GoldenEar Technologies Anticipation Thread - Page 181 - AVS Forum | Home Theater Discussions And Reviews
 838Likes
post #5401 of 5542 Old 06-24-2019, 05:44 PM
HTNUT1975's Avatar
Quoted: 134 Post(s)
Liked: 70
Originally Posted by Laika View Post
LIGHT BULB GOES OFF! You nailed it, I thought we seemed to be dancing out of step but could not figure out why, My bad, I should have used the model/brand or some other descriptor than "Sub" Most of the time I thought you were speaking of the F113 which I now see I did not mention. Yes, It's just the R1's in the graph. Now the minidsp recommendation, (which I will fake with the SMS-1 first to see if I get good results) makes total sense.
Yes, As you say below, BINGO, Treat the R1's sub units as separate entities, cut them somewhere between 40-100, speaker wire no longer causes a huge hump, jack in the LFE with a minidsp (or SMS-1 for trial) and refeed the sub with a processed feed. That should result in nothing but cuts in low end freq, no more worries about the R1's amps, heck, they should last longer with the cuts than ran normally I would think.. Well worth a try, will give it a show this weekend.
Thanks, I love the sub, would go with two 112's now I think due to the room, it was a monster getting dialed in mostly due to weight. The multi sub model and talk of the benefits were just firing up when i bought it.
I did spin the room, it's not well suited for that but as a test, did have a much wider soundstage but the hump was worse.
I will very soon my friend. You are correct, I never processed the R! sub signal but may have sounded like I had if I used the word sub as I did cut the R1's and send the LFE to the F113, never got a decent blend.(Hence my endless comments about why own them if I cut at 100 and send the signal to the F113 (when you likely were talking about sending the signal to the R1's.
Fully following you. (no double bass but yes, phase, room and all that.
Thanks, Will digest the above for a few days as I read the links, Dirac I have noticed has been mentioned quite often in taming R1's (I think because you can box in part of the frequency to tame and leave the high end alone. )
We shall see where the weekend experiment takes me, printing this out to study. I do have the ability to set individual cross overs for all speakers with the 8.8's which I do find very necessary with any HT I have had.
Thanks for the info, Good to know. Will start over with the normal methods which will start with just the R1's and if that all works out adding in the center and then the rears. the stand alone sub is always last in the chain, if needed.
I wish Buddy, I used to wear 4 hats and needed to take it down to three. I'm inactive, just need to pay full dues and 10 hours of CLE if I decide to get back in the game.
Alright! Sounds like we're getting somewhere. I look forward to hearing about how they calibrate. I'd be surprised if the JL performed better than the sum of both subs in those towers.
HTNUT1975 is online now
post #5402 of 5542 Old 06-26-2019, 09:54 PM
Ediddy's Avatar
Quoted: 172 Post(s)
Liked: 156
I am team GoldenEar and I’ve bought bunch of GE speakers including Triton 2s, 1s, and References for my front two at some point. I’ve also purchased center channel XXL. I know the new reference center channel is supposed to pair with the Reference tower series although it may be a solid upgrade to the XXL it’s not in the same class as my T Refs. I really wish there was a monster center that on par with my T refs.
I’ve purchased 4 sets of towers,8 in ceiling speakers, 2 center channels and 2 sat 50 so I’m a huge supporter of the brand. Some of those have been upgrades like SuperCenter XL to XXL and I thought in every case the upgrade was worth it but I don’t think this upgrade will get me what I need center channel wise. Just my two cents
New24K likes this.
(2) GoldenEar References, GoldenEar SuperCenter XXL, (4) GoldenEar HTR 7000 (atmos), (2) GoldenEar SuperSat 50’s, (2) GoldenEar Triton 7 (rears), Dual Seaton Sumbersive HP (Master / Slave), JVC NX5, Dalite 119 inch UTC, Panasonic BP - UB 820, Marantz 8805, Emotiva XPR 2, Emotiva XPA 9 (gen 3) Panamax 5102, Harmony Elite, 4K Apple TV
Ediddy is offline
post #5403 of 5542 Old 06-28-2019, 09:17 AM
lefthandluke's Avatar
Quoted: 182 Post(s)
Liked: 336
I run my one.r's in phantom mode...I would imagine the t-ref's in phantom would be fantastic as well
New24K likes this.
at the zenith of his nadir...
lefthandluke is offline
post #5404 of 5542 Old 07-09-2019, 12:30 PM
Laika's Avatar
Quoted: 50 Post(s)
Liked: 26
Should have a report for you after the weekend, have tried many things, my dealer stopped by yesterday and made a adjustment, it did improve things, I listened to different HT content yesterday. While not great in extensive testing (my old system still is much fuller, I do appear to have something to work with now. This weekend should tell me if I can get away where from where I am.
I now have some midrange, bass is tamed a bit but is often too much or too little when the soundtrack gets complicated. (Plan to push the mains farther out in the room over the weekend and move the couch back). Odd thing though, after the adjustments yesterday the "holographic" imaging they are known for and really one of the main things I liked about Tritons when heard in a showroom is totally gone, everything on HT is very localized to the speakers, I'm just running 3.0 right now to try to dial in one thing at a time. Music does sound much better now. If 95% of my listening was not HT I would be set.
Stay tuned for an update.
Laika is offline
post #5405 of 5542 Old 07-10-2019, 04:54 AM
HTNUT1975's Avatar
Quoted: 134 Post(s)
Liked: 70
Great to hear at least some progress on this front! Quick question, does that holographic imaging cease when running with surround sound, or are you referring to stereo music? I've usually considered that bizarre phenomenon to apply to the latter, and not the former. I'll be interested to find out how the measurements are when you run the experiment we talked about (i.e., using the subs in the towers as if they were separate subs so that you can apply some correction to them--all without your JL sub in the question)--again, more of an experiment than anything so that we can see how they respond to correction. Hopefully, with all this, you're enjoying the process. (At one time, I almost loathed the process, but over time, it really has become a hobby--I am unsure how wise it is, however, to make it such, as these items aren't exactly appreciating assets! Oh well, at least I haven't caught the "golf" bug. )
post #5406 of 5542 Old 07-12-2019, 01:31 PM
Laika's Avatar
Quoted: 50 Post(s)
Liked: 26
Both, Never heard it on music at all, did notice it on home theater with a fly buzzing around in the soundtrack mix I could almost track it going around my head but that was when the R1's were in one of the worst places I tried. I've got solid wonderful midrange now, oddly not much bass (on music) but we shall see if we can fix that this weekend. At least the midrange shines, I'm a midrange junkie and if the mids on music are not solid it a heck of a negative to my ears. (And yes, I would not want music to swish around the room, a solid front soundstage is all I desire)
Will let you know early in the week my friend, fingers crossed.
Hopefully, with all this, you're enjoying the process. (At one time, I almost loathed the process, but over time, it really has become a hobby--I am unsure how wise it is, however, to make it such, as these items aren't exactly appreciating assets! Oh well, at least I haven't caught the "golf" bug. [IMG]file:///C:\Users\Mercer\AppData\Local\Temp\msohtmlclip1\01 \clip_image001.gif[/IMG])
LOL, I enjoy it most of the time, much like anything else, if I am making some progress it's entertaining and educational, if I don't get a better result time and time again or a lesser result it gets tedious. (though for me it's a blast to tweak someone else's system that they have had in place for a while, easy, fast, normally just requires a sound meter moving a few things around to improve things drastically, so may people just plop them down and don't even balance levels. Nice to see their smile after a hour or two of messing around and getting that look like you are the Mother Teresa of Home Theater.
LOL buddy yea, value drops quick, but if I divide out the amount per hour of listening in my mancave it's not bad, have never used my tv speakers in my main rig. Golf, that is a sinkhole, at least my only other hobby (which does involve the outdoors has made me some good $$$).
Laika is offline
post #5407 of 5542 Old 07-15-2019, 12:54 PM
Laika's Avatar
Quoted: 50 Post(s)
Liked: 26
Update, Cut the R1's at 100, the rumored internal crossover point of the R1's and feed them strictly through the LFE cable. Also tried it at 90. Both cleared up the muddiness for the most part, still have a 3db hump in the 20-40 range. Something is amiss though, though it cleared up the imbalance for the most part, I've lost most of the dynamics of the sound. They sound very flat and I don't mean that in a good way.
I'm a bit lost, I know Golden Ear and my dealer seem to really want you to stay clear of any processing (dirac being somewhat of an exception). Bass especially lacks that showroom sound and is coming off as a much smaller non powered sealed speaker. (Which is odd with the 3db hump) I'm starting to think that there is some sort of internal processing going on in the R1's that don't respond well to processing.
But we shall see, my processor lets me store five curves and switch them on the fly. I'm going to start and load them up tonight at 70,65,60 and keep working my way down to the least processing I can. I'm thinking that might bring the dynamics back. I can't help but laugh at this point. Went from dynamic but bloated to flat like a four day can of opened soda. But hey, Still have many options to try, will be hitting it every night this week.
If you think of anything else buddy please let me know. Will report after I've done the cut and rebalanced the R1's at every available crossover point.
Laika is offline
post #5408 of 5542 Old 07-15-2019, 01:36 PM
goldenear tech's Avatar
Quoted: 148 Post(s)
Liked: 173
This is very odd
Hi, Sorry for your issues. Honestly I do not understand what is going on here. Looking at your curve again, you show a 10dB peak with the lower bass turned down 12 dB. Makes no sense. What you are talking about in terms of cutting the speakers off at 100 Hz and running the bass in through the LFE in is absolutely incorrect. If this sounds better to you, so be it but it is wrong. I am not sure what you are doing with the processing. I would suggest hooking the speakers up with only the speaker wire, no LFE in, turn off all processing and EQ. Set the management to large Left and Right and Sub No, and see what you get. I had spoken with your dealer and he was going to come out. Did that ever happen? Thanks, Sandy
goldenear tech is offline
post #5409 of 5542 Old 07-15-2019, 05:51 PM
Quoted: 182 Post(s)
Liked: 336
Originally Posted by goldenear tech View Post
I would suggest hooking the speakers up with only the speaker wire, no LFE in...
that's the ticket...
post #5410 of 5542 Old 07-16-2019, 03:54 PM
Laika's Avatar
Quoted: 50 Post(s)
Liked: 26
Thanks Sandy and a big hello.
That is not a processed curve, the sliders in that instance mean nothing. The LFE goes from my receiver sub out to the SMS then to the F113 sub. The F113 power was unplugged at the time. (The sliders were a prior setting to bring the F113 bass humps down.) The SMS was used solely to read the two R1's which were connected only by speaker wire at the time, no LFE fed was used. The bass knobs at the time were at the 9'Oclock position though I have taken them to 12 which of course causes more bass which I am trying to tame
It does not sound better to me, just different. I've rotated the room to try another wall, reset my receiver to get rid of any artifacts, tried a different receiver moved the couch to the back third of the room, moved it to the front third of the room, moved the speakers well into the double digits, played with toe in and toe out, bought a bunch more bass traps and moved them around each time. Every time speakers are moved I have recalculated speaker distance, and experiment with different toe in's and bass trap positions.
It seemed logical to try to cut the bass at the LFE line since I can't cut it at the speaker wire input since months of trying placement, settings and the bass trap dance did not cut the huge low frequency hump. Honestly I am running out of options and am seeking advice on this and other forums from owners seeking options that have not occurred to me.HTNUT1975 has been very helpful in brainstorming outside the box. Perhaps I should try the subwoofer forum here as the issue is subwoofer room integration since the speakers are a hybrid.
Yes, They came down a bit over a week ago, It's a 120 mile round trip, very nice people. They did toe the speakers out almost straight in the room and set the receiver to no sub. That did bring out the midrange a bit more, at that point it seemed I had a starting point to fine tune by moving the speakers around and moving bass traps so I had left it in a 3.0 setup trying to dial in the mains and center. They sound fairly good when material has no deep bass, when any material has strong low bass the 20 to 40 hump smothers the rest of the spectrum resulting in lack of detail in the high end and very muffled mids. Not your cup of tea I expect but one good example where the hump causes huge issues would be the last episode of this seasons "Stranger Things".
I am in no way questioning the R1's sonically, both through reputation and the fact I own two systems of your prior designs, this was to replace my main system. I have even lowed my expectations, I went into this expecting them to sound better than the STS's. I have decided if they just sound equal I can live with them because they do beat the STS's hands down on music (likely because of little information in the 20-40 area to cause issues.)
I'm a big fan and your designs have gave me many years of great listening. Through process of elimination I am certain the whole issue is the room interaction with the powered R1's subs. I have about two feet of placement play in the front corners of the room which is reinforcing the low bass. I expect this is why I keep reading the mantra from many other owners "bring them further out into the room."
Respectfully, MM
Laika is offline
post #5411 of 5542 Old 07-22-2019, 06:26 AM
HTNUT1975's Avatar
Quoted: 134 Post(s)
Liked: 70
I completely missed this, because I didn't have a "notice." So, in some sense there was "progress," but then that left other areas lacking (the dynamism). Regardless, did you get any measurements with the different hookup, showing that the bass was tamed or giving a flatter response? The original suggestion for doing this wasn't for the purpose of having a permanent alternative solution--it was to show that the bass from the towers only can be tamed via electronic calibration (even if it isn't the ideal permanent solution, obviously, because it bypasses the internal crossovers of the towers in a sense--no telling what all is lost with respect to fullness of sound, when doing it this way).
If the tower subs can be tamed properly, then it stands to reason that newer electronics may solve the problem. If I recall correctly, the reason being is as follows: given your current setup, you're not able to electronically calibrate the subwoofers in those towers when you run them full range. Am I correct in thinking this? If so, then perhaps trying out newer electronics may solve the problem (e.g., getting the kind of electronics we were talking about, with a return window which would make it risk free--except, of course, time and hassle). Think of it this way: you have, in most respects, recently purchased BMW M-level speakers from a technological perspective--but they're running on used tires that are fit for a pretty darn good sporty Maxima. On many roads, that wouldn't be much of an issue just as in many rooms, this wouldn't necessarily be an issue; but apparently, that's not the case in the more problematic rooms (hence, the need for summer Michelin top-rated summer tires when it comes to windy roads and major horsepower).
post #5412 of 5542 Old 07-22-2019, 07:18 AM
HTNUT1975's Avatar
Quoted: 134 Post(s)
Liked: 70
Ok, I've been thinking about this more and more since my last post and I wanted to point out a couple of other things which seem to follow from our discussion--this is only to in a sense show that there is need for updated electronics with the newer setup.
First, the original measurement posted doesn't show any calibration from the towers, as we know--at most, all you're able to do is adjust volume of the tower subs (and that obviously isn't going to address individual frequencies). It wouldn't be fair to compare your older towers and JL subwoofer together with the newer towers alone, because, after all, the older speakers were actually calibrated. So, this is stuff we already know (at best, for a more fair comparison between old speakers and new, you'd have to run your older speakers together without any calibration at all except for volume adjustment of your subwoofer).
Second, when you've run the experiment showing that the subs in those towers actually can be tamed, it lacks the dynamism that it should have--especially comparing your older speaker setup. Here's where I think that isn't a fair comparison with the old setup as well: when you run the experimental setup (i.e., LFE for subs in the towers only, running them as small instead of full range), even though it may show that the calibration of your electronics can tame those tower-subs to some degree (which was the whole point of the experiment), there is no telling what it is doing to each individual frequency at the lower range (e.g., how is phase between the two subs in the towers being affected at 42, 43, 45, 67, 99 and so on?). And, how do the internal crossovers inherent in those towers respond with each individual frequency adjustment, along with phase, etc., when running the experiment? The towers weren't designed to be run like that--hence the reason for newer electronics (e.g., Dirac electronically fixes phase issues).
post #5413 of 5542 Old 07-23-2019, 02:16 PM
Laika's Avatar
Quoted: 50 Post(s)
Liked: 26
[quote=HTNUT1975;58325284]I completely missed this, because I didn't have a "notice." So, in some sense there was "progress," but then that left other areas lacking (the dynamism). Regardless, did you get any measurements with the different hookup, showing that the bass was tamed or giving a flatter response? The original suggestion for doing this wasn't for the purpose of having a permanent alternative solution--it was to show that the bass from the towers only can be tamed via electronic calibration (even if it isn't the ideal permanent solution, obviously, because it bypasses the internal crossovers of the towers in a sense--no telling what all is lost with respect to fullness of sound, when doing it this way).
[QUOTE]
Yes, Mostly cured the bass hump at 20-40, it's about 3 to 6 db's which is an improvement but it sucked the life out of the dynamics. (PS: Check your PM's)
Yes. that would be correct.
Perhaps, I have a friend who has a unit with Dirac, I may see if I can borrow it. As I read though that seems to be really hit and miss with owners. Seems it works for a few though I am reading many reports of it not helping, which I expect is the reason Sandy's setup tips don't recommend this. I may try to borrow his unit but would need it for a few weeks to play around and make sure Dirac is the answer over various material.
Laika is offline
post #5414 of 5542 Old 07-23-2019, 02:29 PM
Laika's Avatar
Quoted: 50 Post(s)
Liked: 26
First, the original measurement posted doesn't show any calibration from the towers, as we know--at most, all you're able to do is adjust volume of the tower subs (and that obviously isn't going to address individual frequencies). It wouldn't be fair to compare your older towers and JL subwoofer together with the newer towers alone, because, after all, the older speakers were actually calibrated. So, this is stuff we already know (at best, for a more fair comparison between old speakers and new, you'd have to run your older speakers together without any calibration at all except for volume adjustment of your subwoofer). .
Actually the older STS were not calibrated, just feed with speaker wire, originally I rant the R1's the same way I ran the STS's full range on fronts, no calibration, just careful placement and bass traps and then filling in the voids with my sub, with the STS's that worked well, with the R1's they were bloated and hollow, honestly I have heard better sounding Bose "Lifestyle" systems but I will talk to my buddy and see if I can borrow his unit with Dirac. I will keep you informed.
HTNUT1975 likes this.
Laika is offline
post #5415 of 5542 Old 08-17-2019, 10:24 AM
Edi-MC's Avatar
Quoted: 79 Post(s)
Liked: 43
Out with the old:
In with the new
I'm A-MA-ZED!
Massive improvement in terms of sonic quality!
The MA BX5's are competent speakers that sit in a good place regarding price-quality. BUT the Tritons are really in a league of their own.
I'm having a blast listening to my music in Stereo (which I never did! Simply because the sound I got from the MA's was not satisfying).
Can't help smiling everytime I turn the system on to listen to some music
Regarding HT, the integration is proving to be a little bit more difficult (I have an SVS SB2000 and a pair of BX1's as surrounds). It was not "plug&play and all is good".
But I have to say that I haven't had much chance yet to fiddle with Audyssey. Only did one sweep.
Been reading this thread from the beginning and I'm already alert to the "Do's" and "Don'ts", but I'm counting with a little bit of work to make everything sound spot on.
Not to worried for now because the SuperCenter XXL is also a (near) future upgrade
Cheers!
Ediddy likes this.
Edi-MC is online now
post #5416 of 5542 Old 08-17-2019, 05:55 PM
Quoted: 28 Post(s)
Liked: 9
The wife said no to any Tritons because of the “sock” look. 😞
Gplusplus is offline
post #5417 of 5542 Old 08-17-2019, 07:26 PM
Quoted: 2524 Post(s)
Liked: 1223
The Reference and One.R don't have the sock.
They are a very classy looking piano black.
klh007 likes this.
Shopping List:
TV: LG CX/GX; Samsung...?
Blu-ray: Panasonic UB820
AVR/Pre-pro: Marantz 8805/7705 or 8012, or Yamaha 5200 or 3080
Speakers: GE Triton One.R, or ML ElectroMotion ESL X
New24K is online now
post #5418 of 5542 Old 08-17-2019, 07:43 PM
Quoted: 28 Post(s)
Liked: 9
Unfortunately, too rich for my blood. But they do look fantastic. 🙂
post #5419 of 5542 Old 08-28-2019, 01:40 AM
mikejedi123's Avatar
Quoted: 77 Post(s)
Liked: 67
Sandy ,
Really have enjoyed your BP7002 , CLR 2500 for about 13 years hooked up to my Yamaha pre/pro and Parasound Halo A52. It is great however , I have been wanting to upgrade to something that is superior but still gives me a bipolar type sound that is not bipolar and a little bit different. I think I have finally found that in your Triton series.(makes sense since you designed both ! ) I listened to the Triton Two Plus and the Triton One and One.R. I feel the best value for my new house I am purchasing is going to be the One.R and feel it will be a significant upgrade to my BP7002. The One.R is wonderful sounding full and huge huge soundstage with amazing neutrality and so much nice bass not overly bright but just right based on what I listened to. My question is , will my Parasound A52 125 x5 or about 140 x 2 (when not using the movies) and I think about 1.5 watts in Class A be plenty for the One.R? My new space is going to be about 15 x 18.. with 10 foot ceilings. I have a feeling it will as it has run my BP7002 with no issues whatsoever.l in a slightly smaller space. But seek your advice ! Appreciate it. Also would like to hook up the matching Ref Center to the Parasound to match the One.R to replace the CLR2500...and thinking Aons for surround to replace my aging Infinity small bookshelves. going to continue to use my Trinity with the One.R ..thanks so much sir!!
Mike
mikejedi123 is offline
post #5420 of 5542 Old 08-28-2019, 09:09 PM
Ediddy's Avatar
Quoted: 172 Post(s)
Liked: 156
I know I might be being annoying but have any folks on here upgraded from the Supercenter XXL to the Supercenter reference. I was talking to my dealer who i trust a lot told me that the Improvements weren’t minor and I would be pleasantly surprised. I know he’s a sales person so I wanted real life users.
Thanks in advance
Ediddy is offline
post #5421 of 5542 Old 08-29-2019, 04:08 AM
Quoted: 182 Post(s)
Liked: 336
Thanks in advance
check out page 2 of this review...
https://www.google.com/url?sa=t&rct=...C90BPSt-kTDRlc
post #5422 of 5542 Old 09-01-2019, 06:55 PM
Ediddy's Avatar
Quoted: 172 Post(s)
Liked: 156
Originally Posted by lefthandluke View Post
I read the review I was just curious if anybody on this page upgraded
Ediddy is offline
post #5423 of 5542 Old 09-02-2019, 03:49 PM
Quoted: 183 Post(s)
Liked: 40
Trying the combo of T-Ref + Benchmark DAC3 + PS Audio M700. This is some serious sound. I imagine Benchmark AHB2 would be even slightly better.
Setup #1: GoldenEar Triton Reference --> Parasound Halo Integrated --> Allo DigiOne Signature, LG OLED C7P 65
Setup #2: Elac Debut B6.2 --> Akitika GT-102 --> ??
tt.tennis-warehouse.com/index.php, www.dpreview.com/forums, www.bimmerfest.com/forums
Shangri-La is offline
post #5424 of 5542 Old 09-05-2019, 12:02 AM
sheavy's Avatar
Quoted: 16 Post(s)
Hello friends, I'm in the process of breaking in my triton 1 r speakers. I'm playing them at a low to mid volume with a speaker burin in cd that makes all kinds of funky sounds. The right speakers blue light is on when playing this disc. The left speakers blue light does not turn on, From what I can gather the speaker is working, just not showing of the blue light during play. Is this typical? Is there a reset of some sort I can do to get both blue lights on when speakers are in use. When I plugged in the speaker that does not shine blue when playing, it did go through the 25 or so on off sequence when first attached. Can anyone offer me any insight here? A huge thank you to anyone who can help.
Kind regards,
Mikey dee.
sheavy is offline
post #5425 of 5542 Old 09-05-2019, 04:22 PM
dscottj's Avatar
Quoted: 262 Post(s)
Liked: 163
Kind regards,
Mikey dee.
The blue light means the amp has turned on. No blue light = no amp. Check to make sure there's nothing wrong with the electrical socket it's plugged in to (plug a lamp in or something.) Then swap power cords to see if the light turns on. Make sure everything is snug & tight. If you still get no blue light, then IMO it's time to bring the dealer in. Even places with stellar quality control sometimes have problems. That's what the warranty is for, after all. Good luck!
I'm also an author! Gemini Gambit - He's trying to save the world. She's trying to hide from it. When they meet, death is the least of their worries. http://www.amazon.com/Gemini-Gambit-...dp/0986396214/
Its sequel, Dragon's Ark, is also available. Behind the Great Firewall of China, there are secrets people will kill to keep. https://www.amazon.com/Dragons-Ark-G...dp/B01LD5BYV4/
dscottj is offline
post #5426 of 5542 Old 09-06-2019, 04:00 AM
sheavy's Avatar
Quoted: 16 Post(s)
Thumbs up
Thank you brother, did what you said, it worked. Both blue lights on now when playing. Thanks again.
sheavy is offline
post #5427 of 5542 Old 09-08-2019, 12:47 PM
Liked: 1223
SoundStage's NRC measurement of the One.R's sensitivity comes in at 89.7dB...
https://www.soundstagenetwork.com/in...nts&Itemid=153
Shopping List:
post #5428 of 5542 Old 09-08-2019, 12:53 PM
mmiles's Avatar
Quoted: 1107 Post(s)
Liked: 572
How far back are you sitting.?
Download a SPL app for your phone. Not 100% but it will give you an idea of volume.
Movies tend to have more dynamic peaks and valleys. Dead silence to gun shot.
Folks wanting “reference” may not understand how loud that is. 75-85dB is VERY loud.
Mike Miles
[email protected]
mmiles is online now
post #5429 of 5542 Old 09-10-2019, 06:07 AM
sonic debauchery's Avatar
Quoted: 72 Post(s)
Liked: 65
Just saw this on hometheaterreview.com. GoldenEar has announced that it will be giving demos of its new Bookshelf Reference X (BRX) speaker at this week's CEDIA Expo in Denver, in Sound Room 2. The new BRX, which is effectively a passive version of the company's highly-lauded DR 3 powered wireless speaker, delivers rated frequency response of 40Hz to 35kHz, 90Hz efficiency, and is designed to handle up to 250 watts per channel. Pricing is set at $599 each, and the speaker is expected to ship in Q1 2020.
Read on for full details from the press release:
GoldenEar Technology is pleased to announce the introduction of a new ultra-high-performance compact bookshelf/stand-mount loudspeaker, the BRX, at the 2019 CEDIA EXPO. The goal of the BRX development project was to create a gorgeous, luxuriously finished, ultra-compact loudspeaker which would incorporate the latest advanced technology developed for GoldenEar's Triton Reference, Reference One.R and DR 3, in order to achieve truly superb sonic performance typical of larger, much more expensive units.
The BRX is basically a passive version of the groundbreaking DR 3 powered wireless loudspeaker. It incorporates a 6" cast-basket bass/midrange driver with a focused-field magnet structure. The cone is formed with a proprietary curve, from a special formulation of polypropylene, which combines superior internal damping with a high speed of wave transmission through the cone (Young's Modulus).
This is basically the same driver used in the award-winning Triton Reference tower. The tweeter is the Reference High-Gauss High-Velocity Folded Ribbon, the same used in both the Triton Reference and Triton One.R as well as the DR 3 and SPS. The two drivers are perfectly blended with a unique "balanced crossover" with a floating configuration that incorporates high quality film capacitors. New internal speaker wire, which has a unique twist as in the Triton Reference, is utilized. A pair of inertially balanced 6.5" planar infrasonic radiators located on either side of the cabinet, acoustically load the active 6" driver as well as couple the internal bass energy to the room for tight, quick, extended bass response. The beautifully styled 12"H x 8"W x 12.25" D cabinet is luxuriously finished in hand-rubbed piano black lacquer.
The BRX has been engineered to deliver superior reference level performance for both two channel as well as home theater systems of the highest quality, with extraordinary three-dimensional imaging and high-resolution clarity. It has been voiced to match the Reference towers, with a tremendous sense of you-are-there lifelike immediacy. Overall frequency response is 40-35 kHz, efficiency is 90 dB and recommended associated amplification is 10-250 watts/channel. Projected US retail price is $599 each and delivery is expected in the first quarter of 2020.
thinkthis likes this.
sonic debauchery is offline
post #5430 of 5542 Old 09-10-2019, 06:59 AM
Buddylee123's Avatar
Quoted: 921 Post(s)
Liked: 628
I have been waiting for something like this, thanks for posting.
Buddylee123 is online now
Reply Speakers
