**The Official Chane Music and Cinema owner's thread** - Page 155 - AVS Forum | Home Theater Discussions And Reviews
 7161Likes
post #4621 of 4641 Old 08-13-2019, 04:35 PM
Bigbirney's Avatar
Quoted: 95 Post(s)
Liked: 76
Well, I decided to work from home today because these were being delivered. I hooked them up and let them play for a few hours in the background while I worked. I did not run YPAO, I just used the settings from the KEF's. Set to small, crossed over at 80hz, Tonight I put them through some paces. Dire Straits Sultans of Swing, Some Bob Marley, Vivaldi and some Tool. These speakers are amazing, my wife was grinning ear to ear. I have owned many speakers in the last 20 years. most recently:
KEF Q 300
KEF Q100
ELAC B6
ELAC B5
Pioneer 22
Paradigm Atom
Monitor Bronze 5
Paradigm mini monitor
Various Klipsch
The Chanes are amazing. Wide soundstage and crystal clear highs without any fatigue. The low end is like nothing I have heard from a small bookshelf. Mine are paired with SVS PB 1000. I can't wait until they break in and I get to spend more time with these bad boys. I appreciate the help on here,
Basement HT 5.1.2 - Marantz 6012, Outlaw 5000 - ELAC Debut F5 Towers, C5 Center, B5 Bookshelves as surrounds - Monolith 15(RETURNED) - BenQ2050a 92" Silver Ticket
Upstairs Living Room, Music 3.1 - Anthem MRX520 - Pair of KEF Q300's, Single Q100 - SVS PB 1000 - Projekt Debut turntable - LG 55" B8 OLED
Bedroom 2.1 - Denon AVR740h - ELAC B4 Bookshelves - Klipsch R-10SW - TCL 49"
Bigbirney is offline
post #4622 of 4641 Old 08-13-2019, 06:30 PM
Quoted: 83 Post(s)
Anyone have any thoughts on pros and cons of the Chane A2.4 vs Ascend Acoustic Sierra
mong00se is online now
post #4623 of 4641 Old 08-13-2019, 07:16 PM - Thread Starter
Audio Engineer
BufordTJustice's Avatar
Quoted: 608 Post(s)
Liked: 1019
KEF Q 300
KEF Q100
ELAC B6
ELAC B5
Pioneer 22
Paradigm Atom
Monitor Bronze 5
Various Klipsch
Between us girls, they'll run with the LS 50 in a general sense. They put a good amount less treble energy into the room than the KEFs, which can be slightly aggressive in this regard, but the imaging is really superb on the A1.5.
Bigbirney likes this.
"If I had asked people what they wanted, they would have said 'faster horses'." -H. Ford | Parasound HALO C2 pre/pro | modded Adcom MOSFET GFA-5500 | Acurus/Mondial A200x3 | Panny BDT-500 | Google Chromecast Audio/Apple TV 4K | Toshiba SD-9200 CD Transport | Vizio 55" LED/LCD | Darbee DVP-5000S | L+R: Chane MTM Prototype | Chane A2.4 center | surround: custom finished Chane A5rx-c | Member: NATIA, LEVA, & AES (full member).
BufordTJustice is offline
post #4624 of 4641 Old 08-14-2019, 04:55 AM
jwskud's Avatar
Quoted: 76 Post(s)
Liked: 213
Check this thread - a head-to-head comparison. The considerably more affordable Chane A2.4s fared quite well.
BufordTJustice and mpk1970 like this.
7.2 system: Chane A2.4 center, Chane A5.4s L/R, Chane A1.5s surround, Kenwood KS-505HTs rear
Subs: Klipsch R-120SW and Kenwood SW-35HT (8"); HiVi Swan X3 monitors (laptop)
Onkyo TX-RZ620, Samsung 4k 43NU7100, PS3, Nintendo Switch, Sennheiser HDR130 headphones
Protection: Tripp Lite Isobar 8 Ultra; VCE SP250-2P
And don't forget - JVC HR-S3900U Super VHS - the last working VCR in America??
jwskud is offline
post #4625 of 4641 Old 08-15-2019, 10:43 AM
rossandwendy's Avatar
Quoted: 153 Post(s)
Liked: 169
Question for @Jon Lane
I may be getting larger subwoofers and might need to use them as speaker stands. Can I place my A5.4 left/right mains upside down? This would put the tweeters at seated listener height on the subs. If this is a bad idea sonically then I may need to downsize the mains to a bookshelf model.
Ross
BufordTJustice likes this.
_______________________________________________
POWER: Emotiva A-300, Denon AVR-X3300W
SOURCE: Oppo BDP-103D multi-region
SPEAKERS: Chane A5.4, A1.4, Rythmik L22 x 4
DISPLAY: Sony 45ES, 175" Silver Ticket screen
rossandwendy is online now
post #4626 of 4641 Old 08-15-2019, 11:07 AM
RayGuy's Avatar
Quoted: 2712 Post(s)
Liked: 2475
Ross
Predefining where your subs are going to go in the room is almost always a mistake. You need to have some flexibility in placement to get the best from them. There is no reason that the mains need to be compromised in order to include subs. See this for lots of good sub placement options:
https://www.aperionaudio.com/blogs/a...-for-your-home
Why compromise both your subs and your mains with this scheme?
It's a VIRTUAL channel unless stated otherwise.
RayGuy is online now
post #4627 of 4641 Old 08-15-2019, 11:09 AM
Quoted: 1350 Post(s)
Liked: 1537
Ross
Absolutely do not try this. Good luck on sub placement hunting
Set up #1 Speakers LR: Tekton Enzo XL ; Center: Tekton Pendragon Subs (2) 2019 JTR 118HTs
Set up #2 : QA3020i LR, Center: Emotiva C1 Subs (2) HSU VTF2 MK5,
mpk1970 is offline
post #4628 of 4641 Old 08-15-2019, 11:16 AM
Jon Lane's Avatar
Quoted: 316 Post(s)
Liked: 1052
It's been done before and it's said to be an acceptable option. Conventional wisdom says that since a vertical driver stack has good horizontal uniformity, it will have little relevance vertically, which means that flipping it end for end won't have much downside.
I'd add that an inverted, multiple-woofer tower like an A5 will no longer mirror midbass energy against the floor to smooth its response - woofers up in the center of the room come closer to being equi-distant from floor and ceiling so response suffers somewhat. Some may find that problematic.
Putting the tweeter end of the speaker directly against another piece of furniture also creates new and unwanted reflections on the treble end of the scale, so the overall effect isn't ideal there either. Crossover and geometry-induced vertical directivity also change somewhat but won't be considered as important.
It's been done but aside from the cost of having to replace the speaker, ideally it's probably something to avoid.
Jon Lane is offline
post #4629 of 4641 Old 08-15-2019, 11:23 AM
Quoted: 153 Post(s)
Liked: 169
Putting the tweeter end of the speaker directly against another piece of furniture also creates new and unwanted reflections on the treble end of the scale, so the overall effect isn't ideal there either. Changes due to crossover and geometry-induced vertical directivity also change somewhat but won't be considered as important.
Thank you very much Jon for your helpful and detailed response, I expected no less from you! I'll rearrange the theater room as needed to keep my A5.4's positioned as is where they sound phenomenal.
Best regards,
Ross
post #4630 of 4641 Old 08-15-2019, 01:46 PM
Quoted: 22 Post(s)
Liked: 2
Question about A1.5
Hello everyone!
I'm looking to upgrade my HT in my large living room (open floor plan with kitchen, living, dining and entry, all in about 40x40, main living area about 19x19, 8 foot ceilings all around). I've researched and discussed extensively, and this is not a question about what speakers I need to actually fill my area with sound (need bigger towers, very large speakers, more power, etc; none of these are options right now).
However, I have my speaker choice narrowed down to a few, the A1.5 being a top contender. What worries me is the sensitivity. My receiver is a Yamaha RX-V683. To be completely honest, I've really struggled understanding power specs. Basically, if my use is 80/20 HT/Music and I'm running a 5.1 system off this receiver (A1.5 as LR), will I have enough power to get the 1.5's loud? I don't have a need for blistering levels, but enough to hear music around the house and to add some excitement to movies.
Really I just want to make sure that if I boost the levels on the A1.5 to where it sounds good that I won't have issues with my receiver. Anyone had issues with the low sensitivity?
Add on question - I've seen so many good reviews about the A1.4, but not a whole lot on the 1.5 since it was just released. Any obvious negatives or massive improvements to note?
Thanks for all of your help in advance!
engineer0928 is offline
post #4631 of 4641 Old 08-15-2019, 02:48 PM
RayGuy's Avatar
Liked: 2475
That receiver is not a powerhouse, but it's not a wimp, either. 90 watts, with 2 channels driven, is probably about the same as most mid-level receivers (who claim 100+ watts, a negligible difference).
Whether it will work for you at 40 feet away is another issue, if you want to listen LOUD at that distance. You would be better off with speakers placed in the other area, so you will not have to drive them so hard to get the volume levels you may want. This is easy with zone 2 capability in the receiver.
There are no guarantees. One man's loud is another man's normal listening level. I would just try it and see. What, maybe $30 to return if dissatisfied? Money well spent, IMO, to be sure you are getting something you can live with for the long term.
1.5 is pretty much the same as 1.4, with minor improvements. This speaker has gotten great reviews during it's many year progression to the 1.5. There is zero reason to assume it has now, all of a sudden, become crap.
I can see your hand wringing from here! Stop overthinking and get on with it.
post #4632 of 4641 Old 08-16-2019, 09:03 AM
jwskud's Avatar
Quoted: 76 Post(s)
Liked: 213
Check my signature for a review of the A1.5s (right at the end of the thread is a stand-alone review), or you can see a smaller portion of it on the Chane website (JS review). Better yet, check out posts No. 4416 by @rhelliott2 and 4621 by @Bigbirney in this thread, who recently upgraded to A1.5s and call them superior to a whole host of other bookshelves they've owned.
I note your space is huge. For comparison purposes, my family room is 15x18x8.5 (2300 cubic feet) but opens to a kitchen area which adds another 2600 cubic feet. As I discuss in my review, I recently tried the A1.5s as L/R in 2.0 and was quite impressed by their ability to fill the space with sound. I'm running off an Onkyo TX-RZ620 (100 wpc, 2 ch driven), so slightly more power than you might have. And I did have to turn the volume know up a bit relative to the A5.4 towers. But not to some ridiculous level. My AVR doesn't do (-dB) measurements from reference, it just runs 0-100. With the A5.4s, in 2.0, I have never pushed volume over 70 (it gets scary loud!). With the A1.5s in 2.0, I pushed volume at 60-70 and it was more than enough to fill the space. I can't imagine what going up to 80 would produce...
jwskud is offline
post #4633 of 4641 Old 08-16-2019, 09:33 AM
indebtbassfreak's Avatar
Quoted: 1379 Post(s)
Liked: 2632
Sorry, don't mean to change the subject,,,, but your Onkyo should have a volume display option in the menu setting,,, just adjust to "relative" if your interested,,,,, "0" will then be reference. Cheers!
-Marantz SR-8012
-Yamaha BD-A1060
-Funk 21.0LX Master/Slave combo 4800 watts RMS/9600watts (peak)-
-Chane A-2.4 L/C/R
-Chane A-1.4 side/rear surrounds.
indebtbassfreak is offline
post #4634 of 4641 Old 08-16-2019, 09:59 AM
jwskud's Avatar
Quoted: 76 Post(s)
Liked: 213
I've looked for this setting on every menu and in the advance manual, and I don't believe it is an option on my AVR. I don't know why - it seems more useful to display relative volume, especially when sharing settings with others, and every other AVR brand operates this way...
If you (or anybody else here) know how to do this on an Onkyo TX-RZ620, please let me know...there's nothing about it in a google search, either...
jwskud is offline
post #4635 of 4641 Old 08-16-2019, 01:01 PM
Liked: 2632
Under "audio" then "volume" then "scale" is that not there anywhere? It's been a while since i had my Integra set up but Onkyo has always had that relative option as far as i know. Found my old Integra instruction manual, hopefully similar to your Onkyo,,,,,,,, in your menu scroll down and select the "miscellaneous" option then "volume set up" should be right there.
-Marantz SR-8012
-Yamaha BD-A1060
-Chane A-2.4 L/C/R
post #4636 of 4641 Old 08-16-2019, 01:16 PM
ellisda1's Avatar
Quoted: 80 Post(s)
Liked: 50
Ross
I have Chane's across the front - A5.4s LR and A2.4 center. I also have (had...) 2 subs placed into the corners (I have only 2 corners available at the front of the room due to great room constraints). A couple of days ago I got my UMIC-1 and started playing with REW. I learned that two subs DON'T always play well together - I had substantial nulls, and peaks, that I could not "position" away. Turns out my room response was much better with only one sub, so now I have an expensive heavy end table...
Chane A5.4 LR, Chane A2.4 center, Polk RC85i in-wall side-surround, NHT Super One rear surround, SVS PB-12 NSD, HSU-VFT-1, LG OLED 55B6A
ellisda1 is offline
post #4637 of 4641 Old 08-16-2019, 02:17 PM
bkeeler10's Avatar
Quoted: 455 Post(s)
Liked: 297
^^ If you want the extra headroom and/or output capability of the two subs, even if you can't position them for a smoother response, just colocate them. You can stack them vertically or move the first one half its width to the left or right and place the new one immediately to the other side. Should result in almost identical response with 3-6 dB more headroom.
It sounds like you may have already divested yourself of the extra sub, but if not it can be more than just an expensive end table.
Edit: With regard to positioning, you need not limit yourself to room corners only - unless WAF or aesthetic issues so dictate.
Sent from my SM-N910V using Tapatalk
Vergiliusm and BufordTJustice like this.
System
Transducers: Revel Concerta2 F36 (3), M16 (4); Tannoy AMS 6DC (4); Rythmik F18 (2)
Front end: NAD T758 v3; Outlaw Model 7125
Sources: Panasonic UB820; Oppo BDP-103; Toshiba HD-A2
Projection: JVC DLA-RS440; Seymour CenterStage UF retractable 110" 2.35:1
bkeeler10 is offline
post #4638 of 4641 Old 08-16-2019, 04:28 PM
ellisda1's Avatar
Quoted: 80 Post(s)
Liked: 50
My room is really, really difficult. Other than the two front corners, no other place is even possible due to furniture and hall ways. I actually did stack the non-identical subs to see what the scans looked like. My "big" sub is the SVS PB12 NSB front firing. Old sub is a down-firing HSU VTF-1. The Hsu has to go on top of the SVS due to footprint and weight (I can't lift the SVS...) That arrangement DID give me essentially duplicate, and acceptable, scans. It also gives me a 4' stack in the corner. I'm not sure I need the extra headroom, but I might see if the wife approves and if I can run another 25' sub cable around the house.
ellisda1 is offline
post #4639 of 4641 Old 08-16-2019, 04:30 PM
jwskud's Avatar
Quoted: 76 Post(s)
Liked: 213
Under Audio Adjust, then under Volume, the only options are
Mute Level
Max Volume (0-100)
Power On Volume
Headphone Level
I spent a long time looking for this option online and in the manual, and some time on the Onkyo RZ owners thread, and it doesn't seem to be an option on these newer AVRs. No matter. I just tell folks I typically max out at 70/100, and that gets the gist across.
jwskud is offline
post #4640 of 4641 Old 08-16-2019, 04:39 PM
Liked: 2632
Mute Level
Max Volume (0-100)
Power On Volume
Headphone Level
Lets not plug up the Chane thread with this,,,,, post this over on the Onkyo thread if you haven't yet as you will get some good help and confirmation likely there. Cheers!
-Marantz SR-8012
-Yamaha BD-A1060
-Chane A-2.4 L/C/R
post #4641 of 4641 Old 08-16-2019, 07:01 PM
bkeeler10's Avatar
Quoted: 455 Post(s)
Liked: 297
With disparate subs and different firing directions, you may have had phase issues causing your poor frequency response. Maybe . . .
Just use a Y connector at the end of the line you already have.
System
Reply Speakers
a1.4 , a2.4 , a5.4 , chane , l-series
