Philharmonic Audio - Dennis Murphy - Page 310 - AVS Forum | Home Theater Discussions And Reviews
 4391Likes
post #9271 of 9341 Old 10-11-2019, 12:45 PM
duc135's Avatar
Quoted: 311 Post(s)
Liked: 410
Originally Posted by Elihawk View Post
3?! Well, Bose, Klipsch and Def Tech are the worst offenders of the Big boys...but Polk, JBL, GoldenEar, (I won't list them all and some of them on AVS will come at you) etc all post stats that aren't real world accurate...
Honest question. What measurements does JBL post that are not accurate? My understanding is that their speaker measurements are among the most complete and accurate.
duc135 is offline
post #9272 of 9341 Old 10-11-2019, 01:36 PM
Elihawk's Avatar
Quoted: 1943 Post(s)
Liked: 2092
probably a bad example, because I think most of their specs are pretty close...but someone posted sensitivity specs of one of their speakers and noted about a 6 dB exaggeration....
Lp85253 likes this.
Set up #1: EMP e5Ti, e5Ci, and EMP e5Bi surrounds, Outlaw LFM1 Plus sub, SVS NSD SB12 sub, Marantz Slimeline 1504 AV receiver
Set up #2: Def Tech SM450, CLR2002, SLS Qline surrounds and EMPtek10i10i sub, Denon 1910 AV receiver
Set up #3: Philharmonics- BMR in a 2.0 system, music only, Yamaha RXV-363 AV receiver
Elihawk is offline
post #9273 of 9341 Old 10-11-2019, 02:32 PM
butie120's Avatar
Quoted: 1122 Post(s)
Liked: 364
I see Dennis that you are now involved on AVS again, glad to hear you are doing well! I recall reading that you are done making speakers and your website even states that no more orders will be processed. Are you still in the position of no longer making speakers? Just wanting to see where you are at with all of this. Thanks!
Speakers: Fronts- JBL 230, Center- JBL 235C, Surrounds: Fluance XLBP
Sub: PSA 15V
Processing: Onkyo 676
Video: BenQ 1080ST
butie120 is offline
post #9274 of 9341 Old 10-11-2019, 03:45 PM
Quoted: 2125 Post(s)
Liked: 1791
3?! Well, Bose, Klipsch and Def Tech are the worst offenders of the Big boys...but Polk, JBL, GoldenEar, (I won't list them all and some of them on AVS will come at you) etc all post stats that aren't real world accurate...Wait, Bose doesn't post stats, they just post ridiculous claims!
In fact, I think what Imagic posted was more the norm that unusual...sure, those speakers can hit 35 hz...if you hold your ear right up to the speaker, and then, I am told, you can also hear the ocean!
I really like what Shane Rich said about the 1st generation EMP Impression series books, with a 5 1/4 inch woofer...he say, sure, we could tune that thing to hit upper 40s/lower 50s, but when they did it didn't sound very good. So they made the cut off just under 60 hz and said use a subwoofer!
def tech and klipsch and polk were the 3 i thought of right away .. polk probably not as much as the other 2...
YAMAHA TSR 5790.. front l/r emotiva b1's and /or kef q100's ..BIC v1220.....Emotiva basx10.... ascend cbm 170 center.. polk t15 rears..samsung 55" j620d
bedroom .. YAMAHA r-xv 383... front l/r.. wharfedale 10.1s... ascend cbm 170 center ... Emotiva basx8... samsung ku6300 50 in
Lp85253 is offline
post #9275 of 9341 Old 10-11-2019, 04:56 PM
Rick Craig's Avatar
Quoted: 177 Post(s)
Liked: 299
Originally Posted by PhilharmonicDennis View Post
The bass spec is taken from modeling done by Paul Kittinger. As I noted in one of my posts on the Albany thread, capturing the true woofer performance in the deep bass is very difficult, and all of the current methods have problems, be they ground plane, nearfield woofer measurements spliced to quasi-anechoic at around 250 Hz, or full range measurements in an anechoic chamber, like those performed by the NRC. Paul and I have had some exchanges with shadyJ concerning his ground plane measurements, and he noted that he may not be picking up the rear port's full output. In any event, shady's qualitative descriptions of the BMR's bass response sure don't seem consistent with a -3dB point of only 53 Hz. For example: "Their bass extension is the best I have seen from a bookshelf speaker, and the bass quality itself is superb much like the rest of the frequency range." "Extraordinarily deep bass extension" "these are bookshelf speakers with the performance goal of having low-frequency extension on par with tower speakers, and with bass extension digging down into the 30 Hz range, they actually exceed many tower speakers in terms of extension.... You cannot get a reasonable level of deep bass output in a small package, and these speakers do an excellent job of providing deep bass output in a reasonable size and shape. I don’t know how that could be done better."
I modeled the woofer in my software and my results are quite different than what Paul gave you. The nearfield measurements have given me no problems and are just like anechoic numbers. I've not used the groundplane method but from what I understand it's pretty accurate. If there's a question on picking up the rear output then he could've just rotated the speaker or measured from the front and rear. Obviously it did pick up most (if not all) of the port output since there's not a dip in the curve around the port tuning.
The NRC curve (no longer on your site?) is quite different and does show the shortcoming of the chamber's 80hz limit. I'm not sure what "correction" they do to simulate below 80hz but I've not noticed the same issue with all of the rear-ported designs that they've tested. This is a case where the groundplane was more accurate than the NRC, at least with your speaker.
Selah Audio
Thinking Inside the Box...
Rick Craig is offline
post #9276 of 9341 Old 10-11-2019, 06:17 PM
zieglj01's Avatar
Quoted: 3200 Post(s)
Liked: 3109
They tend to be closer than most -- on their specs
Who AM I
zieglj01 is online now
post #9277 of 9341 Old 10-12-2019, 12:11 AM
Quoted: 277 Post(s)
Liked: 730
First, I have complete confidence in Paul's modeling. He has an impeccable track record, and he uses very sophisticated software that also can model various transmission line designs with high accuracy. I took very careful and multiple measurements of the new 8545's TS parameters, since Scan's published specs are never correct. If your results are "quite different," I suspect its because you're using the parameters for the old model of the 8545, you relied on factory or third-party specs, or there was some other problem with the modeling. Like you, I don't have any experience with ground plane measurements, so it's hard for me to evaluate James Larson's results. The published results were for a mic placement in front of the speaker. He also sent Paul and me results that averaged measurements in front of and behind the BMR, and these were much closer to Paul's modeling. The only thing I can say for certain is that an F3 of 53 Hz, as shown the published plot, is completely inconsistent with James' own description of the bass and reports from BMR clients, not to mention the 8545's reputation for superior bass extension. I've never received a complaint in this regard--only positive reactions to the BMR's bass performance.
PhilharmonicDennis is online now
post #9278 of 9341 Old 10-12-2019, 09:15 AM
Rick Craig's Avatar
Quoted: 177 Post(s)
Liked: 299
Yes, I modeled the new version of the 8545. Here's a link to further testing as well. https://www.pearl-hifi.com/06_Lit_Ar...2012_8_Aug.pdf
Selah Audio
post #9279 of 9341 Old 10-12-2019, 01:22 PM
brian6751's Avatar
Quoted: 1707 Post(s)
Liked: 1704
I am one of the BMR owners that can confirm its great bass extension. I did not measure it but I never felt a sub was necessary even in my large open area. I felt the speakers bass performance was right in line with its midrange and treble which is to say very detailed, balanced and neutral
overg likes this.
FOR SALE:
Lots of stuff. Check the Audio Gear Classifieds
brian6751 is online now
post #9280 of 9341 Old 10-12-2019, 05:14 PM
Quoted: 277 Post(s)
Liked: 730
Thanks for the link Rick. I didn't realize how old the update was to the 8545. I guess it occurred in 2012. Paul just remodeled the BMR using Vance's TS measurements instead of mine, and although there some significant differences in the parameters, they were largely self-cancelling and the results virtually identical. However--during the course of this discussion I realized that the specs on my BMR page weren't updated when I switched to the smaller cabinet. The F3 for that clocks in closer to 37 Hz. I'll change that shortly. Even with the higher F3, there is still useful output at 34 Hz, and to demonstrate that I included a 34 Hz test tone on every demo CD I shipped.
post #9281 of 9341 Old 10-13-2019, 05:09 AM
Quoted: 17 Post(s)
Liked: 39
Real world case report on the 34 hz test tone.
About a week after getting my BMR's, I was listening to Dennis' test CD at rather high volume. I have a decent sized house, and my system is in my upstairs master bedroom. My 11 year old daughter was also upstairs in her bedroom (down the hall on the other side of the house), and my wife was downstairs in the kitchen (located below the master bedroom).
The 34 test tone came on. Within seconds my daughter comes running in laughing and asking what is going on. Once the tone stopped, my wife very angrily yells upstairs for me to never do that again, because I was rattling the entire kitchen and all the dishes in it. She was very legit displeased with me.
So the BMR's definitely have a lot of usable bass. They're not the equal of a separate sub or true full-sized, full-range speakers, but it would be absurd to expect them to be. If you're looking for lots of "slam" in your bass, you'll probably either need to look at bigger speakers or a separate powered sub. But the bass they put out is real and impressively controlled. I'd describe it as extremely "musical" at a much deeper level than I'd expect out of a bookshelf.
Soulburner and Ryanosaur like this.
overg is offline
post #9282 of 9341 Old 10-13-2019, 08:59 AM
Gyroscopics's Avatar
Quoted: 214 Post(s)
Liked: 280
+1
I run the BMRs full range (2.0) in a dedicated music setup with no room corrections. I can attest to the specs and bass extension of Dennis' BMRs. I even posted the FR curve in post #8761 .
In my room, I am very satisfied running the BMRs without subs. No, my room is not ideal in getting the best speaker measurements. It is a living room in an open space floor plan that opens to the kitchen/dining room to the right. It has a cathedral ceiling that opens up to the game room and bedroom hallways in the 2nd floor. It shares the same ceiling with the 2nd floor rooms.
Edit: Fixed link.
Gyroscopics is offline
post #9283 of 9341 Old 10-13-2019, 10:15 AM
s2000's Avatar
Quoted: 86 Post(s)
Liked: 76
Originally Posted by Gyroscopics View Post
+1
Edit: Fixed link.
Have you tried using the game room as a dedicated HT room or music listening room?
Just curious as we may be thinking about a larger home with a larger loft or bonus room and was thinking of utilizing it both for 2 channel music and dedicated home theater room. It just seems like room correction and treatments are more of a challenge on an open living room concept like I currently have as well...
Sent from my SM-G950U using Tapatalk
[I]Video: Sony XBR-75X850C 75 inch 4k - Samsung 55inch 4k -58 PANASONIC PZ850u plasma
4k-Blu Ray: Sony UBP x800 - PS3 - oppo 103 Amp and power : Pioneer elite SC - 27 - Monster Power AVS 2000 Reference - DT BP 30s- 10s - citation 5.1
Speakers and Sub : Kef Model reference 1 - DT CLR 2000 - DT UIW BP/A in ceiling rears - DT BPX Rears - JTR Captivator 118HT
s2000 is online now
post #9284 of 9341 Old 10-13-2019, 11:14 AM
Quoted: 214 Post(s)
Liked: 280
I also use the game room for music listening. In fact that's where I setup my spare speakers and amps. But the living room gets inhabited more often and it's the best place to get the most usage out of my fav speakers.
post #9285 of 9341 Old 10-13-2019, 11:15 AM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 1756
+1
I run the BMRs full range (2.0) in a dedicated music setup with no room corrections. I can attest to the specs and bass extension of Dennis' BMRs. I even posted the FR curve in post #8761.
Very nice, although in-room is not comparable to anechoic measurements posted by other speaker makers.
However, in-room is what you hear, so there's no doubt it was there.
HT: Samsung PN64H5000 (recommended settings) | NAD T758 V3 | Buchardt S400 (2) | Polk LSiM 702 F/X (2) | Infinity RS152 (4) | Subs TBD (2)
PC: Micca OriGen G2 | Mackie MR624 (2)
Soulburner is online now
post #9286 of 9341 Old 10-15-2019, 06:14 AM
Elihawk's Avatar
Liked: 2092
yes, In room is all I care about. I have never measured my BMRs, but had a studio eng at my house once to listen and he told me he felt like they hit 40hz pretty well...
Elihawk is offline
post #9287 of 9341 Old 10-17-2019, 12:32 PM
Quoted: 277 Post(s)
Liked: 730
Originally Posted by jcr159 View Post
Sounds like I'm in! Do we know more yet? Who will carry the kits? When they might be available? I didn't catch that earlier in this thread...
The parts-only BMR kit just became available from Meniscus: https://meniscusaudio.com/product/ph...r-speaker-kit/ I'm finalizing details for a finished cabinet option and for routed front baffles, which are the hardest part of DIY cabinet construction. I'll have to see a pair of completed cabinets before I can post that option, so they're a month or two away. I'll get pricing info for the front baffles posted shortly.
BuddTX, spkr_diy, defmoot and 9 others like this.
post #9288 of 9341 Old 10-17-2019, 12:37 PM
jcr159's Avatar
Quoted: 186 Post(s)
Liked: 93
Thanks Dennis!
A front baffle would be nice! 😀
I’m remodeling, so can wait a bit, but if I get impatient I may just roll my own! They will be behind an AT screen anyway...
Have a question and want it answered in podcast format?
[email protected]
http://www.avrant.com/
https://www.youtube.com/c/avrant
jcr159 is offline
post #9289 of 9341 Old 10-17-2019, 01:08 PM
_tk
Quoted: 567 Post(s)
Liked: 252
So it looks like ~$940 gets you all the parts for two speakers (minus cabs), plus for an extra $40 they will assemble the crossovers for you.
Not bad. I had it in my mind it'd be more expensive than that.
You have any recommendations on the tweeter capacitor options?
jcr159 likes this.
_tk is offline
post #9290 of 9341 Old 10-17-2019, 01:13 PM
BluesDaddy56's Avatar
Quoted: 572 Post(s)
Liked: 798
If finished cabs come in around $400 you can put a pair together for about what Dennis was charging at the end. Less if you put the crossover together yourself.
Display: Vizio P55-E1l Pre-pro: Marantz 7703; Amps: Emotiva XPA-2 Gen 2, Emotiva XPA-3 Gen 1, H/K AVR 520 (direct in to amps); Sources: Sony UBP-X700; X-box 1 S; Technics 1200 Mk II; Win10 PC for digital; Phono Preamp: Emotiva XPS-1; Speakers - LR: Philharmonic BMR LR; Center: Selah Audio BMR-CC; Surrounds: Wharfedale Reva-2; Rear Surrounds: Wharfedale Diamond 220; Atmos: TF - Monoprice Alpha 8; TR - BIC VI-38; Subwoofers: dual Rythmik L22s
BluesDaddy56 is offline
post #9291 of 9341 Old 10-17-2019, 01:22 PM
Quoted: 277 Post(s)
Liked: 730
There shouldn't be any need to upgrade capacitors except maybe for the tweeter circuit. It uses very low-value caps, so upgrading isn't all that expensive. Would you hear a difference? I don't think so, but you wouldn't lose any sleep over whether you might have heard one.
post #9292 of 9341 Old 10-18-2019, 01:47 PM
Quoted: 63 Post(s)
Liked: 190
@PhilharmonicDennis
Such exciting news! I can almost see myself doing this... Dunno where I'll put them, but...
You mentioned above two different cabinet sizes and the slight change to the responses it might cause... I understand completely that we are talking very minimal change at the end of the day... Amd I've been completely stoked with the Bennic Cabs and the performance of these guys.
What are the two different sizes, and can we choose to build more towards the older/larger cabinet size? (Assuming it did not require any additional XO modification, that is.)
Now for a trickier question! In your experience doing speaker builds, might the BMR still perform as well if it were to have a slot port on the front allowing for slight more freedom in placement?
Thank you!
lewdogg likes this.
7.2: Marantz SR6012, Outlaw Model 2200 (L/C/R/SL/SR)
Philharmonic Phil 3 (L//R), BMR (C), BMR (SL/SR), Mini-Phil (RL/RR), Outlaw X-13
Sony XBR49X900F, Sony UBPX700
Ryanosaur is offline
post #9293 of 9341 Old 10-18-2019, 02:47 PM
Quoted: 277 Post(s)
Liked: 730
Originally Posted by Ryanosaur View Post
@PhilharmonicDennis
Thank you!
I would stick with the smaller .75 cu ft cabinet. It has better power handling, and the centered drivers increase sensitivity a little and actually measure better that way. I don't have a crossover for the larger cabinet with centered drivers. I would not use a slotted front port. The bass response is significantly better with the flared Precision port on the rear, and there's much less port noise than with a slotted.
Lp85253 and Ryanosaur like this.
post #9294 of 9341 Old 10-22-2019, 09:43 AM
Rick Craig's Avatar
Quoted: 177 Post(s)
Liked: 299
Dennis - have you heard the Buchardt S-400? Since you enjoy modifying crossovers that one might me worth taking a look at. It would also be good for comparing to the BMR since they are very different designs.
Selah Audio
post #9295 of 9341 Old 10-22-2019, 10:55 AM
augerpro's Avatar
Quoted: 144 Post(s)
Liked: 76
Rick, was there something you'd like to see improved with the S-400?
augerpro is offline
post #9296 of 9341 Old 10-22-2019, 12:40 PM
Quoted: 277 Post(s)
Liked: 730
Funny you should ask. I may be able to borrow a pair for my edification. I won't be taring into the crossover, however. I'll be treating them with kid gloves. I'll also be hearing lots and lots of speakers at the Capital Audio Fest next week. Will you be attending?
zieglj01, Elihawk, Lp85253 and 3 others like this.
post #9297 of 9341 Old 10-23-2019, 08:25 AM
Rick Craig's Avatar
Quoted: 177 Post(s)
Liked: 299
I haven't listened to the S-400 but the detailed measurements they provide (kudos to Buchardt) do raise some questions. I also noticed some issues with the quoted bass extension and sensitivity specifications. I did model the SB Acoustics woofer in the approximate cabinet volume.
Selah Audio
post #9298 of 9341 Old 10-23-2019, 08:37 AM
Rick Craig's Avatar
Quoted: 177 Post(s)
Liked: 299
Funny you should ask. I may be able to borrow a pair for my edification. I won't be tearing into the crossover, however. I'll be treating them with kid gloves. I'll also be hearing lots and lots of speakers at the Capital Audio Fest next week. Will you be attending?
Sorry, I won't be there this year. Hope you and Jim have a good show.
If you get a chance take some measurements of the S-400 and share your thoughts on the sound.
Lp85253 likes this.
Selah Audio
post #9299 of 9341 Old 10-23-2019, 12:48 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 1756
Keep in mind those are likely in-room specs.
post #9300 of 9341 Old 10-24-2019, 07:45 AM
Rick Craig's Avatar
Quoted: 177 Post(s)
Liked: 299
Yes, I know they quote in-room for the bass extension and that makes it more difficult for buyers to make a comparison. The BMR has quite a bit more cabinet volume than the S-400 and that plays a factor here.
For the sensitivity Dennis could easily shoot a response curve of each speaker from the same distance / position. That would show the accuracy of the S-400's spec.
Selah Audio
Reply Speakers
bmr philharmonitors , slim towers
