GoldenEar Technologies Anticipation Thread - Page 99 - AVS Forum | Home Theater Discussions And Reviews
 806Likes
post #2941 of 5412 Old 02-03-2015, 11:13 AM
Audiguy3's Avatar
Quoted: 181 Post(s)
Liked: 92
I have what may be a stupid question
I have my Ones set up with my 8801 Marantz. I run both speaker cables and LFE cables to it using Audyssey for use with TV and my Oppo player for movies and streaming. I also play music via the Oppo to the Marantz using XLR cables that are stereo only and the Marantz just processes the signal to the Ones using the main speaker cables not LFE. My question is - by having the LFE cables plugged into the Ones, do the Ones expect a LFE signal or are the capable of the full range signal and take care of the bass themselves despite the LFE cable being plugged in.
Reggie Basement: Sony 75" 4K 940D/Marantz AV8802A & MM8077 & MM7055/GoldenEar:Reference (Front) Triton Ones(Rear),/SuperCenter XXL center channel/ 4 GoldenEar Atmos Invisa 650/Oppo BDP-205/Directv HS-17 and C61K/Roku 4K Family Room:LG 65" OLED/Marantz AV8802A & MM8077/ Vandersteen Treo Front/ GoldEar SuperSat60 Surround/ Directv HS-17 and C61K
Audiguy3 is offline
post #2942 of 5412 Old 02-03-2015, 11:48 AM
Liked: 5
I'm getting ready to start my basement home theater build and after a lot of time researching I have decided to go with golden ear. My theater is going to be 12'x22'x7' and my plan was 4 super sat3 for surrounds with triton 3's and supercenter x for the front. should i upgrade to the supercenter xl or will the X be good. Thanks
Swc1981 is offline
post #2943 of 5412 Old 02-03-2015, 12:13 PM
dscottj's Avatar
Quoted: 248 Post(s)
Liked: 156
It's all down to what the receiver sends them. If a full-range signal is sent down the wire, that'll be what's played. If the receiver does bass management, the wire will get the upper range and the LFE will get the lower. If the receiver sends a signal down both paths (typically when bass management is set to "plus"), they'll play both. This is not recommended, as the doubling will likely make the bass unacceptably heavy.
dscottj is offline
post #2944 of 5412 Old 02-03-2015, 12:26 PM
Audiguy3's Avatar
Quoted: 181 Post(s)
Liked: 92
That is what I thought - My Marantz does not use the LFE or any equalization for the music set up but I did not know if the Ones have a switch or sensing circuit that would only send a signal to the subs from the LFE circuit if a LFE cable was attached.
Audiguy3 is offline
post #2945 of 5412 Old 02-03-2015, 12:29 PM
Audiguy3's Avatar
Quoted: 181 Post(s)
Liked: 92
I would suggest going in to listen to them to make that determination. I had been using a subersat for center channel and when I went into the store they set up the XL and the supersat I had been using. I bought the XL
Audiguy3 is offline
post #2946 of 5412 Old 02-03-2015, 05:54 PM
steveting99's Avatar
Quoted: 1847 Post(s)
Liked: 651
Audiguy3,
On your Marantz AV8801 and during setup, did the receiver ping the subs on the Triton Ones as the sub speaker? If so, then correction filters are available of the LFE channel. During Audyssey setup, it should also ping the front left and right speaker (Triton Ones) and determine the F3 point (the lowest frequency) that the Ones can produce in the room. Correction filters are assigned by Audyssey up to the F3 point for each speaker, so it would be worthwhile to check this out.
If you've set the front left and right as LARGE and said 'NO' sub in your setup, then then LFE signals will be combined with front left + right under bass management of the AV8801. Provided the F3 for the front left+right is below 20Hz, then the combined left+right+LFE bass frequencies will be reproduced by the Ones with the correction of 10dB for LFE.
If you've set the front left and right as LARGE and said 'YES' to sub in your setup, you might be getting what's called 'double bass' and this may sound boomy or muddy or stress the built in subs of the One. This is because there is no bass management being employed.
Marantz SR-7009, Oppo BPD-93, MTV 7000D, aTV, Harmony Home Control remote, KEF E301+T101, MiniDSP (2x4)+(10x10HD)+(DDRC-88A), Emotiva 2xXPA-5 (Gen2), Rythmik 2xF12G+2xF8, HiMedia Q16, LG 55EC9300.
steveting99 is offline
post #2947 of 5412 Old 02-04-2015, 05:03 AM
sonic debauchery's Avatar
Quoted: 70 Post(s)
Liked: 63
I would get the XL, as i had SS50C and the XL gives far greater depth. I would also consider the new Triton 5. Supposedly sounds like the Triton One with less bass. Can't wait to hear them in March/April!
sonic debauchery is offline
post #2948 of 5412 Old 02-04-2015, 06:26 AM
Joseph Clark's Avatar
Quoted: 281 Post(s)
Liked: 322
Yes, before buying the Threes, wait for the Fives (or get the Sevens). Worry about a separate sub later if you feel the need for more bass. It's a matter of taste, of course, but I like the Sevens better than the Twos (and the Threes). I have separate subs.
Joe Clark
Joseph Clark is offline
post #2949 of 5412 Old 02-04-2015, 07:13 AM
d_m1010's Avatar
Quoted: 64 Post(s)
Liked: 184
Very true, but the Ones are simply stunning. The best speakers I have ever owned.
dscottj likes this.
Psn: memnoch1010
Xbox live: meadoch
d_m1010 is offline
post #2950 of 5412 Old 02-04-2015, 07:31 AM
Quoted: 281 Post(s)
Liked: 322
True, but the Ones are not in his apparent price range. The Fives and Sevens are.
post #2951 of 5412 Old 02-04-2015, 07:47 AM
d_m1010's Avatar
Quoted: 64 Post(s)
Liked: 184
Gotcha. Skimming and missed that part.
Psn: memnoch1010
Xbox live: meadoch
d_m1010 is offline
post #2952 of 5412 Old 02-04-2015, 05:12 PM
Liked: 5
The triton 1's aren't really out of my price range I just thought they would be overkill for the size of my room. If I'm wrong then I have some more thinking to do.
Swc1981 is offline
post #2953 of 5412 Old 02-05-2015, 04:19 PM
DrSchteeve's Avatar
Hoping to get some jealousy going here - just ordered the Ones, Fives, Supersat 60 Center, and 4 Invisa 650's for the ceiling. Will have to wait on the Fives, of course. Otherwise going with Integra 60.6 and Sony XBR.
DrSchteeve is offline
post #2954 of 5412 Old 02-05-2015, 08:11 PM
Quoted: 281 Post(s)
Liked: 322
If the Triton Ones aren't out of your budget range, then by all means listen to them. I heard a 1947 Andre Segovia recording on them the other day at my dealer's house, along with a few other short pieces, and they sounded spectacular. I'd also consider four Triton Fives and one of GE's new $2,000 SuperSubs. With a space as big as yours, you might want to consider a Dolby Atmos/DTS-X receiver (depends on when you want to finish the room) and a 5.1.4 setup (4 Invisa speakers in the ceiling).
-------xx-x--------
---x------------x--
------x------x-----
------x------x-----
---x------------x--
That's what I'm aiming for in the next few months.
The xx is the sub. The four x's in the middle are the Invisa ceiling speakers. Triton Fives flank all this. All very rough, of course, but the costs would be:
SuperSub: $2,000
4x Triton Fives: $4,000
Four Invisa 650s: $1,200
SuperCenter XL: $800
That's $8,000 worth of speaker bliss.
You could trim that figure by going with Triton Sevens, Invisa 525s, a Forcefield 5 sub and a SuperCenter X (or any combination). That leaves money on the table for a kick-a$$ AVR. And it would include a hemispherical surround system, not just a flat one.
There will be lots of receivers to choose from in the next few months, but Mark Henninger (our AVS reviewer) heard a similar GE setup at CES and thought it sounded great. He convinced Sandy Gross to let him use the system in his studio for the next year.
Joe Clark
post #2955 of 5412 Old 02-06-2015, 05:57 AM
Quoted: 70 Post(s)
Liked: 63
Congrats.You will have a superb system. Stevetin99 got u beat though. How come a 60 c, why not an SSXL?
post #2956 of 5412 Old 02-06-2015, 06:00 AM
rustolemite's Avatar
Quoted: 332 Post(s)
Liked: 97
I was gonna ask the same question, that 60 should not be matched with the Ones. Are you using the fives for rears?
VIDEO: Epson 5040UB * SeymourAV CenterStage XD 137.7" * Samsung UBD-M9500 * Nvidia Shield * HTPC * Xbox OneX * URC MX-990
AUDIO: Marantz AV7704 * Emotiva XPA-9 Gen3
SPEAKERS: PSA MTM-210T L/C/R * PSA MTM-110 (2) Surrounds * S2(4) Atmos * HSU VTF-3MK4
http://www.invelos.com/dvdcollection.aspx/Rustolamite
rustolemite is offline
post #2957 of 5412 Old 02-06-2015, 06:27 AM
thduke's Avatar
No not jealous at all happy for you, I am very happy with my One's, Two's, SCXL, supertsats, and FF5
GoldenEar Triton One's 2
GoldenEar Triton Two's 2
GoldenEar Super Center XL 1
GoldenEar SuperSat 3 2
GoldenEar ForceField 5 1
OPPO 105, Emotiva XPA-5, Emotiva XPA-2
thduke is offline
post #2958 of 5412 Old 02-06-2015, 06:34 AM
dscottj's Avatar
Quoted: 248 Post(s)
Liked: 156
Gonna respectfully disagree. My one-sixty-one center spread sounds fine to me.
dscottj is offline
post #2959 of 5412 Old 02-06-2015, 07:57 AM
Quoted: 70 Post(s)
Liked: 63
Have you heard the SSXL?
post #2960 of 5412 Old 02-06-2015, 07:58 AM
Quoted: 70 Post(s)
Liked: 63
I agree, which is why i asked the question? At minimum a SCXL with the ones. Ideally a one as a center would be pinnacle!
post #2961 of 5412 Old 02-06-2015, 08:16 AM
Quoted: 332 Post(s)
Liked: 97
I guess it can just depend on the room size and what you prefer.
When I had my Two's at the time there was only the SuperSat 50, and I always felt it was never enough especially when I was listening to a big action movie the voices coming out of the 50 would be drowned out by the Two's.
Just my experience.
post #2962 of 5412 Old 02-06-2015, 03:40 PM
Liked: 5
-------xx-x--------
---x------------x--
------x------x-----
------x------x-----
---x------------x--
SuperSub: $2,000
I'm going to wire for atmos but a new reciever and ceiling speakers will be my last upgrade since there really isn't a whole lot of media available yet that utilizes atmos.
Priority flow chart
Room construction
Projector(epson 5030 ub)
7.1 speaker upgrade(I have a Boston acoustic 5.1 set up now)
Acoustical room treatments
New reciever and ceiling speakers(currently have a denon avr-1911).
Swc1981 is offline
post #2963 of 5412 Old 02-06-2015, 04:17 PM
DrSchteeve's Avatar
The Sat is an aesthetic choice based on locating my TV over a fireplace. It is the 60, hopefully enough - the Sat was used in some of the setups done by GoldenEar for demonstrations, so I'm not too worried.
post #2964 of 5412 Old 02-06-2015, 08:57 PM
Quoted: 70 Post(s)
Liked: 63
When I had me Two's at the time there was only the SuperSat 50, and I always felt it was never enough especially when I was listening to a big action movie the voices coming out of the 50 would be drowned out by the Two's.
Just my experience.
Same here, the scxl is a far better speaker to my ears.
post #2965 of 5412 Old 02-08-2015, 06:59 PM
dejanuts's Avatar
Quoted: 12 Post(s)
Liked: 0
Shipping Date for the T5s
Stopped by my local dealer to find out when they expected to have the new T5s on hand and sadly they told me Sept/Oct. They had just checked for another customer. I thought the date reported at CES was March. Did I get that wrong?
Not that I'll be suffering between now and whenever, I'm thrilled with my T7s. But...
dejanuts is offline
post #2966 of 5412 Old 02-08-2015, 07:44 PM
Quoted: 281 Post(s)
Liked: 322
Thank goodness. There are just too many temptations in my life now anyway.
Joe Clark
post #2967 of 5412 Old 02-09-2015, 11:48 AM
DrSchteeve's Avatar
I was told first batch April and my order was in on time. I would hate to have to wait until Sept/Oct - even though the 5's will "only" be my rears, I don't have anything in place now.
post #2968 of 5412 Old 02-09-2015, 11:59 AM
goldenear tech's Avatar
Quoted: 148 Post(s)
Liked: 172
LFE Set Up with Tritons
Hi, Even though the LFE cable is plugged in, as long as you have the processor set to Large Left and Right and Sub Yes, the Ones will play the proper bass information on two channel music. But do not use the Super Bass, Double Bass or Bass Plus Settings, or you will be getting too much bass, as it will send the full bass info to the left and right speakers as well as to the LFE, and it will double up. All the Best, Sandy
goldenear tech is offline
post #2969 of 5412 Old 02-09-2015, 12:01 PM
Quoted: 148 Post(s)
Liked: 172
Triton Five Arrival in Stores
We expect the Triton Fives to be in the stores in April, as long as they order them, of course. Who is your dealer? Thanks, Sandy
post #2970 of 5412 Old 02-09-2015, 12:16 PM
Quoted: 148 Post(s)
Liked: 172
Bass Management
Hi, With Triton One and Two (and usually Three), left and right channels should always be set to Large, with full range signal going to them. You should not use bass management to roll them off on the low end, with bass frequencies sent to the LFE channel. This would eliminate the advantages of stereo bass, as well as insert an additional unneeded crossover point. LFE channel should should be used for LFE signal only, unless you are trying to eliminate some of the bass from the main speakers and send it to a separate subwoofer. Thanks, Sandy
Reply Speakers
