26 PM
chucky7's Avatar
Quoted: 3415 Post(s)
Liked: 4182
I have the relatively meager Noesis 212HTs. I originally ordered the 228HTs but switched to the 212HTs at the 11th hour because they were the most expensive models on sale last Thanksgiving. Even at the special price of $1599 shipped, it was still a lot of money. One 212HT cost more than my last front stage combined.
Before I received them, I was afraid that I couldn't discern the sound quality from these. I knew they would be good, but just how much better and would it worth the additional cost? What if the law of diminishing return starts at a lower price for me? All of these questions were answered once I hooked them up the first time. The 212HTs are neutral with a fuller sound. The FR measurements at the MLP showed elevated 60~300Hz. Now I am bombarded with mid / high bass from music and movies. Movie dialogues are crisp and schintilating and just hook me to the screen. Sometimes I am spooked by the dynamics or the attack. I listen with Audyssey Flat and the treble is just smooth as butter and never fatiguing to me. I feel like crying every time I hear them. They are worth every penny.
So grab whichever model that fit your budget. If the lower end 2 way 212HTs sound like this, I can only imagine how the 3 way Reference series sound.
giomania, Archaea, bulls and 5 others like this.
Speakers: L/C/R: JTR Neosis 212HT. Surrounds: Jamo C103, KEF Q100, Polk Audio RTiA3.
Subwoofer: JTR Captivator 4000ULF.
AVR: Denon AVR-X4400H. TV: Samsung UN75NU8000FXZA.
FS: Jamo C103, KEF Q100 and Polk RTiA3
chucky7 is online now
post #39052 of 39143 Old 05-22-2019, 07:03 AM
beastaudio's Avatar
Liked: 5324
For movies only the more discerning ears will be able to tell a major difference between the two, with all the action and stuff typically going on in the movies we all appreciate around here. But once you throw some 2 channel music at the reference series speakers, you really see where the main differences are. Even if you only do music 30% of the time, I'd say it's well worth the move up. Not saying you are Chucky, just in general.
chucky7, tebling, llang269 and 2 others like this.
post #39053 of 39143 Old 06-03-2019, 04:56 AM
DRC3's Avatar
Quoted: 166 Post(s)
Liked: 173
Finally reran Audyssey after installing 4 slanted 8LP's in ceiling and having crossover upgraded in 215RM. Thanks Jeff!
Popped in Ready Player One for the kids last night. Atmos was definitely worth the expense, time and effort. Glad we finally did it.
With the added height channels (coming from 7 channel) I'm thinking I may back down channel levels...it's so much louder, LOL. Not sure if you guys have experienced this or did the same thing.
chucky7, tebling and pitchcut29 like this.
DRC3 is offline
post #39054 of 39143 Old 06-03-2019, 06:57 AM
Landmonster's Avatar
Quoted: 104 Post(s)
JTR subs vs "regular" home theater subs?
Hi guys...
So I've been hearing great things about JTR. I've never highly considered them...due to size and space constraints, and money contstraints.
But the entry level Capivator JTR 118 is a possibility for me Given that it costs around $1800, it is in the same realm as an SVS pb4000, or similar enthusiast subs.
How would the JTR Capivator sound vs a comparable SVS offering? Or how would it compare to a top of the line HSU vtf-15 mk2?
Is JTR in a different league all together? Furthermore , could it be used in a regular living room?
Landmonster is offline
post #39055 of 39143 Old 06-03-2019, 04:37 PM
chucky7's Avatar
Liked: 4182
Hi guys...
Come on over... Official JTR Speakers Subwoofer Thread
You should get much more replies there.
post #39056 of 39143 Old 06-03-2019, 05:43 PM
chucky7's Avatar
Liked: 4182
So last Saturday night after watching Bumblebee (a pretty decent Transformer movie, BTW), I was going to cover up my JTR speakers as usual. Yes, I cover my JTR speakers/sub with plastic bags/sheets when not in use... Then I started wondering how in the world the Noesis 212 could weigh 125 lbs... that's even more than almost all 15" ID subs... Therefore, I carefully opened one up just to see what kind of magic dust Jeff put into his speakers...
One 12" driver removed, revealing a huge crossover board and cotton/denim sound damping backing...
Another angle showing there were 2 crossover boards...
The 12" drivers looked to be Eminence KL3012CX-8s...
The crossover boards were as wide as the woofer. Look at these heavy duty caps and resistors... I put a can in the speaker for scale...
The horn loaded B&C DE990TN and the 3" cotton/denim sound damping in a cabinet made of 18 ply void free Baltic Birch plywood. The extensively-braced cabinet would have been heavier if MDF were used.
Let's take a closer look at the first crossover board... Metallized polypropylene capacitors (made in France), perfect lay air core inductors (made in Canada), and wirebound resistors by Solen.
Crossover board No. 2 (Yes, there were 2)... More Solen capacitors and iron core inductors. Too bad I do not have a backgound in EE...
I have nothing but wonderful things to say about how my Noesis 212HTs sound. Now I see all these goodies inside a lower end JTR speaker. IMO, if this speaker were offered as a kit on DIYSOUNDGROUP, it would likely be priced at close to the $1899 JTR retail price.
I think I am better off enjoying them and leaving the speaker making to Jeff.
SOWK, tebling, bulls and 10 others like this.
post #39057 of 39143 Old 06-04-2019, 04:25 AM
imureh's Avatar
Liked: 3220
The crossover board was as wide as the woofer. Look at these heavy duty caps and resistors... I put a can in the speaker for scale...
Crossover board No. 2 (Yes, there were were 2)... More Solen capacitors and iron core inductors. Too bad I do not have a backgound in EE...
I can’t imagine what these sound like given I am blown away by my PSA MTMs.
imureh is offline
post #39058 of 39143 Old 06-04-2019, 04:53 PM
jlpowell84's Avatar
Liked: 987
Hi guys...
The 118 uses a pro style woofer, will have a diff sound characteristic to it. Lower moving mass and higher sensitivity, lower 2HD. Seems more are moving to pro style woofers for this reason. Many of them being tested on Data bass lately. You will sacrifice the ULF but it also seems that craze where everyone thought they needed to be flat to 5hz in room has faded. I would see if you can find anyone close that has some pro style woofer setups, most likely a DIY but you can hear what lower 2HD sounds like. Not everyone likes it, 2HD is not offensive like 3HD so some actually prefer it.
post #39059 of 39143 Old 06-04-2019, 08:13 PM
Liked: 0
Thumbs up
It’s amazing
ronaless is offline
post #39060 of 39143 Old 06-04-2019, 08:49 PM
bulls's Avatar
Quoted: 261 Post(s)
Liked: 156
made in France ?
i didnt know they make anything
they seem to have more smoke breaks than actual work time
giomania likes this.
display - vizio p65
AVR x4300h +lepai 2ch amp = 7.2.4
L/C/R - Chane 2.4, SURROUND - dayton 3in cubes *temporary
BASS - 2x Seaton F18 + JTR 1400 "the wind machine" (not port noise)
2100 ft^3
bulls is offline
Reply Speakers
215RT , 228ht , captivator , Jtr , Jtr Noesis 212ht 212ht Lp , noesis
