GoldenEar Technologies Anticipation Thread - Page 110 - AVS Forum | Home Theater Discussions And Reviews
 818Likes
post #3271 of 5453 Old 06-04-2015, 12:45 PM
Cyclonejason93's Avatar
Quoted: 18 Post(s)
Originally Posted by rustolemite View Post
Okay I took one out of the box last night and noticed it was attached but heard some popping but I think it was the bottom of the box, was worried I had done something to the base. They need to upgrade the manual that says to install the feet.
I am not going to use those leveling feet for the center I will just but a slight tilt to my stand for the center, wish the end caps weren't so shiny since it sits right under my TV.
I'm using the spikes on the base, they go on super fast and easy. A little hard to move them around though.
Marantz AV7005 pre-amp, Rotel RB-985 amp, Parasound Halo A31 amp
Oppo BDP-83, Rotel RCD-970BX CD Player
GoldenEar Triton 5s, GoldenEar SuperCenter XL, B&W CCM65 surrounds
REL Storm III Subwoofer
Cyclonejason93 is offline
post #3272 of 5453 Old 06-04-2015, 01:59 PM
Montucky's Avatar
Quoted: 775 Post(s)
Liked: 759
For all the reviews I have read and personal owners input I think that is what the Ones were made for, is 2 channel stand alone music setup. To me the people that have a dedicated 2 channel setup don't listen to the type of music that really requires a dedicated sub, and the Ones would be more than enough bass, but you can always add a small sub down the road.
What would you be powering the Ones with?
Thanks. Not totally sure what I'll be powering them with. I'm thinking perhaps along the lines of the Outlaw RR2150 stereo receiver, or some other simple 2 channel receiver but perhaps with a bit more power. Not sure exactly.
Montucky is offline
post #3273 of 5453 Old 06-05-2015, 07:14 AM
sdolen's Avatar
Quoted: 79 Post(s)
Liked: 50
Check out the Rogue Audio Sphinx or Cronus Magnum, either would be an awesome match with the 5s.
sdolen is offline
post #3274 of 5453 Old 06-05-2015, 07:53 AM
Montucky's Avatar
Quoted: 775 Post(s)
Liked: 759
Those could be very nice. Also thinking along the lines of a nice 2 channel amp with a built in DAC.
Montucky is offline
post #3275 of 5453 Old 06-05-2015, 09:04 AM
rustolemite's Avatar
Quoted: 368 Post(s)
Liked: 110
You might want to give Emotiva Mono blocks a look and their 2 channel amps as well.
https://emotiva.com/products/amplifiers/xpr-1
NextLevel217 likes this.
VIDEO: Epson 5050UB * SeymourAV CenterStage XD 137.7" * Samsung UBD-M9500 * Nvidia Shield * HTPC * Xbox OneX * URC MX-990
AUDIO: Yamaha CX-A5200 * Emotiva XPA-9 Gen3
SPEAKERS: PSA MTM-210T L/C/R * PSA MTM-110 (2) Surrounds * S2(4) Atmos * HSU VTF-3MK4
http://www.invelos.com/dvdcollection.aspx/Rustolamite
rustolemite is offline
post #3276 of 5453 Old 06-05-2015, 12:12 PM
LowTech1's Avatar
Quoted: 1163 Post(s)
Liked: 276
Well the Emotiva is the only amp I have ever had so really nothing to compare too, I have had a XPA-3 and now my XPA-5 and I can say 100% that adding the amp made a difference in the sound and of course volume of all the different brands I have used.
That's funny,because I had an XPA-3 for my ML Electrostat's and sold it,because I heard zero difference. Maybe if I ever cranked up the volume I might,but I never needed to or wanted to. Unless you have a 4 ohm speaker or less,an amp is not going to matter,period!
LowTech1 is offline
post #3277 of 5453 Old 06-05-2015, 12:28 PM
Quoted: 368 Post(s)
Liked: 110
Man you bringing that backup again, do you just troll around for anything about Emotiva so you can bad mouth them?
post #3278 of 5453 Old 06-05-2015, 12:38 PM
LowTech1's Avatar
Liked: 276
I'm not bad mouthing anything and I'm not trolling. I was reading up on people buying the new Triton 5's. Then I see a post that is untrue and commented on it. That's all. I bet your sound stage really opened up also. Those triton 5's are very efficient,you won't hear any difference at all. You will just want to hear a difference.. Sold my amp,best move I made. Room treatments will do much more for your sound than an amp..
htpcforever likes this.
LowTech1 is offline
post #3279 of 5453 Old 06-05-2015, 01:20 PM
Quoted: 18 Post(s)
What amps are you running then if you sold your Emotiva? They seem like a great deal for the price per watt even if you can't hear a difference in your system.
rustolemite likes this.
post #3280 of 5453 Old 06-05-2015, 01:49 PM
Quoted: 368 Post(s)
Liked: 110
Your opinion.
post #3281 of 5453 Old 06-05-2015, 02:02 PM
LowTech1's Avatar
Liked: 276
I'm running the amps in my Onkyo 818,runs my system great and it sounded no different without the Emo. Sorry,I'm just not an amp believer unless you have hard to drive speakers. I'm not a believer in expensive speaker wire either..
LowTech1 is offline
post #3282 of 5453 Old 06-05-2015, 04:40 PM
Quoted: 368 Post(s)
Liked: 110
So got them hooked and ready to start putting them to the test, one thing I can say right off is that the XL center sounds cleaner than my Paradigm CC690 ever did.
Excuse the crappy picture I have never been able to take a decent picture with my phone, not the phones fault but my dumb ass. And yes I am using an Amp.
post #3283 of 5453 Old 06-05-2015, 05:30 PM
mechx's Avatar
Quoted: 41 Post(s)
Liked: 42
Ah come on, let's hear how they sound with 2 channel music, your favorites songs? The top end, the midrange, soundstage, imaging, on and on...I'm dying here...
mechx is offline
post #3284 of 5453 Old 06-05-2015, 07:57 PM
JKR1963's Avatar
Quoted: 327 Post(s)
Liked: 150
Cool
Hey........no 690 now......you better break out the weights again..if you want to keep in shape!
JKR1963 is offline
post #3285 of 5453 Old 06-05-2015, 08:01 PM
NextLevel217's Avatar
Quoted: 76 Post(s)
Liked: 34
Its so many threads being highjacked by this amp hating people! Im so tired of reading the same crap!!
NextLevel217 is offline
post #3286 of 5453 Old 06-05-2015, 08:34 PM
Quoted: 368 Post(s)
Liked: 110
Yeah it was like picking up a couple of dead babies...
post #3287 of 5453 Old 06-05-2015, 08:36 PM
Quoted: 368 Post(s)
Liked: 110
I'm working on it, right just on Xbox and some PC will be checking out movies and music tomorrow, but like I said the Center has been worth it.
post #3288 of 5453 Old 06-05-2015, 11:54 PM
steveting99's Avatar
Quoted: 1847 Post(s)
Liked: 651
That coffee table between the center speaker and your Main Listening Position (MLP) is probably causing interference issues. Wondering if you can move it out of the way for a test to hear any improvements in the sound stage? Might want to do a test later on, after the GE gear has been setup to your satisfaction.
Marantz SR-7009, Oppo BPD-93, MTV 7000D, aTV, Harmony Home Control remote, KEF E301+T101, MiniDSP (2x4)+(10x10HD)+(DDRC-88A), Emotiva 2xXPA-5 (Gen2), Rythmik 2xF12G+2xF8, HiMedia Q16, LG 55EC9300.
steveting99 is offline
post #3289 of 5453 Old 06-06-2015, 06:46 AM
Quoted: 368 Post(s)
Liked: 110
That's not the stand I will use for the Center it will be a little higher so that its just under TV which is exactly where the Paradigm 690 was, but I can tell you that already the XL has a cleaner, clearer sound than the 690 ever did.
post #3290 of 5453 Old 06-06-2015, 07:02 AM
mechx's Avatar
Quoted: 41 Post(s)
Liked: 42
When you raise that center a little higher, you get an even nastier first reflection off that table. These reflections can muddy up dialog more than you may think. Move the table and you likely will hear the full potential of your center...if it's great now, just imagine how great it could be...YMMV
mechx is offline
post #3291 of 5453 Old 06-06-2015, 10:22 AM
Audiguy3's Avatar
Quoted: 186 Post(s)
Liked: 95
I have the XL
And here it is installed
Somehow the voices in movies and TV were still not great and my wife and I had a hard time with some dialog and had to turn up the sound too mcuh. Perhaps because the speaker was too far from the wall???? I was so frustrated with the results that I took the center channel out based on recommendations from a audio forum in Quattroworld. This was an improvement but still not perfect.
I suspect others had the same issues with the GoldenEars Ones (the towers that I have in the picture). So Sandy Gross introduced a new Center Channel designed to work with the Ones.
I just got a call from my rep and he said I should have it in a week. He will allow me to trade in my old one and try out this one to see if it makes a difference. The write up on it is:
The mega-high-performance SuperCenter XXL is only 35" wide and includes four 5-1/4" drivers, the GoldenEar High Velocity Folded Ribbon tweeter, three planar passive radiators, and our unique linear-phase crossover, employing fully balanced technology and precision film capacitors. The unique balanced topology reduces stray capacitance in the magnetic circuit, among other things, with the result of dramatically improved clarity. There are three separate internal chambers: a larger one in the center which contains two 5-1/4Ý drivers which run up to meet the tweeter and are coupled to the larger, 7Ý x 10Ý passive radiator in the center, and two smaller ones which each contain a special 5-1/4Ý driver engineered for low frequency response, which runs up to 500 Hz, and is coupled to one of the smaller, 6-3/4Ý x 8Ý passives.
Reggie Basement: Sony 75" 4K 940D/Marantz AV8802A & MM8077 & MM7055/GoldenEar:Reference (Front) Triton Ones(Rear),/SuperCenter XXL center channel/ 4 GoldenEar Atmos Invisa 650/Oppo BDP-205/Directv HS-17 and C61K/Roku 4K Family Room:LG 65" OLED/Marantz AV8802A & MM8077/ Vandersteen Treo Front/ GoldEar SuperSat60 Surround/ Directv HS-17 and C61K
Audiguy3 is offline
post #3292 of 5453 Old 06-06-2015, 11:43 AM
Phrehdd's Avatar
Quoted: 168 Post(s)
Liked: 217
Very off the wall question/idea.
The latest sound bar makes a option for fair size TV in a smaller space. I was curious if the soundbar might also be used behind the seating to as well to create a quasi 5.x set up. I know this would not be an ideal solution but might be more about practicality of available space. Any thoughts ... Sandy?
Phrehdd is offline
post #3293 of 5453 Old 06-08-2015, 04:51 AM
Ediddy's Avatar
Quoted: 160 Post(s)
Liked: 150
Originally Posted by Audiguy3 View Post
I have the XL
Let me know your thoughts I'm going to reach out to my dealer this week.
Ediddy is offline
post #3294 of 5453 Old 06-08-2015, 03:57 PM
JKR1963's Avatar
Quoted: 327 Post(s)
Liked: 150
I have the XL
This was my concern about the ones (based on experience with other speaker lines where the front L & R are far larger and have more output than the "matching center"). The initial review on the new XXL center sounds good.........and it is not KD this time!!
http://hometheaterhifi.com/center-ch...irst-look.html
JKR1963 is offline
post #3295 of 5453 Old 06-08-2015, 04:34 PM
Montucky's Avatar
Quoted: 775 Post(s)
Liked: 759
Awesome! I do believe that the search for my next center channel just might be over.
Montucky is offline
post #3296 of 5453 Old 06-09-2015, 01:50 PM
ajax-jp's Avatar
Quoted: 57 Post(s)
Liked: 33
Damnit.. XXL.. I just got my XL a month ago...
I was considering getting a pair of Triton Ones to replace my Legacy Signature III's (not that there's anything wrong with them, they're just old) and now meh.. Although, I don't think I'd have enough room for it in my configuration anyway.
ajax-jp is offline
post #3297 of 5453 Old 06-10-2015, 06:57 AM
BenWaB3's Avatar
I picked up a Rogue Audio Pharaoh a few weeks ago & have been wondering about how they would sound with the 5's so if anyone has experience with the 5's & Rogue equipment I would be very interested in their opinion. Thanks
BenWaB3 is offline
post #3298 of 5453 Old 06-10-2015, 10:02 AM
Maison's Avatar
Quoted: 187 Post(s)
Liked: 48
Hello
I'm thinking of using a pair of SS60 for surrounds and 2 pairs of HTR7000 for ceiling atmos, but I'm finding that I'm having space issues with the top front and I can only squeeze in the Invisa 525. So now it would be a pair of SS60, pair of HTR7000, and a pair of 525. How do these match up tone wise? Same since they use the same tweeter and technology? Also for SS, would I do well with SS50 instead of SS60? How are the 525 for atmos?
Thanks!!
Maison is offline
post #3299 of 5453 Old 06-10-2015, 02:59 PM
goldenear tech's Avatar
Quoted: 148 Post(s)
Liked: 172
Rogue Amps with GoldenEars
Hi, Actually, the Rogue amps are particularly good choices for the GoldenEars. Enjoy! Sandy
goldenear tech is offline
post #3300 of 5453 Old 06-10-2015, 06:21 PM
*UFO*'s Avatar
Quoted: 796 Post(s)
Liked: 673
Does best buy sell Golden Ear speakers? I remember a couple of years ago I saw some in there, but their website has none?
*UFO* is offline
Reply Speakers
