GoldenEar Technologies Anticipation Thread - Page 175 - AVS Forum | Home Theater Discussions And Reviews
 846Likes
post #5221 of 5560 Old 01-08-2019, 03:21 PM
mbroadus's Avatar
Quoted: 1221 Post(s)
Liked: 503
Originally Posted by BeMurda View Post
Just got my used 3 Goldenear Supersat 50's for a steal! $650 Canadian, whereas they'd be $2k new! Very happy to get 3 for the price of 1.
I'm currently let them slowly warm up to room temperature before testing them out, as it is -15C / 5F here and the aluminum bodies were very cold on arrival. I'm very impressed with the build quality, it's much better than I expected. They are beautiful.
As an update, I did contact GoldenEar about rotating the tweeters and they responded:
"Typically the tweeter is glued in place so rotating would probably be an issue - plus the grilles are different too. You are correct though, they should be rotated to use the speaker horizontally. Also, it is really best that the front L/R speakers be as far apart as possible, preferably as far apart as the distance to your listening area."
So I think I will just set them up conventionally. I'm going to use Martin Logan LX16's for the surrounds in a 5.1 setup with my old AV123 X-Sub.
What receiver will you be using?
Panasonic P60VT60 Calibrated by Chad B
Anthem MRX-720, Oppo UDP-203, Bluesound Node 2i
Focal Aria 936/CC900, SVS SB-3000
MacBook Pro, AppleTV 3 & 4K, Sony PS4 Pro
Zero Surge 8R15W-I
mbroadus is online now
post #5222 of 5560 Old 01-08-2019, 07:57 PM
Quoted: 197 Post(s)
Liked: 67
I'll be using my trusty old Marantz SR5001, which I have been using for years to power 4ohm Onix Reference series fronts. I'm sure it will do well! Not worrying about getting the latest gadgets for this room. It does have earlyish HDMI. I have a wall mounted Vizio M70 as the TV.
BeMurda is offline
post #5223 of 5560 Old 01-09-2019, 12:01 PM
Atorak's Avatar
Originally Posted by Atorak View Post
Biggest reveal? Apparently, a new SuperCenter Reference is coming (release date?), which ties in perfectly with the One.R and Reference. Let's hope the pricing is reasonable.
Per Facebook, the SuperCenter Reference center speaker will start shipping in February. MSRP?
Also, does anyone know of any dealers in the New Jersey area that have the Triton One.R on display for demo yet? I called all the dealers on the Goldenear website in the past two weeks, and no one had any in yet. Could really use some more listening impressions, I'd be coming from a Triton 5 and an XXL.
Atorak is offline
post #5224 of 5560 Old 01-09-2019, 04:29 PM
Odessit's Avatar
Quoted: 12 Post(s)
I disassembled my GE (another model) and the glue they use inside looks like hot glue or clear silicone. I would try to rotate the twitter.
Odessit is offline
post #5225 of 5560 Old 01-09-2019, 04:52 PM
Ediddy's Avatar
Quoted: 172 Post(s)
Liked: 156
New review on HomeTheaterReview.com for the Triton One.R was just posted!
https://hometheaterreview.com/golden...aker-reviewed/
Here we go! I have my fingers crossed
(2) GoldenEar References, GoldenEar SuperCenter XXL, (4) GoldenEar HTR 7000 (atmos), (2) GoldenEar SuperSat 50’s, (2) GoldenEar Triton 7 (rears), Dual Seaton Sumbersive HP (Master / Slave), JVC NX5, Dalite 119 inch UTC, Panasonic BP - UB 820, Marantz 8805, Emotiva XPR 2, Emotiva XPA 9 (gen 3) Panamax 5102, Harmony Elite, 4K Apple TV
Ediddy is offline
post #5226 of 5560 Old 01-13-2019, 01:48 PM
Corey888's Avatar
Liked: 1
I just found it on a website of a dealer in the U.S. It is very reasonably priced - not that much more than the SuperCenter XXL. Availability appears to be very soon. I just upgraded from the Triton Ones not that long ago, and finally I'll have a center which is more closely matched to the TRefs.
SPKR (GoldenEar): (L/R) Triton Reference; (C) SuperCenter Reference; (LS/RS) SuperSat 50
AVR: Yamaha Aventage RX-A3040 Ext Amp (LCR): Parasound Halo A31
Blu-Ray (4K): Oppo UDP-203 TV: Sony xbr75z9d; Sony xbr65z9d
Corey888 is offline
post #5227 of 5560 Old 01-14-2019, 05:08 AM
Quoted: 81 Post(s)
Liked: 41
Corey,
Do you mind sharing the dealer's web address? Thanks!
Pre/Pro: Marantz 8805 AMPS: Outlaw Audio 7700 & Emotiva Gen 3
Spkrs: GoldenEar T-Ref, SC Ref, SS 3's, T5's & HTR 7000 x 4 Sub: SVS SB16 x 2
Display: Epson 5050UB & 110" SI 7 Series Zero Edge Black Diamond
Blu-Ray: Panasonic DP-UB820-K
John Budny is offline
post #5228 of 5560 Old 01-14-2019, 08:33 AM
gtmorgan23's Avatar
Quoted: 96 Post(s)
Liked: 57
@mbroadus Can you give me some feedback or a review on the supersats you currently have?
I am waiting to go hear the 50s and the 60s at an audio shop up north here in Austin. (I noticed the Horns Helmet- Hookem)
I have not been able to find alot of reviews on them so was hoping you could give me your thoughts.
Media Room= GoldenEar Supersat 60s/GE 60c/BP7004s/SuperCubeII/A-60s/Pio-SC-95
gtmorgan23 is offline
post #5229 of 5560 Old 01-14-2019, 08:55 AM
klh007's Avatar
Quoted: 49 Post(s)
Liked: 33
Corey, What are the most improved areas of performance you note from upgrading from T1s to TRefs?
Kemper Holt
klh007 is offline
post #5230 of 5560 Old 01-14-2019, 01:52 PM
Quoted: 197 Post(s)
Liked: 67
The 50's sound great, typical highs and ultra detailed soundstage for the tweeter but not bright with the grilles on, good bass extension for the size. Sound good crossed over at 100 or 120hz, slightly better at 120 to my ears. Incredibly solid construction (aluminum).
gtmorgan23 likes this.
BeMurda is offline
post #5231 of 5560 Old 01-15-2019, 02:29 PM
mbroadus's Avatar
Liked: 503
I’ve had my SuperSat 50s for 4 years, sold them last week. They’re solid for movies with a good sub and even better with good room correction software. I really like the ribbon tweeter and would definitely buy again if I were looking for an on-wall speaker. Are you going to A&B?
Here’s a good review - https://hometheaterhifi.com/reviews/...peaker-system/
Zero Surge 8R15W-I
post #5232 of 5560 Old 01-15-2019, 02:40 PM
gtmorgan23's Avatar
Quoted: 96 Post(s)
Liked: 57
@mbroadus Yes, Jeffrey at A&B is setting the 50/60 up for me to demo.
I have been a Def Tech guy forever but no one has the mythos line to actually listen to. Jeffrey discussed goldenear with me and Im going to give them a shot.
I have a sub and 2 powered 7004s which will be moved to my rears so I have the low end covered.
The room is a 10x10 bedroom Im making into a media room/mancave. I want to use on-walls to save space in the room.
So it boils down to which sound better to me I guess. Not sure which way Ill go but currenlty Im thinking 50s for the L&R and 60 for the center.
Might pay the extra cash for left and right 60s depending on how the 50s do.
post #5233 of 5560 Old 01-15-2019, 03:43 PM
mbroadus's Avatar
Liked: 503
They’re perfect for bedrooms. I loved the 50s but wish I would have bought the 60s.
Harlan, the sales manager at A&B is a good friend of mine. I’m about to buy a GoldenEar sub from him and have it shipped up here.
Yesterday
Today
Zero Surge 8R15W-I
post #5234 of 5560 Old 01-16-2019, 06:11 AM
gtmorgan23's Avatar
Quoted: 96 Post(s)
Liked: 57
@mbroadus what size room did you have your 50s setup in?
I had a buddy recommend Jeffrey to me and couldnt say enough nice things.
Small world, and Im glad to hear you are happy with them too.
I of course want to go all 60s for my front three but its a jump cost wise for the left and right from 50 to 60.
The ears shall decide.
post #5235 of 5560 Old 01-16-2019, 10:52 AM
mbroadus's Avatar
Liked: 503
They were placed in a small den area of a larger open room and I sat 12ft away from them. Yes, I chose the 50 because they less expensive and I couldn’t have been happier. As an FYI, they’re not very good with music.
Zero Surge 8R15W-I
post #5236 of 5560 Old 01-16-2019, 11:16 AM
gtmorgan23's Avatar
Quoted: 96 Post(s)
Liked: 57
Thanks again for all the info @mbroadus
I will be using the room for movies and video games so the music thing isnt an issue.
Going today after work. Im excited.
mbroadus likes this.
post #5237 of 5560 Old 01-16-2019, 11:56 AM
healthnut's Avatar
Quoted: 990 Post(s)
Liked: 993
Does anyone have any current information regarding the Digital Activ3 speaker? I had thought we’d have had availability sometime last year, but as far as I can determine, it’s still not available.
healthnut is offline
post #5238 of 5560 Old 01-16-2019, 02:56 PM
goldenear tech's Avatar
Quoted: 148 Post(s)
Liked: 173
Matching Surrounds for this T 5/SS XXL System
Originally Posted by SightSeeker1 View Post
Any surround recommendations for a 5.2 setup with the T5s and XXL? Doesn't have to be GE really but would like something that at least comes close if not. Currently using some old Athena satellites that can't keep up at all.
Hi, I would imagine that the combo of the T 5s and XXL is pretty dynamic. Of course, the sky is the limit...how about a pair of T 7s? All the Best, Sandy
goldenear tech is offline
post #5239 of 5560 Old 01-16-2019, 02:59 PM
Quoted: 148 Post(s)
Liked: 173
Using SuperSats Designed to Be Vertical in Horizontal Orientation
This is not an option, as I found a deal for three and only one is a centre channel. The price is a third of the cost new so I can't really compare. I was just planning to mount them straight on...
Hi, Although not ideal it will work fine. All the Best, Sandy
post #5240 of 5560 Old 01-16-2019, 03:01 PM
Quoted: 148 Post(s)
Liked: 173
Nw SuperCenter Reference
Hi, it is shipping now. $1499 each. All the Best, Sandy
post #5241 of 5560 Old 01-16-2019, 03:04 PM
Quoted: 148 Post(s)
Liked: 173
Listening to New Triton One.R in NJ
Hi, I know Expo has them in stock but may not have put them out yet. In Long Island, Audio Breakthroughs in Manhasset has them out and singing. All the Best, Sandy
post #5242 of 5560 Old 01-17-2019, 06:21 AM
gtmorgan23's Avatar
Quoted: 96 Post(s)
Liked: 57
@mbroadus So I ended up getting a set of 3 60 series Supersats. Now the wait for my house to be done.
Thanks for the info and help.
Ediddy likes this.
post #5243 of 5560 Old 01-17-2019, 08:24 AM
mbroadus's Avatar
Liked: 503
Great to hear! Enjoy them and the new house. Hookem!
Zero Surge 8R15W-I
post #5244 of 5560 Old 01-20-2019, 12:27 PM
hpnas's Avatar
Quoted: 124 Post(s)
Liked: 30
Just wanted to pop in here and give major props to Mike (mmiles) who was my dealer for GE Invisa HTR 7000s as I was limited to an in ceiling arrangement. I was hesitant about using only in-ceiling speakers but Mike helped me with selection and placement and the resulting sound is insane! Paired with my SVS PB3000 it feels like I am in a movie theater. You can't tell the speakers are in the ceiling and in some regards actually adds to the soundstage
If anyone is in the market, don't hesitate to shoot Mike a PM and chat with him about your unique set up
hpnas is offline
post #5245 of 5560 Old 01-21-2019, 06:20 PM
Ediddy's Avatar
Quoted: 172 Post(s)
Liked: 156
On the GE website in the shopping area the new center channel looks cosmetically and structurally like the XXL. I think it’s just newer technology because the drivers are all the same number and size but I think the tweeter maybe larger. I’ve upgraded a lot of different GE Speakers but may sit this one out unless I’m just blown away with them side by side. From a cosmetic stand point they don’t have any similarities to my T Refs
Ediddy is offline
post #5246 of 5560 Old 01-22-2019, 12:13 PM
Quoted: 148 Post(s)
Liked: 173
New SuperCenter Reference
Hi, Yes, the new SuperCenter Reference does look externally like the XXL. However it has much of the technology developed for the T Ref and Triton One.R: Reference tweeter, new drivers with FocussedField magnet structures, new crossover specifically voiced like the T Ref and Triton One.R, new wiring, etc. Have a look at the hometheaterreview.com review of the Triton One.R as the reviewer goes into the sonic improvements of the center channel in some detail. All the Best, Sandy
post #5247 of 5560 Old 01-22-2019, 01:43 PM
mbroadus's Avatar
Liked: 503
Anyone know if the SuperSub XXL will be getting a makeover anytime soon?
Zero Surge 8R15W-I
post #5248 of 5560 Old 01-22-2019, 01:54 PM
Quoted: 148 Post(s)
Liked: 173
SuperSub XXL Question
Hi, I know and the answer is absolutely no. All the Best, Sandy
mbroadus and captainbrent like this.
post #5249 of 5560 Old 01-22-2019, 02:32 PM
mbroadus's Avatar
Liked: 503
Many thanks Sandy!
Zero Surge 8R15W-I
post #5250 of 5560 Old 01-23-2019, 11:03 AM
UserName1's Avatar
Will their be a Goldenear Triton five.R ?
Would seem to be a similar upgrade path as the SuperCenter XXL.
Already have SVS subwoofers.
UserName1 is offline
Reply Speakers
