JBL Studio Series 5 - The Magic Guaranteed - Page 117 - AVS Forum | Home Theater Discussions And Reviews
 1048Likes
post #3481 of 3576 Old 06-19-2020, 07:00 PM
Jaurhead's Avatar
Quoted: 320 Post(s)
Liked: 350
Originally Posted by genaccmiller View Post
Yes Dan. That's what I am finding as well. Movies do not make a lot of difference it looks like.
Sent from my GM1917 using Tapatalk
I bought four 580's with the intention of using them for my surrounds. I really wanted to be surround by towers on all sides with 590's up front. Presently there is no space for the 580's, so I've been using 530's instead, and they are PLENTY sufficient as surrounds. I've pushed reference and they barely show any signs of giving up. IMO they blend nicely with the 590's. I will be continuing to use the 530s in the new theater as well.
diablo900t likes this.
The Studio | Planning Stages - https://www.avsforum.com/forum/19-dedicated-theater-design-construction/3155530-studio-semi-dedicated-theater.html
9.4.4 - JVC X790R - JBL 590/530/227C - PSA S3000i + S3600i + T18HT^2
Oppo 203 - PS4 - Xbox One S - Apple TV 4K
400+ UHD and counting...
Jaurhead is online now
post #3482 of 3576 Old 06-19-2020, 07:37 PM
genaccmiller's Avatar
Quoted: 1055 Post(s)
Liked: 293
Good for you. I love my 580s as surrounds.
Step by Step Theater Build - http://imgur.com/gallery/2tpaSru
My Theater Build Youtube Channel - https://www.youtube.com/channel/UCs_..._as=subscriber
My Theater Build Thread - https://www.avsforum.com/forum/19-de...ld-thread.html
genaccmiller is offline
post #3483 of 3576 Old 06-19-2020, 11:11 PM
Jaurhead's Avatar
Quoted: 320 Post(s)
Liked: 350
Apologies, I honestly thought I was quoting @diablo900t asking about 530's vs 580's. You and I have discussed the topic at length already.
post #3484 of 3576 Old 06-20-2020, 07:27 PM
DekPM19's Avatar
Quoted: 242 Post(s)
Liked: 79
I listen to my 530s next to my 590s and the 590s are diffidently fuller sounding. If I didn’t have 530 I would order the 580 because at the sale price the 580;are only about a$150 more by the time you add stands to the 530s. Plus the stability is better with the towers.
Just my two cents.
Allen
diablo900t and Lp85253 like this.
DekPM19 is online now
post #3485 of 3576 Old 06-22-2020, 09:07 PM
rrj
rrj's Avatar
Quoted: 16 Post(s)
Ladies & Gentlemen,
I was so excited to get my 3 new 580s today for my front LCR that I purchased during the Fathers Day sale. I arrived home and lo and behold the boxes were pretty beat up. One was obviously damaged (both speaker and exterior box). The other two did not look bad but on further inspection one has a small dent in the front right edge. The other has some discoloration on the front panel on the right which is weird.
I chatted on-line with JBL and now I have to wait about two weeks or more according to them while they sort things out with UPS. Then AFTER that they will ship a replacement. I am definitely frustrated!
As far as the other two, listening to them right now and they sound OK. With the big delay, not sure what folks have done here in the past with this type of situation. Should I keep the other two? Send back? All advice and opinions welcome. Thanks!
Pictures attached...
ID:	2747328   Click image for larger version
ID:	2747332   Click image for larger version
ID:	2747334   Click image for larger version
rrj is online now
post #3486 of 3576 Old 06-23-2020, 01:41 PM
DekPM19's Avatar
Quoted: 242 Post(s)
Liked: 79
Originally Posted by rrj View Post
Ladies & Gentlemen,
If they are damage and you can see it or it bothers you send them back. If you can’t see the damage and it not going to bother you keep them, but resell would loose out if damage, so in reality you bought new they should look new. Send them back. My 590 came wrapped on a pallet by a trucking company and I went to there lot to pick them up.
Allen
post #3487 of 3576 Old 06-24-2020, 12:27 PM
rrj
rrj's Avatar
Quoted: 16 Post(s)
Allen
Allen,
You are right. Going to send them back. Thanks for your feedback!
rrj is online now
post #3488 of 3576 Old 06-29-2020, 04:08 AM
diablo900t's Avatar
Quoted: 152 Post(s)
Liked: 84
JBL is running another sale again, looks like the entire 5 series is on sale.
Ended up splurging to get 580s for side surrounds and moving my 530s to back rear.
Sent from my SM-N975U using Tapatalk
diablo900t is online now
post #3489 of 3576 Old 06-30-2020, 11:16 AM
Quoted: 14 Post(s)
Liked: 5
Ladies & Gentlemen,
If they are damage and you can see it or it bothers you send them back. If you can’️t see the damage and it not going to bother you keep them, but resell would loose out if damage, so in reality you bought new they should look new. Send them back. My 590 came wrapped on a pallet by a trucking company and I went to there lot to pick them up.
Allen
Did your order your 590’s straight from JBL’s website? If so, I assume they strap them to a pallet and deliver these by freight? I plan on ordering the 590’s and fingers crossed that they don’t show up beat to hell. All floor standing speakers should be strapped to a pallet to minimize damage.
BucFan00 is offline
post #3490 of 3576 Old 06-30-2020, 11:27 AM
rrj
rrj's Avatar
Quoted: 16 Post(s)
@BucFan00
I ordered the Studio 580's, which are a "bit" smaller and lighter than the 590's. IMHO I think if they just double boxed the 580's they probably would have arrived without damage. Its my understanding that the 590's on the other hand do indeed arrive on a pallet.
rrj is online now
post #3491 of 3576 Old 06-30-2020, 12:52 PM
Quoted: 492 Post(s)
Liked: 396
@BucFan00
Yup, it's the lack of double-boxing that is the bigger culprit. Would love to see the corporate numbers on damage costs vs costs to double-box.
For comparison my Revels were double-boxed.
KSpan is online now
post #3492 of 3576 Old 06-30-2020, 01:26 PM
Quoted: 14 Post(s)
Liked: 5
That’s good to hear that the 590’s are shipped on a pallet. I plan on ordering them tonight when I get home from work.
BucFan00 is offline
post #3493 of 3576 Old 06-30-2020, 03:58 PM
Quoted: 129 Post(s)
Liked: 161
I see a lot of people using the 580's for surround duty. Are they that much less then the 590 for up front? IE how would the 580's work for the front L/R with say 530s for surround??
AVR: Yamaha TSR-7850, Fronts: DCM TP260, Center: DCM TP160C, Sub: Premier Acoustic PA-150 (2-FV18/PC on the way!!)
Deaf-Forever is offline
post #3494 of 3576 Old 06-30-2020, 04:25 PM
nbk13nw's Avatar
Quoted: 95 Post(s)
Liked: 60
@BucFan00
My 590's and 580's both came on a pallet
Sent from my SM-G988U using Tapatalk
Yamaha CX-A5200, Yamaha MX-A5000, Sanway DSP-6KQ, XBox One X, Panasonic DMP-UB900, NVIDIA Shield, D-Link 16-Port Gigabit Switch, Caavo, Control Center, 2 x JBL Studio 590 Mains, 1 x JBL Studio 520C Center, 2 x JBL 580's side surrounds, 2 x JBL 530's rear surrounds, 4 x RSL C34E's ATMOS, 4 x Chane SBE-118's
nbk13nw is online now
post #3495 of 3576 Old 06-30-2020, 05:28 PM
Quoted: 492 Post(s)
Liked: 396
Depends on your volume needs and room size/listening distance but in most cases they are plenty.
KSpan is online now
post #3496 of 3576 Old 06-30-2020, 06:16 PM
DekPM19's Avatar
Quoted: 242 Post(s)
Liked: 79
Yes I ordered straight from Jbl and they came on a pallet. I picked them up at the depot for my convenience .
Allen
post #3497 of 3576 Old 06-30-2020, 06:25 PM
DekPM19's Avatar
Quoted: 242 Post(s)
Liked: 79
I did a straight down and dirty compression of my 590s to my 530s meaning I unplugged the 590 and plugged in the 530 in the top end very similar. The mids and lower is where they start sounding different both crossed at 50 hz. Which is no surprise since The 590s has a lot more bigger drivers in it.. know what I know now I would have gotten the 580 over the 530 because after you add speaker stands to the 530 there is only $150 difference or in my case it was. Plus the 580s would be harder to knock over Than the 530s on speaker stands.
Allen
diablo900t and Deaf-Forever like this.
post #3498 of 3576 Old 06-30-2020, 06:35 PM
Quoted: 129 Post(s)
Liked: 161
21' x23' x 10' (4830 cubes) Im guessing I run 85-88 Db. Music might be a hair louder when the mood strikes.
post #3499 of 3576 Old 07-01-2020, 05:48 AM
diablo900t's Avatar
Quoted: 152 Post(s)
Liked: 84
Allen
Your suggestion is what prompted me to get 580s for side surrounds. The 530s on stands are just too easy to knock over, and are better suited in the rear on stands behind my 2nd row. I also tested our my 530s in the front of the room instead of my 590s as well, they sounded good, but nowhere near as "big" sounding as the 590s. Even tried a 530 at center, but having a 580 on its side there a marked improvement. For rear surround work, I'm fine with 530s, and they are easier to get above ear height in the back row.
post #3500 of 3576 Old 07-01-2020, 04:31 PM
C S
Quoted: 18 Post(s)
Liked: 4
Does anyone have a link to a decent price for some JBL control 328c to use as satellites?
C S is online now
post #3501 of 3576 Old 07-01-2020, 04:49 PM
Jaurhead's Avatar
Quoted: 320 Post(s)
Liked: 350
By "satellites" do you mean Atmos? Because those are distinctly in-ceiling speakers. FWIW, I went with Control 227C's for what ended up being almost half of the 328's cost.
post #3502 of 3576 Old 07-01-2020, 04:51 PM
C S
Quoted: 18 Post(s)
Liked: 4
Yes atmos I’m sorry. I’m looking to get something that should pair up nicely with the studio 5s.
C S is online now
post #3503 of 3576 Old 07-01-2020, 05:16 PM
Jaurhead's Avatar
Quoted: 320 Post(s)
Liked: 350
Awesome. From what I was told in this post, the 328C's are an ideal match as they are almost identical to the SCS-8's, minus the mount-on-ceiling enclosure. However, the space needed above the ceiling for the crossover and backcan is something in the neighborhood of 12"+! So if mounting into an attic, no problem. If there's a room above your theater, that may post a challenge.
I was concerned about 2 things: cost foremost, and then above-ceiling space second. I eventually went with the 227C as it was less expensive and required less depth above the ceiling. Both models have the same baffle diameter (12") and use the same speaker grilles. Here's a pic of the 227C followed by its backcan - they're not small. I can only imagine how deep the 328 would have been!
I'm a little confused as to how to install these into my own ceiling - I think you have to drop the backcan in from the attic by cutting a 12" hole in the ceiling, which the flange rests behind. Then you screw the speaker into the backcan from the front. The rise from the flange is maybe 3/4" I believe, so if you have thick or multi-layer sheetrock, the baffle of the speaker will not be flush with the face of the ceiling, and then the grille - if used - won't be compatible.
This is all just cursory observation as JBL has not published any documentation on in-ceiling installation with the backcan. I asked about this in my own theater build thread and didn't get a response, but I'm still months away from any actual construction anyway.
post #3504 of 3576 Old 07-01-2020, 05:21 PM
C S
Quoted: 18 Post(s)
Liked: 4
Thanks man. All good info. I found a little info on them. Looks like you need the speaker, back can, flange mount, and grill for full assembly. Do you have links where you got them? Pics below of the parts you need for install.
C S is online now
post #3505 of 3576 Old 07-01-2020, 05:33 PM
Jaurhead's Avatar
Quoted: 320 Post(s)
Liked: 350
I am such a dunce. I only read that they were for the in-ceiling subs. Didn't realize they were compatible with the speakers. Thank you. I'll PM with some other deets.
C S likes this.
post #3506 of 3576 Old 07-01-2020, 06:07 PM
diablo900t's Avatar
Quoted: 152 Post(s)
Liked: 84
This is the first time I'm hearing about a back box / can for ceiling speakers. I'm kind of kicking myself for not knowing that ahead of installation.
I have 4 JBL SP8II ceiling speakers for Atmos. Is there a universal back box / can that I can buy that would work for these?
They're installed on the 2nd floor where my theater is and the attic area is easily accessible so I can get above them if needed.
post #3507 of 3576 Old 07-01-2020, 06:32 PM
Quoted: 14 Post(s)
Liked: 5
Thanks guys. I ordered the 590’s late last night. They already shipped today by UPS ground?? I’m going to be pissed if these are not on a pallet as heavy as these things are. They will surely get beat up by being thrown around. Can’t wait to get these. Just gotta hope for the best.
BucFan00 is offline
post #3508 of 3576 Old 07-01-2020, 06:35 PM
diablo900t's Avatar
Quoted: 152 Post(s)
Liked: 84
It might be Estes Express. Check the tracking number, if it's just numbers it's Estes. My 580s are coming Estes, but I ordered a single 580 a couple weeks ago and some of the infinity reference and all of those came UPS.
post #3509 of 3576 Old 07-01-2020, 06:45 PM
Quoted: 129 Post(s)
Liked: 161
If you look at that flange, they look like they need to be installed before the sheetrock. Similar to a can light. That flange is the "mud ring" so to speak.
C S likes this.
post #3510 of 3576 Old 07-01-2020, 06:49 PM
Jaurhead's Avatar
Quoted: 320 Post(s)
Liked: 350
You could consider building your own out of MDF/drywall. I went through the manual for the SP8II and it does not mention any other compatible accessories except for the rough-in kit. They don't look like they were meant to be used with a backbox - I don't see any potential mounting options for it so you'd likely be engineering your own fasteners.
The Control speakers discussed above are designed to be installed with backcans - they don't have the traditional dog ears for securing to the drywall. So I don't think you need to feel bad for not knowing about them earlier on for your particular situation.
Reply Speakers
