JBL Studio Series 5 - The Magic Guaranteed - Page 103 - AVS Forum | Home Theater Discussions And Reviews
 849Likes
post #3061 of 3086 Old 09-07-2019, 10:18 AM
LNEWoLF's Avatar
Quoted: 476 Post(s)
Liked: 291
Anyone still [email protected]@king for a deal on a pair of JBL 590’s
https://www.avsforum.com/forum/209-a...ladelphia.html
Twin Pioneer AVR Locomotives-Elite SC 97, SC 1222 7.2.4, DOLBY Atmos and DTS X, (Front Pre Out,) JBL Pro Synthesis LS Series Speakers, F L R-LS80, Cen-LS, S L R-LS60, SB L R-LS60, 4 Dolby Atmos Enabled Klipsch R41SA, Twin Klipsch R120SW. Mitz 73740 DLP, Sony UBP-X800, ATV G4, Yamaha ATS 1060 Sound Bar, True Depth Firestorm 2.0 3D Glasses, Harmony Hub with Utlimate 1 Remote, Broadlink RM Pro2, EYE Pad Air, Winegard FL6550A
LNEWoLF is offline
post #3062 of 3086 Old 09-08-2019, 09:08 PM
rochesterboy's Avatar
Quoted: 41 Post(s)
Originally Posted by skypop View Post
That falls into room design and choices for access to the speakers. I have a door that opens into the area behind my Screen,but I can still take the screen off the mounts to swap out speakers if needed. If you have the space for an accessible space with a door on the side that's great,if you don't than plan on taking the screen down to work on the speakers which shouldn't happen much unless you blow one up! 😎
I have attached a plan to install Silver Ticket 125" (diagonally) 2.35:1 AT screen. Gray area is my front wall. For SkyPop and others who have installed 590s behind an AT screen,
1. Can you post a picture of your behind AT setup?
2. I am looking at leaving about 20-24" from the floor to install the screen. In this case, would you install the speaker from the floor or would you raise a platform for 20-24" height and install the speakers and subwoofers on top of that? 590s are as tall as my screen height (i.e. 50") hence the question.
3. Would you finish the wall behind the AT before installing the speakers and screen (or) What kind of insulation would you have for better sound?
I would appreciate your answers.
Name:	Silver Ticket 2.35 Screen Installation Plan.jpg
rochesterboy is online now
post #3063 of 3086 Old 09-09-2019, 06:44 AM
skypop's Avatar
Quoted: 375 Post(s)
Liked: 262
My speakers are on the floor-no platform- I use a 16X9 screen. You can either leave a cutout in your screen wall for each speaker,or just set your speakers up and use speaker grill cloth on the wall behind the screen,in other words just frame out the screen area but don't use any studs and hang the screen on the top part of the frame out. Doing it like this will give you the ability to move your speakers laft or right or toe them in if you want. Also it's easier to try different speakers since there won't be a specific cutout for one speaker. I haven't done any insulation around my speakers,maybe a winter project for me. They sound great to me as they are.
rochesterboy likes this.
2 Channel: Fi 2A3 mono's,Hovland HP100,Technics SP10MK2/SME/Benz....HT:126" Seymour AT Screen,JBL Studio 590's for LCR, Side and Rear Surrounds. Jbl SCS8'S for Fr Heights, and Rear Heights,2 Epik Empire Subs,2 Behringer B1200D Midbass Subs,Marantz 7702MK2,Proceed Amp-5,Outlaw 7125,Panasonic UB820 ,Toshiba HD35,JVC RS600. Black Velvet.
skypop is offline
post #3064 of 3086 Old 09-09-2019, 10:47 AM
Quoted: 41 Post(s)
Thank you SkyPop. Do you have a picture of your setup?
post #3065 of 3086 Old 09-09-2019, 11:58 AM
skypop's Avatar
Quoted: 375 Post(s)
Liked: 262
Nope,I'm out of town for another week,on vacation with the wife!
skypop is offline
post #3066 of 3086 Old 09-09-2019, 12:04 PM
DekPM19's Avatar
Quoted: 209 Post(s)
Liked: 67
My front wall is not flat here are pictures. I am putting up rock wool and I put up some foam diffusion panels.
Allen
ID:	2612950   Click image for larger version
ID:	2612952   Click image for larger version
ID:	2612954   Click image for larger version
ID:	2612956   Click image for larger version
ID:	2612960   Click image for larger version
ID:	2612962   Click image for larger version
rochesterboy and skypop like this.
DekPM19 is offline
post #3067 of 3086 Old 09-09-2019, 12:57 PM
Quoted: 41 Post(s)
Allen
Awesome. Thank you Allen.
post #3068 of 3086 Old 09-14-2019, 11:36 PM
Quoted: 53 Post(s)
I decided to buy a pair of these off ebay.. i gotta tell ya... i really do not hear anything outstanding..
The speakers have a very wide soundstage thanks to the horn. They have clear sound and deep bass but the vocals are too shallow. the highs are too high. teh bass is too thick... So, I took out the inner stuffing. That white clothe stuff. Yea I know all about what that stuff does.. I been doing audio for 35 years.. anyway.. it cleaned up the bass. It sounds a bit better however the speaker overal geberally is just not all that outstanding.
What it does do very good is through the sound out side of the enclosure. its almost liek surround sound.. however the tonal sound is not outstanding..
The bass is the deepest ive heard from any bookshelf of its size but the problem is its a bit augmented by the port and so i find it has too much bass even when someone is talking and has a low pitch boice the voice sometimes have too much bass... where as often the voices are too laid bad or shallow or .. i dont know.. they are just somewhat missing..
There are 2 electrolytic caps that can be replaced with something better... They are easily assesable and probabbly easy to swao put for teflon or poly caps.. electro caps just suck so bad.. This may help the mids..
The highs go wayyy up there. I can hear super high frequencies clear ... in some songs like old Madonna music the instruments will be well outside of the speakers and you can actually look at and point at them.. however like i say, the tonal value is not so accurate...
also i am getting ear fatigue... not sure why.. its rather aggrivating.. its not bad.. its more like fatugue from all the different things i can now hear in the music.. its not really from all the highs... If I can increase the vocals they would be much better... I might work on than in the next week or so.. I have several different audio caps i can try..
Anybody have a schematic for the crossover? that would be very useful. Allot fo times there are things you can do to it to make the sound way better.. Either this crossover has a very high crossover rate or there is some sort of equalization and zobel networking goin on .. it has more parts in the crossover than i ever seen in a bookshelf... Them cement resistors can be upfraded to metal oxide as well....
UPDATE: I got the schematics and bad news for your JBL 5 series fanboys..
The mids on the 530 and 520c use **** crap electrolytic caps.
I do not know about the other models..
The 2 large black caps need to be replaced with better poly caps.
The rating for the 530 midrange is 24uf 100v and on the tweeter it is 12uf 100v.
The rating for the 520c midrange is 27uf 100v and on the tweeter is 15uf 100v
CHANGE THESE! Repalce them with Poly caps or whatever favorite caps you like. Just change them cause they are sucking the life out of these speakers. Have no idea why JBL would make such a great crossover with all those poly caps and skimp out on just these 2 caps. Dam shame.
ALSO on the 530 and 520c there are cheap ceramic cement resistors which need to be changed. These are not such a big deal but I am changing them to non incuctive higher quality parts.
The 520C has 3 resistors values at 12ohm and 5.1ohm both at 10watts and a 2ohm 5watt
The 530 uses 3 resistors values at 16ohm and 2.7ohm both at 10watts and a 1.5ohm 5watt
Changing these all on a 5.1 surround sound setup will cost around 100$. This upgrade should be significant because we all know electrolytic caps just plain suck.
Also it seems the crossver has MANY circuits on the tweeter which look like eqalization and impedance compensation. The mid has one small cap on it which seems to be just some sort of safety cap for dc voltage across the + and - of the mid. This cap is valued at just .01uf 100v on both the 530 and 520c. You could actually remove this cap and often see another upgrade in sound because its sapping off some of the potential in exchange for safety..
I do not want to remove the tweeter circuits, just change out the parts that can be upgraded becuase the circuits on the tweeter are complicated and could be detrimenatl to the overall tweeter performance.
jbl_lvr likes this.
SeventhHeaven is offline
post #3069 of 3086 Old 09-16-2019, 04:36 PM
Quoted: 50 Post(s)
Liked: 4
I'm right on top of that, Rose!
Lp85253 likes this.
papatoony2 is offline
post #3070 of 3086 Old 09-17-2019, 03:46 PM
genaccmiller's Avatar
Quoted: 492 Post(s)
Liked: 56
Hello - I am finishing my basement and will be buying the silver ticket frame 16:9. I am still deciding size of screen. Mine is a fairly small room. As you see in the picture I am building out a door behind the screen which can be entered from under the stairs. This area will also have a door on the opposite side so that I can enter through it, open the door shown below and access the back of the speakers. On the right side I will have a similar but small opening. I am also still deciding if I keep speakers in floor or mount them on a stand.
Sent from my Moto G (5) Plus using Tapatalk
genaccmiller is offline
post #3071 of 3086 Old 09-17-2019, 06:58 PM
Quoted: 2102 Post(s)
Liked: 1758
don't tell mom..
YAMAHA TSR 5790.. front l/r emotiva b1's and /or kef q100's ..BIC v1220.....Emotiva basx10.... ascend cbm 170 center.. polk t15 rears..samsung 55" j620d
bedroom .. YAMAHA r-xv 383... front l/r.. wharfedale 10.1s... ascend cbm 170 center ... Emotiva basx8... samsung ku6300 50 in
Lp85253 is online now
post #3072 of 3086 Old 09-18-2019, 05:54 AM
Quoted: 492 Post(s)
Liked: 56
I have three studio 590 and two studio 580 boxes. Since I have not yet installed the speakers in my theater I have kept the boxes in case I need to return as part of warranty if something doesn't work. It's been about 3 months since I have purchased them and I have test run them and they work good. However the boxes consume a lot of place. Are you folks keeping the boxes or just throwing them away?
post #3073 of 3086 Old 09-18-2019, 11:41 AM
Quoted: 41 Post(s)
Originally Posted by genaccmiller View Post
I have five studio 590 and two studio 580 boxes. Since I have not yet installed the speakers in my theater I have kept the boxes in case I need to return as part of warranty if something doesn't work. It's been about 3 months since I have purchased them and I have test run them and they work good. However the boxes consume a lot of place. Are you folks keeping the boxes or just throwing them away?
I was also thinking about the same thing. Should we collect all the foams in one 590 box and flatten the remaining boxes to store? Though I bought 5 590s, I can only use 3 for LCRs due to space issue. I was not thinking straight I have to sell the remaining two as 30 days return window has passed
post #3074 of 3086 Old 09-18-2019, 12:25 PM
Quoted: 492 Post(s)
Liked: 56
I had the same space issue. So purchase three 590s and two 580s.
post #3075 of 3086 Old 09-18-2019, 08:31 PM
srw1000's Avatar
Quoted: 299 Post(s)
Liked: 65
I'd keep at least one box of each, for possible warranty return. These things would be tough to ship safely without the original packaging.
srw1000 is offline
post #3076 of 3086 Old 09-18-2019, 08:32 PM
Quoted: 492 Post(s)
Liked: 56
Corrected my count above.
post #3077 of 3086 Old 09-18-2019, 08:32 PM
Quoted: 492 Post(s)
Liked: 56
I have corrected my count above.
post #3078 of 3086 Old 09-28-2019, 02:13 AM
Eggtuary's Avatar
Quoted: 135 Post(s)
Liked: 53
Anyone use SVS Prime Elevation speakers with a Studio 590 setup? I've got 5 of the 590 towers in a 5.2 setup, and love them. I bought two Studio 530 bookshelf speakers, and sometimes enjoy adding them for 7.2, or even replacing my surround 590s, especially if I want to tinker with placement of the surrounds.
But I'm finding the 530s are not ideal for Atmos placement. My main listening area is our family room, so my wife is already being quite tolerant to put up with 5 Studio 590 towers. So I don't want to junk it up worse by coming up with some odd way of mounting the 530 speakers to my ceiling. For the moment, I've got one 530 up on a tall bookshelf, and another on a speaker stand on top of a low shelf. It's not ideal, but it's showing me that I definitely want Atmos.
I worry the SVS Elevations will be too different in sound quality than the JBLs. But does that matter as much for overhead speakers? I noticed a big difference when I went from Studio 230 bookshelf speakers as my surrounds to the Studio 590. Less difference when subbing in the 530 bookshelf speakers. But is matching more critical among speakers at the base level?
Eggtuary is offline
post #3079 of 3086 Old 09-28-2019, 06:35 AM
skypop's Avatar
Quoted: 375 Post(s)
Liked: 262
I've never used any SVS speakers so I can't be totally honest here,But the other day I was watching Hellboy2-not that remake crap-and early in the movie when the prince is underground practicing with his sword, the way the sound moved from left to right to up and down and with the added water sounds it was great, no change in tonality at all! So basically if you have a movie that has a scene like that than you can hear the difference or not.
Eggtuary likes this.
skypop is offline
post #3080 of 3086 Old 09-28-2019, 08:51 AM
Quoted: 492 Post(s)
Liked: 56
Do you use an external amp or is your receiver able to take the load of the five 590s?
post #3081 of 3086 Old 09-28-2019, 09:10 AM
Eggtuary's Avatar
Quoted: 135 Post(s)
Liked: 53
My current Denon X3400H can handle the load just fine, but I do use a couple of Outlaw mono block amplifiers for the front mains. Seems to give them just a bit more oomph and clarity, though I wonder if that's placebo effect. :-)
I'm playing with the idea of upgrading to X4500H or the new X3600H. Both receivers have 9 internal amps, but can process 11.2. So, combined with my mono block amps, I could do 7.2.4, which would be a nice upgrade. I don't have the ideal layout for a good 5.2.2, since I can't put speakers in the ceiling, so I think I need at least 5.2.4 to get a strong overhead sound. 7.2.4 may or may not be worth it to me over 5.2.4. But I need a new receiver to do anything more than 5.2.2.
Eggtuary is offline
post #3082 of 3086 Old 09-28-2019, 12:49 PM
JosephTonyStark's Avatar
Quoted: 250 Post(s)
Liked: 160
I don't think you'll have much issue with that combo. I used to have a pair of Prime Elevations pulling Top Middle duty in my setup. Ran that way for 1.5 years, I think.
I don't claim ultimate awareness of timbre changes as sounds go from speaker to speaker, but having experienced both different and exactly matched surrounds, I can certainly vouch for the improved panning and seamless sound field that comes from identical/same model line speaker matching.
I say all that to say, the Primes in height duty never stood apart from the Studios and blended well, even at my moderately high watch volumes. Maybe room EQ helped, but either way, I certainly missed them in those moments I would switch them off to remember what only the bed layer sounded like.
Sent from my GT-N5110 using Tapatalk
Eggtuary and skypop like this.
TV: Samsung 65" UHD LED | Sources: PS4; Panasonic DMP-BT460; LG UB870; Dell 7010 SFF; Roku Ultra | AVP: Marantz AV8802A | Amps: Emotiva XPA-1L\100 (LR\C); Outlaw Audio 7125 | Front LR\C: JBL Studio 590\Studio 520C | Surrounds: JBL P520WS | Subs: PSA S1801 | Heights: JBL Pro Control CRV (2)
JosephTonyStark is offline
post #3083 of 3086 Old 10-09-2019, 02:08 PM
Eggtuary's Avatar
Quoted: 135 Post(s)
Liked: 53
I read great stuff about those SCS8 height speakers you have, and how well they blend with the 590s. But aren't those over $400 each?
Has anyone tried the Studio 530 for heights? I have a pair that I really like when in surround rear duty, and they match very nicely with the 590 towers. But I'd think they would be a huge pain to mount as heights?
I've seen where someone bought a bunch of 520C center channels and used those for heights. But I am not a big fan of that speaker. I've tried it twice, and didn't think it blended well when cranked to high volumes.
Eggtuary is offline
post #3084 of 3086 Old 10-09-2019, 04:02 PM
skypop's Avatar
Quoted: 375 Post(s)
Liked: 262
Yes they are pricey when you need 4 of them! But I bought 2 at first to make sure that I liked them, and after just 1 movie I was online buying 2 more! They're kinda big but when used in A dedicated theater room with A Black Velvet ceiling you don't see them at all during A movie. At one time JBL made A SCS6 which was A little smaller and for A little less money. I couldn't find any of the 6" version anywhere,BUT the JBL Control5 speaker might work out for you, you ceiling or wall mount them,good price for the pr. also.
skypop is offline
post #3085 of 3086 Old 10-09-2019, 07:27 PM
srw1000's Avatar
Quoted: 299 Post(s)
Liked: 65
You can find the SCS-8 for less than that. Keep in mind that they also come with their own mounting brackets. That's kind of a nice feature, since you don't have to worry about jury-rigging something to hold them up.
Scott
srw1000 is offline
post #3086 of 3086 Old 10-15-2019, 03:03 PM
reikoshea's Avatar
Quoted: 14 Post(s)
I've had my 590s for a few years, and a friend wanted me to do an inroom measurement of mine before he went out and bought a pair. Figured I'd share the results.
Studio 590s + Yamaha RX-A840 (No DSP) + REW + UMIK-1.
I had to double check and make sure I had bass boost turned off after seeing this. I guess the boxes piled up relatively close to the side of the left channel are reinforcing most of the low frequencies .
tinman143 likes this.
reikoshea is offline
Reply Speakers
