Remove Grills on Cambridge SoundWorks Ensemble Sat Speakers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 10-23-2010, 07:11 PM - Thread Starter
jayw's Avatar
Quoted: 22 Post(s)
Hi,
I have an old pair that I would like to use again. While they sound great and are a good match for the purpose, I really want them to be black. I would like to spray paint them, but cannot figure out how to remove the grills to mask the drivers. Anyone have any ideas on how to do that?
TIA,
Jay W
Check here later for a thoughtful, funny, profound .sig line.
jayw is offline
post #2 of 6 Old 10-23-2010, 07:32 PM
afrogt's Avatar
Quoted: 2051 Post(s)
Liked: 1376
you have any pics of the speaker?
Afro GT
afrogt is offline
post #3 of 6 Old 10-23-2010, 07:57 PM
zieglj01's Avatar
Quoted: 2962 Post(s)
Liked: 2875
Originally Posted by jayw View Post
Hi,
TIA,
Jay W
You will have to use something with a tip on it, similar to a cork
screw. Press in to the edge of the grill slightly, to get a grip - be
gentle when pulling back. Work your way around the edges of the
grill, till it comes off. Or try using a small hook or pick tool.
Who AM I
zieglj01 is online now
post #4 of 6 Old 12-19-2012, 03:09 PM
theneweddie's Avatar
Hi,
I am in a similar situation and was wondering if you ever managed to remove the grill from your speakers.
theneweddie is offline
post #5 of 6 Old 03-02-2019, 03:45 AM - Thread Starter
jayw's Avatar
Quoted: 22 Post(s)
Originally Posted by theneweddie View Post
Hi,
I'm a bit late. No, and now I'm back to trying figure it out again, 9 years later.
jayw is offline
post #6 of 6 Old 03-03-2019, 08:24 AM
SgtNarc1's Avatar
Liked: 0
I have removed many grills and found that the tip of a dry wall screw used gently all around works for me. I also used a small screwdriver to act as a wedge. Tedious job.
Thank goodness magnetic grills are becoming norm.
Good luck
SgtNarc1 is offline
Reply Speakers
