Philharmonic Audio - Dennis Murphy - Page 250 - AVS Forum | Home Theater Discussions And Reviews
 4969Likes
post #7471 of 10010 Old 01-17-2019, 09:36 AM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 2075
Originally Posted by BluesDaddy56 View Post
Originally Posted by Soulburner View Post
Has anyone heard the KEF R3?
https://www.kefdirect.com/speakers/h...s-2018/r3.html
They don't compete on price, but they (sort of) do on specs. 3-way stand mount. I'd guess the midrange dispersion won't be as wide as the BMR, possibly hurting off-axis response, but otherwise they look good and imaging could be better with the Uni-Q driver. I'm not sure if they are worth the $600 premium but they seem like a good speaker. Similar profile, gloss black box (other options are available).
I'm not sure they do spec as good as the BMR. They're 6 db down at 38hz and 3 db down at 52 hz. The BMRs are + / - 2 db at 34 hz. So even with in room response helping out the KEFs, the BMRs in the same room should have lower extension. The only thing I can see is that the KEF may image better with the UniQ. I would think definitely NOT worth the extra $600.
They measure well: http://us.kef.com/media/doc/r2018_whitepaper_en.pdf
Yes, their -3dB point is 58Hz which is not great, but on and off axis response is great. Imaging should be best in class, though there has to be some tweeter distortion with this design because its waveguide is a moving midwoofer cone. How much I don't know, but probably more than the RAAL.
I would tend to agree that the BMR Philharmonitor is a very good deal in comparison. Another point in their favor is that Dennis can make you a third for center duty. The KEF R3s appear to be sold in pairs.
HT: Samsung PN64H5000 (recommended settings) | NAD T758 V3 | Buchardt S400 (2) | Polk LSiM 702 F/X (2) | Infinity RS152 (4) | Subs TBD (2)
PC: Micca OriGen G2 | Mackie MR624 (2)
Soulburner is online now
post #7472 of 10010 Old 01-17-2019, 01:19 PM
Elihawk's Avatar
Quoted: 2099 Post(s)
Liked: 2270
Originally Posted by Lp85253 View Post
are the tweeters in for the aa+'s ?.. i'm getting a jones going lately...
The tweeter in the AA are a really good metallic done tweeter- Morel tweeters.
https://www.madisoundspeakerstore.co...e-rear-chambe/
Set up #1: EMP e5Ti, e5Ci, and EMP e5Bi surrounds, Outlaw LFM1 Plus sub, SVS NSD SB12 sub, Integra AV receiver
Set up #2: Def Tech CA Aero 2, CLR2002, SLS Qline surrounds and EMPtek10i10i sub, Slimline AV receiver
Set up #3: Philharmonics- BMR in a 2.0 system, music only, Integra AV receiver
Elihawk is offline
post #7473 of 10010 Old 01-17-2019, 01:25 PM
Quoted: 2481 Post(s)
Liked: 2293
thanks , my question, i guess i wasn't clear, are they back in stock, i heard mid January , but haven't heard whether they actually came in yet , my guess is the govt shutdown might be screwing up the works( customs isn't working right now on a full scale and stereo equipment isn't exactly a high priority)
YAMAHA TSR 5790.. front l/r Dennis Murphy modded emotiva b1's ..BIC v1220.....Emotiva basx10.... infinity alpha 20 center.. polk t15 rears..samsung 55" j620d
bedroom .. YAMAHA r-xv 383... front l/r.. ascend cbm 170 se... kef q100 center ... Emotiva basx8... samsung ku6300 50 in
Lp85253 is offline
post #7474 of 10010 Old 01-17-2019, 02:23 PM
Elihawk's Avatar
Liked: 2270
oh, sorry...Dennis will have to answer that one!
Lp85253 likes this.
Elihawk is offline
post #7475 of 10010 Old 01-17-2019, 02:56 PM
Liked: 2293
no problem.. my dynaudio emit m10 demo at the dealer is on hold for that very reason, thank goodness i have no need to hurry , i'm listening to wharfedale 10.1s on that system now .. not exactly slumming it ... did i see in your set ups that you have the bmr's being driven by a yamaha entry level avr? that makes me optimistic that either the dyns or aa+'s will be easily driven by mine...
Lp85253 is offline
post #7476 of 10010 Old 01-17-2019, 03:19 PM
audiofreak38's Avatar
Quoted: 750 Post(s)
Liked: 1080
Lee a lot of that will depend on your listening habits. That is, if you like to play it very loud, then you might run into some problems w/a 4 ohm speakers. I have never been one to play at absurd levels. Do like to rock out every now and then though. For me, it is much about SQ than SPL. Kenny Wayne Sheppard's Blue On Black has to sound just right for me.
Cheers,
Phil
ahblaza, ambesolman and Lp85253 like this.
audiofreak38 is offline
post #7477 of 10010 Old 01-17-2019, 03:29 PM
Liked: 2293
i never was one to see if i could blow up amps or tweeters , i stay more concerned with sq .. i don't buy into the " you have to have better than an avr" for sq theory, *but* i know that some amps are a bit better sounding (i don't hear a huge difference when i have a/b'd though).. it just made me feel a bit better that somebody else runs a music 1st set up with an entry level avr..
Lp85253 is offline
post #7478 of 10010 Old 01-18-2019, 02:49 AM
charmerci's Avatar
Quoted: 497 Post(s)
Liked: 357
The RAAL tweeter is just in a league by itself, especially when compared to the good, but not outstanding folded ribbon tweeters that are available one many budget speakers (HTD, Emotiva, etc). Dennis can explain what sets a "real" ribbon tweeter apart from some of the other versions...
Like I've said several times on this thread before - there is nothing better out there (well, I haven't heard everything out there...) than the RAAL tweeter for female vocalists. Amazing.
charmerci is online now
post #7479 of 10010 Old 01-18-2019, 05:27 AM
Elihawk's Avatar
Liked: 2270
unfortunately, since the tweeter are imports, they may be affected by the government shutdown!
Yes, I don't listen to music at a really loud level, but my AVrec drives the BMRs plenty loud without sweating!
DavidKirsh likes this.
Elihawk is offline
post #7480 of 10010 Old 01-18-2019, 07:57 AM
Liked: 2293
that is a great sign for my future usage ( i like avr's for their flexibility in set up)... thanks for the feedback..
Lp85253 is offline
post #7481 of 10010 Old 01-18-2019, 09:21 AM
Elihawk's Avatar
Liked: 2270
yes, me as well! And while my signature isn't updated (I am currently using an Integra, 80 wtt/channel)...the point still stands!
ahblaza and Lp85253 like this.
Elihawk is offline
post #7482 of 10010 Old 01-18-2019, 04:20 PM
brian6751's Avatar
Quoted: 1752 Post(s)
Liked: 1784
They are silk dome actually
Lp85253 likes this.
FOR SALE:
Lots of stuff. Check the Audio Gear Classifieds
brian6751 is offline
post #7483 of 10010 Old 01-18-2019, 04:27 PM
Liked: 2293
i can't believe i didn't catch that , i knew it too.. i checked out the morel website when the aa+'s came out..
Lp85253 is offline
post #7484 of 10010 Old 01-19-2019, 05:15 PM
Elihawk's Avatar
Liked: 2270
Yes, the Madison Sound website is a little confusing as they list it as "textile dome tweeter with an aluminum face plate. Good catch, either way, that is a pretty pricey tweeter in that speaker!
Elihawk is offline
post #7485 of 10010 Old 01-19-2019, 05:50 PM
Dennis Murphy's Avatar
Quoted: 960 Post(s)
Liked: 1491
Pricey indeed. And in fact too pricey. When I launched the AA+ I thought i was going to be able to obtain a substantial quantity discount on the Morels. As it turned out, the discount only applied to sales at a retail price. I've been losing my shirt on the AA+, and to a lesser extent, the original AA with the Dayton tweeter. When you add to that the hours and hours it takes to hand-wire the crossovers and assemble the components, the AA line just isn't practical. So I've had to bring the AA's to a screeching halt. I wish I had had an automatic braking system much earlier. It's a shame because I really haven't heard as good an all-around product in that price class. But as it turns out, they were too good to be true. I apologize to any prospective purchasers.
gajCA, t1337Dude, jomartz and 1 others like this.
Dennis Murphy is offline
post #7486 of 10010 Old 01-19-2019, 05:55 PM
Liked: 2293
o well.. such is life .. thanks for the effort ..
Lp85253 is offline
post #7487 of 10010 Old 01-19-2019, 06:15 PM
canyoncreek's Avatar
Quoted: 69 Post(s)
Liked: 90
What about putting g that design in the public lic domain or charge a small licensing fee...
Sent from my SM-G955U using Tapatalk
canyoncreek is offline
post #7488 of 10010 Old 01-19-2019, 06:34 PM
Liked: 2293
@Dennis Murphy .. i think this was meant for your eyes..
Lp85253 is offline
post #7489 of 10010 Old 01-19-2019, 06:37 PM
Quoted: 960 Post(s)
Liked: 1491
I'm not sure very many people would want to take it on if they saw how complex it was. And they would have to pay retail for the parts.
Lp85253 likes this.
post #7490 of 10010 Old 01-19-2019, 06:41 PM
Liked: 2293
it really is a shame about the aa's, but all great things have an end... any ideas about replacements since it seems everything less expensive than the bmr is shut down.. ??? (or soon will be)
Lp85253 is offline
post #7491 of 10010 Old 01-19-2019, 06:46 PM
Quoted: 591 Post(s)
Liked: 520
Oh no!!! These speakers are fabulous and perhaps a price adjustment is warranted.
Do you have parts for a few more as I'd really love to get enough for a center and two surrounds. Have built a few crossovers and speakers in my day. Let me know. Thanks.
cocrh is offline
post #7492 of 10010 Old 01-19-2019, 07:15 PM
kaiyen's Avatar
Quoted: 52 Post(s)
Indeed - are they completely gone or can one snag a last pair?
Sent from my Pixel 2 XL using Tapatalk
kaiyen is offline
post #7493 of 10010 Old 01-19-2019, 07:19 PM
Quoted: 2053 Post(s)
Liked: 1687
@Dennis Murphy
Maybe consider still offering the AA’s but increasing the price respectively. I think that your speakers are still extremely well performers in a price bracket two, maybe even three times your asking price.
I’m sure people would pay the extra.
Soulburner, Lp85253 and cocrh like this.
Leave it at 8 ohms and call it a day :)
Russdawg1 is online now
post #7494 of 10010 Old 01-19-2019, 10:20 PM
Quoted: 591 Post(s)
Liked: 520
Originally Posted by Russdawg1 View Post
@Dennis Murphy
I think I figured it out. He wants me to buy 3 BMR's for my fronts!!! Gonna have to save some coin up for that upgrade!!
cocrh is offline
post #7495 of 10010 Old 01-19-2019, 10:23 PM
Liked: 1687
I’m sure if you asked for some BMR’s he’d tell you that they discontinued the Seas Woofer and force you to buy some of his Phil 3’s
cocrh likes this.
post #7496 of 10010 Old 01-20-2019, 05:50 AM
charmerci's Avatar
Quoted: 497 Post(s)
Liked: 357
Question
@Dennis Murphy
Nope, because he does these - http://philharmonicaudio.com/Mini-Monitor.html - at $700/750. Why spend 600 when you can get better at 700?
post #7497 of 10010 Old 01-20-2019, 07:58 AM
Striper Mark's Avatar
Quoted: 138 Post(s)
Liked: 63
Phil BMR Question
For those that have the Phil BMR's is it fair to say that these have a sweet spot when played louder? I've had a pair for a few weeks now and while I'm still trying to play around with placement my general sense is that when they are played at lower volume they sound almost boxy or thin. (Sorry if I don' thave the lingo down...) When played at moderate and higher levels these really sing and sound tremendous. These are powered from NAD 368 and music is FLAC or Tidal. Also, do these tend to have a narrower sound stage?
Is that consistent with other's experience?
Mark
Living Room: Samsung 65" KS8000; Oppo 203; NAD 758V3; Philharmonic BMR L/C/R; Elac B5's Rear Left/Right; SVS PB2000
Basement : BenqHT3550; Denon x4300; SVS Ultra L/C/R; Prime Surrounds; Prime Elevation; Infinity in-Ceiling (7.1.4) Dual PSA V1500
Striper Mark is offline
post #7498 of 10010 Old 01-20-2019, 08:43 AM
Liked: 2293
the mini's are going away soon though .. as are the larger 2 way monitors , as i remember his supplier is no longer offering the curved cabinets he uses ..so everything under $1300 is gone or is soon to go bye -bye.. i hope, but i am not holding my breathe , that he will offer a new speaker at the $300-1000 range .. i get the feeling Dennis works a bit harder than most of us realize and is "gearing down" a bit...i salute him for the work he has done..
Lp85253 is offline
post #7499 of 10010 Old 01-20-2019, 09:51 AM
Liked: 1687
Well I was just stating how well they perform (Like $600-$900 speakers) but I would not pay that much for them. I would however pay the extra that it costs to get the morel tweeter and however much Dennis would like extra for his impeccable crossovers.
post #7500 of 10010 Old 01-20-2019, 10:00 AM
gajCA's Avatar
Quoted: 10079 Post(s)
Liked: 7084
Not sure how you make money on the BMRs either!
Fantastic price/value on those as well.
ahblaza likes this.
Geoff A. J., California
gajCA is offline
Reply Speakers
bmr philharmonitors , slim towers
